path: root/net/tipc/port.c
2010-10-16tipc: cleanup function namespacestephen hemminger
Do some cleanups of TIPC based on make namespacecheck 1. Don't export unused symbols 2. Eliminate dead code 3. Make functions and variables local 4. Rename buf_acquire to tipc_buf_acquire since it is used in several files Compile tested only. This make break out of tree kernel modules that depend on TIPC routines. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Jon Maloy <jon.maloy@ericsson.com> Acked-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-13tipc: clean out all instances of #if 0'd unused codePaul Gortmaker
Remove all instances of legacy, or as yet to be implemented code that is currently living within an #if 0 ... #endif block. In the rare instance that some of it be needed in the future, it can still be dragged out of history, but there is no need for it to sit in mainline. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-06tipc: Minor optimizations to name table translation codeAllan Stephens
Optimizes TIPC's name table translation code to avoid unnecessary manipulation of the node address field of the resulting port id when name translation fails. This change is possible because a valid port id cannot have a reference field of zero, so examining the reference only is sufficient to determine if the translation was successful. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-17tipc: Remove per-connection sequence number logicAllan Stephens
Remove validation of the per-connection sequence numbers on routable connections, since routable connections are not supported by TIPC. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-12tipc: add tipc_ prefix to fcns targeted for un-inliningAllan Stephens
These functions have enough code in them such that they seem like sensible targets for un-inlining. Prior to doing that, this adds the tipc_ prefix to the functions, so that in the event of a panic dump or similar, the subsystem from which the functions come from is immediately clear. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-12tipc: Eliminate unnecessary initialization in native API send routinesAllan Stephens
Eliminate a couple of instances where TIPC's native API send routines were doing pointless initialization of local variables. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-12tipc: Eliminate obsolete port's "congested_link" fieldAllan Stephens
Eliminate a field of the TIPC port structure that is populated, but never referenced. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-14tipc: Eliminate improper use of TIPC_OK error codeAllan Stephens
This patch corrects many places where TIPC routines indicated successful completion by returning TIPC_OK instead of 0. (The TIPC_OK symbol has the value 0, but it should only be used in contexts that deal with the error code field of a TIPC message header.) Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-14tipc: Remove unneeded parameter to tipc_createport_raw()Allan Stephens
This patch eliminates an unneeded parameter when creating a low-level TIPC port object. Instead of returning both the pointer to the port structure and the port's reference ID, it now returns only the pointer since the port structure contains the reference ID as one of its fields. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-04tipc: Fix bugs in rejection of message with short headerAllan Stephens
This patch ensures that TIPC doesn't try to access non-existent message header fields when rejecting a message with a short header. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-04tipc: Message header creation optimizationsAllan Stephens
This patch eliminates several cases where message header fields were being set to the same value twice. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-04tipc: Optimize message initialization routineAllan Stephens
This patch eliminates the rarely-used "error code" argument when initializing a TIPC message header, since the default value of zero is the desired result in most cases; the few exceptional cases now set the error code explicitly. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-04tipc: Standardize error checking on incoming messages via native APIAllan Stephens
This patch re-orders & re-groups the error checks performed on messages being delivered to native API ports, in order to clarify the similarities and differences required for the various message types. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-04tipc: Fix bug in connection setup via native APIAllan Stephens
This patch fixes a bug that prevented TIPC from receiving a connection setup request message on a native TIPC port. The revised connection setup logic ensures that validation of the source of a connection-based message is skipped if the port is not yet connected to a peer. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-21tipc: Update "previous node" indicators when node address changesAllan Stephens
This patch ensures that the "previous node" field in any existing TIPC port message header templates is updated properly when a TIPC network address is assigned to the node. (Previously, only the "originating node" field was updated.) Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-12tipc: Fix race condition when creating socket or native portAllan Stephens
This patch eliminates the (very remote) chance of a crash resulting from a partially initialized socket or native port unexpectedly receiving a message. Now, during the creation of a socket or native port, the underlying generic port's lock is not released until all initialization required to handle incoming messages has been done. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-15[TIPC]: Overhaul of socket locking logicAllan Stephens
This patch modifies TIPC's socket code to follow the same approach used by other protocols. This change eliminates the need for a mutex in the TIPC-specific portion of the socket protocol data structure -- in its place, the standard Linux socket backlog queue and associated locking routines are utilized. These changes fix a long-standing receive queue bug on SMP systems, and also enable individual read and write threads to utilize a socket without unnecessarily interfering with each other. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-06[TIPC]: Minor cleanup of message header codeAllan Stephens
This patch eliminates some unused or duplicate message header symbols, and fixes up the comments and/or location of a few other symbols. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-06[TIPC]: Removal of message header option codeAllan Stephens
This patch removes code associated with optional, user-specified fields of the TIPC message header. Such fields were never utilized by TIPC, and have now been removed from the protocol specification. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TIPC]: Use tipc_port_unlockJulia Lawall
The file net/tipc/port.c takes a lock using the function tipc_port_lock and then releases the lock sometimes using tipc_port_unlock and sometimes using spin_unlock_bh(p_ptr->publ.lock). tipc_port_unlock simply does the spin_unlock_bh, but it seems cleaner to use it everywhere. The problem was fixed using the following semantic patch. (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ struct port *p_ptr; @@ p_ptr = tipc_port_lock(...) ... ( p_ptr = tipc_port_lock(...); | ?- spin_unlock_bh(p_ptr->publ.lock); + tipc_port_unlock(p_ptr); ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Jon Paul Maloy <maloy@donjonn.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-13[TIPC]: Clean up duplicate includes in net/tipc/Jesper Juhl
This patch cleans up duplicate includes in net/tipc/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[TIPC]: Optimize stream send routine to avoid fragmentationAllan Stephens
This patch enhances TIPC's stream socket send routine so that it avoids transmitting data in chunks that require fragmentation and reassembly, thereby improving performance at both the sending and receiving ends of the connection. The "maximum packet size" hint that records MTU info allows the socket to decide how big a chunk it should send; in the event that the hint has become stale, fragmentation may still occur, but the data will be passed correctly and the hint will be updated in time for the following send. Note: The 66060 byte pseudo-MTU used for intra-node connections requires the send routine to perform an additional check to ensure it does not exceed TIPC"s limit of 66000 bytes of user data per chunk. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Jon Paul Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_copy_to_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying to linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
2007-02-10[NET] TIPC: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-01[TIPC] net/tipc/port.c: fix NULL dereferenceAdrian Bunk
The correct order is: NULL check before dereference Spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-18[TIPC]: Add missing unlock in port timeout code.Allan Stephens
Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Per Liden <per.liden@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[NET]: Conversions from kmalloc+memset to k(z|c)alloc.Panagiotis Issaris
Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-27[PATCH] spin/rwlock init cleanupsIngo Molnar
locking init cleanups: - convert " = SPIN_LOCK_UNLOCKED" to spin_lock_init() or DEFINE_SPINLOCK() - convert rwlocks in a similar manner this patch was generated automatically. Motivation: - cleanliness - lockdep needs control of lock initialization, which the open-coded variants do not give - it's also useful for -rt and for lock debugging in general Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[TIPC]: Enhanced & cleaned up system messages; fixed 2 obscure memory leaks.Allan Stephens
2006-06-25[TIPC]: First phase of assert() cleanupAllan Stephens
This also contains enhancements to simplify comparisons in name table publication removal algorithm and to simplify name table sanity checking when shutting down TIPC. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Per Liden <per.liden@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-25[TIPC]: Added missing warning for out-of-memory conditionAllan Stephens
2006-06-25[TIPC]: Withdrawing all names from nameless port now returns success, not errorAllan Stephens
2006-06-25[TIPC]: Allow ports to receive multicast messages through native API.Allan Stephens
This fix prevents a kernel panic if an application mistakenly sends a multicast message to TIPC's topology service or configuration service. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Per Liden <per.liden@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[TIPC]: Remove unused functionsPer Liden
2006-03-20[TIPC]: Remove inlines from *.cSam Ravnborg
With reference to latest discussions on linux-kernel with respect to inline here is a patch for tipc to remove all inlines as used in the .c files. See also chapter 14 in Documentation/CodingStyle. Before: text data bss dec hex filename 102990 5292 1752 110034 1add2 tipc.o Now: text data bss dec hex filename 101190 5292 1752 108234 1a6ca tipc.o This is a nice text size reduction which will improve icache usage. In some cases bigger (> 4 lines) functions where declared inline and used in many places, they are most probarly no longer inlined by gcc resulting in the size reduction. There are several one liners that no longer are declared inline, but gcc should inline these just fine without the inline hint. With this patch applied one warning is added about an unused static function - that was hidded by utilising inline before. The function in question were kept so this patch is solely a inline removal patch. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Per Liden <per.liden@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[TIPC]: Fix simple sparse warningsSam Ravnborg
Tried to run the new tipc stack through sparse. Following patch fixes all cases where 0 was used as replacement of NULL. Use NULL to document this is a pointer and to silence sparse. This brough sparse warning count down with 127 to 24 warnings. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Per Liden <per.liden@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-18[TIPC] Avoid polluting the global namespacePer Liden
This patch adds a tipc_ prefix to all externally visible symbols. Signed-off-by: Per Liden <per.liden@ericsson.com>
2006-01-12[TIPC]: Fix 64-bit build warnings.David S. Miller
When storing u32 values in a pointer, need to do some long casts to keep GCC happy. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-12[TIPC] More updates of file headersPer Liden
Updated copyright notice to include the year the file was actually created. Information about file creation dates was extracted from the files in the old CVS repository at tipc.sourceforge.net. Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
2006-01-12[TIPC] Update of file headersPer Liden
The copyright statements from different parts of Ericsson have been merged into one. Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
2006-01-12[TIPC] License header updatePer Liden
The license header in each file now more clearly state that this code is licensed under a dual BSD/GPL. Before this was only evident if you looked at the MODULE_LICENSE line in core.c. Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
2006-01-12[TIPC] Initial mergePer Liden
TIPC (Transparent Inter Process Communication) is a protocol designed for intra cluster communication. For more information see http://tipc.sourceforge.net Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
