path: root/net/sctp
2006-12-07[PATCH] slab: remove SLAB_ATOMICChristoph Lameter
SLAB_ATOMIC is an alias of GFP_ATOMIC Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-05Merge branch 'master' of ↵David Howells
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/infiniband/core/iwcm.c drivers/net/chelsio/cxgb2.c drivers/net/wireless/bcm43xx/bcm43xx_main.c drivers/net/wireless/prism54/islpci_eth.c drivers/usb/core/hub.h drivers/usb/input/hid-core.c net/core/netpoll.c Fix up merge failures with Linus's head and fix new compilation failures. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-12-02[SCTP]: Use kzalloc where appropriateArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[SCTP]: Even more trivial sctp annotations.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: SCTP_CMD_PROCESS_CTSN annotations.Al Viro
argument passed as __be32 Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: More trivial sctp annotations.Al Viro
2006-12-02[SCTP]: Annotate ->supported_addrs().Al Viro
2006-12-02[SCTP]: Get rid of the last remnants of sin_port flipping.Al Viro
2006-12-02[SCTP]: Annotate ->inaddr_any().Al Viro
2006-12-02[SCTP]: Don't bother setting sin_port in ->from_sk().Al Viro
... the only caller will overwrite immediately Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: ->a_h is gone now.Al Viro
2006-12-02[SCTP]: ip6_send() doesn't need fl_ip_[sd]port.Al Viro
2006-12-02[SCTP]: sctp_sf_send_restart_abort() is endian-agnostic.Al Viro
... so caller can use ->ipaddr instead of ->ipaddr_h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: We need to be careful when copying to sockaddr_storage.Al Viro
2006-12-02[SCTP]: Trivial ->ipaddr_h -> ->ipaddr conversions.Al Viro
2006-12-02[SCTP]: sctp_make_asconf_update_ip() and sctp_find_unmatch_addr().Al Viro
... switched to taking and returning pointers to net-endian sctp_addr resp. Together, since the only user of sctp_find_unmatch_addr() just passes its value to sctp_make_asconf_update_ip(). sctp_make_asconf_update_ip() is actually endian-agnostic. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Trivial parts of a_h -> a switch.Al Viro
2006-12-02[SCTP]: ->source_h is not used anymore.Al Viro
kill it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Switch all remaining users of ->saddr_h to ->saddr.Al Viro
2006-12-02[SCTP]: Switch sctp_chunk ->dest to net-endian.Al Viro
2006-12-02[SCTP]: sctp_transport_route() switched to net-endian.Al Viro
2006-12-02[SCTP]: Pass net-endian to ->get_dst().Al Viro
all instances are actually endian-agnostic... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: ->get_saddr() switched to net-endian.Al Viro
2006-12-02[SCTP]: sctp_process_init() and sctp_source() switched to net-endian.Al Viro
both are done in one go since almost always we have result of the latter immediately passed to the former. Possibly non-obvious note: sctp_process_param() is endian-agnostic Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: sctp_copy_one_addr() switched to net-endian.Al Viro
2006-12-02[SCTP]: sctp_has_association() switched to net-endian.Al Viro
Ditto for its only caller (sctp_endpoint_is_peeled_off) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: sctp_endpoint_lookup_assoc() switched to net-endian.Al Viro
2006-12-02[SCTP]: Switch ->from_addr_param() to net-endian.Al Viro
2006-12-02[SCTP]: Switch sctp_add_bind_addr() to net-endian.Al Viro
2006-12-02[SCTP]: Switch sctp_assoc_add_peer() to net-endian.Al Viro
2006-12-02[SCTP]: sctp_transport_{init,new}() switched to net-endian.Al Viro
2006-12-02[SCTP]: Switch ->from_skb() to net-endian.Al Viro
All instances switched, callers updated. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Switch sctp_cookie ->peer_addr to net-endian.Al Viro
2006-12-02[SCTP]: sctp_init_addrs() switched to net-endian.Al Viro
Caller adjusted. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Switch sctp_assoc_is_match to net-endian.Al Viro
Along with it, statics in input.c that end up calling it (__sctp_lookup_association, sctp_lookup_association, __sctp_rcv_init_lookup, __sctp_rcv_lookup). Callers are adjusted. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Switch sctp_endpoint_is_match() to net-endian.Al Viro
The only caller (__sctp_rcv_lookup_endpoint()) also switched, its caller adjusted Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Switch sctp_del_bind_addr() to net-endian.Al Viro
Callers adjusted. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Switch address inside the heartbeat opaque data to net-endian.Al Viro
Its only use happens on the same host, when it gets quoted back to us. So we are free to flip to net-endian and avoid extra PITA. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Switch sctp_assoc_lookup_paddr() to net-endian.Al Viro
Callers updated. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: sctp_assoc_del_peer() switched to net-endian.Al Viro
2006-12-02[SCTP]: Annotate ->dst_saddr()Al Viro
switched to taking a pointer to net-endian sctp_addr and a net-endian port number. Instances and callers adjusted; interestingly enough, the only calls are direct calls of specific instances - the method is not used at all. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Switch ->primary_addr to net-endian.Al Viro
Users adjusted. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Switch sctp_bind_addr_match() to net-endian.Al Viro
2006-12-02[SCTP]: Switch ->cmp_addr() and sctp_cmp_addr_exact() to net-endian.Al Viro
instances of ->cmp_addr() are fine with switching both arguments to net-endian; callers other than in sctp_cmp_addr_exact() (both as ->cmp_addr(...) and direct calls of instances) adjusted; sctp_cmp_addr_exact() switched to net-endian itself and adjustment is done in its callers Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Pass net-endian to ->seq_dump_addr()Al Viro
No actual modifications of method instances are needed - they don't look at port numbers. Switch callers... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP] embedded sctp_addr: net-endian mirrorsAl Viro
Add sctp_chunk->source, sctp_sockaddr_entry->a, sctp_transport->ipaddr and sctp_transport->saddr, maintain them as net-endian mirrors of their host-endian counterparts. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Beginning of conversion to net-endian for embedded sctp_addr.Al Viro
Part 1: rename sctp_chunk->source, sctp_sockaddr_entry->a, sctp_transport->ipaddr and sctp_transport->saddr (to ..._h) The next patch will reintroduce these fields and keep them as net-endian mirrors of the original (renamed) ones. Split in two patches to make sure that we hadn't forgotten any instanes. Later in the series we'll eliminate uses of host-endian variants (basically switching users to net-endian counterparts as we progress through that mess). Then host-endian ones will die. Other embedded host-endian sctp_addr will be easier to switch directly, so we leave them alone for now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP] bug: endianness problem in sctp_getsockopt_sctp_status()Al Viro
Again, invalid sockaddr passed to userland - host-endiand sin_port. Potential leak, again, but less dramatic than in previous case. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP] bug: sctp_assoc_control_transport() breakageAl Viro
a) struct sockaddr_storage * passed to sctp_ulpevent_make_peer_addr_change() actually points at union sctp_addr field in a structure. Then that sucker gets copied to userland, with whatever junk we might have there. b) it's actually having host-endian sin_port. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
