It is a frequent mistake to confuse the netlink port identifier with a
process identifier. Try to reduce this confusion by renaming fields
that hold port identifiers portid instead of pid.
I have carefully avoided changing the structures exported to
userspace to avoid changing the userspace API.
I have successfully built an allyesconfig kernel with this change.
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
Before this patch sock_diag works for init_net only and dumps
information about sockets from all namespaces.
This patch expands sock_diag for all name-spaces.
It creates a netlink kernel socket for each netns and filters
data during dumping.
v2: filter accoding with netns in all places
remove an unused variable.
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Pavel Emelyanov <xemul@parallels.com>
CC: Eric Dumazet <eric.dumazet@gmail.com>
Cc: netdev@vger.kernel.org
Signed-off-by: Andrew Vagin <avagin@openvz.org>
Acked-by: Pavel Emelyanov <xemul@parallels.com>
Also, no need to trim on nlmsg_put() failure, nothing has been added
yet. We also want to use nlmsg_end(), nlmsg_new() and nlmsg_free().
Signed-off-by: Thomas Graf <tgraf@suug.ch>
And use nlmsg_data() while we're here too and remove useless
casts.
/proc/net/unix has quadratic behavior, and can hold unix_table_lock for
a while if high number of unix sockets are alive. (90 ms for 200k
sockets...)
We already have a hash table, so its quite easy to use it.
Problem is unbound sockets are still hashed in a single hash slot
(unix_socket_table[UNIX_HASH_TABLE])
This patch also spreads unbound sockets to 256 hash slots, to speedup
both /proc/net/unix and unix_diag.
Time to read /proc/net/unix with 200k unix sockets :
(time dd if=/proc/net/unix of=/dev/null bs=4k)
before : 520 secs
after : 2 secs
Cc: Steven Whitehouse <swhiteho@redhat.com>
read only, so change it to const.
Signed-off-by: Shan Wei <davidshan@tencent.com>
Pull vfs pile 1 from Al Viro:
"This is _not_ all; in particular, Miklos' and Jan's stuff is not there
yet."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (64 commits)
ext4: initialization of ext4_li_mtx needs to be done earlier
debugfs-related mode_t whack-a-mole
hfsplus: add an ioctl to bless files
hfsplus: change finder_info to u32
hfsplus: initialise userflags
qnx4: new helper - try_extent()
qnx4: get rid of qnx4_bread/qnx4_getblk
take removal of PF_FORKNOEXEC to flush_old_exec()
trim includes in inode.c
um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() doesn't hold it
um: embed ->stub_pages[] into mmu_context
gadgetfs: list_for_each_safe() misuse
ocfs2: fix leaks on failure exits in module_init
ecryptfs: make register_filesystem() the last potential failure exit
ntfs: forgets to unregister sysctls on register_filesystem() failure
logfs: missing cleanup on register_filesystem() failure
jfs: mising cleanup on register_filesystem() failure
make configfs_pin_fs() return root dentry on success
configfs: configfs_create_dir() has parent dentry in dentry->d_parent
configfs: sanitize configfs_create()
Davem considers that the argument list of this interface is getting
out of control. This patch tries to address this issue following
his proposal:
struct netlink_dump_control c = { .dump = dump, .done = done, ... };
netlink_dump_start(..., &c);
Suggested by David S. Miller.
While it's not too late fix the recently added RQLEN diag extension
to report rqlen and wqlen in the same way as TCP does.
I.e. for listening sockets the ack backlog length (which is the input
queue length for socket) in rqlen and the max ack backlog length in
wqlen, and what the CINQ/OUTQ ioctls do for established.
Signed-off-by: Pavel Emelyanov <xemul@parallels.com>
[ Fix indentation of sock_diag*() calls. -DaveM ]
Otherwise we leave uninitialized kernel memory in there.
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
The NLA_PUT macro should accept the actual attribute length, not
the amount of elements in array :(
Otherwise getting
| net/unix/diag.c:312:16: error: expected declaration specifiers or ‘...’ before string constant
| net/unix/diag.c:313:1: error: expected declaration specifiers or ‘...’ before string constant
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
When establishing a unix connection on stream sockets the
server end receives an skb with socket in its receive queue.
Report who is waiting for these ends to be accepted for
listening sockets via NLA.
There's a lokcing issue with this -- the unix sk state lock is
required to access the peer, and it is taken under the listening
sk's queue lock. Strictly speaking the queue lock should be taken
inside the state lock, but since in this case these two sockets
are different it shouldn't lead to deadlock.
Report the peer socket inode ID as NLA. With this it's finally
possible to find out the other end of an interesting unix connection.
Actually, the socket path if it's not anonymous doesn't give
a clue to which file the socket is bound to. Even if the path
is absolute, it can be unlinked and then new socket can be
bound to it.
With this NLA it's possible to check which file a particular
socket is really bound to.
Report the sun_path when requested as NLA. With leading '\0' if
present but without the leading AF_UNIX bits.
The socket inode is used as a key for lookup. This is effectively
the only really unique ID of a unix socket, but using this for
search currently has one problem -- it is O(number of sockets) :(
Does it worth fixing this lookup or inventing some other ID for
unix sockets?
Walk the unix sockets table and fill the core response structure,
which includes type, state and inode.
Includes basic module_init/_exit functionality, dump/get_exact stubs
and declares the basic API structures for request and response.
