path: root/net/unix/af_unix.c
2008-01-28[UNIX] Move the unix sock iterators in to proper placePavel Emelyanov
The first_unix_socket() and next_unix_sockets() are now used in proc file and in forall_unix_socets macro only. The forall_unix_sockets is not used in this file at all so remove it. After this move the helpers to where they really belong, i.e. closer to proc code under the #ifdef CONFIG_PROC_FS option. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Consolidate net namespace related proc files creation.Denis V. Lunev
Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Make AF_UNIX per network namespace safe [v2]Denis V. Lunev
Because of the global nature of garbage collection, and because of the cost of per namespace hash tables unix_socket_table has been kept global. With a filter added on lookups so we don't see sockets from the wrong namespace. Currently I don't fold the namesapce into the hash so multiple namespaces using the same socket name will be guaranteed a hash collision. Changes from v1: - fixed unix_seq_open Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-29[UNIX]: EOF on non-blocking SOCK_SEQPACKETFlorian Zumbiehl
I am not absolutely sure whether this actually is a bug (as in: I've got no clue what the standards say or what other implementations do), but at least I was pretty surprised when I noticed that a recv() on a non-blocking unix domain socket of type SOCK_SEQPACKET (which is connection oriented, after all) where the remote end has closed the connection returned -1 (EAGAIN) rather than 0 to indicate end of file. This is a test case: | #include <sys/types.h> | #include <unistd.h> | #include <sys/socket.h> | #include <sys/un.h> | #include <fcntl.h> | #include <string.h> | #include <stdlib.h> | | int main(){ | int sock; | struct sockaddr_un addr; | char buf[4096]; | int pfds[2]; | | pipe(pfds); | sock=socket(PF_UNIX,SOCK_SEQPACKET,0); | addr.sun_family=AF_UNIX; | strcpy(addr.sun_path,"/tmp/foobar_testsock"); | bind(sock,(struct sockaddr *)&addr,sizeof(addr)); | listen(sock,1); | if(fork()){ | close(sock); | sock=socket(PF_UNIX,SOCK_SEQPACKET,0); | connect(sock,(struct sockaddr *)&addr,sizeof(addr)); | fcntl(sock,F_SETFL,fcntl(sock,F_GETFL)|O_NONBLOCK); | close(pfds[1]); | read(pfds[0],buf,sizeof(buf)); | recv(sock,buf,sizeof(buf),0); // <-- this one | }else accept(sock,NULL,NULL); | exit(0); | } If you try it, make sure /tmp/foobar_testsock doesn't exist. The marked recv() returns -1 (EAGAIN) on 2.6.23.9. Below you find a patch that fixes that. Signed-off-by: Florian Zumbiehl <florz@florz.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-11-10[UNIX]: The unix_nr_socks limit can be exceededPavel Emelyanov
The unix_nr_socks value is limited with the 2 * get_max_files() value, as seen from the unix_create1(). However, the check and the actual increment are separated with the GFP_KERNEL allocation, so this limit can be exceeded under a memory pressure - task may go to sleep freeing the pages and some other task will be allowed to allocate a new sock and so on and so forth. So make the increment before the check (similar thing is done in the sock_kmalloc) and go to kmalloc after this. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-10[AF_UNIX]: Make unix_tot_inflight counter non-atomicPavel Emelyanov
This counter is _always_ modified under the unix_gc_lock spinlock, so its atomicity can be provided w/o additional efforts. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-01[NET]: Forget the zero_it argument of sk_alloc()Pavel Emelyanov
Finally, the zero_it argument can be completely removed from the callers and from the function prototype. Besides, fix the checkpatch.pl warnings about using the assignments inside if-s. This patch is rather big, and it is a part of the previous one. I splitted it wishing to make the patches more readable. Hope this particular split helped. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-19pid namespaces: changes to show virtual ids to userPavel Emelyanov
This is the largest patch in the set. Make all (I hope) the places where the pid is shown to or get from user operate on the virtual pids. The idea is: - all in-kernel data structures must store either struct pid itself or the pid's global nr, obtained with pid_nr() call; - when seeking the task from kernel code with the stored id one should use find_task_by_pid() call that works with global pids; - when showing pid's numerical value to the user the virtual one should be used, but however when one shows task's pid outside this task's namespace the global one is to be used; - when getting the pid from userspace one need to consider this as the virtual one and use appropriate task/pid-searching functions. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: nuther build fix] [akpm@linux-foundation.org: yet nuther build fix] [akpm@linux-foundation.org: remove unneeded casts] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-15sched: affine sync wakeupsIngo Molnar
make sync wakeups affine for cache-cold tasks: if a cache-cold task is woken up by a sync wakeup then use the opportunity to migrate it straight away. (the two tasks are 'related' because they communicate) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-10[NET]: Make core networking code use seq_open_privatePavel Emelyanov
This concerns the ipv4 and ipv6 code mostly, but also the netlink and unix sockets. The netlink code is an example of how to use the __seq_open_private() call - it saves the net namespace on this private. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make socket creation namespace safe.Eric W. Biederman
This patch passes in the namespace a new socket should be created in and has the socket code do the appropriate reference counting. By virtue of this all socket create methods are touched. In addition the socket create methods are modified so that they will fail if you attempt to create a socket in a non-default network namespace. Failing if we attempt to create a socket outside of the default network namespace ensures that as we incrementally make the network stack network namespace aware we will not export functionality that someone has not audited and made certain is network namespace safe. Allowing us to partially enable network namespaces before all of the exotic protocols are supported. Any protocol layers I have missed will fail to compile because I now pass an extra parameter into the socket creation code. [ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make /proc/net per network namespaceEric W. Biederman
This patch makes /proc/net per network namespace. It modifies the global variables proc_net and proc_net_stat to be per network namespace. The proc_net file helpers are modified to take a network namespace argument, and all of their callers are fixed to pass &init_net for that argument. This ensures that all of the /proc/net files are only visible and usable in the initial network namespace until the code behind them has been updated to be handle multiple network namespaces. Making /proc/net per namespace is necessary as at least some files in /proc/net depend upon the set of network devices which is per network namespace, and even more files in /proc/net have contents that are relevant to a single network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31[AF_UNIX]: Make code static.Adrian Bunk
The following code can now become static: - struct unix_socket_table - unix_table_lock Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-11[AF_UNIX]: Rewrite garbage collector, fixes race.Miklos Szeredi
Throw out the old mark & sweep garbage collector and put in a refcounting cycle detecting one. The old one had a race with recvmsg, that resulted in false positives and hence data loss. The old algorithm operated on all unix sockets in the system, so any additional locking would have meant performance problems for all users of these. The new algorithm instead only operates on "in flight" sockets, which are very rare, and the additional locking for these doesn't negatively impact the vast majority of users. In fact it's probable, that there weren't *any* heavy senders of sockets over sockets, otherwise the above race would have been discovered long ago. The patch works OK with the app that exposed the race with the old code. The garbage collection has also been verified to work in a few simple cases. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET]: Make all initialized struct seq_operations const.Philippe De Muyter
Make all initialized struct seq_operations in net/ const Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-07[AF_UNIX]: Fix stream recvmsg() race.Miklos Szeredi
A recv() on an AF_UNIX, SOCK_STREAM socket can race with a send()+close() on the peer, causing recv() to return zero, even though the sent data should be received. This happens if the send() and the close() is performed between skb_dequeue() and checking sk->sk_shutdown in unix_stream_recvmsg(): process A skb_dequeue() returns NULL, there's no data in the socket queue process B new data is inserted onto the queue by unix_stream_sendmsg() process B sk->sk_shutdown is set to SHUTDOWN_MASK by unix_release_sock() process A sk->sk_shutdown is checked, unix_release_sock() returns zero I'm surprised nobody noticed this, it's not hard to trigger. Maybe it's just (un)luck with the timing. It's possible to work around this bug in userspace, by retrying the recv() once in case of a zero return value. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-03[AF_UNIX]: Fix datagram connect race causing an OOPS.David S. Miller
Based upon an excellent bug report and initial patch by Frederik Deweerdt. The UNIX datagram connect code blindly dereferences other->sk_socket via the call down to the security_unix_may_send() function. Without locking 'other' that pointer can go NULL via unix_release_sock() which does sock_orphan() which also marks the socket SOCK_DEAD. So we have to lock both 'sk' and 'other' yet avoid all kinds of potential deadlocks (connect to self is OK for datagram sockets and it is possible for two datagram sockets to perform a simultaneous connect to each other). So what we do is have a "double lock" function similar to how we handle this situation in other areas of the kernel. We take the lock of the socket pointer with the smallest address first in order to avoid ABBA style deadlocks. Once we have them both locked, we check to see if SOCK_DEAD is set for 'other' and if so, drop everything and retry the lookup. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-03[AF_UNIX]: Make socket locking much less confusing.David S. Miller
The unix_state_*() locking macros imply that there is some rwlock kind of thing going on, but the implementation is actually a spinlock which makes the code more confusing than it needs to be. So use plain unix_state_lock and unix_state_unlock. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_transport_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->h.raw = skb->data' operation, so that we can later turn skb->h.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple cases: skb->h.raw = skb->data; skb->h.raw = {skb_push|[__]skb_pull}() The next ones will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-06[NET]: Revert incorrect accept queue backlog changes.David S. Miller
This reverts two changes: 8488df894d05d6fa41c2bd298c335f944bb0e401 248f06726e866942b3d8ca8f411f9067713b7ff8 A backlog value of N really does mean allow "N + 1" connections to queue to a listening socket. This allows one to specify "0" as the backlog and still get 1 connection. Noticed by Gerrit Renker and Rick Jones. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-02[AF_UNIX]: Test against sk_max_ack_backlog properly.David S. Miller
This brings things inline with the sk_acceptq_is_full() bug fix. The limit test should be x >= sk_max_ack_backlog. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[PATCH] mark struct file_operations const 8Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[NET] UNIX: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Annotate csum_partial() callers in net/*Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[AF_UNIX]: Change max_dgram_qlen sysctl to __read_mostlyBrian Haley
Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Use BUILD_BUG_ON() for checking size of skb->cb.YOSHIFUJI Hideaki
2006-08-02[AF_UNIX]: Kernel memory leak fix for af_unix datagram getpeersec patchCatherine Zhang
From: Catherine Zhang <cxzhang@watson.ibm.com> This patch implements a cleaner fix for the memory leak problem of the original unix datagram getpeersec patch. Instead of creating a security context each time a unix datagram is sent, we only create the security context when the receiver requests it. This new design requires modification of the current unix_getsecpeer_dgram LSM hook and addition of two new hooks, namely, secid_to_secctx and release_secctx. The former retrieves the security context and the latter releases it. A hook is required for releasing the security context because it is up to the security module to decide how that's done. In the case of Selinux, it's a simple kfree operation. Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[NET]: Conversions from kmalloc+memset to k(z|c)alloc.Panagiotis Issaris
Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-03[AF_UNIX]: datagram getpeersec fixAndrew Morton
The unix_get_peersec_dgram() stub should have been inlined so that it disappears. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-03[PATCH] lockdep: annotate af_unix lockingIngo Molnar
Teach special (recursive) locking code to the lock validator. Also splits af_unix's sk_receive_queue.lock class from the other networking skb-queue locks. Has no effect on non-lockdep kernels. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[AF_UNIX]: Datagram getpeersecCatherine Zhang
This patch implements an API whereby an application can determine the label of its peer's Unix datagram sockets via the auxiliary data mechanism of recvmsg. Patch purpose: This patch enables a security-aware application to retrieve the security context of the peer of a Unix datagram socket. The application can then use this security context to determine the security context for processing on behalf of the peer who sent the packet. Patch design and implementation: The design and implementation is very similar to the UDP case for INET sockets. Basically we build upon the existing Unix domain socket API for retrieving user credentials. Linux offers the API for obtaining user credentials via ancillary messages (i.e., out of band/control messages that are bundled together with a normal message). To retrieve the security context, the application first indicates to the kernel such desire by setting the SO_PASSSEC option via getsockopt. Then the application retrieves the security context using the auxiliary data mechanism. An example server application for Unix datagram socket should look like this: toggle = 1; toggle_len = sizeof(toggle); setsockopt(sockfd, SOL_SOCKET, SO_PASSSEC, &toggle, &toggle_len); recvmsg(sockfd, &msg_hdr, 0); if (msg_hdr.msg_controllen > sizeof(struct cmsghdr)) { cmsg_hdr = CMSG_FIRSTHDR(&msg_hdr); if (cmsg_hdr->cmsg_len <= CMSG_LEN(sizeof(scontext)) && cmsg_hdr->cmsg_level == SOL_SOCKET && cmsg_hdr->cmsg_type == SCM_SECURITY) { memcpy(&scontext, CMSG_DATA(cmsg_hdr), sizeof(scontext)); } } sock_setsockopt is enhanced with a new socket option SOCK_PASSSEC to allow a server socket to receive security context of the peer. Testing: We have tested the patch by setting up Unix datagram client and server applications. We verified that the server can retrieve the security context using the auxiliary data mechanism of recvmsg. Signed-off-by: Catherine Zhang <cxzhang@watson.ibm.com> Acked-by: Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-25[PATCH] POLLRDHUP/EPOLLRDHUP handling for half-closed devices notificationsDavide Libenzi
Implement the half-closed devices notifiation, by adding a new POLLRDHUP (and its alias EPOLLRDHUP) bit to the existing poll/select sets. Since the existing POLLHUP handling, that does not report correctly half-closed devices, was feared to be changed, this implementation leaves the current POLLHUP reporting unchanged and simply add a new bit that is set in the few places where it makes sense. The same thing was discussed and conceptually agreed quite some time ago: http://lkml.org/lkml/2003/7/12/116 Since this new event bit is added to the existing Linux poll infrastruture, even the existing poll/select system calls will be able to use it. As far as the existing POLLHUP handling, the patch leaves it as is. The pollrdhup-2.6.16.rc5-0.10.diff defines the POLLRDHUP for all the existing archs and sets the bit in the six relevant files. The other attached diff is the simple change required to sys/epoll.h to add the EPOLLRDHUP definition. There is "a stupid program" to test POLLRDHUP delivery here: http://www.xmailserver.org/pollrdhup-test.c It tests poll(2), but since the delivery is same epoll(2) will work equally. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-20[NET]: sem2mutex part 2Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[AF_UNIX]: use shift instead of integer divisionBenjamin LaHaise
The patch below replaces a divide by 2 with a shift -- sk_sndbuf is an integer, so gcc emits an idiv, which takes 10x longer than a shift by 1. This improves af_unix bandwidth by ~6-10K/s. Also, tidy up the comment to fit in 80 columns while we're at it. Signed-off-by: Benjamin LaHaise <benjamin.c.lahaise@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-08[PATCH] fix file countingDipankar Sarma
I have benchmarked this on an x86_64 NUMA system and see no significant performance difference on kernbench. Tested on both x86_64 and powerpc. The way we do file struct accounting is not very suitable for batched freeing. For scalability reasons, file accounting was constructor/destructor based. This meant that nr_files was decremented only when the object was removed from the slab cache. This is susceptible to slab fragmentation. With RCU based file structure, consequent batched freeing and a test program like Serge's, we just speed this up and end up with a very fragmented slab - llm22:~ # cat /proc/sys/fs/file-nr 587730 0 758844 At the same time, I see only a 2000+ objects in filp cache. The following patch I fixes this problem. This patch changes the file counting by removing the filp_count_lock. Instead we use a separate percpu counter, nr_files, for now and all accesses to it are through get_nr_files() api. In the sysctl handler for nr_files, we populate files_stat.nr_files before returning to user. Counting files as an when they are created and destroyed (as opposed to inside slab) allows us to correctly count open files with RCU. Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-03[NET]: Add a dev_ioctl() fallback to sock_ioctl()Christoph Hellwig
Currently all network protocols need to call dev_ioctl as the default fallback in their ioctl implementations. This patch adds a fallback to dev_ioctl to sock_ioctl if the protocol returned -ENOIOCTLCMD. This way all the procotol ioctl handlers can be simplified and we don't need to export dev_ioctl. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[AF_UNIX]: Convert to use a spinlock instead of rwlockBenjamin LaHaise
From: Benjamin LaHaise <bcrl@kvack.org> In af_unix, a rwlock is used to protect internal state. At least on my P4 with HT it is faster to use a spinlock due to the simpler memory barrier used to unlock. This patch raises bw_unix to ~690K/s. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: move struct proto_ops to constEric Dumazet
I noticed that some of 'struct proto_ops' used in the kernel may share a cache line used by locks or other heavily modified data. (default linker alignement is 32 bytes, and L1_CACHE_LINE is 64 or 128 at least) This patch makes sure a 'struct proto_ops' can be declared as const, so that all cpus can share all parts of it without false sharing. This is not mandatory : a driver can still use a read/write structure if it needs to (and eventually a __read_mostly) I made a global stubstitute to change all existing occurences to make them const. This should reduce the possibility of false sharing on SMP, and speedup some socket system calls. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[AF_UNIX]: Use spinlock for unix_table_lockDavid S. Miller
This lock is actually taken mostly as a writer, so using a rwlock actually just makes performance worse especially on chips like the Intel P4. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[AF_UNIX]: Remove superfluous reference counting in unix_stream_sendmsgBenjamin LaHaise
AF_UNIX stream socket performance on P4 CPUs tends to suffer due to a lot of pipeline flushes from atomic operations. The patch below removes the sock_hold() and sock_put() in unix_stream_sendmsg(). This should be safe as the socket still holds a reference to its peer which is only released after the file descriptor's final user invokes unix_release_sock(). The only consideration is that we must add a memory barrier before setting the peer initially. Signed-off-by: Benjamin LaHaise <benjamin.c.lahaise@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-09[PATCH] add a vfs_permission helperChristoph Hellwig
Most permission() calls have a struct nameidata * available. This helper takes that as an argument and thus makes sure we pass it down for lookup intents and prepares for per-mount read-only support where we need a struct vfsmount for checking whether a file is writeable. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-29[NET]: Fix sparse warningsArnaldo Carvalho de Melo
Of this type, mostly: CHECK net/ipv6/netfilter.c net/ipv6/netfilter.c:96:12: warning: symbol 'ipv6_netfilter_init' was not declared. Should it be static? net/ipv6/netfilter.c:101:6: warning: symbol 'ipv6_netfilter_fini' was not declared. Should it be static? Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[TCP]: Move the tcp sock states to net/tcp_states.hArnaldo Carvalho de Melo
Lots of places just needs the states, not even linux/tcp.h, where this enum was, needs it. This speeds up development of the refactorings as less sources are rebuilt when things get moved from net/tcp.h. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-08[NET]: Transform skb_queue_len() binary tests into skb_queue_empty()David S. Miller
This is part of the grand scheme to eliminate the qlen member of skb_queue_head, and subsequently remove the 'list' member of sk_buff. Most users of skb_queue_len() want to know if the queue is empty or not, and that's trivially done with skb_queue_empty() which doesn't use the skb_queue_head->qlen member and instead uses the queue list emptyness as the test. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-19[AF_UNIX]: Use lookup_create().Christoph Hellwig
currently it opencodes it, but that's in the way of chaning the lookup_hash interface. I'd prefer to disallow modular af_unix over exporting lookup_create, but I'll leave that to you. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-25[PATCH] kill gratitious includes of major.h under net/*Al Viro
A lot of places in there are including major.h for no reason whatsoever. Removed. And yes, it still builds. The history of that stuff is often amusing. E.g. for net/core/sock.c the story looks so, as far as I've been able to reconstruct it: we used to need major.h in net/socket.c circa 1.1.early. In 1.1.13 that need had disappeared, along with register_chrdev(SOCKET_MAJOR, "socket", &net_fops) in sock_init(). Include had not. When 1.2 -> 1.3 reorg of net/* had moved a lot of stuff from net/socket.c to net/core/sock.c, this crap had followed... Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
