path: root/net/tipc/socket.c
2007-04-25[SK_BUFF]: Convert skb->tail to sk_buff_data_tArnaldo Carvalho de Melo
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes on 64bit architectures, allowing us to combine the 4 bytes hole left by the layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4 64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN... :-) Many calculations that previously required that skb->{transport,network, mac}_header be first converted to a pointer now can be done directly, being meaningful as offsets or pointers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] TIPC: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-18[TIPC]: Optimize wakeup logic when socket has no waiting processesAllan Stephens
This patch adds a simple test so TIPC doesn't try waking up processes waiting on a socket if there are none waiting. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Per Liden <per.liden@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-18[TIPC]: Stream socket can now send > 66000 bytes at a timeAllan Stephens
The stream socket send code was not initializing some required fields of the temporary msghdr structure it was utilizing; this is now fixed. A check has also been added to detect if a user illegally specifies a destination address when sending on an established stream connection. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Per Liden <per.liden@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-10[PATCH] tipc __user annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[TIPC]: Optimized argument validation done by connect().Allan Stephens
2006-06-25[TIPC]: Simplify code for returning partial success of stream send request.Allan Stephens
2006-06-25[TIPC]: recvmsg() now returns TIPC ancillary data using correct level (SOL_TIPC)Allan Stephens
2006-06-25[TIPC]: Improved performance of error checking during socket creation.Allan Stephens
2006-06-25[TIPC]: Stream socket send indicates partial success if data partially sent.Allan Stephens
2006-06-25[TIPC]: Connected send now checks socket state when retrying congested send.Allan Stephens
2006-06-25[TIPC]: Can now return destination name of form {0,x,y} via ancillary data.Allan Stephens
2006-06-25[TIPC]: Implied connect now saves dest name for retrieval as ancillary data.Allan Stephens
2006-06-25[TIPC]: Fixed connect() to detect a dest address that is missing or too short.Allan Stephens
2006-06-25[TIPC]: Non-operation-affecting corrections to comments & function definitions.Allan Stephens
2006-06-25[TIPC]: Fixed privilege checking typo in dest_name_check().Allan Stephens
This patch originated by Stephane Ouellette <ouellettes@videotron.ca>. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Per Liden <per.liden@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[TIPC]: Remove inlines from *.cSam Ravnborg
With reference to latest discussions on linux-kernel with respect to inline here is a patch for tipc to remove all inlines as used in the .c files. See also chapter 14 in Documentation/CodingStyle. Before: text data bss dec hex filename 102990 5292 1752 110034 1add2 tipc.o Now: text data bss dec hex filename 101190 5292 1752 108234 1a6ca tipc.o This is a nice text size reduction which will improve icache usage. In some cases bigger (> 4 lines) functions where declared inline and used in many places, they are most probarly no longer inlined by gcc resulting in the size reduction. There are several one liners that no longer are declared inline, but gcc should inline these just fine without the inline hint. With this patch applied one warning is added about an unused static function - that was hidded by utilising inline before. The function in question were kept so this patch is solely a inline removal patch. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Per Liden <per.liden@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[TIPC]: Fix simple sparse warningsSam Ravnborg
Tried to run the new tipc stack through sparse. Following patch fixes all cases where 0 was used as replacement of NULL. Use NULL to document this is a pointer and to silence sparse. This brough sparse warning count down with 127 to 24 warnings. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Per Liden <per.liden@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-18[TIPC] Avoid polluting the global namespacePer Liden
This patch adds a tipc_ prefix to all externally visible symbols. Signed-off-by: Per Liden <per.liden@ericsson.com>
2006-01-18[TIPC] Remove unused #includesPer Liden
2006-01-12[TIPC] More updates of file headersPer Liden
Updated copyright notice to include the year the file was actually created. Information about file creation dates was extracted from the files in the old CVS repository at tipc.sourceforge.net. Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
2006-01-12[TIPC] Update of file headersPer Liden
The copyright statements from different parts of Ericsson have been merged into one. Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
2006-01-12[TIPC] Cleaned up info/warn/err macrosPer Liden
2006-01-12[TIPC] License header updatePer Liden
The license header in each file now more clearly state that this code is licensed under a dual BSD/GPL. Before this was only evident if you looked at the MODULE_LICENSE line in core.c. Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
2006-01-12[TIPC] Moved configuration interface into tipc_config.hPer Liden
Restored the old tipc_config.h to get a cleaner division between the interfaces used by normal TIPC users and TIPC administration utilities. Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
2006-01-12[TIPC] Initial mergePer Liden
TIPC (Transparent Inter Process Communication) is a protocol designed for intra cluster communication. For more information see http://tipc.sourceforge.net Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
