path: root/net/sunrpc/svc_xprt.c
2009-01-07SUNRPC: The sunrpc server code should not be used by out-of-tree modulesTrond Myklebust
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-07svc: Clean up deferred requests on transport destructionTom Tucker
A race between svc_revisit and svc_delete_xprt can result in deferred requests holding references on a transport that can never be recovered because dead transports are not enqueued for subsequent processing. Check for XPT_DEAD in revisit to clean up completing deferrals on a dead transport and sweep a transport's deferred queue to do the same for queued but unprocessed deferrals. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-07svc: Move kfree of deferral record to common codeTom Tucker
The rqstp structure has a pointer to a svc_deferred_req record that is allocated when requests are deferred. This record is common to all transports and can be freed in common code. Move the kfree of the rq_deferred to the common svc_xprt_release function. This also fixes a memory leak in the RDMA transport which does not kfree the dr structure in it's version of the xpo_release_rqst callback. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2009-01-06sunrpc: add sv_maxconn field to svc_serv (try #3)Jeff Layton
svc_check_conn_limits() attempts to prevent denial of service attacks by having the service close old connections once it reaches a threshold. This threshold is based on the number of threads in the service: (serv->sv_nrthreads + 3) * 20 Once we reach this, we drop the oldest connections and a printk pops to warn the admin that they should increase the number of threads. Increasing the number of threads isn't an option however for services like lockd. We don't want to eliminate this check entirely for such services but we need some way to increase this limit. This patch adds a sv_maxconn field to the svc_serv struct. When it's set to 0, we use the current method to calculate the max number of connections. RPC services can then set this on an as-needed basis. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-09-29SUNRPC: Use proper INADDR_ANY when setting up RPC services on IPv6Chuck Lever
Teach svc_create_xprt() to use the correct ANY address for AF_INET6 based RPC services. No caller uses AF_INET6 yet. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-05-19svc: Remove unused header files from svc_xprt.cTom Tucker
This cosmetic patch removes unused header files that svc_xprt.c inherited from svcsock.c Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
2008-05-19svc: Remove extra check for XPT_DEAD bit in svc_xprt_enqueueTom Tucker
Remove a redundant check for the XPT_DEAD bit in the svc_xprt_enqueue function. This same bit is checked below while holding the pool lock and prints a debug message if found to be dead. Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
2008-04-23SUNRPC: allow svc_recv to break out of 500ms sleep when alloc_page failsJeff Layton
svc_recv() calls alloc_page(), and if it fails it does a 500ms uninterruptible sleep and then reattempts. There doesn't seem to be any real reason for this to be uninterruptible, so change it to an interruptible sleep. Also check for kthread_stop() and signalled() after setting the task state to avoid races that might lead to sleeping after kthread_stop() wakes up the task. I've done some very basic smoke testing with this, but obviously it's hard to test the actual changes since this all depends on an alloc_page() call failing. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-04-23SUNRPC: have svc_recv() check kthread_should_stop()Jeff Layton
When using kthreads that call into svc_recv, we want to make sure that they do not block there for a long time when we're trying to take down the kthread. This patch changes svc_recv() to check kthread_should_stop() at the same places that it checks to see if it's signalled(). Also check just before svc_recv() tries to schedule(). By making sure that we check it just after setting the task state we can avoid having to use any locking or signalling to ensure it doesn't block for a long time. There's still a chance of a 500ms sleep if alloc_page() fails, but that should be a rare occurrence and isn't a terribly long time in the context of a kthread being taken down. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-03-17[NET] endianness noise: INADDR_ANYAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-01SUNRPC: Move exported symbol definitions after function declaration part 2Trond Myklebust
Do it for the server code... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Add svc_xprt_names service to replace svc_sock_namesTom Tucker
Create a transport independent version of the svc_sock_names function. The toclose capability of the svc_sock_names service can be implemented using the svc_xprt_find and svc_xprt_close services. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01knfsd: Support adding transports by writing portlist fileTom Tucker
Update the write handler for the portlist file to allow creating new listening endpoints on a transport. The general form of the string is: <transport_name><space><port number> For example: echo "tcp 2049" > /proc/fs/nfsd/portlist This is intended to support the creation of a listening endpoint for RDMA transports without adding #ifdef code to the nfssvc.c file. Transports can also be removed as follows: '-'<transport_name><space><port number> For example: echo "-tcp 2049" > /proc/fs/nfsd/portlist Attempting to add a listener with an invalid transport string results in EPROTONOSUPPORT and a perror string of "Protocol not supported". Attempting to remove an non-existent listener (.e.g. bad proto or port) results in ENOTCONN and a perror string of "Transport endpoint is not connected" Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Add svc API that queries for a transport instanceTom Tucker
Add a new svc function that allows a service to query whether a transport instance has already been created. This is used in lockd to determine whether or not a transport needs to be created when a lockd instance is brought up. Specifying 0 for the address family or port is effectively a wild-card, and will result in matching the first transport in the service's list that has a matching class name. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Add /proc/sys/sunrpc/transport filesTom Tucker
Add a file that when read lists the set of registered svc transports. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Add transport hdr size for defer/revisitTom Tucker
Some transports have a header in front of the RPC header. The current defer/revisit processing considers only the iov_len and arg_len to determine how much to back up when saving the original request to revisit. Add a field to the rqstp structure to save the size of the transport header so svc_defer can correctly compute the start of a request. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Move the xprt independent code to the svc_xprt.c fileTom Tucker
This functionally trivial patch moves all of the transport independent functions from the svcsock.c file to the transport independent svc_xprt.c file. In addition the following formatting changes were made: - White space cleanup - Function signatures on single line - The inline directive was removed - Lines over 80 columns were reformatted - The term 'socket' was changed to 'transport' in comments - The SMP comment was moved and updated. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Move create logic to common codeTom Tucker
Move the svc transport list logic into common transport creation code. Refactor this code path to make the flow of control easier to read. Move the setting and clearing of the BUSY_BIT during transport creation to common code. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Move the sockaddr information to svc_xprtTom Tucker
This patch moves the transport sockaddr to the svc_xprt structure. Convenience functions are added to set and get the local and remote addresses of a transport from the transport provider as well as determine the length of a sockaddr. A transport is responsible for setting the xpt_local and xpt_remote addresses in the svc_xprt structure as part of transport creation and xpo_accept processing. This cannot be done in a generic way and in fact varies between TCP, UDP and RDMA. A set of xpo_ functions (e.g. getlocalname, getremotename) could have been added but this would have resulted in additional caching and copying of the addresses around. Note that the xpt_local address should also be set on listening endpoints; for TCP/RDMA this is done as part of endpoint creation. For connected transports like TCP and RDMA, the addresses never change and can be set once and copied into the rqstp structure for each request. For UDP, however, the local and remote addresses may change for each request. In this case, the address information is obtained from the UDP recvmsg info and copied into the rqstp structure from there. A svc_xprt_local_port function was also added that returns the local port given a transport. This is used by svc_create_xprt when returning the port associated with a newly created transport, and later when creating a generic find transport service to check if a service is already listening on a given port. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Make deferral processing xprt independentTom Tucker
This patch moves the transport independent sk_deferred list to the svc_xprt structure and updates the svc_deferred_req structure to keep pointers to svc_xprt's directly. The deferral processing code is also moved out of the transport dependent recvfrom functions and into the generic svc_recv path. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Move the authinfo cache to svc_xprt.Tom Tucker
Move the authinfo cache to svc_xprt. This allows both the TCP and RDMA transports to share this logic. A flag bit is used to determine if auth information is to be cached or not. Previously, this code looked at the transport protocol. I've also changed the spin_lock/unlock logic so that a lock is not taken for transports that are not caching auth info. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Make svc_send transport neutralTom Tucker
Move the sk_mutex field to the transport independent svc_xprt structure. Now all the fields that svc_send touches are transport neutral. Change the svc_send function to use the transport independent svc_xprt directly instead of the transport dependent svc_sock structure. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Make close transport independentTom Tucker
Move sk_list and sk_ready to svc_xprt. This involves close because these lists are walked by svcs when closing all their transports. So I combined the moving of these lists to svc_xprt with making close transport independent. The svc_force_sock_close has been changed to svc_close_all and takes a list as an argument. This removes some svc internals knowledge from the svcs. This code races with module removal and transport addition. Thanks to Simon Holm Thøgersen for a compile fix. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Cc: Simon Holm Thøgersen <odie@cs.aau.dk>
2008-02-01svc: Move sk_server and sk_pool to svc_xprtTom Tucker
This is another incremental change that moves transport independent fields from svc_sock to the svc_xprt structure. The changes should be functionally null. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Change sk_inuse to a krefTom Tucker
Change the atomic_t reference count to a kref and move it to the transport indepenent svc_xprt structure. Change the reference count wrapper names to be generic. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Add a generic transport svc_create_xprt functionTom Tucker
The svc_create_xprt function is a transport independent version of the svc_makesock function. Since transport instance creation contains transport dependent and independent components, add an xpo_create transport function. The transport implementation of this function allocates the memory for the endpoint, implements the transport dependent initialization logic, and calls svc_xprt_init to initialize the transport independent field (svc_xprt) in it's data structure. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Add an svc transport classTom Tucker
The transport class (svc_xprt_class) represents a type of transport, e.g. udp, tcp, rdma. A transport class has a unique name and a set of transport operations kept in the svc_xprt_ops structure. A transport class can be dynamically registered and unregisterd. The svc_xprt_class represents the module that implements the transport type and keeps reference counts on the module to avoid unloading while there are active users. The endpoint (svc_xprt) is a generic, transport independent endpoint that can be used to send and receive data for an RPC service. It inherits it's operations from the transport class. A transport driver module registers and unregisters itself with svc sunrpc by calling svc_reg_xprt_class, and svc_unreg_xprt_class respectively. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
