path: root/net/sunrpc/sysctl.c
2013-06-13net: Convert uses of typedef ctl_table to struct ctl_tableJoe Perches
Reduce the uses of this unnecessary typedef. Done via perl script: $ git grep --name-only -w ctl_table net | \ xargs perl -p -i -e '\ sub trim { my ($local) = @_; $local =~ s/(^\s+|\s+$)//g; return $local; } \ s/\b(?<!struct\s)ctl_table\b(\s*\*\s*|\s+\w+)/"struct ctl_table " . trim($1)/ge' Reflow the modified lines that now exceed 80 columns. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-31SUNRPC: make SUNPRC clients list per network namespace contextStanislav Kinsbursky
This patch moves static SUNRPC clients list and it's lock to sunrpc_net structure. Currently this list is used only for debug purposes. But later it will be used also for selecting clients by networks namespace on PipeFS mount/umount events. Per-network namespace lists will make this faster and simplier. Note: client list is taken from "init_net" network namespace context in rpc_show_tasks(). This will be changed some day later with making SUNRPC sysctl's per network namespace context. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-11-18sysctl: Drop & in front of every proc_handler.Eric W. Biederman
For consistency drop & in front of every proc_handler. Explicity taking the address is unnecessary and it prevents optimizations like stubbing the proc_handlers to NULL. Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joe Perches <joe@perches.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-12sysctl net: Remove unused binary sysctl codeEric W. Biederman
Now that sys_sysctl is a compatiblity wrapper around /proc/sys all sysctl strategy routines, and all ctl_name and strategy entries in the sysctl tables are unused, and can be revmoed. In addition neigh_sysctl_register has been modified to no longer take a strategy argument and it's callers have been modified not to pass one. Cc: "David Miller" <davem@davemloft.net> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: netdev@vger.kernel.org Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-09-24sysctl: remove "struct file *" argument of ->proc_handlerAlexey Dobriyan
It's unused. It isn't needed -- read or write flag is already passed and sysctl shouldn't care about the rest. It _was_ used in two places at arch/frv for some reason. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-01sunrpc: fix possible overrun on read of /proc/sys/sunrpc/transportsCyrill Gorcunov
Vegard Nossum reported ---------------------- > I noticed that something weird is going on with /proc/sys/sunrpc/transports. > This file is generated in net/sunrpc/sysctl.c, function proc_do_xprt(). When > I "cat" this file, I get the expected output: > $ cat /proc/sys/sunrpc/transports > tcp 1048576 > udp 32768 > But I think that it does not check the length of the buffer supplied by > userspace to read(). With my original program, I found that the stack was > being overwritten by the characters above, even when the length given to > read() was just 1. David Wagner added (among other things) that copy_to_user could be probably used here. Ingo Oeser suggested to use simple_read_from_buffer() here. The conclusion is that proc_do_xprt doesn't check for userside buffer size indeed so fix this by using Ingo's suggestion. Reported-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> CC: Ingo Oeser <ioe-lkml@rameria.de> Cc: Neil Brown <neilb@suse.de> Cc: Chuck Lever <chuck.lever@oracle.com> Cc: Greg Banks <gnb@sgi.com> Cc: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Add /proc/sys/sunrpc/transport filesTom Tucker
Add a file that when read lists the set of registered svc transports. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-01-30SUNRPC: Restrict sunrpc client exportsTrond Myklebust
The sunrpc client exports are not meant to be part of any official kernel API: they can change at the drop of a hat. Mark them as internal functions using EXPORT_SYMBOL_GPL. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Move exported declarations to the function declarationsTrond Myklebust
Do this for all RPC client related functions and XDR functions. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-30sunrpc: fix rpc debuggingJ. Bruce Fields
Commit baa3a2a0d24ebcf1c451bec8e5bee3d3467f4cbb ("sysctl: remove broken sunrpc debug binary sysctls"), by removing initialization of the ctl_name field, broke this conditional, preventing the display of rpc_tasks that you previously got when turning on rpc debugging. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18sysctl: remove broken sunrpc debug binary sysctlsEric W. Biederman
This is debug code so no need to support binary sysctl, and the binary sysctls as they were written were not consistent with what showed up in /proc so remove the binary sysctl support. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Alexey Dobriyan <adobriyan@sw.ru> Cc: "David S. Miller" <davem@davemloft.net> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: remove insert_at_head from register_sysctlEric W. Biederman
The semantic effect of insert_at_head is that it would allow new registered sysctl entries to override existing sysctl entries of the same name. Which is pain for caching and the proc interface never implemented. I have done an audit and discovered that none of the current users of register_sysctl care as (excpet for directories) they do not register duplicate sysctl entries. So this patch simply removes the support for overriding existing entries in the sys_sysctl interface since no one uses it or cares and it makes future enhancments harder. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Neil Brown <neilb@suse.de> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jan Kara <jack@ucw.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: sunrpc: don't unnecessarily set ctl_table->deEric W. Biederman
We don't need this to prevent module unload races so remove the unnecessary code. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: sunrpc: remove unnecessary insert_at_head flagEric W. Biederman
Because the sunrpc sysctls don't conflict with any other sysctls the setting the insert at head flag to register_sysctl has no semantic meaning. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[NET] SUNRPC: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-06SUNRPC: relocate the creation of socket-specific tunablesChuck Lever
Clean-up: The RPC client currently creates some sysctls that are specific to the socket transport. Move those entirely into xprtsock.c. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-11-04SUNRPC: allow sunrpc.o to link when CONFIG_SYSCTL is disabledChuck Lever
The sunrpc module should build properly even when CONFIG_SYSCTL is disabled. Reported by Jan-Benedict Glaw. Test plan: Compile kernel with CONFIG_NFS as a module and built-in, and CONFIG_SYSCTL enabled and disabled. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-09-23[PATCH] RPC: allow RPC client's port range to be adjustableChuck Lever
Select an RPC client source port between 650 and 1023 instead of between 1 and 800. The old range conflicts with a number of network services. Provide sysctls to allow admins to select a different port range. Note that this doesn't affect user-level RPC library behavior, which still uses 1 to 800. Based on a suggestion by Olaf Kirch <okir@suse.de>. Test-plan: Repeated mount and unmount. Destructive testing. Idle timeouts. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-09-23[PATCH] RPC: introduce client-side transport switchChuck Lever
Move the bulk of client-side socket-specific code into a separate source file, net/sunrpc/xprtsock.c. Test-plan: Millions of fsx operations. Performance characterization such as "sio" or "iozone". Destructive testing (unplugging the network temporarily, server reboots). Connectathon with v2, v3, and v4. Version: Thu, 11 Aug 2005 16:03:38 -0400 Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
