path: root/net/sunrpc/rpcb_clnt.c
2012-08-10SUNRPC: return negative value in case rpcbind client creation errorStanislav Kinsbursky
commit caea33da898e4e14f0ba58173e3b7689981d2c0b upstream. Without this patch kernel will panic on LockD start, because lockd_up() checks lockd_up_net() result for negative value. From my pow it's better to return negative value from rpcbind routines instead of replacing all such checks like in lockd_up(). Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2011-10-25SUNRPC: remove rpcbind clients destruction on module cleanupStanislav Kinsbursky
Rpcbind clients destruction during SUNRPC module removing is obsolete since now those clients are destroying during last RPC service shutdown. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-10-25SUNRPC: remove rpcbind clients creation during service registeringStanislav Kinsbursky
We don't need this code since rpcbind clients are creating during RPC service creation. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-10-25SUNRPC: introduce svc helpers for prepairing rpcbind infrastructureStanislav Kinsbursky
This helpers will be used only for those services, that will send portmapper registration calls. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-10-25SUNRPC: use rpcbind reference counting helpersStanislav Kinsbursky
All is simple: we just increase users counter if rpcbind clients has been created already. Otherwise we create them and set users counter to 1. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-10-25SUNRPC: introduce helpers for reference counted rpcbind clientsStanislav Kinsbursky
v6: 1) added write memory barrier to rpcb_set_local to make sure, that rpcbind clients become valid before rpcb_users assignment 2) explicitly set rpcb_users to 1 instead of incrementing it (looks clearer from my pow). v5: fixed races with rpcb_users in rpcb_get_local() This helpers will be used for dynamical creation and destruction of rpcbind clients. Variable rpcb_users is actually a counter of lauched RPC services. If rpcbind clients has been created already, then we just increase rpcb_users. Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-10-18SUNRPC: Fix rpc_sockaddr2uaddrTrond Myklebust
rpc_sockaddr2uaddr is only used by net/sunrpc/rpcb_clnt.c, where it is used in a non-blockable context in at least one case. Add non-blocking capability by adding a gfp_t argument Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-07-12SUNRPC: Fix use of static variable in rpcb_getport_asyncBen Greear
Because struct rpcbind_args *map was declared static, if two threads entered this method at the same time, the values assigned to map could be sent two two differen tasks. This could cause all sorts of problems, include use-after-free and double-free of memory. Fix this by removing the static declaration so that the map pointer is on the stack. Signed-off-by: Ben Greear <greearb@candelatech.com> Cc: stable@kernel.org Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-05-27SUNRPC: Use AF_LOCAL for rpcbind upcallsChuck Lever
As libtirpc does in user space, have our registration API try using an AF_LOCAL transport first when registering and unregistering. This means we don't chew up privileged ports, and our registration is bound to an "owner" (the effective uid of the process on the sending end of the transport). Only that "owner" may unregister the service. The kernel could probe rpcbind via an rpcbind query to determine whether rpcbind has an AF_LOCAL service. For simplicity, we use the same technique that libtirpc uses: simply fail over to network loopback if creating an AF_LOCAL transport to the well-known rpcbind service socket fails. This means we open-code the pathname of the rpcbind socket in the kernel. For now we have to do that anyway because the kernel's RPC over AF_LOCAL implementation does not support autobind. That may be undesirable in the long term. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16SUNRPC: New xdr_streams XDR decoder APIChuck Lever
Now that all client-side XDR decoder routines use xdr_streams, there should be no need to support the legacy calling sequence [rpc_rqst *, __be32 *, RPC res *] anywhere. We can construct an xdr_stream in the generic RPC code, instead of in each decoder function. This is a refactoring change. It should not cause different behavior. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16SUNRPC: New xdr_streams XDR encoder APIChuck Lever
Now that all client-side XDR encoder routines use xdr_streams, there should be no need to support the legacy calling sequence [rpc_rqst *, __be32 *, RPC arg *] anywhere. We can construct an xdr_stream in the generic RPC code, instead of in each encoder function. Also, all the client-side encoder functions return 0 now, making a return value superfluous. Take this opportunity to convert them to return void instead. This is a refactoring change. It should not cause different behavior. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16SUNRPC: Determine value of "nrprocs" automaticallyChuck Lever
Clean up. Just fixed a panic where the nrprocs field in a different upper layer client was set by hand incorrectly. Use the compiler-generated method used by the other upper layer protocols. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-12-16SUNRPC: Avoid return code checking in rpcbind XDR encoder functionsChuck Lever
Clean up. The trend in the other XDR encoder functions is to BUG() when encoding problems occur, since a problem here is always due to a local coding error. Then, instead of a status, zero is unconditionally returned. Update the rpcbind XDR encoders to behave this way. To finish the update, use the new-style be32_to_cpup() and cpu_to_be32() macros, and compute the buffer sizes using raw integers instead of sizeof(). This matches the conventions used in other XDR functions. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-10-26Merge branch 'for-2.6.37' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.37' of git://linux-nfs.org/~bfields/linux: (99 commits) svcrpc: svc_tcp_sendto XPT_DEAD check is redundant svcrpc: no need for XPT_DEAD check in svc_xprt_enqueue svcrpc: assume svc_delete_xprt() called only once svcrpc: never clear XPT_BUSY on dead xprt nfsd4: fix connection allocation in sequence() nfsd4: only require krb5 principal for NFSv4.0 callbacks nfsd4: move minorversion to client nfsd4: delay session removal till free_client nfsd4: separate callback change and callback probe nfsd4: callback program number is per-session nfsd4: track backchannel connections nfsd4: confirm only on succesful create_session nfsd4: make backchannel sequence number per-session nfsd4: use client pointer to backchannel session nfsd4: move callback setup into session init code nfsd4: don't cache seq_misordered replies SUNRPC: Properly initialize sock_xprt.srcaddr in all cases SUNRPC: Use conventional switch statement when reclassifying sockets sunrpc/xprtrdma: clean up workqueue usage sunrpc: Turn list_for_each-s into the ..._entry-s ... Fix up trivial conflicts (two different deprecation notices added in separate branches) in Documentation/feature-removal-schedule.txt
2010-10-19sunrpc: Don't return NULL from rpcb_createPavel Emelyanov
> The reason for this is in the future, we may want to support additional > address family types. We should, therefore, ensure that every piece of > code that is sensitive to address families fail in some orderly manner > to let developers know where a change is needed. Makes sense. I was under impression, that AF-s other than INET are not cared about at all :( Here's a fixed version of the patch. Log: Its callers check for ERR_PTR. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-10-01sunrpc: Add net to rpc_create_argsPavel Emelyanov
Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2010-09-21SUNRPC: Correct an rpcbind debugging messageChuck Lever
Clean up. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-09-17SUNRPC: Remove rpcb_getport_sync()Chuck Lever
Clean up: rpcb_getport_sync() has no more users, so remove it. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2010-05-25kernel-wide: replace USHORT_MAX, SHORT_MAX and SHORT_MIN with USHRT_MAX, ↵Alexey Dobriyan
SHRT_MAX and SHRT_MIN - C99 knows about USHRT_MAX/SHRT_MAX/SHRT_MIN, not USHORT_MAX/SHORT_MAX/SHORT_MIN. - Make SHRT_MIN of type s16, not int, for consistency. [akpm@linux-foundation.org: fix drivers/dma/timb_dma.c] [akpm@linux-foundation.org: fix security/keys/keyring.c] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-03SUNRPC: Use soft connects for autobinding over TCPChuck Lever
Autobinding is handled by the rpciod process, not in user processes that are generating regular RPC requests. Thus autobinding is usually not affected by signals targetting user processes, such as KILL or timer expiration events. In addition, an RPC request generated by a user process that has RPC_TASK_SOFTCONN set and needs to perform an autobind will hang if the remote rpcbind service is not available. For rpcbind queries on connection-oriented transports, let's use the new soft connect semantic to return control to the user's process quickly, if the kernel's rpcbind client can't connect to the remote rpcbind service. Logic is introduced in call_bind_status() to handle connection errors that occurred during an asynchronous rpcbind query. The logic abandons the rpcbind query if the RPC request has SOFTCONN set, and retries after a few seconds in the normal case. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-12-03SUNRPC: Use TCP for local rpcbind upcallsChuck Lever
Use TCP with the soft connect semantic for local rpcbind upcalls so the kernel can detect immediately if the local rpcbind daemon is not running. Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
2009-12-03SUNRPC: Use a cached RPC client and transport for rpcbind upcallsChuck Lever
The kernel's rpcbind client creates and deletes an rpc_clnt and its underlying transport socket for every upcall to the local rpcbind daemon. When starting a typical NFS server on IPv4 and IPv6, the NFS service itself does three upcalls (one per version) times two upcalls (one per transport) times two upcalls (one per address family), making 12, plus another one for the initial call to unregister previous NFS services. Starting the NLM service adds an additional 13 upcalls, for similar reasons. (Currently the NFS service doesn't start IPv6 listeners, but it will soon enough). Instead, let's create an rpc_clnt for rpcbind upcalls during the first local rpcbind query, and cache it. This saves the overhead of creating and destroying an rpc_clnt and a socket for every upcall. The new logic also prevents the kernel from attempting an RPCB_SET or RPCB_UNSET if it knows from the start that the local portmapper does not support rpcbind protocol version 4. This will cut down on the number of rpcbind upcalls in legacy environments. Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
2009-12-03SUNRPC: Simplify synopsis of rpcb_local_clnt()Chuck Lever
Clean up: At one point, rpcb_local_clnt() handled IPv6 loopback addresses too, but it doesn't any more; only IPv4 loopback is used now. Get rid of the @addr and @addrlen arguments to rpcb_local_clnt(). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-09SUNRPC: Eliminate PROC macro from rpcb_clntChuck Lever
Clean up: Replace PROC macro with open coded C99 structure initializers to improve readability. The rpcbind v4 GETVERSADDR procedure is never sent by the current implementation, so it is not copied to the new structures. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-09SUNRPC: Clean up: Remove unused XDR decoder functions from rpcb_clnt.cChuck Lever
2009-08-09SUNRPC: Introduce new xdr_stream-based decoders to rpcb_clnt.cChuck Lever
Replace the open-coded decode logic for PMAP_GETPORT/RPCB_GETADDR with an xdr_stream-based implementation, similar to what NFSv4 uses, to protect against buffer overflows. The new implementation also checks that the incoming port number is reasonable. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-09SUNRPC: Introduce xdr_stream-based decoders for RPCB_UNSETChuck Lever
Replace the open-coded decode logic for rpcbind UNSET results with an xdr_stream-based implementation, similar to what NFSv4 uses, to protect against buffer overflows. The new function is unused for the moment. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-09SUNRPC: Clean up: Remove unused XDR encoder functions from rpcb_clnt.cChuck Lever
2009-08-09SUNRPC: Introduce new xdr_stream-based encoders to rpcb_clnt.cChuck Lever
Replace the open-coded encode logic for rpcbind arguments with an xdr_stream-based implementation, similar to what NFSv4 uses, to better protect against buffer overflows. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-09SUNRPC: Remove duplicate universal address generationChuck Lever
RPC universal address generation is currently done in several places: rpcb_clnt.c, nfs4proc.c xprtsock.c, and xprtrdma.c. Remove the redundant cases that convert a socket address to a universal address. The nfs4proc.c case takes a pre-formatted presentation address string, not a socket address, so we'll leave that one. Because the new uaddr constructor uses the recently introduced rpc_ntop(), it now supports proper "::" shorthanding for IPv6 addresses. This allows the kernel to register properly formed universal addresses with the local rpcbind service, in _all_ cases. The kernel can now also send properly formed universal addresses in RPCB_GETADDR requests, and support link-local properly when encoding and decoding IPv6 addresses. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-08-09SUNRPC: Move XDR data type size macrosChuck Lever
Clean up: To make subsequent patches cleaner, move the XDR data type size macros to the top of the file (similar to nfs4xdr.c) first. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: rpcb_register() should handle errors silentlyChuck Lever
Move error reporting for RPC registration to rpcb_register's caller. This way the caller can choose to recover silently from certain errors, but report errors it does not recognize. Error reporting for kernel RPC service registration is now handled in one place. This patch is part of a series that addresses http://bugzilla.kernel.org/show_bug.cgi?id=12256 Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: Allow callers to pass rpcb_v4_register a NULL addressChuck Lever
The user space TI-RPC library uses an empty string for the universal address when unregistering all target addresses for [program, version]. The kernel's rpcb client should behave the same way. Here, we are switching between several registration methods based on the protocol family of the incoming address. Rename the other rpcbind v4 registration functions to make it clear that they, as well, are switched on protocol family. In /etc/netconfig, this is either "inet" or "inet6". NB: The loopback protocol families are not supported in the kernel. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: rpcbind actually interprets r_owner stringChuck Lever
RFC 1833 has little to say about the contents of r_owner; it only specifies that it is a string, and states that it is used to control who can UNSET an entry. Our port of rpcbind (from Sun) assumes this string contains a numeric UID value, not alphabetical or symbolic characters, but checks this value only for AF_LOCAL RPCB_SET or RPCB_UNSET requests. In all other cases, rpcbind ignores the contents of the r_owner string. The reference user space implementation of rpcb_set(3) uses a numeric UID for all SET/UNSET requests (even via the network) and an empty string for all other requests. We emulate that behavior here to maintain bug-for-bug compatibility. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: Clean up address type casts in rpcb_v4_register()Chuck Lever
Clean up: Simplify rpcb_v4_register() and its helpers by moving the details of sockaddr type casting to rpcb_v4_register()'s helper functions. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: Use IPv4 loopback for registering AF_INET6 kernel RPC servicesChuck Lever
The kernel uses an IPv6 loopback address when registering its AF_INET6 RPC services so that it can tell whether the local portmapper is actually IPv6-enabled. Since the legacy portmapper doesn't listen on IPv6, however, this causes a long timeout on older systems if the kernel happens to try creating and registering an AF_INET6 RPC service. Originally I wanted to use a connected transport (either TCP or connected UDP) so that the upcall would fail immediately if the portmapper wasn't listening on IPv6, but we never agreed on what transport to use. In the end, it's of little consequence to the kernel whether the local portmapper is listening on IPv6. It's only important whether the portmapper supports rpcbind v4. And the kernel can't tell that at all if it is sending requests via IPv6 -- the portmapper will just ignore them. So, send both rpcbind v2 and v4 SET/UNSET requests via IPv4 loopback to maintain better backwards compatibility between new kernels and legacy user space, and prevent multi-second hangs in some cases when the kernel attempts to register RPC services. This patch is part of a series that addresses http://bugzilla.kernel.org/show_bug.cgi?id=12256 Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-03-28SUNRPC: Don't flag empty RPCB_GETADDR reply as bogusChuck Lever
In 2007, commit e65fe3976f594603ed7b1b4a99d3e9b867f573ea added additional sanity checking to rpcb_decode_getaddr() to make sure we were getting a reply that was long enough to be an actual universal address. If the uaddr string isn't long enough, the XDR decoder returns EIO. However, an empty string is a valid RPCB_GETADDR response if the requested service isn't registered. Moreover, "::.n.m" is also a valid RPCB_GETADDR response for IPv6 addresses that is shorter than rpcb_decode_getaddr()'s lower limit of 11. So this sanity check introduced a regression for rpcbind requests against IPv6 remotes. So revert the lower bound check added by commit e65fe3976f594603ed7b1b4a99d3e9b867f573ea, and add an explicit check for an empty uaddr string, similar to libtirpc's rpcb_getaddr(3). Pointed-out-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-10-31net: replace NIPQUAD() in net/*/Harvey Harrison
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u can be replaced with %pI4 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-29net: replace %p6 with %pI6Harvey Harrison
2008-10-28net, misc: replace uses of NIP6_FMT with %p6Harvey Harrison
2008-10-15Merge branch 'next'Trond Myklebust
2008-10-07SUNRPC: Fix a memory leak in rpcb_getport_asyncTrond Myklebust
2008-10-07SUNRPC: Fix autobind on cloned rpc clientsTrond Myklebust
Despite the fact that cloned rpc clients won't have the cl_autobind flag set, they may still find themselves calling rpcb_getport_async(). For this to happen, it suffices for a _parent_ rpc_clnt to use autobinding, in which case any clone may find itself triggering the !xprt_bound() case in call_bind(). The correct fix for this is to walk back up the tree of cloned rpc clients, in order to find the parent that 'owns' the transport, either because it has clnt->cl_autobind set, or because it originally created the transport... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-09-29SUNRPC: Clean up debug messages in rpcb_clnt.cChuck Lever
The RPCB XDR functions are used for multiple procedures. For instance, rpcb_encode_getaddr() is used for RPCB_GETADDR, RPCB_SET, and RPCB_UNSET. Make the XDR debug messages more generic so they are less confusing. And, unlike in other RPC consumers in the kernel, a single debug flag enables all levels of debug messages in the RPC bind client, including XDR debug messages. Since the XDR decoders already report success or failure in this case, remove redundant debug messages in the mid-level rpcb_register_call() function. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-09-29SUNRPC: Use short-hand IPv6 ANYADDR for RPCB_SETChuck Lever
Clean up: When doing an RPCB_SET, make the kernel's rpcb client use the shorthand "::" for the universal form of the IPv6 ANY address. Without this patch, rpcbind will advertise: 0000:0000:0000:0000:0000:0000:0000:0000.x.y This is cosmetic only. It cleans up the display of information from /sbin/rpcinfo. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-09-29SUNRPC: Simplify rpcb_register() APIChuck Lever
Bruce suggested there's no need to expose the difference between an error sending the PMAP_SET request and an error reply from the portmapper to rpcb_register's callers. The user space equivalent of rpcb_register() is pmap_set(3), which returns a bool_t : either the PMAP set worked, or it didn't. Simple. So let's remove the "*okay" argument from rpcb_register() and rpcb_v4_register(), and simply return an error if any part of the call didn't work. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-07-15SUNRPC: Support registering IPv6 interfaces with local rpcbind daemonChuck Lever
Introduce a new API to register RPC services on IPv6 interfaces to allow the NFS server and lockd to advertise on IPv6 networks. Unlike rpcb_register(), the new rpcb_v4_register() function uses rpcbind protocol version 4 to contact the local rpcbind daemon. The version 4 SET/UNSET procedures allow services to register address families besides AF_INET, register at specific network interfaces, and register transport protocols besides UDP and TCP. All of this functionality is exposed via the new rpcb_v4_register() kernel API. A user-space rpcbind daemon implementation that supports version 4 of the rpcbind protocol is required in order to make use of this new API. Note that rpcbind version 3 is sufficient to support the new rpcbind facilities listed above, but most extant implementations use version 4. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-15SUNRPC: Refactor rpcb_register to make rpcbindv4 support easierChuck Lever
rpcbind version 4 registration will reuse part of rpcb_register, so just split it out into a separate function now. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-07-15SUNRPC: None of rpcb_create's callers wants a privileged source portChuck Lever
Clean up: Callers that required a privileged source port now use rpcb_create_local(), so we can remove the @privileged argument from rpcb_create(). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
