path: root/net/socket.c
2015-03-23net: socket: add support for async operationstadeusz.struk@intel.com
Add support for async operations. Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/emulex/benet/be_main.c net/core/sysctl_net_core.c net/ipv4/inet_diag.c The be_main.c conflict resolution was really tricky. The conflict hunks generated by GIT were very unhelpful, to say the least. It split functions in half and moved them around, when the real actual conflict only existed solely inside of one function, that being be_map_pci_bars(). So instead, to resolve this, I checked out be_main.c from the top of net-next, then I applied the be_main.c changes from 'net' since the last time I merged. And this worked beautifully. The inet_diag.c and sysctl_net_core.c conflicts were simple overlapping changes, and were easily to resolve. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-20net: validate the range we feed to iov_iter_init() in sys_sendto/sys_recvfromAl Viro
Cc: stable@vger.kernel.org # v3.19 Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-02net: Remove iocb argument from sendmsg and recvmsgYing Xue
After TIPC doesn't depend on iocb argument in its internal implementations of sendmsg() and recvmsg() hooks defined in proto structure, no any user is using iocb argument in them at all now. Then we can drop the redundant iocb argument completely from kinds of implementations of both sendmsg() and recvmsg() in the entire networking stack. Cc: Christoph Hellwig <hch@lst.de> Suggested-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-02net: move skb->dropcount to skb->cb[]Eyal Birger
Commit 977750076d98 ("af_packet: add interframe drop cmsg (v6)") unionized skb->mark and skb->dropcount in order to allow recording of the socket drop count while maintaining struct sk_buff size. skb->dropcount was introduced since there was no available room in skb->cb[] in packet sockets. However, its introduction led to the inability to export skb->mark, or any other aliased field to userspace if so desired. Moving the dropcount metric to skb->cb[] eliminates this problem at the expense of 4 bytes less in skb->cb[] for protocol families using it. Signed-off-by: Eyal Birger <eyal.birger@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-04net: switch sockets to ->read_iter/->write_iterAl Viro
2015-02-04net/socket.c: fold do_sock_{read,write} into callersAl Viro
2015-01-28net: remove sock_iocbChristoph Hellwig
The sock_iocb structure is allocate on stack for each read/write-like operation on sockets, and contains various fields of which only the embedded msghdr and sometimes a pointer to the scm_cookie is ever used. Get rid of the sock_iocb and put a msghdr directly on the stack and pass the scm_cookie explicitly to netlink_mmap_sendmsg. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: arch/arm/boot/dts/imx6sx-sdb.dts net/sched/cls_bpf.c Two simple sets of overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-27net: don't OOPS on socket aioChristoph Hellwig
2015-01-17socket: use ki_nbytes instead of iov_length()Nicolas Dichtel
This field already contains the length of the iovec, no need to calculate it again. Suggested-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-15socket: use iov_length()Nicolas Dichtel
Better to use available helpers. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-19[regression] chunk lost from bd9b51Al Viro
Reported-by: Pavel Emelyanov <xemul@parallels.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-12-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile #2 from Al Viro: "Next pile (and there'll be one or two more). The large piece in this one is getting rid of /proc/*/ns/* weirdness; among other things, it allows to (finally) make nameidata completely opaque outside of fs/namei.c, making for easier further cleanups in there" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: coda_venus_readdir(): use file_inode() fs/namei.c: fold link_path_walk() call into path_init() path_init(): don't bother with LOOKUP_PARENT in argument fs/namei.c: new helper (path_cleanup()) path_init(): store the "base" pointer to file in nameidata itself make default ->i_fop have ->open() fail with ENXIO make nameidata completely opaque outside of fs/namei.c kill proc_ns completely take the targets of /proc/*/ns/* symlinks to separate fs bury struct proc_ns in fs/proc copy address of proc_ns_ops into ns_common new helpers: ns_alloc_inum/ns_free_inum make proc_ns_operations work with struct ns_common * instead of void * switch the rest of proc_ns_operations to working with &...->ns netns: switch ->get()/->put()/->install()/->inum() to working with &net->ns make mntns ->get()/->put()/->install()/->inum() work with &mnt_ns->ns common object embedded into various struct ....ns
2014-12-10make default ->i_fop have ->open() fail with ENXIOAl Viro
As it is, default ->i_fop has NULL ->open() (along with all other methods). The only case where it matters is reopening (via procfs symlink) a file that didn't get its ->f_op from ->i_fop - anything else will have ->i_fop assigned to something sane (default would fail on read/write/ioctl/etc.). Unfortunately, such case exists - alloc_file() users, especially anon_get_file() ones. There we have tons of opened files of very different kinds sharing the same inode. As the result, attempt to reopen those via procfs succeeds and you get a descriptor you can't do anything with. Moreover, in case of sockets we set ->i_fop that will only be used on such reopen attempts - and put a failing ->open() into it to make sure those do not succeed. It would be simpler to put such ->open() into default ->i_fop and leave it unchanged both for anon inode (as we do anyway) and for socket ones. Result: * everything going through do_dentry_open() works as it used to * sock_no_open() kludge is gone * attempts to reopen anon-inode files fail as they really ought to * ditto for aio_private_file() * ditto for perfmon - this one actually tried to imitate sock_no_open() trick, but failed to set ->i_fop, so in the current tree reopens succeed and yield completely useless descriptor. Intent clearly had been to fail with -ENXIO on such reopens; now it actually does. * everything else that used alloc_file() keeps working - it has ->i_fop set for its inodes anyway Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-12-09put iov_iter into msghdrAl Viro
Note that the code _using_ ->msg_iter at that point will be very unhappy with anything other than unshifted iovec-backed iov_iter. We still need to convert users to proper primitives. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-12-09net/socket.c : introduce helper function do_sock_sendmsg to replace ↵Gu Zheng
reduplicate code Introduce helper function do_sock_sendmsg() to simplify sock_sendmsg{_nosec}, and replace reduplicate code. Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-19fold verify_iovec() into copy_msghdr_from_user()Al Viro
... and do the same on the compat side of things. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-11-19{compat_,}verify_iovec(): switch to generic copying of iovecsAl Viro
use {compat_,}rw_copy_check_uvector(). As the result, we are guaranteed that all iovecs seen in ->msg_iov by ->sendmsg() and ->recvmsg() will pass access_ok(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-11-19separate kernel- and userland-side msghdrAl Viro
Kernel-side struct msghdr is (currently) using the same layout as userland one, but it's not a one-to-one copy - even without considering 32bit compat issues, we have msg_iov, msg_name and msg_control copied to kernel[1]. It's fairly localized, so we get away with a few functions where that knowledge is needed (and we could shrink that set even more). Pretty much everything deals with the kernel-side variant and the few places that want userland one just use a bunch of force-casts to paper over the differences. The thing is, kernel-side definition of struct msghdr is *not* exposed in include/uapi - libc doesn't see it, etc. So we can add struct user_msghdr, with proper annotations and let the few places that ever deal with those beasts use it for userland pointers. Saner typechecking aside, that will allow to change the layout of kernel-side msghdr - e.g. replace msg_iov/msg_iovlen there with struct iov_iter, getting rid of the need to modify the iovec as we copy data to/from it, etc. We could introduce kernel_msghdr instead, but that would create much more noise - the absolute majority of the instances would need to have the type switched to kernel_msghdr and definition of struct msghdr in include/linux/socket.h is not going to be seen by userland anyway. This commit just introduces user_msghdr and switches the few places that are dealing with userland-side msghdr to it. [1] actually, it's even trickier than that - we copy msg_control for sendmsg, but keep the userland address on recvmsg. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-11Merge tag 'locks-v3.18-1' of git://git.samba.org/jlayton/linuxLinus Torvalds
Pull file locking related changes from Jeff Layton: "This release is a little more busy for file locking changes than the last: - a set of patches from Kinglong Mee to fix the lockowner handling in knfsd - a pile of cleanups to the internal file lease API. This should get us a bit closer to allowing for setlease methods that can block. There are some dependencies between mine and Bruce's trees this cycle, and I based my tree on top of the requisite patches in Bruce's tree" * tag 'locks-v3.18-1' of git://git.samba.org/jlayton/linux: (26 commits) locks: fix fcntl_setlease/getlease return when !CONFIG_FILE_LOCKING locks: flock_make_lock should return a struct file_lock (or PTR_ERR) locks: set fl_owner for leases to filp instead of current->files locks: give lm_break a return value locks: __break_lease cleanup in preparation of allowing direct removal of leases locks: remove i_have_this_lease check from __break_lease locks: move freeing of leases outside of i_lock locks: move i_lock acquisition into generic_*_lease handlers locks: define a lm_setup handler for leases locks: plumb a "priv" pointer into the setlease routines nfsd: don't keep a pointer to the lease in nfs4_file locks: clean up vfs_setlease kerneldoc comments locks: generic_delete_lease doesn't need a file_lock at all nfsd: fix potential lease memory leak in nfs4_setlease locks: close potential race in lease_get_mtime security: make security_file_set_fowner, f_setown and __f_setown void return locks: consolidate "nolease" routines locks: remove lock_may_read and lock_may_write lockd: rip out deferred lock handling from testlock codepath NFSD: Get reference of lockowner when coping file_lock ...
2014-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: arch/mips/net/bpf_jit.c drivers/net/can/flexcan.c Both the flexcan and MIPS bpf_jit conflicts were cases of simple overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-09net:socket: set msg_namelen to 0 if msg_name is passed as NULL in msghdr ↵Ani Sinha
struct from userland. Linux manpage for recvmsg and sendmsg calls does not explicitly mention setting msg_namelen to 0 when msg_name passed set as NULL. When developers don't set msg_namelen member in msghdr, it might contain garbage value which will fail the validation check and sendmsg and recvmsg calls from kernel will return EINVAL. This will break old binaries and any code for which there is no access to source code. To fix this, we set msg_namelen to 0 when msg_name is passed as NULL from userland. Signed-off-by: Ani Sinha <ani@arista.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-09net-timestamp: optimize sock_tx_timestamp default pathWillem de Bruijn
Few packets have timestamping enabled. Exit sock_tx_timestamp quickly in this common case. Signed-off-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-09security: make security_file_set_fowner, f_setown and __f_setown void returnJeff Layton
security_file_set_fowner always returns 0, so make it f_setown and __f_setown void return functions and fix up the error handling in the callers. Cc: linux-security-module@vger.kernel.org Signed-off-by: Jeff Layton <jlayton@primarydata.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2014-09-05net: treewide: Fix typo found in DocBook/networking.xmlMasanari Iida
This patch fix spelling typo found in DocBook/networking.xml. It is because the neworking.xml is generated from comments in the source, I have to fix typo in comments within the source. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-05net-timestamp: only report sw timestamp if reporting bit is setWillem de Bruijn
The timestamping API has separate bits for generating and reporting timestamps. A software timestamp should only be reported for a packet when the packet has the relevant generation flag (SKBTX_..) set and the socket has reporting bit SOF_TIMESTAMPING_SOFTWARE set. The second check was accidentally removed. Reinstitute the original behavior. Tested: Without this patch, Documentation/networking/txtimestamp reports timestamps regardless of whether SOF_TIMESTAMPING_SOFTWARE is set. After the patch, it only reports them when the flag is set. Fixes: f24b9be5957b ("net-timestamp: extend SCM_TIMESTAMPING ancillary data struct") Signed-off-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-06net-timestamp: sock_tx_timestamp() fixEric Dumazet
sock_tx_timestamp() should not ignore initial *tx_flags value, as TCP stack can store SKBTX_SHARED_FRAG in it. Also first argument (struct sock *) can be const. Signed-off-by: Eric Dumazet <edumazet@google.com> Fixes: 4ed2d765dfac ("net-timestamp: TCP timestamping") Cc: Willem de Bruijn <willemb@google.com> Acked-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-05net-timestamp: ACK timestamp for bytestreamsWillem de Bruijn
Add SOF_TIMESTAMPING_TX_ACK, a request for a tstamp when the last byte in the send() call is acknowledged. It implements the feature for TCP. The timestamp is generated when the TCP socket cumulative ACK is moved beyond the tracked seqno for the first time. The feature ignores SACK and FACK, because those acknowledge the specific byte, but not necessarily the entire contents of the buffer up to that byte. Signed-off-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-05net-timestamp: SCHED timestamp on entering packet schedulerWillem de Bruijn
Kernel transmit latency is often incurred in the packet scheduler. Introduce a new timestamp on transmission just before entering the scheduler. When data travels through multiple devices (bonding, tunneling, ...) each device will export an individual timestamp. Signed-off-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-05net-timestamp: move timestamp flags out of sk_flagsWillem de Bruijn
sk_flags is reaching its limit. New timestamping options will not fit. Move all of them into a new field sk->sk_tsflags. Added benefit is that this removes boilerplate code to convert between SOF_TIMESTAMPING_.. and SOCK_TIMESTAMPING_.. in getsockopt/setsockopt. SOCK_TIMESTAMPING_RX_SOFTWARE is also used to toggle the receive timestamp logic (netstamp_needed). That can be simplified and this last key removed, but will leave that for a separate patch. Signed-off-by: Willem de Bruijn <willemb@google.com> ---- The u16 in sock can be moved into a 16-bit hole below sk_gso_max_segs, though that scatters tstamp fields throughout the struct. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-05net-timestamp: extend SCM_TIMESTAMPING ancillary data structWillem de Bruijn
Applications that request kernel tx timestamps with SO_TIMESTAMPING read timestamps as recvmsg() ancillary data. The response is defined implicitly as timespec[3]. 1) define struct scm_timestamping explicitly and 2) add support for new tstamp types. On tx, scm_timestamping always accompanies a sock_extended_err. Define previously unused field ee_info to signal the type of ts[0]. Introduce SCM_TSTAMP_SND to define the existing behavior. The reception path is not modified. On rx, no struct similar to sock_extended_err is passed along with SCM_TIMESTAMPING. Signed-off-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-29net: remove deprecated syststamp timestampWillem de Bruijn
The SO_TIMESTAMPING API defines three types of timestamps: software, hardware in raw format (hwtstamp) and hardware converted to system format (syststamp). The last has been deprecated in favor of combining hwtstamp with a PTP clock driver. There are no active users in the kernel. The option was device driver dependent. If set, but without hardware support, the correct behavior is to return zero in the relevant field in the SCM_TIMESTAMPING ancillary message. Without device drivers implementing the option, this field is effectively always zero. Remove the internal plumbing to dissuage new drivers from implementing the feature. Keep the SOF_TIMESTAMPING_SYS_HARDWARE flag, however, to avoid breaking existing applications that request the timestamp. Signed-off-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-16net: use SYSCALL_DEFINEx for sys_recvJan Glauber
Make sys_recv a first class citizen by using the SYSCALL_DEFINEx macro. Besides being cleaner this will also generate meta data for the system call so tracing tools like ftrace or LTTng can resolve this system call. Signed-off-by: Jan Glauber <jan.glauber@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-01net: ptp: move PTP classifier in its own fileDaniel Borkmann
This commit fixes a build error reported by Fengguang, that is triggered when CONFIG_NETWORK_PHY_TIMESTAMPING is not set: ERROR: "ptp_classify_raw" [drivers/net/ethernet/oki-semi/pch_gbe/pch_gbe.ko] undefined! The fix is to introduce its own file for the PTP BPF classifier, so that PTP_1588_CLOCK and/or NETWORK_PHY_TIMESTAMPING can select it independently from each other. IXP4xx driver on ARM needs to select it as well since it does not seem to select PTP_1588_CLOCK or similar that would pull it in automatically. This also allows for hiding all of the internals of the BPF PTP program inside that file, and only exporting relevant API bits to drivers. This patch also adds a kdoc documentation of ptp_classify_raw() API to make it clear that it can return PTP_CLASS_* defines. Also, the BPF program has been translated into bpf_asm code, so that it can be more easily read and altered (extensively documented in [1]). In the kernel tree under tools/net/ we have bpf_asm and bpf_dbg tools, so the commented program can simply be translated via `./bpf_asm -c prog` where prog is a file that contains the commented code. This makes it easily readable/verifiable and when there's a need to change something, jump offsets etc do not need to be replaced manually which can be very error prone. Instead, a newly translated version via bpf_asm can simply replace the old code. I have checked opcode diffs before/after and it's the very same filter. [1] Documentation/networking/filter.txt Fixes: 164d8c666521 ("net: ptp: do not reimplement PTP/BPF classifier") Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Jiri Benc <jbenc@redhat.com> Acked-by: Richard Cochran <richardcochran@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/usb/r8152.c drivers/net/xen-netback/netback.c Both the r8152 and netback conflicts were simple overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "I know this is a bit more than you want to see, and I've told the wireless folks under no uncertain terms that they must severely scale back the extent of the fixes they are submitting this late in the game. Anyways: 1) vmxnet3's netpoll doesn't perform the equivalent of an ISR, which is the correct implementation, like it should. Instead it does something like a NAPI poll operation. This leads to crashes. From Neil Horman and Arnd Bergmann. 2) Segmentation of SKBs requires proper socket orphaning of the fragments, otherwise we might access stale state released by the release callbacks. This is a 5 patch fix, but the initial patches are giving variables and such significantly clearer names such that the actual fix itself at the end looks trivial. From Michael S. Tsirkin. 3) TCP control block release can deadlock if invoked from a timer on an already "owned" socket. Fix from Eric Dumazet. 4) In the bridge multicast code, we must validate that the destination address of general queries is the link local all-nodes multicast address. From Linus Lüssing. 5) The x86 BPF JIT support for negative offsets puts the parameter for the helper function call in the wrong register. Fix from Alexei Starovoitov. 6) The descriptor type used for RTL_GIGA_MAC_VER_17 chips in the r8169 driver is incorrect. Fix from Hayes Wang. 7) The xen-netback driver tests skb_shinfo(skb)->gso_type bits to see if a packet is a GSO frame, but that's not the correct test. It should use skb_is_gso(skb) instead. Fix from Wei Liu. 8) Negative msg->msg_namelen values should generate an error, from Matthew Leach. 9) at86rf230 can deadlock because it takes the same lock from it's ISR and it's hard_start_xmit method, without disabling interrupts in the latter. Fix from Alexander Aring. 10) The FEC driver's restart doesn't perform operations in the correct order, so promiscuous settings can get lost. Fix from Stefan Wahren. 11) Fix SKB leak in SCTP cookie handling, from Daniel Borkmann. 12) Reference count and memory leak fixes in TIPC from Ying Xue and Erik Hugne. 13) Forced eviction in inet_frag_evictor() must strictly make sure all frags are deleted, otherwise module unload (f.e. 6lowpan) can crash. Fix from Florian Westphal. 14) Remove assumptions in AF_UNIX's use of csum_partial() (which it uses as a hash function), which breaks on PowerPC. From Anton Blanchard. The main gist of the issue is that csum_partial() is defined only as a value that, once folded (f.e. via csum_fold()) produces a correct 16-bit checksum. It is legitimate, therefore, for csum_partial() to produce two different 32-bit values over the same data if their respective alignments are different. 15) Fix endiannes bug in MAC address handling of ibmveth driver, also from Anton Blanchard. 16) Error checks for ipv6 exthdrs offload registration are reversed, from Anton Nayshtut. 17) Externally triggered ipv6 addrconf routes should count against the garbage collection threshold. Fix from Sabrina Dubroca. 18) The PCI shutdown handler added to the bnx2 driver can wedge the chip if it was not brought up earlier already, which in particular causes the firmware to shut down the PHY. Fix from Michael Chan. 19) Adjust the sanity WARN_ON_ONCE() in qdisc_list_add() because as currently coded it can and does trigger in legitimate situations. From Eric Dumazet. 20) BNA driver fails to build on ARM because of a too large udelay() call, fix from Ben Hutchings. 21) Fair-Queue qdisc holds locks during GFP_KERNEL allocations, fix from Eric Dumazet. 22) The vlan passthrough ops added in the previous release causes a regression in source MAC address setting of outgoing headers in some circumstances. Fix from Peter Boström" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (70 commits) ipv6: Avoid unnecessary temporary addresses being generated eth: fec: Fix lost promiscuous mode after reconnecting cable bonding: set correct vlan id for alb xmit path at86rf230: fix lockdep splats net/mlx4_en: Deregister multicast vxlan steering rules when going down vmxnet3: fix building without CONFIG_PCI_MSI MAINTAINERS: add networking selftests to NETWORKING net: socket: error on a negative msg_namelen MAINTAINERS: Add tools/net to NETWORKING [GENERAL] packet: doc: Spelling s/than/that/ net/mlx4_core: Load the IB driver when the device supports IBoE net/mlx4_en: Handle vxlan steering rules for mac address changes net/mlx4_core: Fix wrong dump of the vxlan offloads device capability xen-netback: use skb_is_gso in xenvif_start_xmit r8169: fix the incorrect tx descriptor version tools/net/Makefile: Define PACKAGE to fix build problems x86: bpf_jit: support negative offsets bridge: multicast: enable snooping on general queries only bridge: multicast: add sanity check for general query destination tcp: tcp_release_cb() should release socket ownership ...
2014-03-12net: socket: error on a negative msg_namelenMatthew Leach
When copying in a struct msghdr from the user, if the user has set the msg_namelen parameter to a negative value it gets clamped to a valid size due to a comparison between signed and unsigned values. Ensure the syscall errors when the user passes in a negative value. Signed-off-by: Matthew Leach <matthew.leach@arm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-10sockfd_lookup_light(): switch to fdget^W^Waway from fget_lightAl Viro
2014-02-13socket: replace some printk with pr_*Yang Yingliang
Prefer pr_*(...) to printk(KERN_* ...). Signed-off-by: Yang Yingliang <yangyingliang@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-10net: handle error more gracefully in socketpair()Yann Droneaud
This patch makes socketpair() use error paths which do not rely on heavy-weight call to sys_close(): it's better to try to push the file descriptor to userspace before installing the socket file to the file descriptor, so that errors are catched earlier and being easier to handle. Using sys_close() seems to be the exception, while writing the file descriptor before installing it look like it's more or less the norm: eg. except for code used in init/, error handling involve fput() and put_unused_fd(), but not sys_close(). This make socketpair() usage of sys_close() quite unusual. So it deserves to be replaced by the common pattern relying on fput() and put_unused_fd() just like, for example, the one used in pipe(2) or recvmsg(2). Three distinct error paths are still needed since calling fput() on file structure returned by sock_alloc_file() will implicitly call sock_release() on the associated socket structure. Cc: David S. Miller <davem@davemloft.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Yann Droneaud <ydroneaud@opteya.com> Link: http://marc.info/?i=1385979146-13825-1-git-send-email-ydroneaud@opteya.com Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-05Merge branch 'siocghwtstamp' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/bwh/sfc-next Ben Hutchings says: ==================== SIOCGHWTSTAMP ioctl 1. Add the SIOCGHWTSTAMP ioctl and update the timestamping documentation. 2. Implement SIOCGHWTSTAMP in most drivers that support SIOCSHWTSTAMP. 3. Add a test program to exercise SIOC{G,S}HWTSTAMP. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-29net: clamp ->msg_namelen instead of returning an errorDan Carpenter
If kmsg->msg_namelen > sizeof(struct sockaddr_storage) then in the original code that would lead to memory corruption in the kernel if you had audit configured. If you didn't have audit configured it was harmless. There are some programs such as beta versions of Ruby which use too large of a buffer and returning an error code breaks them. We should clamp the ->msg_namelen value instead. Fixes: 1661bf364ae9 ("net: heap overflow in __audit_sockaddr()") Reported-by: Eric Wong <normalperson@yhbt.net> Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Tested-by: Eric Wong <normalperson@yhbt.net> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-20net: add BUG_ON if kernel advertises msg_namelen > sizeof(struct ↵Hannes Frederic Sowa
sockaddr_storage) In that case it is probable that kernel code overwrote part of the stack. So we should bail out loudly here. The BUG_ON may be removed in future if we are sure all protocols are conformant. Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-20net: rework recvmsg handler msg_name and msg_namelen logicHannes Frederic Sowa
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must set msg_namelen to the proper size <= sizeof(struct sockaddr_storage) to return msg_name to the user. This prevents numerous uninitialized memory leaks we had in the recvmsg handlers and makes it harder for new code to accidentally leak uninitialized memory. Optimize for the case recvfrom is called with NULL as address. We don't need to copy the address at all, so set it to NULL before invoking the recvmsg handler. We can do so, because all the recvmsg handlers must cope with the case a plain read() is called on them. read() also sets msg_name to NULL. Also document these changes in include/linux/net.h as suggested by David Miller. Changes since RFC: Set msg->msg_name = NULL if user specified a NULL in msg_name but had a non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't affect sendto as it would bail out earlier while trying to copy-in the address. It also more naturally reflects the logic by the callers of verify_iovec. With this change in place I could remove " if (!uaddr || msg_sys->msg_namelen == 0) msg->msg_name = NULL ". This change does not alter the user visible error logic as we ignore msg_namelen as long as msg_name is NULL. Also remove two unnecessary curly brackets in ___sys_recvmsg and change comments to netdev style. Cc: David Miller <davem@davemloft.net> Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-19net_tstamp: Add SIOCGHWTSTAMP ioctl to match SIOCSHWTSTAMPBen Hutchings
SIOCSHWTSTAMP returns the real configuration to the application using it, but there is currently no way for any other application to find out the configuration non-destructively. Add a new ioctl for this, making it unprivileged. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2013-11-18net/compat: Merge multiple implementations of ifreq::ifr_data conversionBen Hutchings
2013-11-18net/compat: Fix minor information leak in siocdevprivate_ioctl()Ben Hutchings
We don't need to check that ifr_data itself is a valid user pointer, but we should check &ifr_data is. Thankfully the copy of ifr_name is checked, so this can only leak a few bytes from immediately above the user address limit. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2013-10-03net: heap overflow in __audit_sockaddr()Dan Carpenter
We need to cap ->msg_namelen or it leads to a buffer overflow when we to the memcpy() in __audit_sockaddr(). It requires CAP_AUDIT_CONTROL to exploit this bug. The call tree is: ___sys_recvmsg() move_addr_to_user() audit_sockaddr() __audit_sockaddr() Reported-by: Jüri Aedla <juri.aedla@gmail.com> Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-13Merge git://git.kvack.org/~bcrl/aio-nextLinus Torvalds
Pull aio changes from Ben LaHaise: "First off, sorry for this pull request being late in the merge window. Al had raised a couple of concerns about 2 items in the series below. I addressed the first issue (the race introduced by Gu's use of mm_populate()), but he has not provided any further details on how he wants to rework the anon_inode.c changes (which were sent out months ago but have yet to be commented on). The bulk of the changes have been sitting in the -next tree for a few months, with all the issues raised being addressed" * git://git.kvack.org/~bcrl/aio-next: (22 commits) aio: rcu_read_lock protection for new rcu_dereference calls aio: fix race in ring buffer page lookup introduced by page migration support aio: fix rcu sparse warnings introduced by ioctx table lookup patch aio: remove unnecessary debugging from aio_free_ring() aio: table lookup: verify ctx pointer staging/lustre: kiocb->ki_left is removed aio: fix error handling and rcu usage in "convert the ioctx list to table lookup v3" aio: be defensive to ensure request batching is non-zero instead of BUG_ON() aio: convert the ioctx list to table lookup v3 aio: double aio_max_nr in calculations aio: Kill ki_dtor aio: Kill ki_users aio: Kill unneeded kiocb members aio: Kill aio_rw_vect_retry() aio: Don't use ctx->tail unnecessarily aio: io_cancel() no longer returns the io_event aio: percpu ioctx refcount aio: percpu reqs_available aio: reqs_active -> reqs_available aio: fix build when migration is disabled ...
