path: root/net/sunrpc/svcauth_unix.c
2009-08-04sunrpc: fix memory leak in unix_gid cache.NeilBrown
When we look up an entry in the uid->gidlist cache, we take a reference to the content but don't drop the reference to the cache entry. So it never gets freed. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-07SUNRPC: The sunrpc server code should not be used by out-of-tree modulesTrond Myklebust
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-10-31net: replace NIPQUAD() in net/*/Harvey Harrison
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u can be replaced with %pI4 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-29net: replace %p6 with %pI6Harvey Harrison
2008-10-28net: remove NIP6(), NIP6_FMT, NIP6_SEQFMT and final usersHarvey Harrison
Open code NIP6_FMT in the one call inside sscanf and one user of NIP6() that could use %p6 in the netfilter code. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-28net, misc: replace uses of NIP6_FMT with %p6Harvey Harrison
2008-05-18svcrpc: fix proc/net/rpc/auth.unix.ip/content displayJ. Bruce Fields
Commit f15364bd4cf8799a7677b6daeed7b67d9139d974 ("IPv6 support for NFS server export caches") dropped a couple spaces, rendering the output here difficult to read. (However note that we expect the output to be parsed only by humans, not machines, so this shouldn't have broken any userland software.) Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-04-23IPv6 support for NFS server export cachesAurélien Charbon
This adds IPv6 support to the interfaces that are used to express nfsd exports. All addressed are stored internally as IPv6; backwards compatibility is maintained using mapped addresses. Thanks to Bruce Fields, Brian Haley, Neil Brown and Hideaki Joshifuji for comments Signed-off-by: Aurelien Charbon <aurelien.charbon@bull.net> Cc: Neil Brown <neilb@suse.de> Cc: Brian Haley <brian.haley@hp.com> Cc: YOSHIFUJI Hideaki / 吉藤英明 <yoshfuji@linux-ipv6.org> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01SUNRPC: Move exported symbol definitions after function declaration part 2Trond Myklebust
Do it for the server code... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Move the authinfo cache to svc_xprt.Tom Tucker
Move the authinfo cache to svc_xprt. This allows both the TCP and RDMA transports to share this logic. A flag bit is used to determine if auth information is to be cached or not. Previously, this code looked at the transport protocol. I've also changed the spin_lock/unlock logic so that a lock is not taken for transports that are not caching auth info. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2007-07-17knfsd: nfsd: set rq_client to ip-address-determined-domainJ. Bruce Fields
We want it to be possible for users to restrict exports both by IP address and by pseudoflavor. The pseudoflavor information has previously been passed using special auth_domains stored in the rq_client field. After the preceding patch that stored the pseudoflavor in rq_pflavor, that's now superfluous; so now we use rq_client for the ip information, as auth_null and auth_unix do. However, we keep around the special auth_domain in the rq_gssclient field for backwards compatibility purposes, so we can still do upcalls using the old "gss/pseudoflavor" auth_domain if upcalls using the unix domain to give us an appropriate export. This allows us to continue supporting old mountd. In fact, for this first patch, we always use the "gss/pseudoflavor" auth_domain (and only it) if it is available; thus rq_client is ignored in the auth_gss case, and this patch on its own makes no change in behavior; that will be left to later patches. Note on idmap: I'm almost tempted to just replace the auth_domain in the idmap upcall by a dummy value--no version of idmapd has ever used it, and it's unlikely anyone really wants to perform idmapping differently depending on the where the client is (they may want to perform *credential* mapping differently, but that's a different matter--the idmapper just handles id's used in getattr and setattr). But I'm updating the idmapd code anyway, just out of general backwards-compatibility paranoia. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: nfsd4: store pseudoflavor in requestAndy Adamson
Add a new field to the svc_rqst structure to record the pseudoflavor that the request was made with. For now we record the pseudoflavor but don't use it for anything. Signed-off-by: Andy Adamson <andros@citi.umich.edu> Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09knfsd: rename sk_defer_lock to sk_lockNeilBrown
Now that sk_defer_lock protects two different things, make the name more generic. Also don't bother with disabling _bh as the lock is only ever taken from process context. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-17knfsd: use a spinlock to protect sk_info_authunixNeilBrown
sk_info_authunix is not being protected properly so the object that it points to can be cache_put twice, leading to corruption. We borrow svsk->sk_defer_lock to provide the protection. We should probably rename that lock to have a more generic name - later. Thanks to Gabriel for reporting this. Cc: Greg Banks <gnb@melbourne.sgi.com> Cc: Gabriel Barazer <gabriel@oxeva.fr> Signed-off-by: Neil Brown <neilb@suse.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] knfsd: allow the server to provide a gid list when using AUTH_UNIX ↵NeilBrown
authentication AUTH_UNIX authentication (the standard with NFS) has a limit of 16 groups ids. This causes problems for people in more than 16 groups. So allow the server to map a uid into a list of group ids based on local knowledge rather depending on the (possibly truncated) list from the client. If there is no process on the server responding to upcalls, the gidlist in the request will still be used. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] knfsd: SUNRPC: Provide room in svc_rqst for larger addressesChuck Lever
Expand the rq_addr field to allow it to contain larger addresses. Specifically, we replace a 'sockaddr_in' with a 'sockaddr_storage', then everywhere the 'sockaddr_in' was referenced, we use instead an accessor function (svc_addr_in) which safely casts the _storage to _in. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Aurelien Charbon <aurelien.charbon@ext.bull.net> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[NET] SUNRPC: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-13[PATCH] knfsd: Don't ignore kstrdup failure in rpc cachesNeilBrown
Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] knfsd: nfsd: don't drop silently on upcall deferralJ.Bruce Fields
To avoid tying up server threads when nfsd makes an upcall (to mountd, to get export options, to idmapd, for nfsv4 name<->id mapping, etc.), we temporarily "drop" the request and save enough information so that we can revisit it later. Certain failures during the deferral process can cause us to really drop the request and never revisit it. This is often less than ideal, and is unacceptable in the NFSv4 case--rfc 3530 forbids the server from dropping a request without also closing the connection. As a first step, we modify the deferral code to return -ETIMEDOUT (which is translated to nfserr_jukebox in the v3 and v4 cases, and remains a drop in the v2 case). Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-02[SUNRPC]: annotate hash_ip()Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-04[PATCH] knfsd: knfsd: cache ipmap per TCP socketGreg Banks
Speed up high call-rate workloads by caching the struct ip_map for the peer on the connected struct svc_sock instead of looking it up in the ip_map cache hashtable on every call. This helps workloads using AUTH_SYS authentication over TCP. Testing was on a 4 CPU 4 NIC Altix using 4 IRIX clients, each with 16 synthetic client threads simulating an rsync (i.e. recursive directory listing) workload reading from an i386 RH9 install image (161480 regular files in 10841 directories) on the server. That tree is small enough to fill in the server's RAM so no disk traffic was involved. This setup gives a sustained call rate in excess of 60000 calls/sec before being CPU-bound on the server. Profiling showed strcmp(), called from ip_map_match(), was taking 4.8% of each CPU, and ip_map_lookup() was taking 2.9%. This patch drops both contribution into the profile noise. Note that the above result overstates this value of this patch for most workloads. The synthetic clients are all using separate IP addresses, so there are 64 entries in the ip_map cache hash. Because the kernel measured contained the bug fixed in commit commit 1f1e030bf75774b6a283518e1534d598e14147d4 and was running on 64bit little-endian machine, probably all of those 64 entries were on a single chain, thus increasing the cost of ip_map_lookup(). With a modern kernel you would need more clients to see the same amount of performance improvement. This patch has helped to scale knfsd to handle a deployment with 2000 NFS clients. Signed-off-by: Greg Banks <gnb@melbourne.sgi.com> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] knfsd: remove an unused variable from auth_unix_lookup()Greg Banks
2006-09-28[SUNRPC]: more sunrpc endianness annotationsAl Viro
2006-09-28[SUNRPC]: trivial endianness annotationsAlexey Dobriyan
pure s/u32/__be32/ [AV: large part based on Alexey's patches] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[SUNRPC]: svc_{get,put}nl()Alexey Dobriyan
* add svc_getnl(): Take network-endian value from buffer, convert to host-endian and return it. * add svc_putnl(): Take host-endian value, convert to network-endian and put it into a buffer. * annotate svc_getu32()/svc_putu32() as dealing with network-endian. * convert to svc_getnl(), svc_putnl(). [AV: in large part it's a carved-up Alexey's patch] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-27[PATCH] knfsd: Tidy up unix_domain_findNeilBrown
We shouldn't really compare &new->h with anything when new ==NULL, and gather three different if statements that all start if (rv ... into one large if. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] knfsd: Convert sunrpc_cache to use krefsNeilBrown
.. it makes some of the code nicer. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] knfsd: Convert ip_map cache to use the new lookup routineNeilBrown
2006-03-27[PATCH] knfsd: Get rid of 'inplace' sunrpc cachesNeilBrown
These were an unnecessary wart. Also only have one 'DefineSimpleCache..' instead of two. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] knfsd: Change the store of auth_domains to not be a 'cache'NeilBrown
The 'auth_domain's are simply handles on internal data structures. They do not cache information from user-space, and forcing them into the mold of a 'cache' misrepresents their true nature and causes confusion. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] knfsd: fix hash function for IP addresses on 64bit little-endian ↵NeilBrown
machines. The hash.h hash_long function, when used on a 64 bit machine, ignores many of the middle-order bits. (The prime chosen it too bit-sparse). IP addresses for clients of an NFS server are very likely to differ only in the low-order bits. As addresses are stored in network-byte-order, these bits become middle-order bits in a little-endian 64bit 'long', and so do not contribute to the hash. Thus you can have the situation where all clients appear on one hash chain. So, until hash_long is fixed (or maybe forever), us a hash function that works well on IP addresses - xor the bytes together. Thanks to "Iozone" <capps@iozone.org> for identifying this problem. Cc: "Iozone" <capps@iozone.org> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] sunrpc: cache_register can use wrong module referenceBruce Allan
When registering an RPC cache, cache_register() always sets the owner as the sunrpc module. However, there are RPC caches owned by other modules. With the incorrect owner setting, the real owning module can be removed potentially with an open reference to the cache from userspace. For example, if one were to stop the nfs server and unmount the nfsd filesystem, the nfsd module could be removed eventhough rpc.idmapd had references to the idtoname and nametoid caches (i.e. /proc/net/rpc/nfs4.<cachename>/channel is still open). This resulted in a system panic on one of our machines when attempting to restart the nfs services after reloading the nfsd module. The following patch adds a 'struct module *owner' field in struct cache_detail. The owner is further assigned to the struct proc_dir_entry in cache_register() so that the module cannot be unloaded while user-space daemons have an open reference on the associated file under /proc. Signed-off-by: Bruce Allan <bwa@us.ibm.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] create a kstrdup library functionPaulo Marques
This patch creates a new kstrdup library function and changes the "local" implementations in several places to use this function. Most of the changes come from the sound and net subsystems. The sound part had already been acknowledged by Takashi Iwai and the net part by David S. Miller. I left UML alone for now because I would need more time to read the code carefully before making changes there. Signed-off-by: Paulo Marques <pmarques@grupopie.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
