path: root/net/tipc/socket.c
2013-06-17tipc: cosmetic realignment of function argumentsPaul Gortmaker
No runtime code changes here. Just a realign of the function arguments to start where the 1st one was, and fit as many args as can be put in an 80 char line. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17tipc: save sock structure pointer instead of void pointer to tipc_portYing Xue
Directly save sock structure pointer instead of void pointer to avoid unnecessary cast conversions. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17tipc: rename tipc_createport_raw to tipc_createportYing Xue
After the removal of the native API, there is now only one way to to create a TIPC port instance -- the function tipc_createport_raw(). We make it more readable by renaming it to tipc_createport(). Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17tipc: convert configuration server to use new server facilityYing Xue
As the new socket-based TIPC server infrastructure has been introduced, we can now convert the configuration server to use it. Then we can take future steps to simplify the configuration server locking policy. Some minor reordering of initialization is done, due to the dependency on having tipc_socket_init completed. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17tipc: convert topology server to use new server facilityYing Xue
As the new TIPC server infrastructure has been introduced, we can now convert the TIPC topology server to it. We get two benefits from doing this: 1) It simplifies the topology server locking policy. In the original locking policy, we placed one spin lock pointer in the tipc_subscriber structure to reuse the lock of the subscriber's server port, controlling access to members of tipc_subscriber instance. That is, we only used one lock to ensure both tipc_port and tipc_subscriber members were safely accessed. Now we introduce another spin lock for tipc_subscriber structure only protecting themselves, to get a finer granularity locking policy. Moreover, the change will allow us to make the topology server code more readable and maintainable. 2) It fixes a bug where sent subscription events may be lost when the topology port is congested. Using the new service, the topology server now queues sent events into an outgoing buffer, and then wakes up a sender process which has been blocked in workqueue context. The process will keep picking events from the buffer and send them to their respective subscribers, using the kernel socket interface, until the buffer is empty. Even if the socket is congested during transmission there is no risk that events may be dropped, since the sender process may block when needed. Some minor reordering of initialization is done, since we now have a scenario where the topology server must be started after socket initialization has taken place, as the former depends on the latter. And overall, we see a simplification of the TIPC subscriber code in making this changeover. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17tipc: introduce new TIPC server infrastructureYing Xue
TIPC has two internal servers, one providing a subscription service for topology events, and another providing the configuration interface. These servers have previously been running in BH context, accessing the TIPC-port (aka native) API directly. Apart from these servers, even the TIPC socket implementation is partially built on this API. As this API may simultaneously be called via different paths and in different contexts, a complex and costly lock policiy is required in order to protect TIPC internal resources. To eliminate the need for this complex lock policiy, we introduce a new, generic service API that uses kernel sockets for message passing instead of the native API. Once the toplogy and configuration servers are converted to use this new service, all code pertaining to the native API can be removed. This entails a significant reduction in code amount and complexity, and opens up for a complete rework of the locking policy in TIPC. The new service also solves another problem: As the current topology server works in BH context, it cannot easily be blocked when sending of events fails due to congestion. In such cases events may have to be silently dropped, something that is unacceptable. Therefore, the new service keeps a dedicated outbound queue receiving messages from BH context. Once messages are inserted into this queue, we will immediately schedule a work from a special workqueue. This way, messages/events from the topology server are in reality sent in process context, and the server can block if necessary. Analogously, there is a new workqueue for receiving messages. Once a notification about an arriving message is received in BH context, we schedule a work from the receive workqueue to do the job of receiving the message in process context. As both sending and receive messages are now finished in processes, subscribed events cannot be dropped any more. As of this commit, this new server infrastructure is built, but not actually yet called by the existing TIPC code, but since the conversion changes required in order to use it are significant, the addition is kept here as a separate commit. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17tipc: allow implicit connect for stream socketsErik Hugne
TIPC's implied connect feature, aka piggyback connect, allows applications to save one syscall and all SYN/SYN-ACK signalling overhead when setting up a connection. Until now, this has only been supported for SEQPACKET sockets. Here, we make it possible to use this feature even with stream sockets. At the connecting side, the connection is completed when the first data message arrives from the accepting peer. This means that we must allow the connecting user to call blocking recv() before the socket has reached state SS_CONNECTED. So we must must relax the state machine check at recv_stream(), and allow the recv() call even if socket is in state SS_CONNECTING. Signed-off-by: Erik Hugne <erik.hugne@ericsson.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17tipc: change socket buffer overflow control to respect sk_rcvbufYing Xue
As per feedback from the netdev community, we change the buffer overflow protection algorithm in receiving sockets so that it always respects the nominal upper limit set in sk_rcvbuf. Instead of scaling up from a small sk_rcvbuf value, which leads to violation of the configured sk_rcvbuf limit, we now calculate the weighted per-message limit by scaling down from a much bigger value, still in the same field, according to the importance priority of the received message. To allow for administrative tunability of the socket receive buffer size, we create a tipc_rmem sysctl variable to allow the user to configure an even bigger value via sysctl command. It is a size of three (min/default/max) to be consistent with things like tcp_rmem. By default, the value initialized in tipc_rmem[1] is equal to the receive socket size needed by a TIPC_CRITICAL_IMPORTANCE message. This value is also set as the default value of sk_rcvbuf. Originally-by: Jon Maloy <jon.maloy@ericsson.com> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Jon Maloy <jon.maloy@ericsson.com> [Ying: added sysctl variation to Jon's original patch] Signed-off-by: Ying Xue <ying.xue@windriver.com> [PG: don't compile sysctl.c if not config'd; add Documentation] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-07tipc: fix info leaks via msg_name in recv_msg/recv_streamMathias Krause
The code in set_orig_addr() does not initialize all of the members of struct sockaddr_tipc when filling the sockaddr info -- namely the union is only partly filled. This will make recv_msg() and recv_stream() -- the only users of this function -- leak kernel stack memory as the msg_name member is a local variable in net/socket.c. Additionally to that both recv_msg() and recv_stream() fail to update the msg_namelen member to 0 while otherwise returning with 0, i.e. "success". This is the case for, e.g., non-blocking sockets. This will lead to a 128 byte kernel stack leak in net/socket.c. Fix the first issue by initializing the memory of the union with memset(0). Fix the second one by setting msg_namelen to 0 early as it will be updated later if we're going to fill the msg_name member. Cc: Jon Maloy <jon.maloy@ericsson.com> Cc: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-15tipc: remove redundant checking for the number of iovecs in a send requestYing Xue
As the number of iovecs in a send request is already limited within UIO_MAXIOV(i.e. 1024) in __sys_sendmsg(), it's unnecessary to check it again in TIPC stack. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2013-02-15tipc: byte-based overload control on socket receive queueYing Xue
Change overload control to be purely byte-based, using sk->sk_rmem_alloc as byte counter, and compare it to a calculated upper limit for the socket receive queue. For all connection messages, irrespective of message importance, the overload limit is set to a constant value (i.e, 67MB). This limit should normally never be reached because of the lower limit used by the flow control algorithm, and is there only as a last resort in case a faulty peer doesn't respect the send window limit. For datagram messages, message importance is taken into account when calculating the overload limit. The calculation is based on sk->sk_rcvbuf, and is hence configurable via the socket option SO_RCVBUF. Cc: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2013-02-15tipc: eliminate duplicated discard_rx_queue routineYing Xue
The tipc function discard_rx_queue() is just a duplicated implementation of __skb_queue_purge(). Remove the former and directly invoke __skb_queue_purge(). In doing so, the underscores convey to the code reader, more information about the current locking state that is assumed. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-12-07tipc: refactor accept() code for improved readabilityPaul Gortmaker
In TIPC's accept() routine, there is a large block of code relating to initialization of a new socket, all within an if condition checking if the allocation succeeded. Here, we simply flip the check of the if, so that the main execution path stays at the same indentation level, which improves readability. If the allocation fails, we jump to an already existing exit label. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-12-07tipc: add lock nesting notation to quiet lockdep warningYing Xue
TIPC accept() call grabs the socket lock on a newly allocated socket while holding the socket lock on an old socket. But lockdep worries that this might be a recursive lock attempt: [ INFO: possible recursive locking detected ] --------------------------------------------- kworker/u:0/6 is trying to acquire lock: (sk_lock-AF_TIPC){+.+.+.}, at: [<c8c1226c>] accept+0x15c/0x310 [tipc] but task is already holding lock: (sk_lock-AF_TIPC){+.+.+.}, at: [<c8c12138>] accept+0x28/0x310 [tipc] other info that might help us debug this: Possible unsafe locking scenario: CPU0 ---- lock(sk_lock-AF_TIPC); lock(sk_lock-AF_TIPC); *** DEADLOCK *** May be due to missing lock nesting notation [...] Tell lockdep that this locking is safe by using lock_sock_nested(). This is similar to what was done in commit 5131a184a3458d9 for SCTP code ("SCTP: lock_sock_nested in sctp_sock_migrate"). Also note that this is isn't something that is seen normally, as it was uncovered with some experimental work-in-progress code not yet ready for mainline. So no need for stable backports or similar of this commit. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-12-07tipc: eliminate connection setup for implied connect in recv_msg()Ying Xue
As connection setup is now completed asynchronously in BH context, in the function filter_connect(), the corresponding code in recv_msg() becomes redundant. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-12-07tipc: introduce non-blocking socket connectYing Xue
TIPC has so far only supported blocking connect(), meaning that a call to connect() doesn't return until either the connection is fully established, or an error occurs. This has proved insufficient for many users, so we now introduce non-blocking connect(), analogous to how this is done in TCP and other protocols. With this feature, if a connection cannot be established instantly, connect() will return the error code "-EINPROGRESS". If the user later calls connect() again, he will either have the return code "-EALREADY" or "-EISCONN", depending on whether the connection has been established or not. The user must have explicitly set the socket to be non-blocking (SOCK_NONBLOCK or O_NONBLOCK, depending on method used), so unless for some reason they had set this already (the socket would anyway remain blocking in current TIPC) this change should be completely backwards compatible. It is also now possible to call select() or poll() to wait for the completion of a connection. An effect of the above is that the actual completion of a connection may now be performed asynchronously, independent of the calls from user space. Therefore, we now execute this code in BH context, in the function filter_rcv(), which is executed upon reception of messages in the socket. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> [PG: minor refactoring for improved connect/disconnect function names] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-12-07tipc: consolidate connection-oriented message reception in one functionYing Xue
Handling of connection-related message reception is currently scattered around at different places in the code. This makes it harder to verify that things are handled correctly in all possible scenarios. So we consolidate the existing processing of connection-oriented message reception in a single routine. In the process, we convert the chain of if/else into a switch/case for improved readability. A cast on the socket_state in the switch is needed to avoid compile warnings on 32 bit, like "net/tipc/socket.c:1252:2: warning: case value ‘4294967295’ not in enumerated type". This happens because existing tipc code pseudo extends the default linux socket state values with: #define SS_LISTENING -1 /* socket is listening */ #define SS_READY -2 /* socket is connectionless */ It may make sense to add these as _positive_ values to the existing socket state enum list someday, vs. these already existing defines. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> [PG: add cast to fix warning; remove returns from middle of switch] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-12-07tipc: standardize across connect/disconnect function namingPaul Gortmaker
Currently we have tipc_disconnect and tipc_disconnect_port. It is not clear from the names alone, what they do or how they differ. It turns out that tipc_disconnect just deals with the port locking and then calls tipc_disconnect_port which does all the work. If we rename as follows: tipc_disconnect_port --> __tipc_disconnect then we will be following typical linux convention, where: __tipc_disconnect: "raw" function that does all the work. tipc_disconnect: wrapper that deals with locking and then calls the real core __tipc_disconnect function With this, the difference is immediately evident, and locking violations are more apt to be spotted by chance while working on, or even just while reading the code. On the connect side of things, we currently only have the single "tipc_connect2port" function. It does both the locking at enter/exit, and the core of the work. Pending changes will make it desireable to have the connect be a two part locking wrapper + worker function, just like the disconnect is already. Here, we make the connect look just like the updated disconnect case, for the above reason, and for consistency. In the process, we also get rid of the "2port" suffix that was on the original name, since it adds no descriptive value. On close examination, one might notice that the above connect changes implicitly move the call to tipc_link_get_max_pkt() to be within the scope of tipc_port_lock() protected region; when it was not previously. We don't see any issues with this, and it is in keeping with __tipc_connect doing the work and tipc_connect just handling the locking. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-12-07tipc: change sk_receive_queue upper limitJon Maloy
The sk_recv_queue upper limit for connectionless sockets has empirically turned out to be too low. When we double the current limit we get much fewer rejected messages and no noticable negative side-effects. Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-12-07tipc: eliminate aggregate sk_receive_queue limitYing Xue
As a complement to the per-socket sk_recv_queue limit, TIPC keeps a global atomic counter for the sum of sk_recv_queue sizes across all tipc sockets. When incremented, the counter is compared to an upper threshold value, and if this is reached, the message is rejected with error code TIPC_OVERLOAD. This check was originally meant to protect the node against buffer exhaustion and general CPU overload. However, all experience indicates that the feature not only is redundant on Linux, but even harmful. Users run into the limit very often, causing disturbances for their applications, while removing it seems to have no negative effects at all. We have also seen that overall performance is boosted significantly when this bottleneck is removed. Furthermore, we don't see any other network protocols maintaining such a mechanism, something strengthening our conviction that this control can be eliminated. As a result, the atomic variable tipc_queue_size is now unused and so it can be deleted. There is a getsockopt call that used to allow reading it; we retain that but just return zero for maximum compatibility. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Cc: Neil Horman <nhorman@tuxdriver.com> [PG: phase out tipc_queue_size as pointed out by Neil Horman] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-11-21tipc: wake up all waiting threads at socket shutdownYing Xue
When a socket is shut down, we should wake up all thread sleeping on it, instead of just one of them. Otherwise, when several threads are polling the same socket, and one of them does shutdown(), the remaining threads may end up sleeping forever. Also, to align socket usage with common practice in other stacks, we use one of the common socket callback handlers, sk_state_change(), to wake up pending users. This is similar to the usage in e.g. inet_shutdown(). [net/ipv4/af_inet.c]. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-11-21tipc: return POLLOUT for sockets in an unconnected stateErik Hugne
If an implied connect is attempted on a nonblocking STREAM/SEQPACKET socket during link congestion, the connect message will be discarded and sendmsg will return EAGAIN. This is normal behavior, and the application is expected to poll the socket until POLLOUT is set, after which the connection attempt can be retried. However, the POLLOUT flag is never set for unconnected sockets and poll() always returns a zero mask. The application is then left without a trigger for when it can make another attempt at sending the message. The solution is to check if we're polling on an unconnected socket and set the POLLOUT flag if the TIPC port owned by this socket is not congested. The TIPC ports waiting on a specific link will be marked as 'not congested' when the link congestion have abated. Signed-off-by: Erik Hugne <erik.hugne@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-11-21tipc: fix race/inefficiencies in poll/wait behaviourYing Xue
When an application blocks at poll/select on a TIPC socket while requesting a specific event mask, both the filter_rcv() and wakeupdispatch() case will wake it up unconditionally whenever the state changes (i.e an incoming message arrives, or congestion has subsided). No mask is used. To avoid this, we populate sk->sk_data_ready and sk->sk_write_space with tipc_data_ready and tipc_write_space respectively, which makes tipc more in alignment with the rest of the networking code. These pass the exact set of possible events to the waker in fs/select.c hence avoiding waking up blocked processes unnecessarily. In doing so, we uncover another issue -- that there needs to be a memory barrier in these poll/receive callbacks, otherwise we are subject to the the same race as documented above wq_has_sleeper() [in commit a57de0b4 "net: adding memory barrier to the poll and receive callbacks"]. So we need to replace poll_wait() with sock_poll_wait() and use rcu protection for the sk->sk_wq pointer in these two new functions. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-10-04tipc: prevent dropped connections due to rcvbuf overflowErik Hugne
When large buffers are sent over connected TIPC sockets, it is likely that the sk_backlog will be filled up on the receiver side, but the TIPC flow control mechanism is happily unaware of this since that is based on message count. The sender will receive a TIPC_ERR_OVERLOAD message when this occurs and drop it's side of the connection, leaving it stale on the receiver end. By increasing the sk_rcvbuf to a 'worst case' value, we avoid the overload caused by a full backlog queue and the flow control will work properly. This worst case value is the max TIPC message size times the flow control window, multiplied by two because a sender will transmit up to double the window size before a port is marked congested. We multiply this by 2 to account for the sk_buff and other overheads. Signed-off-by: Erik Hugne <erik.hugne@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-13tipc: use standard printk shortcut macros (pr_err etc.)Erik Hugne
All messages should go directly to the kernel log. The TIPC specific error, warning, info and debug trace macro's are removed and all references replaced with pr_err, pr_warn, pr_info and pr_debug. Commonly used sub-strings are explicitly declared as a const char to reduce .text size. Note that this means the debug messages (changed to pr_debug), are now enabled through dynamic debugging, instead of a TIPC specific Kconfig option (TIPC_DEBUG). The latter will be phased out completely Signed-off-by: Erik Hugne <erik.hugne@ericsson.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> [PG: use pr_fmt as suggested by Joe Perches <joe@perches.com>] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-07-10net: Fix non-kernel-doc comments with kernel-doc start markerBen Hutchings
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-04net: Remove casts to same typeJoe Perches
Adding casts of objects to the same type is unnecessary and confusing for a human reader. For example, this cast: int y; int *p = (int *)&y; I used the coccinelle script below to find and remove these unnecessary casts. I manually removed the conversions this script produces of casts with __force and __user. @@ type T; T *p; @@ - (T *)p + p Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-30tipc: compress out gratuitous extra carriage returnsPaul Gortmaker
Some of the comment blocks are floating in limbo between two functions, or between blocks of code. Delete the extra line feeds between any comment and its associated following block of code, to be consistent with the majority of the rest of the kernel. Also delete trailing newlines at EOF and fix a couple trivial typos in existing comments. This is a 100% cosmetic change with no runtime impact. We get rid of over 500 lines of non-code, and being blank line deletes, they won't even show up as noise in git blame. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-04-27tipc: Reject payload messages with invalid message typeAllan Stephens
Adds check to ensure TIPC sockets reject incoming payload messages that have an unrecognized message type. Remove the old open question about whether TIPC_ERR_NO_PORT is the proper return value. It is appropriate here since there are valid instances where another node can make use of the reply, and at this point in time the host is already broadcasting TIPC data, so there are no real security concerns. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-04-23net: add a limit parameter to sk_add_backlog()Eric Dumazet
sk_add_backlog() & sk_rcvqueues_full() hard coded sk_rcvbuf as the memory limit. We need to make this limit a parameter for TCP use. No functional change expected in this patch, all callers still using the old sk_rcvbuf limit. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Neal Cardwell <ncardwell@google.com> Cc: Tom Herbert <therbert@google.com> Cc: Maciej Żenczykowski <maze@google.com> Cc: Yuchung Cheng <ycheng@google.com> Cc: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Cc: Rick Jones <rick.jones2@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-19tipc: Ensure network address change doesn't impact local connectionsAllan Stephens
Revises routines that deal with connections between two ports on the same node to ensure the connection is not impacted if the node's network address is changed in mid-operation. The routines now treat the default node address of <0.0.0> as an alias for "this node" in the following situations: 1) Incoming messages destined to a connected port now handle the alias properly when validating that the message was sent by the expected peer port, ensuring that the message will be accepted regardless of whether it specifies the node's old network address or it's current one. 2) The code which completes connection establishment now handles the alias properly when determining if the peer port is on the same node as the connected port. An added benefit of addressing issue 1) is that some peer port validation code has been relocated to TIPC's socket subsystem, which means that validation is no longer done twice when a message is sent to a non-socket port (such as TIPC's configuration service or network topology service). Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-04-15net: cleanup unsigned to unsigned intEric Dumazet
Use of "unsigned int" is preferred to bare "unsigned" in net tree. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-24tipc: Eliminate trivial buffer manipulation helper routinesAllan Stephens
Gets rid of two inlined routines that simply call existing sk_buff manipulation routines, since there is no longer any extra processing done by the helper routines. Note that these changes are essentially cosmetic in nature, and have no impact on the actual operation of TIPC. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-02-24tipc: Simplify enforcement of reserved name type prohibitionAllan Stephens
Streamlines the logic that prevents an application from binding a reserved TIPC name type to a port by moving the check to the code that handles a socket bind() operation. This allows internal TIPC subsystems to bind a reserved name without having to set an atomic flag to gain permission to use such a name. (This simplification is now possible due to the elimination of support for TIPC's native API.) Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-12-27tipc: Enable use by containers having their own network namespaceAllan Stephens
Permits a Linux container to use TIPC sockets even when it has its own network namespace defined by removing the check that prohibits such use. This makes it possible for users who wish to isolate their container network traffic from normal network traffic to utilize TIPC. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31net: Add export.h for EXPORT_SYMBOL/THIS_MODULE to non-modulesPaul Gortmaker
These files are non modular, but need to export symbols using the macros now living in export.h -- call out the include so that things won't break when we remove the implicit presence of module.h from everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-17tipc: Simplify prohibition of listen and accept for connectionless socketsYing Xue
Modifies the proto_ops structure used by TIPC DGRAM and RDM sockets so that calls to listen() and accept() are handled by existing kernel "unsupported operation" routines, and eliminates the related checks in the listen and accept routines used by SEQPACKET and STREAM sockets that are no longer needed. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-17tipc: Add support for SO_SNDTIMEO socket optionYing Xue
Adds support for the SO_SNDTIMEO socket option. (This complements the existing support for SO_RCVTIMEO that is already present.) Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-01tipc: Prevent rounding issues when saving connect timeout optionAllan Stephens
Saves a socket's TIPC_CONN_TIMEOUT socket option value in its original form (milliseconds), rather than jiffies. This ensures that the exact value set using setsockopt() is always returned by getsockopt(), without being subject to rounding issues introduced by a ms->jiffies->ms conversion sequence. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-06-24tipc: Remove unnecessary includes in socket codeAllan Stephens
Eliminates a pair of #include statements for files that are brought in automatically by including core.h. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-05-10tipc: Avoid recomputation of outgoing message lengthAllan Stephens
Rework TIPC's message sending routines to take advantage of the total amount of data value passed to it by the kernel socket infrastructure. This change eliminates the need for TIPC to compute the size of outgoing messages itself, as well as the check for an oversize message in tipc_msg_build(). In addition, this change warrants an explanation: - res = send_packet(NULL, sock, &my_msg, 0); + res = send_packet(NULL, sock, &my_msg, bytes_to_send); Previously, the final argument to send_packet() was ignored (since the amount of data being sent was recalculated by a lower-level routine) and we could just pass in a dummy value (0). Now that the recalculation is being eliminated, the argument value being passed to send_packet() is significant and we have to supply the actual amount of data we want to send. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-05-10tipc: Abort excessive send requests as early as possibleAllan Stephens
Adds checks to TIPC's socket send routines to promptly detect and abort attempts to send more than 66,000 bytes in a single TIPC message or more than 2**31-1 bytes in a single TIPC byte stream request. In addition, this ensures that the number of iovecs in a send request does not exceed the limits of a standard integer variable. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-03-13tipc: Add support for SO_RCVTIMEO socket optionAllan Stephens
Adds support for the SO_RCVTIMEO socket option to TIPC's socket receive routines. Thanks go out to Raj Hegde <rajenhegde@yahoo.ca> for his contribution to the development and testing this enhancement. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-03-13tipc: Allow receiving into iovec containing multiple entriesAllan Stephens
Enhances TIPC's socket receive routines to support iovec structures containing more than a single entry. This change leverages existing sk_buff routines to do most of the work; the only significant change to TIPC itself is that an sk_buff now records how much data has been already consumed as an numeric offset, rather than as a pointer to the first unread data byte. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-02-23tipc: Prevent invalid memory access when sending to configuration serviceAllan Stephens
Reject TIPC configuration service messages without a full message header. Previously, an application that sent a message to the configuration service that was too short could cause the validation code to access an uninitialized field in the msghdr structure, resulting in a memory access exception. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-02-23tipc: Remove unused global variable tipc_user_countAllan Stephens
Eliminates a global variable that was previously used by TIPC's user registry to track the number of distinct applications using TIPC. Due to the recent elimination of the user registry this variable no longer serves any purpose and can be removed. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-01-01tipc: remove extraneous braces from single statementsAllan Stephens
Cleans up TIPC's source code to eliminate the presence of unnecessary use of {} around single statements. These changes are purely cosmetic and do not alter the operation of TIPC in any way. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: remove zeroing assignments to static global variablesAllan Stephens
Cleans up TIPC's source code to eliminate the needless initialization of static variables to zero. These changes are purely cosmetic and do not alter the operation of TIPC in any way. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: split variable assignments out of conditional expressionsAllan Stephens
Cleans up TIPC's source code to eliminate assigning values to variables within conditional expressions, improving code readability and reducing warnings from various code checker tools. These changes are purely cosmetic and do not alter the operation of TIPC in any way. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: cleanup various cosmetic whitespace issuesAllan Stephens
Cleans up TIPC's source code to eliminate deviations from generally accepted coding conventions relating to leading/trailing white space and white space around commas, braces, cases, and sizeof. These changes are purely cosmetic and do not alter the operation of TIPC in any way. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
