path: root/net/sunrpc/xprtrdma/rpc_rdma.c
2011-03-11RPCRDMA: Fix to XDR page base interpretation in marshalling logic.Tom Tucker
The RPCRDMA marshalling logic assumed that xdr->page_base was an offset into the first page of xdr->page_list. It is in fact an offset into the xdr->page_list itself, that is, it selects the first page in the page_list and the offset into that page. The symptom depended in part on the rpc_memreg_strategy, if it was FRMR, or some other one-shot mapping mode, the connection would get torn down on a base and bounds error. When the badly marshalled RPC was retransmitted it would reconnect, get the error, and tear down the connection again in a loop forever. This resulted in a hung-mount. For the other modes, it would result in silent data corruption. This bug is most easily reproduced by writing more data than the filesystem has space for. This fix corrects the page_base assumption and otherwise simplifies the iov mapping logic. Signed-off-by: Tom Tucker <tom@ogc.us> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-08-11rpcrdma: Fix SQ size calculation when memreg is FRMRTom Tucker
This patch updates the computation to include the worst case situation where three FRMR are required to map a single RPC REQ. Signed-off-by: Tom Tucker <tom@ogc.us> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-11XPRTRDMA: correct an rpc/rdma inline send marshaling errorTom Talpey
Certain client rpc's which contain both lengthy page-contained metadata and a non-empty xdr_tail buffer require careful handling to avoid overlapped memory copying. Rearranging of existing rpcrdma marshaling code avoids it; this fixes an NFSv4 symlink creation error detected with connectathon basic/test8 to multiple servers. Signed-off-by: Tom Talpey <tmtalpey@gmail.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-15Merge branch 'next'Trond Myklebust
2008-10-10RPC/RDMA: reformat a debug printk to keep lines together.Tom Talpey
The send marshaling code split a particular dprintk across two lines, which makes it hard to extract from logfiles. Signed-off-by: Tom Talpey <talpey@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-10RPC/RDMA: return a consistent error, when connect fails.Tom Talpey
The xprt_connect call path does not expect such errors as ECONNREFUSED to be returned from failed transport connection attempts, otherwise it translates them to EIO and signals fatal errors. For example, mount.nfs prints simply "internal error". Translate all such errors to ENOTCONN from RPC/RDMA to match sockets behavior. Signed-off-by: Tom Talpey <talpey@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-10RPC/RDMA: adhere to protocol for unpadded client trailing write chunks.Tom Talpey
The RPC/RDMA protocol allows clients and servers to avoid RDMA operations for data which is purely the result of XDR padding. On the client, automatically insert the necessary padding for such server replies, and optionally don't marshal such chunks. Signed-off-by: Tom Talpey <talpey@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-10RPC/RDMA: suppress retransmit on RPC/RDMA clients.Tom Talpey
An RPC/RDMA client cannot retransmit on an unbroken connection, doing so violates its flow control with the server. Signed-off-by: Tom Talpey <talpey@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-09-20net: Use hton[sl]() instead of __constant_hton[sl]() where applicableArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-30SUNRPC: Fix an unnecessary implicit type cast in rpcrdma_count_chunks()Chuck Lever
Nit: rl_nchunks is an unsigned integer, so pass it into rpcrdma_count_chunks() via an unsigned integer argument. This eliminates a harmless mixed sign comparison in rpcrdma_count_chunks() Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Thomas Talpey <Thomas.Talpey@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Prevent mixed sign comparisons in rpcrdma_convert_iovs()Chuck Lever
Keep the type of the buffer position the same during iovec conversion to reduce the likelihood of unexpected results from comparisons and length computations. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Thomas Talpey <Thomas.Talpey@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-28[SUNRPC]: Use htonl() where appropriate.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-11SUNRPC xprtrdma: fix XDR tail buf marshalling for all opsJames Lentini
rpcrdma_convert_iovs is passed an xdr_buf representing either an RPC request or an RPC reply. In the case of a request, several calculations and tests involving pos are unnecessary. In the case of a reply, several calculations and tests involving pos are incorrect (the code tests pos against the reply xdr buf's len field, which is always 0 at the time rpcrdma_convert_iovs is executed). This change removes the incorrect/unnecessary calculations and tests involving pos. This fixes an observed problem when reading certain file sizes over NFS/RDMA. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: Tom Talpey <talpey@netapp.com> Signed-off-by: James Lentini <jlentini@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-30[SUNRPC] rpc_rdma: we need to cast u64 to unsigned long long for printingStephen Rothwell
as some architectures have unsigned long for u64. net/sunrpc/xprtrdma/rpc_rdma.c: In function 'rpcrdma_create_chunks': net/sunrpc/xprtrdma/rpc_rdma.c:222: warning: format '%llx' expects type 'long long unsigned int', but argument 4 has type 'u64' net/sunrpc/xprtrdma/rpc_rdma.c:234: warning: format '%llx' expects type 'long long unsigned int', but argument 5 has type 'u64' net/sunrpc/xprtrdma/rpc_rdma.c: In function 'rpcrdma_count_chunks': net/sunrpc/xprtrdma/rpc_rdma.c:577: warning: format '%llx' expects type 'long long unsigned int', but argument 4 has type 'u64 Noticed on PowerPC pseries_defconfig build. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-29SUNRPC endianness annotationsAl Viro
rpcrdma stuff lacks endianness annotations for on-the-wire data. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-09RPCRDMA: rpc rdma protocol implementation\"Talpey, Thomas\
This implements the marshaling and unmarshaling of the rpcrdma transport headers. Connection management is also addressed. Signed-off-by: Tom Talpey <talpey@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09RPCRDMA: rpc rdma transport switch\"Talpey, Thomas\
This implements the configuration and building of the core transport switch implementation of the rpcrdma transport. Stubs are provided for the rpcrdma protocol handling, and the infiniband/iwarp verbs interface. These are provided in following patches. Signed-off-by: Tom Talpey <talpey@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
