Removes a symbol that is not referenced anywhere by TIPC's link code.
Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com>
Gets rid of #include statements that are no longer required as a
result of the merging of obsolete native API header file content
into other TIPC include files.
Do some cleanups of TIPC based on make namespacecheck
1. Don't export unused symbols
2. Eliminate dead code
3. Make functions and variables local
4. Rename buf_acquire to tipc_buf_acquire since it is used in several files
Compile tested only.
This make break out of tree kernel modules that depend on TIPC routines.
Acked-by: Jon Maloy <jon.maloy@ericsson.com>
Acked-by: Paul Gortmaker <paul.gortmaker@windriver.com>
Remove all instances of legacy, or as yet to be implemented code
that is currently living within an #if 0 ... #endif block.
In the rare instance that some of it be needed in the future,
it can still be dragged out of history, but there is no need
for it to sit in mainline.
Change "return (EXPR);" to "return EXPR;"
return is not a function, parentheses are not required.
Ensure that TIPC does not re-establish communication with a
neighboring node until it has finished updating all data structures
containing information about that node to reflect the earlier loss of
contact. Previously, it was possible for TIPC to perform its purge of
name table entries relating to the node once contact had already been
re-established, resulting in the unwanted removal of valid name table
entries.
Signed-off-by: Allan Stephens <allan.stephens@windriver.com>
Add a check to tipc_recv_msg() to ensure it discards messages
arriving on a newly disabled bearer. This is needed to deal with a
race condition that can arise if the bearer is in the midst of being
disabled when it receives a message. Performing the check after
tipc_net_lock has been taken ensures that TIPC's bearers are in a
stable state while the message is being processed.
These functions have enough code in them such that they
seem like sensible targets for un-inlining. Prior to doing
that, this adds the tipc_ prefix to the functions, so that
in the event of a panic dump or similar, the subsystem from
which the functions come from is immediately clear.
Rather than live in link.c where they can only be used in that file alone,
these helper routines are better served by being in link.h
Relocated are the following:
link_working_working
link_working_unknown
link_reset_unknown
link_reset_reset
link_blocked
link_congested
This is just a straight return of a field; there is no
value in the abstraction of hiding it behind a function.
Eliminate an argument in a print statement that has no corresponding
format specification.
Eliminate a field of the TIPC port structure that is populated,
but never referenced.
Signed-off-by: Frans Pop <elendil@planet.nl>
Cc: Per Liden <per.liden@ericsson.com>
Cc: Jon Maloy <jon.maloy@ericsson.com>
Cc: Allan Stephens <allan.stephens@windriver.com>
Forward port commit
fc477e160af086f6e30c3d4fdf5f5c000d29beb5
from git://tipc.cslab.ericsson.net/pub/git/people/allan/tipc.git
Origional commit message:
Allow retransmission of cloned buffers
This patch fixes an issue with TIPC's message retransmission logic
that prevented retransmission of clone sk_buffs. Originally intended
as a means of avoiding wasted work in retransmitting messages that
were still on the driver's outbound queue, it also prevented TIPC
from retransmitting messages through other means -- such as the
secondary bearer of the broadcast link, or another interface in a
set of bonded interfaces. This fix removes existing checks for
cloned sk_buffs that prevented such retransmission.
Origionally-Signed-off-by: Allan Stephens <allan.stephens@windriver.com>
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Port commit 20deb48d16fdd07ce2fdc8d03ea317362217e085
Part of the large effort I'm trying to help with getting all the downstreamed
code from windriver forward ported to the upstream tree
Restore check to filter out inadverdently received messages
This patch reimplements a check that allows TIPC to discard messages
that are not intended for it. This check was present in TIPC 1.5/1.6,
but was removed by accident during the development of TIPC 1.7; it has
now been updated to account for new features present in TIPC 1.7 and
reinserted into TIPC. The main benefit of this check is to filter
out messages arriving from orphaned link endpoints, which can arise
when a node exits the network and then re-enters it with a different
TIPC network address (i.e. <Z.C.N> value).
Origionally-authored-by: Allan Stephens <allan.stephens@windriver.com>
Not including net/atm/
Compiled tested x86 allyesconfig only
Added a > 80 column line or two, which I ignored.
Existing checkpatch plaints willfully, cheerfully ignored.
Andrew Morton reported a build failure on sparc32, because TIPC
uses names like "struct node" and there is a like named data
structure defined in linux/node.h
This just regexp replaces "struct node*" to "struct tipc_node*"
to avoid this and any future similar problems.
This patch corrects many places where TIPC routines indicated
successful completion by returning TIPC_OK instead of 0.
(The TIPC_OK symbol has the value 0, but it should only be used
in contexts that deal with the error code field of a TIPC
message header.)
This patch eliminates the rarely-used "error code" argument
when initializing a TIPC message header, since the default
value of zero is the desired result in most cases; the few
exceptional cases now set the error code explicitly.
This patch eliminates a case where TIPC's link code could try reading
a field that is not present in a short message header. (The random
value obtained was not being used, but the read operation could result
in an invalid memory access exception in extremely rare circumstances.)
This patch enhances TIPC's handler for incoming messages in two
ways:
- the trivial, single-use routine for processing non-sequenced
messages has been merged into the main handler
- the interface that received a message is now identified without
having to access and/or modify the associated sk_buff
This patch introduces a new, out-of-range value to indicate that
a link endpoint does not have an existing session established
with its peer, eliminating the risk that the previously used
"invalid session number" value (i.e. zero) might eventually be
assigned as a valid session number and cause incorrect link
behavior.
The patch also introduces explicit bit masking when assigning a
new link session number to ensure it does not exceed 16 bits.
This patch modifies TIPC to only exclude debug-related print buffer
routines when debugging capabilities are not required. It also
fixes up some related #defines that exceed 80 characters.
This patch ensures that TIPC properly handles incoming messages
that have incorrect or unexpected formats. Most significantly,
it now ensures that each sl_buff has at least as much data as
the message header indicates it should, and that the entire
message header is stored contiguously; this prevents TIPC from
accidentally accessing memory that is not part of the sk_buff.
This patch allows TIPC to process incoming messages that are
stored in a fragmented sk_buff, by forcing the linearization
of any such messages it receives.
Note: This is an interim solution to allow TIPC to operate with
Ethernet devices that generate non-linear buffers (such as the
gianfar driver), until such time as the rest of TIPC is enhanced
to handle sk_buffs with multiple data areas.
This patch eliminates some unused or duplicate message header
symbols, and fixes up the comments and/or location of a few
other symbols.
net/tipc/cluster.c:145:2: warning: Using plain integer as NULL pointer
net/tipc/link.c:3254:36: warning: Using plain integer as NULL pointer
net/tipc/ref.c:151:15: warning: Using plain integer as NULL pointer
net/tipc/zone.c:85:2: warning: Using plain integer as NULL pointer
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
fix two warnings generated by sparse:
link.c:2386 symbol 'msgcount' shadows an earlier one
node.c:244 symbol 'addr_string' shadows an earlier one
if printbuf allocation or tipc_node_attach_link() fails, invalid
references to the link are left in the associated node and bearer
structures.
Fix by allocating printbuf early and moving timer initialization
and the addition of the new link to the b_ptr->links list after
tipc_node_attach_link() succeeded.
This patch enhances TIPC's stream socket send routine so that
it avoids transmitting data in chunks that require fragmentation
and reassembly, thereby improving performance at both the
sending and receiving ends of the connection.
The "maximum packet size" hint that records MTU info allows
the socket to decide how big a chunk it should send; in the
event that the hint has become stale, fragmentation may still
occur, but the data will be passed correctly and the hint will
be updated in time for the following send. Note: The 66060 byte
pseudo-MTU used for intra-node connections requires the send
routine to perform an additional check to ensure it does not
exceed TIPC"s limit of 66000 bytes of user data per chunk.
Signed-off-by: Jon Paul Maloy <jon.maloy@ericsson.com>
Spring cleaning time...
There seems to be a lot of places in the network code that have
extra bogus semicolons after conditionals. Most commonly is a
bogus semicolon after: switch() { }
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
To clearly state the intent of copying to linear sk_buffs, _offset being a
overly long variant but interesting for the sake of saving some bytes.
Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
This patch allows the compiler to optimize out any code that tries to
send debugging output to the null print buffer (TIPC_NULL), a capability
that was unintentionally broken during the recent print buffer rework.
Signed-off-by: Per Liden <per.liden@ericsson.com>
gcc spits out this warning:
net/tipc/link.c: In function ‘link_retransmit_failure’:
net/tipc/link.c:1669: warning: cast from pointer to integer of different
size
More than a little bit ugly, storing integers in void*, but at least the
code is correct, unlike some of the more crufty Linux kernel code found
elsewhere.
Rather than having two casts to massage the value into u32, it's easier
just to have a single cast and use "%lu", since it's just a printk.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Signed-off-by: Panagiotis Issaris <takis@issaris.org>
The recent change to direct inspection of bundle buffer tailroom did not
account for the possiblity of unrequested tailroom added by skb_alloc(),
thereby allowing a bundle to be created that exceeds the current link MTU.
An additional check now ensures that bundling works correctly no matter
if the bundle buffer is smaller, larger, or equal to the link MTU.
Now determines tailroom of bundle buffer by directly inspection of buffer.
Previously, buffer was assumed to have a max capacity equal to the link MTU,
but the addition of link MTU negotiation means that the link MTU can increase
after the bundle buffer is allocated.
Incorporates several related fixes:
- switchover now occurs when switching from an active link to a standby link
- failure of a standby link no longer initiates switchover
- links now display correct # of received packtes following reactivation
This also contains enhancements to simplify comparisons in name table
publication removal algorithm and to simplify name table sanity checking
when shutting down TIPC.
This fix prevents node from crashing.
This fix prevents link flopping and name table inconsistency problems arising
when a node is assigned a different <Z.C.N> value than it used previously.
(Changing the <Z.C.N> value causes other nodes to have two link endpoints
sending to the same MAC address using two different destination <Z.C.N> values,
requiring the receiving node to filter out the unwanted messages.)
With reference to latest discussions on linux-kernel with respect to
inline here is a patch for tipc to remove all inlines as used in
the .c files. See also chapter 14 in Documentation/CodingStyle.
Before:
102990 5292 1752 110034 1add2 tipc.o
Now:
101190 5292 1752 108234 1a6ca tipc.o
This is a nice text size reduction which will improve icache usage.
In some cases bigger (> 4 lines) functions where declared inline
and used in many places, they are most probarly no longer inlined by gcc
resulting in the size reduction.
There are several one liners that no longer are declared inline, but gcc
should inline these just fine without the inline hint.
With this patch applied one warning is added about an unused static
function - that was hidded by utilising inline before.
The function in question were kept so this patch is solely a
inline removal patch.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Tried to run the new tipc stack through sparse.
Following patch fixes all cases where 0 was used
as replacement of NULL.
Use NULL to document this is a pointer and to silence sparse.
This brough sparse warning count down with 127 to 24 warnings.
This patch adds a tipc_ prefix to all externally visible symbols.
Added macros for min/default/max link priority in tipc_config.h.
Also renamed TIPC_NUM_LINK_PRI to TIPC_MEDIA_LINK_PRI since that
is a more accurate description of what it is used for.
