path: root/net/sunrpc/clnt.c
2015-07-03SUNRPC: Don't reencode message if transmission failed with ENOBUFSTrond Myklebust
If we're running out of buffer memory when transmitting data, then we want to just delay for a moment, and then continue transmitting the remainder of the message. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-19SUNRPC: Handle connection issues correctly on the back channelTrond Myklebust
If the back channel is disconnected, we can and should just fail the transmission. The expectation is that the NFSv4.1 server will always retransmit any outstanding callbacks once the connection is re-established. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-10SUNRPC: Transport fault injectionChuck Lever
It has been exceptionally useful to exercise the logic that handles local immediate errors and RDMA connection loss. To enable developers to test this regularly and repeatably, add logic to simulate connection loss every so often. Fault injection is disabled by default. It is enabled with $ sudo echo xxx > /sys/kernel/debug/sunrpc/inject_fault/disconnect where "xxx" is a large positive number of transport method calls before a disconnect. A value of several thousand is usually a good number that allows reasonable forward progress while still causing a lot of connection drops. These hooks are disabled when SUNRPC_DEBUG is turned off. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-10sunrpc: turn swapper_enable/disable functions into rpc_xprt_opsJeff Layton
RDMA xprts don't have a sock_xprt, but an rdma_xprt, so the xs_swapper_enable/disable functions will likely oops when fed an RDMA xprt. Turn these functions into rpc_xprt_ops so that that doesn't occur. For now the RDMA versions are no-ops that just return -EINVAL on an attempt to swapon. Cc: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Jeff Layton <jeff.layton@primarydata.com> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-10sunrpc: make xprt->swapper an atomic_tJeff Layton
Split xs_swapper into enable/disable functions and eliminate the "enable" flag. Currently, it's racy if you have multiple swapon/swapoff operations running in parallel over the same xprt. Also fix it so that we only set it to a memalloc socket on a 0->1 transition and only clear it on a 1->0 transition. Cc: Mel Gorman <mgorman@suse.de> Signed-off-by: Jeff Layton <jeff.layton@primarydata.com> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-10sunrpc: keep a count of swapfiles associated with the rpc_clntJeff Layton
Jerome reported seeing a warning pop when working with a swapfile on NFS. The nfs_swap_activate can end up calling sk_set_memalloc while holding the rcu_read_lock and that function can sleep. To fix that, we need to take a reference to the xprt while holding the rcu_read_lock, set the socket up for swapping and then drop that reference. But, xprt_put is not exported and having NFS deal with the underlying xprt is a bit of layering violation anyway. Fix this by adding a set of activate/deactivate functions that take a rpc_clnt pointer instead of an rpc_xprt, and have nfs_swap_activate and nfs_swap_deactivate call those. Also, add a per-rpc_clnt atomic counter to keep track of the number of active swapfiles associated with it. When the counter does a 0->1 transition, we enable swapping on the xprt, when we do a 1->0 transition we disable swapping on it. This also allows us to be a bit more selective with the RPC_TASK_SWAPPER flag. If non-swapper and swapper clnts are sharing a xprt, then we only need to flag the tasks from the swapper clnt with that flag. Acked-by: Mel Gorman <mgorman@suse.de> Reported-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Jeff Layton <jeff.layton@primarydata.com> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-06-05SUNRPC: Remove unused argument 'tk_ops' in rpc_run_bc_taskTrond Myklebust
2015-06-02SUNRPC: Backchannel handle socket nospaceTrond Myklebust
If the socket was busy due to a socket nospace error, then we should retry the send. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-03-31sunrpc: make debugfs file creation failure non-fatalJeff Layton
We currently have a problem that SELinux policy is being enforced when creating debugfs files. If a debugfs file is created as a side effect of doing some syscall, then that creation can fail if the SELinux policy for that process prevents it. This seems wrong. We don't do that for files under /proc, for instance, so Bruce has proposed a patch to fix that. While discussing that patch however, Greg K.H. stated: "No kernel code should care / fail if a debugfs function fails, so please fix up the sunrpc code first." This patch converts all of the sunrpc debugfs setup code to be void return functins, and the callers to not look for errors from those functions. This should allow rpc_clnt and rpc_xprt creation to work, even if the kernel fails to create debugfs files for some reason. Symptoms were failing krb5 mounts on systems using gss-proxy and selinux. Fixes: 388f0c776781 "sunrpc: add a debugfs rpc_xprt directory..." Cc: stable@vger.kernel.org Signed-off-by: Jeff Layton <jeff.layton@primarydata.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2015-02-08SUNRPC: Handle EADDRINUSE on connectTrond Myklebust
Now that we're setting SO_REUSEPORT, we still need to handle the case where a connect() is attempted, but the old socket is still lingering. Essentially, all we want to do here is handle the error by waiting a few seconds and then retrying. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2015-02-03SUNRPC: NULL utsname dereference on NFS umount during namespace cleanupTrond Myklebust
Fix an Oopsable condition when nsm_mon_unmon is called as part of the namespace cleanup, which now apparently happens after the utsname has been freed. Link: http://lkml.kernel.org/r/20150125220604.090121ae@neptune.home Reported-by: Bruno Prémont <bonbons@linux-vserver.org> Cc: stable@vger.kernel.org # 3.18 Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-11-27sunrpc: add debugfs file for displaying client rpc_task queueJeff Layton
It's possible to get a dump of the RPC task queue by writing a value to /proc/sys/sunrpc/rpc_debug. If you write any value to that file, you get a dump of the RPC client task list into the log buffer. This is a rather inconvenient interface however, and makes it hard to get immediate info about the task queue. Add a new directory hierarchy under debugfs: sunrpc/ rpc_clnt/ <clientid>/ Within each clientid directory we create a new "tasks" file that will dump info similar to what shows up in the log buffer, but with a few small differences -- we avoid printing raw kernel addresses in favor of symbolic names and the XID is also displayed. Signed-off-by: Jeff Layton <jlayton@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-11-24sunrpc: eliminate RPC_DEBUGJeff Layton
It's always set to whatever CONFIG_SUNRPC_DEBUG is, so just use that. Signed-off-by: Jeff Layton <jlayton@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-09-30Merge branch 'bugfixes' into linux-nextTrond Myklebust
* bugfixes: NFSv4.1: Fix an NFSv4.1 state renewal regression NFSv4: fix open/lock state recovery error handling NFSv4: Fix lock recovery when CREATE_SESSION/SETCLIENTID_CONFIRM fails NFS: Fabricate fscache server index key correctly SUNRPC: Add missing support for RPC_CLNT_CREATE_NO_RETRANS_TIMEOUT nfs: fix duplicate proc entries
2014-09-25SUNRPC: Add missing support for RPC_CLNT_CREATE_NO_RETRANS_TIMEOUTTrond Myklebust
The flag RPC_CLNT_CREATE_NO_RETRANS_TIMEOUT was intended introduced in order to allow NFSv4 clients to disable resend timeouts. Since those cause the RPC layer to break the connection, they mess up the duplicate reply caches that remain indexed on the port number in NFSv4.. This patch includes the code that was missing in the original to set the appropriate flag in struct rpc_clnt, when the caller of rpc_create() sets RPC_CLNT_CREATE_NO_RETRANS_TIMEOUT. Fixes: 8a19a0b6cb2e (SUNRPC: Add RPC task and client level options to...) Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-09-24rpc: Add -EPERM processing for xs_udp_send_request()Jason Baron
If an iptables drop rule is added for an nfs server, the client can end up in a softlockup. Because of the way that xs_sendpages() is structured, the -EPERM is ignored since the prior bits of the packet may have been successfully queued and thus xs_sendpages() returns a non-zero value. Then, xs_udp_send_request() thinks that because some bits were queued it should return -EAGAIN. We then try the request again and again, resulting in cpu spinning. Reproducer: 1) open a file on the nfs server '/nfs/foo' (mounted using udp) 2) iptables -A OUTPUT -d <nfs server ip> -j DROP 3) write to /nfs/foo 4) close /nfs/foo 5) iptables -D OUTPUT -d <nfs server ip> -j DROP The softlockup occurs in step 4 above. The previous patch, allows xs_sendpages() to return both a sent count and any error values that may have occurred. Thus, if we get an -EPERM, return that to the higher level code. With this patch in place we can successfully abort the above sequence and avoid the softlockup. I also tried the above test case on an nfs mount on tcp and although the system does not softlockup, I still ended up with the 'hung_task' firing after 120 seconds, due to the i/o being stuck. The tcp case appears a bit harder to fix, since -EPERM appears to get ignored much lower down in the stack and does not propogate up to xs_sendpages(). This case is not quite as insidious as the softlockup and it is not addressed here. Reported-by: Yigong Lou <ylou@akamai.com> Signed-off-by: Jason Baron <jbaron@akamai.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-07-03SUNRPC: Handle EPIPE in xprt_connect_statusTrond Myklebust
The callback handler xs_error_report() can end up propagating an EPIPE error by means of the call to xprt_wake_pending_tasks(). Ensure that xprt_connect_status() does not automatically convert this into an EIO error. Reported-by: Weston Andros Adamson <dros@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-06-30SUNRPC: Ensure that we handle ENOBUFS errors correctly.Trond Myklebust
Currently, an ENOBUFS error will result in a fatal error for the RPC call. Normally, we will just want to wait and then retry. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-04-08Merge branch 'for-3.15' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd updates from Bruce Fields: "Highlights: - server-side nfs/rdma fixes from Jeff Layton and Tom Tucker - xdr fixes (a larger xdr rewrite has been posted but I decided it would be better to queue it up for 3.16). - miscellaneous fixes and cleanup from all over (thanks especially to Kinglong Mee)" * 'for-3.15' of git://linux-nfs.org/~bfields/linux: (36 commits) nfsd4: don't create unnecessary mask acl nfsd: revert v2 half of "nfsd: don't return high mode bits" nfsd4: fix memory leak in nfsd4_encode_fattr() nfsd: check passed socket's net matches NFSd superblock's one SUNRPC: Clear xpt_bc_xprt if xs_setup_bc_tcp failed NFSD/SUNRPC: Check rpc_xprt out of xs_setup_bc_tcp SUNRPC: New helper for creating client with rpc_xprt NFSD: Free backchannel xprt in bc_destroy NFSD: Clear wcc data between compound ops nfsd: Don't return NFS4ERR_STALE_STATEID for NFSv4.1+ nfsd4: fix nfs4err_resource in 4.1 case nfsd4: fix setclientid encode size nfsd4: remove redundant check from nfsd4_check_resp_size nfsd4: use more generous NFS4_ACL_MAX nfsd4: minor nfsd4_replay_cache_entry cleanup nfsd4: nfsd4_replay_cache_entry should be static nfsd4: update comments with obsolete function name rpc: Allow xdr_buf_subsegment to operate in-place NFSD: Using free_conn free connection SUNRPC: fix memory leak of peer addresses in XPRT ...
2014-03-30SUNRPC: New helper for creating client with rpc_xprtKinglong Mee
Signed-off-by: Kinglong Mee <kinglongmee@gmail.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2014-03-20SUNRPC: rpc_restart_call/rpc_restart_call_prepare should clear task->tk_statusTrond Myklebust
When restarting an rpc call, we should not be carrying over data from the previous call. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-03-20SUNRPC: Ensure call_connect_status() deals correctly with SOFTCONN tasksSteve Dickson
Don't schedule an rpc_delay before checking to see if the task is a SOFTCONN because the tk_callback from the delay (__rpc_atrun) clears the task status before the rpc_exit_task can be run. Signed-off-by: Steve Dickson <steved@redhat.com> Fixes: 561ec1603171c (SUNRPC: call_connect_status should recheck...) Link: http://lkml.kernel.org/r/5329CF7C.7090308@RedHat.com Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-03-19SUNRPC: Ensure call_status() deals correctly with SOFTCONN tasksTrond Myklebust
2014-03-17SUNRPC: Ensure that call_bind times out correctlyTrond Myklebust
If the rpcbind server is unavailable, we still want the RPC client to respect the timeout. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-03-17SUNRPC: Ensure that call_connect times out correctlyTrond Myklebust
When the server is unavailable due to a networking error, etc, we want the RPC client to respect the timeout delays when attempting to reconnect. Reported-by: Neil Brown <neilb@suse.de> Fixes: 561ec1603171 (SUNRPC: call_connect_status should recheck bind..) Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-01-05sunrpc: Fix infinite loop in RPC state machineWeston Andros Adamson
When a task enters call_refreshresult with status 0 from call_refresh and !rpcauth_uptodatecred(task) it enters call_refresh again with no rate-limiting or max number of retries. Instead of trying forever, make use of the retry path that other errors use. This only seems to be possible when the crrefresh callback is gss_refresh_null, which only happens when destroying the context. To reproduce: 1) mount with sec=krb5 (or sec=sys with krb5 negotiated for non FSID specific operations). 2) reboot - the client will be stuck and will need to be hard rebooted BUG: soft lockup - CPU#0 stuck for 22s! [kworker/0:2:46] Modules linked in: rpcsec_gss_krb5 nfsv4 nfs fscache ppdev crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd serio_raw i2c_piix4 i2c_core e1000 parport_pc parport shpchp nfsd auth_rpcgss oid_registry exportfs nfs_acl lockd sunrpc autofs4 mptspi scsi_transport_spi mptscsih mptbase ata_generic floppy irq event stamp: 195724 hardirqs last enabled at (195723): [<ffffffff814a925c>] restore_args+0x0/0x30 hardirqs last disabled at (195724): [<ffffffff814b0a6a>] apic_timer_interrupt+0x6a/0x80 softirqs last enabled at (195722): [<ffffffff8103f583>] __do_softirq+0x1df/0x276 softirqs last disabled at (195717): [<ffffffff8103f852>] irq_exit+0x53/0x9a CPU: 0 PID: 46 Comm: kworker/0:2 Not tainted 3.13.0-rc3-branch-dros_testing+ #4 Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 07/31/2013 Workqueue: rpciod rpc_async_schedule [sunrpc] task: ffff8800799c4260 ti: ffff880079002000 task.ti: ffff880079002000 RIP: 0010:[<ffffffffa0064fd4>] [<ffffffffa0064fd4>] __rpc_execute+0x8a/0x362 [sunrpc] RSP: 0018:ffff880079003d18 EFLAGS: 00000246 RAX: 0000000000000005 RBX: 0000000000000007 RCX: 0000000000000007 RDX: 0000000000000007 RSI: ffff88007aecbae8 RDI: ffff8800783d8900 RBP: ffff880079003d78 R08: ffff88006e30e9f8 R09: ffffffffa005a3d7 R10: ffff88006e30e7b0 R11: ffff8800783d8900 R12: ffffffffa006675e R13: ffff880079003ce8 R14: ffff88006e30e7b0 R15: ffff8800783d8900 FS: 0000000000000000(0000) GS:ffff88007f200000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00007f3072333000 CR3: 0000000001a0b000 CR4: 00000000001407f0 Stack: ffff880079003d98 0000000000000246 0000000000000000 ffff88007a9a4830 ffff880000000000 ffffffff81073f47 ffff88007f212b00 ffff8800799c4260 ffff8800783d8988 ffff88007f212b00 ffffe8ffff604800 0000000000000000 Call Trace: [<ffffffff81073f47>] ? trace_hardirqs_on_caller+0x145/0x1a1 [<ffffffffa00652d3>] rpc_async_schedule+0x27/0x32 [sunrpc] [<ffffffff81052974>] process_one_work+0x211/0x3a5 [<ffffffff810528d5>] ? process_one_work+0x172/0x3a5 [<ffffffff81052eeb>] worker_thread+0x134/0x202 [<ffffffff81052db7>] ? rescuer_thread+0x280/0x280 [<ffffffff81052db7>] ? rescuer_thread+0x280/0x280 [<ffffffff810584a0>] kthread+0xc9/0xd1 [<ffffffff810583d7>] ? __kthread_parkme+0x61/0x61 [<ffffffff814afd6c>] ret_from_fork+0x7c/0xb0 [<ffffffff810583d7>] ? __kthread_parkme+0x61/0x61 Code: e8 87 63 fd e0 c6 05 10 dd 01 00 01 48 8b 43 70 4c 8d 6b 70 45 31 e4 a8 02 0f 85 d5 02 00 00 4c 8b 7b 48 48 c7 43 48 00 00 00 00 <4c> 8b 4b 50 4d 85 ff 75 0c 4d 85 c9 4d 89 cf 0f 84 32 01 00 00 And the output of "rpcdebug -m rpc -s all": RPC: 61 call_refresh (status 0) RPC: 61 call_refresh (status 0) RPC: 61 refreshing RPCSEC_GSS cred ffff88007a413cf0 RPC: 61 refreshing RPCSEC_GSS cred ffff88007a413cf0 RPC: 61 call_refreshresult (status 0) RPC: 61 refreshing RPCSEC_GSS cred ffff88007a413cf0 RPC: 61 call_refreshresult (status 0) RPC: 61 refreshing RPCSEC_GSS cred ffff88007a413cf0 RPC: 61 call_refresh (status 0) RPC: 61 call_refreshresult (status 0) RPC: 61 call_refresh (status 0) RPC: 61 call_refresh (status 0) RPC: 61 refreshing RPCSEC_GSS cred ffff88007a413cf0 RPC: 61 call_refreshresult (status 0) RPC: 61 call_refresh (status 0) RPC: 61 refreshing RPCSEC_GSS cred ffff88007a413cf0 RPC: 61 call_refresh (status 0) RPC: 61 refreshing RPCSEC_GSS cred ffff88007a413cf0 RPC: 61 refreshing RPCSEC_GSS cred ffff88007a413cf0 RPC: 61 call_refreshresult (status 0) RPC: 61 call_refresh (status 0) RPC: 61 call_refresh (status 0) RPC: 61 call_refresh (status 0) RPC: 61 call_refresh (status 0) RPC: 61 call_refreshresult (status 0) RPC: 61 refreshing RPCSEC_GSS cred ffff88007a413cf0 Signed-off-by: Weston Andros Adamson <dros@netapp.com> Cc: stable@vger.kernel.org # 2.6.37+ Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2013-12-31SUNRPC: Handle connect errors ECONNABORTED and EHOSTUNREACHTrond Myklebust
Ensure that call_bind_status, call_connect_status, call_transmit_status and call_status all are capable of handling ECONNABORTED and EHOSTUNREACH. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2013-11-12SUNRPC: Avoid deep recursion in rpc_release_clientTrond Myklebust
In cases where an rpc client has a parent hierarchy, then rpc_free_client may end up calling rpc_release_client() on the parent, thus recursing back into rpc_free_client. If the hierarchy is deep enough, then we can get into situations where the stack simply overflows. The fix is to have rpc_release_client() loop so that it can take care of the parent rpc client hierarchy without needing to recurse. Reported-by: Jeff Layton <jlayton@redhat.com> Reported-by: Weston Andros Adamson <dros@netapp.com> Reported-by: Bruce Fields <bfields@fieldses.org> Link: http://lkml.kernel.org/r/2C73011F-0939-434C-9E4D-13A1EB1403D7@netapp.com Cc: stable@vger.kernel.org Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-10-30SUNRPC: remove duplicated include from clnt.cWei Yongjun
Remove duplicated include. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-10-28SUNRPC: Add correct rcu_dereference annotation in rpc_clnt_set_transportTrond Myklebust
rpc_clnt_set_transport should use rcu_derefence_protected(), as it is only safe to be called with the rpc_clnt::cl_lock held. Cc: Chuck Lever <Chuck.Lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-10-28SUNRPC: Add a helper to switch the transport of an rpc_clntTrond Myklebust
Add an RPC client API to redirect an rpc_clnt's transport from a source server to a destination server during a migration event. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> [ cel: forward ported to 3.12 ] Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-10-28SUNRPC: Modify synopsis of rpc_client_register()Chuck Lever
The rpc_client_register() helper was added in commit e73f4cc0, "SUNRPC: split client creation routine into setup and registration," Mon Jun 24 11:52:52 2013. In a subsequent patch, I'd like to invoke rpc_client_register() from a context where a struct rpc_create_args is not available. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-10-01SUNRPC: call_connect_status should recheck bind and connect status on errorTrond Myklebust
Currently, we go directly to call_transmit which sends us to call_status on error. If we know that the connect attempt failed, we should rather just jump straight back to call_bind and call_connect. Ditto for EAGAIN, except do not delay. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-10-01SUNRPC: Fix RPC call retransmission statisticsTrond Myklebust
A retransmit should be when you successfully transmit an RPC call to the server a second time. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-10-01SUNRPC: Add RPC task and client level options to disable the resend timeoutTrond Myklebust
2013-10-01SUNRPC: Clean up - convert xprt_prepare_transmit to return a boolTrond Myklebust
2013-09-09Merge tag 'nfs-for-3.12-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client updates from Trond Myklebust: "Highlights include: - Fix NFSv4 recovery so that it doesn't recover lost locks in cases such as lease loss due to a network partition, where doing so may result in data corruption. Add a kernel parameter to control choice of legacy behaviour or not. - Performance improvements when 2 processes are writing to the same file. - Flush data to disk when an RPCSEC_GSS session timeout is imminent. - Implement NFSv4.1 SP4_MACH_CRED state protection to prevent other NFS clients from being able to manipulate our lease and file locking state. - Allow sharing of RPCSEC_GSS caches between different rpc clients. - Fix the broken NFSv4 security auto-negotiation between client and server. - Fix rmdir() to wait for outstanding sillyrename unlinks to complete - Add a tracepoint framework for debugging NFSv4 state recovery issues. - Add tracing to the generic NFS layer. - Add tracing for the SUNRPC socket connection state. - Clean up the rpc_pipefs mount/umount event management. - Merge more patches from Chuck in preparation for NFSv4 migration support" * tag 'nfs-for-3.12-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (107 commits) NFSv4: use mach cred for SECINFO_NO_NAME w/ integrity NFS: nfs_compare_super shouldn't check the auth flavour unless 'sec=' was set NFSv4: Allow security autonegotiation for submounts NFSv4: Disallow security negotiation for lookups when 'sec=' is specified NFSv4: Fix security auto-negotiation NFS: Clean up nfs_parse_security_flavors() NFS: Clean up the auth flavour array mess NFSv4.1 Use MDS auth flavor for data server connection NFS: Don't check lock owner compatability unless file is locked (part 2) NFS: Don't check lock owner compatibility in writes unless file is locked nfs4: Map NFS4ERR_WRONG_CRED to EPERM nfs4.1: Add SP4_MACH_CRED write and commit support nfs4.1: Add SP4_MACH_CRED stateid support nfs4.1: Add SP4_MACH_CRED secinfo support nfs4.1: Add SP4_MACH_CRED cleanup support nfs4.1: Add state protection handler nfs4.1: Minimal SP4_MACH_CRED implementation SUNRPC: Replace pointer values with task->tk_pid and rpc_clnt->cl_clid SUNRPC: Add an identifier for struct rpc_clnt SUNRPC: Ensure rpc_task->tk_pid is available for tracepoints ...
2013-09-05SUNRPC: Add an identifier for struct rpc_clntTrond Myklebust
Add an identifier in order to aid debugging. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-09-03SUNRPC refactor rpcauth_checkverf error returnsAndy Adamson
Most of the time an error from the credops crvalidate function means the server has sent us a garbage verifier. The gss_validate function is the exception where there is an -EACCES case if the user GSS_context on the client has expired. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-09-03SUNRPC: don't map EKEYEXPIRED to EACCES in call_refreshresultAndy Adamson
The NFS layer needs to know when a key has expired. This change also returns -EKEYEXPIRED to the application, and the informative "Key has expired" error message is displayed. The user then knows that credential renewal is required. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-09-02SUNRPC: rpcauth_create needs to know about rpc_clnt clone statusTrond Myklebust
Ensure that we set rpc_clnt->cl_parent before calling rpc_client_register so that rpcauth_create can find any existing RPCSEC_GSS caches for this transport. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-09-01SUNRPC: Remove the rpc_client->cl_dentryTrond Myklebust
It is now redundant. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-09-01SUNRPC: Remove the obsolete auth-only interface for pipefs dentry managementTrond Myklebust
2013-08-30SUNRPC: Add a framework to clean up management of rpc_pipefs directoriesTrond Myklebust
The current system requires everyone to set up notifiers, manage directory locking, etc. What we really want to do is have the rpc_client create its directory, and then create all the entries. This patch will allow the RPCSEC_GSS and NFS code to register all the objects that they want to have appear in the directory, and then have the sunrpc code call them back to actually create/destroy their pipefs dentries when the rpc_client creates/destroys the parent. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-08-30SUNRPC: Replace clnt->cl_principalTrond Myklebust
The clnt->cl_principal is being used exclusively to store the service target name for RPCSEC_GSS/krb5 callbacks. Replace it with something that is stored only in the RPCSEC_GSS-specific code. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-08-30SUNRPC: Cleanup rpc_setup_pipedirTrond Myklebust
The directory name is _always_ clnt->cl_program->pipe_dir_name. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-08-30SUNRPC: Remove unused struct rpc_clnt field cl_protnameTrond Myklebust
2013-08-30SUNRPC: Deprecate rpc_client->cl_protnameTrond Myklebust
It just duplicates the cl_program->name, and is not used in any fast paths where the extra dereference will cause a hit. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-08-07SUNRPC: If the rpcbind channel is disconnected, fail the call to unregisterTrond Myklebust
If rpcbind causes our connection to the AF_LOCAL socket to close after we've registered a service, then we want to be careful about reconnecting since the mount namespace may have changed. By simply refusing to reconnect the AF_LOCAL socket in the case of unregister, we avoid the need to somehow save the mount namespace. While this may lead to some services not unregistering properly, it should be safe. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Nix <nix@esperi.org.uk> Cc: Jeff Layton <jlayton@redhat.com> Cc: stable@vger.kernel.org # 3.9.x
2013-07-15SUNRPC: Fix another issue with rpc_client_register()Trond Myklebust
Fix the error pathway if rpcauth_create() fails. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
