path: root/net/sunrpc/xdr.c
2010-05-14xdr: Add an export for the helper function write_bytes_to_xdr_buf()Kevin Coffman
Signed-off-by: Kevin Coffman <kwc@citi.umich.edu> Signed-off-by: Steve Dickson <steved@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-08-14sunrpc: ntoh -> be*_to_cpuBenny Halevy
ntohl is already defined as be32_to_cpu. be64_to_cpu has architecture specific optimized implementations. Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-14sunrpc: hton -> cpu_to_be*Benny Halevy
htonl is already defined as cpu_to_be32. cpu_to_be64 has architecture specific optimized implementations. Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-12-23SUNRPC: Convert the xdr helpers and rpc_pipefs to EXPORT_SYMBOL_GPLTrond Myklebust
We've never considered the sunrpc code as part of any ABI to be used by out-of-tree modules. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-04-08SUNRPC: don't call flush_dcache_page() with an invalid pointerTrond Myklebust
Fix a problem in _copy_to_pages(), whereby it may call flush_dcache_page() with an invalid pointer due to the fact that 'pgto' gets incremented beyond the end of the page array. Fix is to exit the loop without this unnecessary increment of pgto. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-01SUNRPC: Use unsigned string lengths in xdr_decode_string_inplaceChuck Lever
XDR strings, opaques, and net objects should all use unsigned lengths. To wit, RFC 4506 says: 4.2. Unsigned Integer An XDR unsigned integer is a 32-bit datum that encodes a non-negative integer in the range [0,4294967295]. ... 4.11. String The standard defines a string of n (numbered 0 through n-1) ASCII bytes to be the number n encoded as an unsigned integer (as described above), and followed by the n bytes of the string. After this patch, xdr_decode_string_inplace now matches the other XDR string and array helpers that take a string length argument. See: xdr_encode_opaque_fixed, xdr_encode_opaque, xdr_encode_array Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Acked-By: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-01-30SUNRPC: Move exported declarations to the function declarationsTrond Myklebust
Do this for all RPC client related functions and XDR functions. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-27[CRYPTO] users: Fix up scatterlist conversion errorsHerbert Xu
This patch fixes the errors made in the users of the crypto layer during the sg_init_table conversion. It also adds a few conversions that were missing altogether. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-24SG: Change sg_set_page() to take length and offset argumentJens Axboe
Most drivers need to set length and offset as well, so may as well fold those three lines into one. Add sg_assign_page() for those two locations that only needed to set the page, where the offset/length is set outside of the function context. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-22Update net/ to use sg helpersJens Axboe
2007-02-10[NET] SUNRPC: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-06rpc: move process_xdr_bufOlga Kornievskaia
Since process_xdr_buf() is useful outside of the kerberos-specific code, we move it to net/sunrpc/xdr.c, export it, and rename it in keeping with xdr_* naming convention of xdr.c. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-12-06SUNRPC: Ensure xdr_buf_read_netobj() checks for memory overrunsTrond Myklebust
Also clean up the code... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-12-06SUNRPC: Add __(read|write)_bytes_from_xdr_bufTrond Myklebust
2006-12-06SUNRPC: Clean up argument types in xdr.cTrond Myklebust
Converts various integer buffer offsets and sizes to unsigned integer. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-28[SUNRPC]: trivial endianness annotationsAlexey Dobriyan
pure s/u32/__be32/ [AV: large part based on Alexey's patches] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-05This fixes a panic doing the first READDIR or READDIRPLUS call when:Trond Myklebust
* the client is ia64 or any platform that actually implements flush_dcache_page(), and * the server returns fsinfo.dtpref >= client's PAGE_SIZE, and * the server does *not* return post-op attributes for the directory in the READDIR reply. Problem diagnosed by Greg Banks <gnb@melbourne.sgi.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-06-09RPC: Allow struc xdr_stream to read the page section of an xdr_bufTrond Myklebust
2006-01-06SUNRPC: net/sunrpc/xdr.c: remove xdr_decode_string()Adrian Bunk
This patch removes ths unused function xdr_decode_string(). Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Neil Brown <neilb@suse.de> Acked-by: Charles Lever <Charles.Lever@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-11-08[NET]: kfree cleanupJesper Juhl
From: Jesper Juhl <jesper.juhl@gmail.com> This is the net/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in net/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Arnaldo Carvalho de Melo <acme@conectiva.com.br> Acked-by: Marcel Holtmann <marcel@holtmann.org> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-09-23[PATCH] RPC: introduce client-side transport switchChuck Lever
Move the bulk of client-side socket-specific code into a separate source file, net/sunrpc/xprtsock.c. Test-plan: Millions of fsx operations. Performance characterization such as "sio" or "iozone". Destructive testing (unplugging the network temporarily, server reboots). Connectathon with v2, v3, and v4. Version: Thu, 11 Aug 2005 16:03:38 -0400 Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-09-23[PATCH] RPC: extract socket logic common to both client and serverChuck Lever
Clean-up: Move some code that is common to both RPC client- and server-side socket transports into its own source file, net/sunrpc/socklib.c. Test-plan: Compile kernel with CONFIG_NFS enabled. Millions of fsx operations over UDP, client and server. Connectathon over UDP. Version: Thu, 11 Aug 2005 16:03:09 -0400 Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-08-16[PATCH] NFS: Ensure ACL xdr code doesn't overflow.Trond Myklebust
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-22[PATCH] RPC: Encode and decode arbitrary XDR arraysAndreas Gruenbacher
Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Olaf Kirch <okir@suse.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] RPC: fix accounting bug in the case of a truncated RPC messageTrond Myklebust
2005-06-22[PATCH] RPC: Lazy RPC receive buffer allocationOlaf Kirch
Signed-off-by: Olaf Kirch <okir@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] RPC: Ensure XDR iovec length is initialized correctly in call_headerTrond Myklebust
Fix up call_header() so that it calls xdr_adjust_iovec(). Fix calculation of the scratch buffer length in xdr_init_encode(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-05-01[PATCH] DocBook: changes and extensions to the kernel documentationPavel Pisa
I have recompiled Linux kernel 2.6.11.5 documentation for me and our university students again. The documentation could be extended for more sources which are equipped by structured comments for recent 2.6 kernels. I have tried to proceed with that task. I have done that more times from 2.6.0 time and it gets boring to do same changes again and again. Linux kernel compiles after changes for i386 and ARM targets. I have added references to some more files into kernel-api book, I have added some section names as well. So please, check that changes do not break something and that categories are not too much skewed. I have changed kernel-doc to accept "fastcall" and "asmlinkage" words reserved by kernel convention. Most of the other changes are modifications in the comments to make kernel-doc happy, accept some parameters description and do not bail out on errors. Changed <pid> to @pid in the description, moved some #ifdef before comments to correct function to comments bindings, etc. You can see result of the modified documentation build at http://cmp.felk.cvut.cz/~pisa/linux/lkdb-2.6.11.tar.gz Some more sources are ready to be included into kernel-doc generated documentation. Sources has been added into kernel-api for now. Some more section names added and probably some more chaos introduced as result of quick cleanup work. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
