path: root/net/tipc/server.c
2015-01-12tipc: make subscriber server support net namespaceYing Xue
TIPC establishes one subscriber server which allows users to subscribe their interesting name service status. After tipc supports namespace, one dedicated tipc stack instance is created for each namespace, and each instance can be deemed as one independent TIPC node. As a result, subscriber server must be built for each namespace. Signed-off-by: Ying Xue <ying.xue@windriver.com> Tested-by: Tero Aho <Tero.Aho@coriant.com> Reviewed-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-12tipc: name tipc name table support net namespaceYing Xue
TIPC name table is used to store the mapping relationship between TIPC service name and socket port ID. When tipc supports namespace, it allows users to publish service names only owned by a certain namespace. Therefore, every namespace must have its private name table to prevent service names published to one namespace from being contaminated by other service names in another namespace. Therefore, The name table global variable (ie, nametbl) and its lock must be moved to tipc_net structure, and a parameter of namespace must be added for necessary functions so that they can obtain name table variable defined in tipc_net structure. Signed-off-by: Ying Xue <ying.xue@windriver.com> Tested-by: Tero Aho <Tero.Aho@coriant.com> Reviewed-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-12tipc: cleanup core.c and core.h filesYing Xue
Only the works of initializing and shutting down tipc module are done in core.h and core.c files, so all stuffs which are not closely associated with the two tasks should be moved to appropriate places. Signed-off-by: Ying Xue <ying.xue@windriver.com> Tested-by: Tero Aho <Tero.Aho@coriant.com> Reviewed-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-11net: Fix use after free by removing length arg from sk_data_ready callbacks.David S. Miller
Several spots in the kernel perform a sequence like: skb_queue_tail(&sk->s_receive_queue, skb); sk->sk_data_ready(sk, skb->len); But at the moment we place the SKB onto the socket receive queue it can be consumed and freed up. So this skb->len access is potentially to freed up memory. Furthermore, the skb->len can be modified by the consumer so it is possible that the value isn't accurate. And finally, no actual implementation of this callback actually uses the length argument. And since nobody actually cared about it's value, lots of call sites pass arbitrary values in such as '0' and even '1'. So just remove the length argument from the callback, that way there is no confusion whatsoever and all of these use-after-free cases get fixed as a side effect. Based upon a patch by Eric Dumazet and his suggestion to audit this issue tree-wide. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-06tipc: fix connection refcount leakYing Xue
When tipc_conn_sendmsg() calls tipc_conn_lookup() to query a connection instance, its reference count value is increased if it's found. But subsequently if it's found that the connection is closed, the work of sending message is not queued into its server send workqueue, and the connection reference count is not decreased. This will cause a reference count leak. To reproduce this problem, an application would need to open and closes topology server connections with high intensity. We fix this by immediately decrementing the connection reference count if a send fails due to the connection being closed. Signed-off-by: Ying Xue <ying.xue@windriver.com> Acked-by: Erik Hugne <erik.hugne@ericsson.com> Reviewed-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-06tipc: allow connection shutdown callback to be invoked in advanceYing Xue
Currently connection shutdown callback function is called when connection instance is released in tipc_conn_kref_release(), and receiving packets and sending packets are running in different threads. Even if connection is closed by the thread of receiving packets, its shutdown callback may not be called immediately as the connection reference count is non-zero at that moment. So, although the connection is shut down by the thread of receiving packets, the thread of sending packets doesn't know it. Before its shutdown callback is invoked to tell the sending thread its connection has been closed, the sending thread may deliver messages by tipc_conn_sendmsg(), this is why the following error information appears: "Sending subscription event failed, no memory" To eliminate it, allow connection shutdown callback function to be called before connection id is removed in tipc_close_conn(), which makes the sending thread know the truth in time that its socket is closed so that it doesn't send message to it. We also remove the "Sending XXX failed..." error reporting for topology and config services. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Erik Hugne <erik.hugne@ericsson.com> Reviewed-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-22tipc: remove all enabled flags from all tipc componentsYing Xue
When tipc module is inserted, many tipc components are initialized one by one. During the initialization period, if one of them is failed, tipc_core_stop() will be called to stop all components whatever corresponding components are created or not. To avoid to release uncreated ones, relevant components have to add necessary enabled flags indicating whether they are created or not. But in the initialization stage, if one component is unsuccessfully created, we will just destroy successfully created components before the failed component instead of all components. All enabled flags defined in components, in turn, become redundant. Additionally it's also unnecessary to identify whether table.types is NULL in tipc_nametbl_stop() because name stable has been definitely created successfully when tipc_nametbl_stop() is called. Cc: Jon Maloy <jon.maloy@ericsson.com> Cc: Erik Hugne <erik.hugne@ericsson.com> Signed-off-by: Ying Xue <ying.xue@windriver.com> Reviewed-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-14tipc: spelling fixesstephen hemminger
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-01tipc: fix oops when creating server socket failsYing Xue
When creation of TIPC internal server socket fails, we get an oops with the following dump: BUG: unable to handle kernel NULL pointer dereference at 0000000000000020 IP: [<ffffffffa0011f49>] tipc_close_conn+0x59/0xb0 [tipc] PGD 13719067 PUD 12008067 PMD 0 Oops: 0000 [#1] SMP DEBUG_PAGEALLOC Modules linked in: tipc(+) CPU: 4 PID: 4340 Comm: insmod Not tainted 3.10.0+ #1 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007 task: ffff880014360000 ti: ffff88001374c000 task.ti: ffff88001374c000 RIP: 0010:[<ffffffffa0011f49>] [<ffffffffa0011f49>] tipc_close_conn+0x59/0xb0 [tipc] RSP: 0018:ffff88001374dc98 EFLAGS: 00010292 RAX: 0000000000000000 RBX: ffff880012ac09d8 RCX: 0000000000000000 RDX: 0000000000000046 RSI: 0000000000000001 RDI: ffff880014360000 RBP: ffff88001374dcb8 R08: 0000000000000001 R09: 0000000000000001 R10: 0000000000000000 R11: 0000000000000000 R12: ffffffffa0016fa0 R13: ffffffffa0017010 R14: ffffffffa0017010 R15: ffff880012ac09d8 FS: 0000000000000000(0000) GS:ffff880016600000(0063) knlGS:00000000f76668d0 CS: 0010 DS: 002b ES: 002b CR0: 000000008005003b CR2: 0000000000000020 CR3: 0000000012227000 CR4: 00000000000006e0 Stack: ffff88001374dcb8 ffffffffa0016fa0 0000000000000000 0000000000000001 ffff88001374dcf8 ffffffffa0012922 ffff88001374dce8 00000000ffffffea ffffffffa0017100 0000000000000000 ffff8800134241a8 ffffffffa0017150 Call Trace: [<ffffffffa0012922>] tipc_server_stop+0xa2/0x1b0 [tipc] [<ffffffffa0009995>] tipc_subscr_stop+0x15/0x20 [tipc] [<ffffffffa00130f5>] tipc_core_stop+0x1d/0x33 [tipc] [<ffffffffa001f0d4>] tipc_init+0xd4/0xf8 [tipc] [<ffffffffa001f000>] ? 0xffffffffa001efff [<ffffffff8100023f>] do_one_initcall+0x3f/0x150 [<ffffffff81082f4d>] ? __blocking_notifier_call_chain+0x7d/0xd0 [<ffffffff810cc58a>] load_module+0x11aa/0x19c0 [<ffffffff810c8d60>] ? show_initstate+0x50/0x50 [<ffffffff8190311c>] ? retint_restore_args+0xe/0xe [<ffffffff810cce79>] SyS_init_module+0xd9/0x110 [<ffffffff8190dc65>] sysenter_dispatch+0x7/0x1f Code: 6c 24 70 4c 89 ef e8 b7 04 8f e1 8b 73 04 4c 89 e7 e8 7c 9e 32 e1 41 83 ac 24 b8 00 00 00 01 4c 89 ef e8 eb 0a 8f e1 48 8b 43 08 <4c> 8b 68 20 4d 8d a5 48 03 00 00 4c 89 e7 e8 04 05 8f e1 4c 89 RIP [<ffffffffa0011f49>] tipc_close_conn+0x59/0xb0 [tipc] RSP <ffff88001374dc98> CR2: 0000000000000020 ---[ end trace b02321f40e4269a3 ]--- We have the following call chain: tipc_core_start() ret = tipc_subscr_start() ret = tipc_server_start(){ server->enabled = 1; ret = tipc_open_listening_sock() } I.e., the server->enabled flag is unconditionally set to 1, whatever the return value of tipc_open_listening_sock(). This causes a crash when tipc_core_start() tries to clean up resources after a failed initialization: if (ret == failed) tipc_subscr_stop() tipc_server_stop(){ if (server->enabled) tipc_close_conn(){ NULL reference of con->sock-sk OOPS! } } To avoid this, tipc_server_start() should only set server->enabled to 1 in case of a succesful socket creation. In case of failure, it should release all allocated resources before returning. Problem introduced in commit c5fa7b3cf3cb22e4ac60485fc2dc187fe012910f ("tipc: introduce new TIPC server infrastructure") in v3.11-rc1. Note that it won't be seen often; it takes a module load under memory constrained conditions in order to trigger the failure condition. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17tipc: introduce new TIPC server infrastructureYing Xue
TIPC has two internal servers, one providing a subscription service for topology events, and another providing the configuration interface. These servers have previously been running in BH context, accessing the TIPC-port (aka native) API directly. Apart from these servers, even the TIPC socket implementation is partially built on this API. As this API may simultaneously be called via different paths and in different contexts, a complex and costly lock policiy is required in order to protect TIPC internal resources. To eliminate the need for this complex lock policiy, we introduce a new, generic service API that uses kernel sockets for message passing instead of the native API. Once the toplogy and configuration servers are converted to use this new service, all code pertaining to the native API can be removed. This entails a significant reduction in code amount and complexity, and opens up for a complete rework of the locking policy in TIPC. The new service also solves another problem: As the current topology server works in BH context, it cannot easily be blocked when sending of events fails due to congestion. In such cases events may have to be silently dropped, something that is unacceptable. Therefore, the new service keeps a dedicated outbound queue receiving messages from BH context. Once messages are inserted into this queue, we will immediately schedule a work from a special workqueue. This way, messages/events from the topology server are in reality sent in process context, and the server can block if necessary. Analogously, there is a new workqueue for receiving messages. Once a notification about an arriving message is received in BH context, we schedule a work from the receive workqueue to do the job of receiving the message in process context. As both sending and receive messages are now finished in processes, subscribed events cannot be dropped any more. As of this commit, this new server infrastructure is built, but not actually yet called by the existing TIPC code, but since the conversion changes required in order to use it are significant, the addition is kept here as a separate commit. Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
