path: root/net/sunrpc/sched.c
2007-08-07SUNRPC: Fix a race in rpciod_down()Trond Myklebust
The commit 4ada539ed77c7a2bbcb75cafbbd7bd8d2b9bef7b lead to the unpleasant possibility of an asynchronous rpc_task being required to call rpciod_down() when it is complete. This again means that the rpciod workqueue may get to call destroy_workqueue on itself -> hang... Change rpciod_up/rpciod_down to just get/put the module, and then create/destroy the workqueues on module load/unload. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: clean up rpc_call_async/rpc_call_sync/rpc_run_taskTrond Myklebust
2007-07-10SUNRPC: Move rpc_register_client and friends into net/sunrpc/clnt.cTrond Myklebust
2007-07-10SUNRPC: Make create_client() take a reference to the rpciod workqueueTrond Myklebust
Ensures that an rpc_client always has the possibility to send asynchronous RPC calls. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Optimise rpciod_up()Trond Myklebust
Instead of taking the mutex every time we just need to increment/decrement rpciod_users, we can optmise by using atomic_inc_not_zero and atomic_dec_and_test. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Kill rpc_clnt->cl_oneshotTrond Myklebust
Replace it with explicit calls to rpc_shutdown_client() or rpc_destroy_client() (for the case of asynchronous calls). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Convert rpc_clnt->cl_users to a krefTrond Myklebust
2007-07-10SUNRPC: Clean up tk_pid allocation and make it locklessTrond Myklebust
2007-07-10SUNRPC: Add a per-rpc_clnt spinlockTrond Myklebust
Use that to protect the rpc_clnt->cl_tasks list instead of using a global lock. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-10SUNRPC: Move rpc_task->tk_task list into struct rpc_clntTrond Myklebust
2007-05-14SUNRPC: remove dead variable 'rpciod_running'Christoph Hellwig
rpciod_running is not used at all, but due to the way DECLARE_MUTEX_LOCKED works we don't get a warning for it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-09sunrpc: fix crash in rpc_malloc()Peter Zijlstra
While the comment says: * To prevent rpciod from hanging, this allocator never sleeps, * returning NULL if the request cannot be serviced immediately. The function does not actually check for NULL pointers being returned. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-09SUNRPC: Fix pointer arithmetic bug recently introduced in rpc_malloc/freeChuck Lever
Use a cleaner method to find the size of an rpc_buffer. This actually works on x86-64! Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-05-08Fix sunrpc warning noiseGeert Uytterhoeven
Commit c5a4dd8b7c15927a8fbff83171b57cad675a79b9 introduced the following compiler warnings: net/sunrpc/sched.c:766: warning: format '%u' expects type 'unsigned int', but argument 3 has type 'size_t' net/sunrpc/sched.c:785: warning: format '%u' expects type 'unsigned int', but argument 2 has type 'size_t' - Use %zu to format size_t - Kill 2 useless casts Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30SUNRPC: Eliminate side effects from rpc_mallocChuck Lever
Currently rpc_malloc sets req->rq_buffer internally. Make this a more generic interface: return a pointer to the new buffer (or NULL) and make the caller set req->rq_buffer and req->rq_bufsize. This looks much more like kmalloc and eliminates the side effects. To fix a potential deadlock, this patch also replaces GFP_NOFS with GFP_NOWAIT in rpc_malloc. This prevents async RPCs from sleeping outside the RPC's task scheduler while allocating their buffer. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-02-12Merge branch 'master' of /home/trondmy/kernel/linux-2.6/Trond Myklebust
Conflicts: net/sunrpc/auth_gss/gss_krb5_crypto.c net/sunrpc/auth_gss/gss_spkm3_token.c net/sunrpc/clnt.c Merge with mainline and fix conflicts.
2007-02-10[NET] SUNRPC: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-03SUNRPC: fix print format for tk_pidChuck Lever
The tk_pid field is an unsigned short. The proper print format specifier for that type is %5u, not %4d. Also clean up some miscellaneous print formatting nits. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-02-03RPC: Clean up rpc_execute...Trond Myklebust
The error values are already propagated through task->tk_status, and none of the callers check one without checking the other, so we can drop the return value. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-01-24[PATCH] NFS: Fix Oops in rpc_call_sync()Trond Myklebust
Fix the Oops in http://bugzilla.linux-nfs.org/show_bug.cgi?id=138 We shouldn't be calling rpc_release_task() for tasks that are not active. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07Merge branch 'master' of /home/trondmy/kernel/linux-2.6/ into merge_linusTrond Myklebust
Conflicts: include/linux/sunrpc/xprt.h net/sunrpc/xprtsock.c Fix up conflicts with the workqueue changes.
2006-12-06SUNRPC: Remove BKL around the RPC socket operations etc.Trond Myklebust
All internal RPC client operations should no longer depend on the BKL, however lockd and NFS callbacks may still require it. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-12-06SUNRPC: Fix up missing BKL in asynchronous RPC callback functionsTrond Myklebust
2006-12-06SUNRPC: Fix a potential race in rpc_wake_up_task()Trond Myklebust
Use RCU to ensure that we can safely call rpc_finish_wakeup after we've called __rpc_do_wake_up_task. If not, there is a theoretical race, in which the rpc_task finishes executing, and gets freed first. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-12-06Fix a second potential rpc_wakeup race...Trond Myklebust
2006-12-06Subject: Re: [PATCH] Fix SUNRPC wakeup/execute race conditionChristophe Saout
The sunrpc scheduler contains a race condition that can let an RPC task end up being neither running nor on any wait queue. The race takes place between rpc_make_runnable (called from rpc_wake_up_task) and __rpc_execute under the following condition: First __rpc_execute calls tk_action which puts the task on some wait queue. The task is dequeued by another process before __rpc_execute continues its execution. While executing rpc_make_runnable exactly after setting the task `running' bit and before clearing the `queued' bit __rpc_execute picks up execution, clears `running' and subsequently both functions fall through, both under the false assumption somebody else took the job. Swapping rpc_test_and_set_running with rpc_clear_queued in rpc_make_runnable fixes that hole. This introduces another possible race condition that can be handled by checking for `queued' after setting the `running' bit. Bug noticed on a 4-way x86_64 system under XEN with an NFSv4 server on the same physical machine, apparently one of the few ways to hit this race condition at all. Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Christophe Saout <christophe@saout.de> Signed-off-by: Trond Myklebust <trond.myklebust@fys.uio.no>
2006-11-22WorkStruct: Pass the work_struct pointer instead of context dataDavid Howells
Pass the work_struct pointer to the work function rather than context data. The work function can use container_of() to work out the data. For the cases where the container of the work_struct may go away the moment the pending bit is cleared, it is made possible to defer the release of the structure by deferring the clearing of the pending bit. To make this work, an extra flag is introduced into the management side of the work_struct. This governs auto-release of the structure upon execution. Ordinarily, the work queue executor would release the work_struct for further scheduling or deallocation by clearing the pending bit prior to jumping to the work function. This means that, unless the driver makes some guarantee itself that the work_struct won't go away, the work function may not access anything else in the work_struct or its container lest they be deallocated.. This is a problem if the auxiliary data is taken away (as done by the last patch). However, if the pending bit is *not* cleared before jumping to the work function, then the work function *may* access the work_struct and its container with no problems. But then the work function must itself release the work_struct by calling work_release(). In most cases, automatic release is fine, so this is the default. Special initiators exist for the non-auto-release case (ending in _NAR). Signed-Off-By: David Howells <dhowells@redhat.com>
2006-09-27[PATCH] Really ignore kmem_cache_destroy return valueAlexey Dobriyan
* Rougly half of callers already do it by not checking return value * Code in drivers/acpi/osl.c does the following to be sure: (void)kmem_cache_destroy(cache); * Those who check it printk something, however, slab_error already printed the name of failed cache. * XFS BUGs on failed kmem_cache_destroy which is not the decision low-level filesystem driver should make. Converted to ignore. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-22SUNRPC: rpc_delay() should not clobber the rpc_task->tk_statusTrond Myklebust
Doing so prevents stuff like call_encode() from working correctly. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22SUNRPC: remove extraneous header inclusionsChuck Lever
include/linux/sunrpc/clnt.h already includes include/linux/sunrpc/xprt.h. We can remove xprt.h from source files that already include clnt.h. Likewise include/linux/sunrpc/timer.h. Test plan: Compile kernel with CONFIG_NFS enabled. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-22SUNRPC: Support for RPC child tasks no longer neededChuck Lever
The previous patches removed the last user of RPC child tasks, so we can remove support for child tasks from net/sunrpc/sched.c now. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-26[PATCH] mempool: use mempool_create_slab_pool()Matthew Dobson
Modify well over a dozen mempool users to call mempool_create_slab_pool() rather than calling mempool_create() with extra arguments, saving about 30 lines of code and increasing readability. Signed-off-by: Matthew Dobson <colpatch@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23Merge branch 'linus'Trond Myklebust
2006-03-20[NET] sem2mutex: net/Arjan van de Ven
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20SUNRPC: Ensure rpc_call_async() always calls tk_ops->rpc_release()Trond Myklebust
Currently this will not happen if we exit before rpc_new_task() was called. Also fix up rpc_run_task() to do the same (for consistency). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20SUNRPC: introduce per-task RPC iostatsChuck Lever
Account for various things that occur while an RPC task is executed. Separate timers for RPC round trip and RPC execution time show how long RPC requests wait in queue before being sent. Eventually these will be accumulated at xprt_release time in one place where they can be viewed from userland. Test plan: Compile kernel with CONFIG_NFS enabled. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20SUNRPC: track length of RPC wait queuesChuck Lever
RPC wait queue length will eventually be exported to userland via the RPC iostats interface. Test plan: Compile kernel with CONFIG_NFS enabled. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-20SUNRPC: Run rpci->queue_timeout on the rpciod workqueue instead of genericTrond Myklebust
2006-03-14[PATCH] SUNRPC: Fix potential deadlock in RPC codeTrond Myklebust
In rpc_wake_up() and rpc_wake_up_status(), it is possible for the call to __rpc_wake_up_task() to fail if another thread happens to be calling rpc_wake_up_task() on the same rpc_task. Problem noticed by Bruno Faccini. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] DocBook: fix some kernel-doc comments in net/sunrpcMartin Waitz
Fix the syntax of some kernel-doc comments Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06SUNRPC: switchable buffer allocationChuck Lever
Add RPC client transport switch support for replacing buffer management on a per-transport basis. In the current IPv4 socket transport implementation, RPC buffers are allocated as needed for each RPC message that is sent. Some transport implementations may choose to use pre-allocated buffers for encoding, sending, receiving, and unmarshalling RPC messages, however. For transports capable of direct data placement, the buffers can be carved out of a pre-registered area of memory rather than from a slab cache. Test-plan: Millions of fsx operations. Performance characterization with "sio" and "iozone". Use oprofile and other tools to look for significant regression in CPU utilization. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-06SUNRPC: rpc_execute should not return task->tk_status;Trond Myklebust
2006-01-06NFSv4: stateful NFSv4 RPC call interfaceTrond Myklebust
The NFSv4 model requires us to complete all RPC calls that might establish state on the server whether or not the user wants to interrupt it. We may also need to schedule new work (including new RPC calls) in order to cancel the new state. The asynchronous RPC model will allow us to ensure that RPC calls always complete, but in order to allow for "synchronous" RPC, we want to add the ability to wait for completion. The waits are, of course, interruptible. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-06SUNRPC: Further cleanupsTrond Myklebust
2006-01-06RPC: Clean up RPC task structureTrond Myklebust
Shrink the RPC task structure. Instead of storing separate pointers for task->tk_exit and task->tk_release, put them in a structure. Also pass the user data pointer as a parameter instead of passing it via task->tk_calldata. This enables us to nest callbacks. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-06SUNRPC: Yet more RPC cleanupsTrond Myklebust
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
