[ Upstream commit b5c37fe6e24eec194bb29d22fdd55d73bcc709bf ]
On sctp_endpoint_destroy, previously used sensitive keying material
should be zeroed out before the memory is returned, as we already do
with e.g. auth keys when released.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Vlad Yasevich <vyasevic@redhat.com>
[ Upstream commit 6ba542a291a5e558603ac51cda9bded347ce7627 ]
In sctp_setsockopt_auth_key, we create a temporary copy of the user
passed shared auth key for the endpoint or association and after
internal setup, we free it right away. Since it's sensitive data, we
should zero out the key before returning the memory back to the
allocator. Thus, use kzfree instead of kfree, just as we do in
sctp_auth_key_put().
[ Upstream commit 2f94aabd9f6c925d77aecb3ff020f1cc12ed8f86 ]
Jamie Parsons reported a problem recently, in which the re-initalization of an
association (The duplicate init case), resulted in a loss of receive window
space. He tracked down the root cause to sctp_outq_teardown, which discarded
all the data on an outq during a re-initalization of the corresponding
association, but never reset the outq->outstanding_data field to zero. I wrote,
and he tested this fix, which does a proper full re-initalization of the outq,
fixing this problem, and hopefully future proofing us from simmilar issues down
the road.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Reported-by: Jamie Parsons <Jamie.Parsons@metaswitch.com>
Tested-by: Jamie Parsons <Jamie.Parsons@metaswitch.com>
CC: Jamie Parsons <Jamie.Parsons@metaswitch.com>
CC: Vlad Yasevich <vyasevich@gmail.com>
CC: "David S. Miller" <davem@davemloft.net>
CC: netdev@vger.kernel.org
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit 6e51fe7572590d8d86e93b547fab6693d305fd0d ]
Consider the following program, that sets the second argument to the
sendto() syscall incorrectly:
#include <string.h>
#include <arpa/inet.h>
#include <sys/socket.h>
int main(void)
int fd;
struct sockaddr_in sa;
fd = socket(AF_INET, SOCK_STREAM, 132 /*IPPROTO_SCTP*/);
if (fd < 0)
return 1;
memset(&sa, 0, sizeof(sa));
sa.sin_family = AF_INET;
sa.sin_addr.s_addr = inet_addr("127.0.0.1");
sa.sin_port = htons(11111);
sendto(fd, NULL, 1, 0, (struct sockaddr *)&sa, sizeof(sa));
return 0;
We get -ENOMEM:
$ strace -e sendto ./demo
sendto(3, NULL, 1, 0, {sa_family=AF_INET, sin_port=htons(11111), sin_addr=inet_addr("127.0.0.1")}, 16) = -1 ENOMEM (Cannot allocate memory)
Propagate the error code from sctp_user_addto_chunk(), so that we will
tell user space what actually went wrong:
sendto(3, NULL, 1, 0, {sa_family=AF_INET, sin_port=htons(11111), sin_addr=inet_addr("127.0.0.1")}, 16) = -1 EFAULT (Bad address)
Noticed while running Trinity (the syscall fuzzer).
Signed-off-by: Tommi Rantala <tt.rantala@gmail.com>
fails
[ Upstream commit be364c8c0f17a3dd42707b5a090b318028538eb9 ]
Trinity (the syscall fuzzer) discovered a memory leak in SCTP,
reproducible e.g. with the sendto() syscall by passing invalid
user space pointer in the second argument:
#include <string.h>
int main(void)
int fd;
if (fd < 0)
return 1;
return 0;
As far as I can tell, the leak has been around since ~2003.
[ Upstream commit f6e80abeab928b7c47cc1fbf53df13b4398a2bec ]
Bug introduced by commit edfee0339e681a784ebacec7e8c2dc97dc6d2839
(sctp: check src addr when processing SACK to update transport state)
Signed-off-by: Zijie Pan <zijie.pan@6wind.com>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
[ Upstream commit 4c3a5bdae293f75cdf729c6c00124e8489af2276 ]
SCTP charges wmem_alloc via sctp_set_owner_w() in sctp_sendmsg() and via
skb_set_owner_w() in sctp_packet_transmit(). If a sender runs out of
sndbuf it will sleep in sctp_wait_for_sndbuf() and expects to be waken up
by __sctp_write_space().
Buffer space charged via sctp_set_owner_w() is released in sctp_wfree()
which calls __sctp_write_space() directly.
Buffer space charged via skb_set_owner_w() is released via sock_wfree()
which calls sk->sk_write_space() _if_ SOCK_USE_WRITE_QUEUE is not set.
sctp_endpoint_init() sets SOCK_USE_WRITE_QUEUE on all sockets.
Therefore if sctp_packet_transmit() manages to queue up more than sndbuf
bytes, sctp_wait_for_sndbuf() will never be woken up again unless it is
interrupted by a signal.
This could be fixed by clearing the SOCK_USE_WRITE_QUEUE flag but ...
Charging for the data twice does not make sense in the first place, it
leads to overcharging sndbuf by a factor 2. Therefore this patch only
charges a single byte in wmem_alloc when transmitting an SCTP packet to
ensure that the socket stays alive until the packet has been released.
This means that control chunks are no longer accounted for in wmem_alloc
which I believe is not a problem as skb->truesize will typically lead
to overcharging anyway and thus compensates for any control overhead.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
CC: Vlad Yasevich <vyasevic@redhat.com>
CC: Neil Horman <nhorman@tuxdriver.com>
CC: David Miller <davem@davemloft.net>
[ Upstream commit 2eebc1e188e9e45886ee00662519849339884d6d ]
A few days ago Dave Jones reported this oops:
[22766.294255] general protection fault: 0000 [#1] PREEMPT SMP
[22766.295376] CPU 0
[22766.295384] Modules linked in:
[22766.387137] ffffffffa169f292 6b6b6b6b6b6b6b6b ffff880147c03a90
ffff880147c03a74
[22766.387135] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 00000000000
[22766.387136] Process trinity-watchdo (pid: 10896, threadinfo ffff88013e7d2000,
[22766.387137] Stack:
[22766.387140] ffff880147c03a10
[22766.387140] ffffffffa169f2b6
[22766.387140] ffff88013ed95728
[22766.387143] 0000000000000002
[22766.387143] 0000000000000000
[22766.387143] ffff880003fad062
[22766.387144] ffff88013c120000
[22766.387144]
[22766.387145] Call Trace:
[22766.387145] <IRQ>
[22766.387150] [<ffffffffa169f292>] ? __sctp_lookup_association+0x62/0xd0
[sctp]
[22766.387154] [<ffffffffa169f2b6>] __sctp_lookup_association+0x86/0xd0 [sctp]
[22766.387157] [<ffffffffa169f597>] sctp_rcv+0x207/0xbb0 [sctp]
[22766.387161] [<ffffffff810d4da8>] ? trace_hardirqs_off_caller+0x28/0xd0
[22766.387163] [<ffffffff815827e3>] ? nf_hook_slow+0x133/0x210
[22766.387166] [<ffffffff815902fc>] ? ip_local_deliver_finish+0x4c/0x4c0
[22766.387168] [<ffffffff8159043d>] ip_local_deliver_finish+0x18d/0x4c0
[22766.387169] [<ffffffff815902fc>] ? ip_local_deliver_finish+0x4c/0x4c0
[22766.387171] [<ffffffff81590a07>] ip_local_deliver+0x47/0x80
[22766.387172] [<ffffffff8158fd80>] ip_rcv_finish+0x150/0x680
[22766.387174] [<ffffffff81590c54>] ip_rcv+0x214/0x320
[22766.387176] [<ffffffff81558c07>] __netif_receive_skb+0x7b7/0x910
[22766.387178] [<ffffffff8155856c>] ? __netif_receive_skb+0x11c/0x910
[22766.387180] [<ffffffff810d423e>] ? put_lock_stats.isra.25+0xe/0x40
[22766.387182] [<ffffffff81558f83>] netif_receive_skb+0x23/0x1f0
[22766.387183] [<ffffffff815596a9>] ? dev_gro_receive+0x139/0x440
[22766.387185] [<ffffffff81559280>] napi_skb_finish+0x70/0xa0
[22766.387187] [<ffffffff81559cb5>] napi_gro_receive+0xf5/0x130
[22766.387218] [<ffffffffa01c4679>] e1000_receive_skb+0x59/0x70 [e1000e]
[22766.387242] [<ffffffffa01c5aab>] e1000_clean_rx_irq+0x28b/0x460 [e1000e]
[22766.387266] [<ffffffffa01c9c18>] e1000e_poll+0x78/0x430 [e1000e]
[22766.387268] [<ffffffff81559fea>] net_rx_action+0x1aa/0x3d0
[22766.387270] [<ffffffff810a495f>] ? account_system_vtime+0x10f/0x130
[22766.387273] [<ffffffff810734d0>] __do_softirq+0xe0/0x420
[22766.387275] [<ffffffff8169826c>] call_softirq+0x1c/0x30
[22766.387278] [<ffffffff8101db15>] do_softirq+0xd5/0x110
[22766.387279] [<ffffffff81073bc5>] irq_exit+0xd5/0xe0
[22766.387281] [<ffffffff81698b03>] do_IRQ+0x63/0xd0
[22766.387283] [<ffffffff8168ee2f>] common_interrupt+0x6f/0x6f
[22766.387283] <EOI>
[22766.387284]
[22766.387285] [<ffffffff8168eed9>] ? retint_swapgs+0x13/0x1b
[22766.387285] Code: c0 90 5d c3 66 0f 1f 44 00 00 4c 89 c8 5d c3 0f 1f 00 55 48
89 e5 48 83
ec 20 48 89 5d e8 4c 89 65 f0 4c 89 6d f8 66 66 66 66 90 <0f> b7 87 98 00 00 00
48 89 fb
49 89 f5 66 c1 c0 08 66 39 46 02
[22766.387307]
[22766.387307] RIP
[22766.387311] [<ffffffffa168a2c9>] sctp_assoc_is_match+0x19/0x90 [sctp]
[22766.387311] RSP <ffff880147c039b0>
[22766.387142] ffffffffa16ab120
[22766.599537] ---[ end trace 3f6dae82e37b17f5 ]---
[22766.601221] Kernel panic - not syncing: Fatal exception in interrupt
It appears from his analysis and some staring at the code that this is likely
occuring because an association is getting freed while still on the
sctp_assoc_hashtable. As a result, we get a gpf when traversing the hashtable
while a freed node corrupts part of the list.
Nominally I would think that an mibalanced refcount was responsible for this,
but I can't seem to find any obvious imbalance. What I did note however was
that the two places where we create an association using
sctp_primitive_ASSOCIATE (__sctp_connect and sctp_sendmsg), have failure paths
which free a newly created association after calling sctp_primitive_ASSOCIATE.
sctp_primitive_ASSOCIATE brings us into the sctp_sf_do_prm_asoc path, which
issues a SCTP_CMD_NEW_ASOC side effect, which in turn adds a new association to
the aforementioned hash table. the sctp command interpreter that process side
effects has not way to unwind previously processed commands, so freeing the
association from the __sctp_connect or sctp_sendmsg error path would lead to a
freed association remaining on this hash table.
I've fixed this but modifying sctp_[un]hash_established to use hlist_del_init,
which allows us to proerly use hlist_unhashed to check if the node is on a
hashlist safely during a delete. That in turn alows us to safely call
sctp_unhash_established in the __sctp_connect and sctp_sendmsg error paths
before freeing them, regardles of what the associations state is on the hash
list.
I noted, while I was doing this, that the __sctp_unhash_endpoint was using
hlist_unhsashed in a simmilar fashion, but never nullified any removed nodes
pointers to make that function work properly, so I fixed that up in a simmilar
fashion.
I attempted to test this using a virtual guest running the SCTP_RR test from
netperf in a loop while running the trinity fuzzer, both in a loop. I wasn't
able to recreate the problem prior to this fix, nor was I able to trigger the
failure after (neither of which I suppose is suprising). Given the trace above
however, I think its likely that this is what we hit.
Reported-by: davej@redhat.com
CC: davej@redhat.com
CC: Sridhar Samudrala <sri@us.ibm.com>
CC: linux-sctp@vger.kernel.org
[ Upstream commit e0268868ba064980488fc8c194db3d8e9fb2959c ]
dst_check() will take care of SA (and obsolete field), hence
IPsec rekeying scenario is taken into account.
Acked-by: Vlad Yaseivch <vyasevich@gmail.com>
[ Upstream commit acdd5985364f8dc511a0762fab2e683f29d9d692 ]
getsockopt(..., SCTP_EVENTS, ...) performs a length check and returns
an error if the user provides less bytes than the size of struct
sctp_event_subscribe.
Struct sctp_event_subscribe needs to be extended by an u8 for every
new event or notification type that is added.
This obviously makes getsockopt fail for binaries that are compiled
against an older versions of <net/sctp/user.h> which do not contain
all event types.
This patch changes getsockopt behaviour to no longer return an error
if not enough bytes are being provided by the user. Instead, it
returns as much of sctp_event_subscribe as fits into the provided buffer.
This leads to the new behavior that users see what they have been aware
of at compile time.
The setsockopt(..., SCTP_EVENTS, ...) API is already behaving like this.
Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com>
When checking whether a DATA chunk fits into the estimated rwnd a
full sizeof(struct sk_buff) is added to the needed chunk size. This
quickly exhausts the available rwnd space and leads to packets being
sent which are much below the PMTU limit. This can lead to much worse
performance.
The reason for this behaviour was to avoid putting too much memory
pressure on the receiver. The concept is not completely irational
because a Linux receiver does in fact clone an skb for each DATA chunk
delivered. However, Linux also reserves half the available socket
buffer space for data structures therefore usage of it is already
accounted for.
When proposing to change this the last time it was noted that this
behaviour was introduced to solve a performance issue caused by rwnd
overusage in combination with small DATA chunks.
Trying to reproduce this I found that with the sk_buff overhead removed,
the performance would improve significantly unless socket buffer limits
are increased.
The following numbers have been gathered using a patched iperf
supporting SCTP over a live 1 Gbit ethernet network. The -l option
was used to limit DATA chunk sizes. The numbers listed are based on
the average of 3 test runs each. Default values have been used for
sk_(r|w)mem.
Chunk
Size Unpatched No Overhead
4 15.2 Kbit [!] 12.2 Mbit [!]
8 35.8 Kbit [!] 26.0 Mbit [!]
16 95.5 Kbit [!] 54.4 Mbit [!]
32 106.7 Mbit 102.3 Mbit
64 189.2 Mbit 188.3 Mbit
128 331.2 Mbit 334.8 Mbit
256 537.7 Mbit 536.0 Mbit
512 766.9 Mbit 766.6 Mbit
1024 810.1 Mbit 808.6 Mbit
Signed-off-by: Thomas Graf <tgraf@redhat.com>
Commit 8ffd3208 voids the previous patches f6778aab and 810c0719 for
limiting the autoclose value. If userspace passes in -1 on 32-bit
platform, the overflow check didn't work and autoclose would be set
to 0xffffffff.
This patch defines a max_autoclose (in seconds) for limiting the value
and exposes it through sysctl, with the following intentions.
1) Avoid overflowing autoclose * HZ.
2) Keep the default autoclose bound consistent across 32- and 64-bit
platforms (INT_MAX / HZ in this patch).
3) Keep the autoclose value consistent between setsockopt() and
getsockopt() calls.
Suggested-by: Vlad Yasevich <vladislav.yasevich@hp.com>
Signed-off-by: Xi Wang <xi.wang@gmail.com>
The check from commit 30c2235c is incomplete and cannot prevent
cases like key_len = 0x80000000 (INT_MAX + 1). In that case, the
left-hand side of the check (INT_MAX - key_len), which is unsigned,
becomes 0xffffffff (UINT_MAX) and bypasses the check.
However this shouldn't be a security issue. The function is called
from the following two code paths:
1) setsockopt()
2) sctp_auth_asoc_set_secret()
In case (1), sca_keylength is never going to exceed 65535 since it's
bounded by a u16 from the user API. As such, the key length will
never overflow.
In case (2), sca_keylength is computed based on the user key (1 short)
and 2 * key_vector (3 shorts) for a total of 7 * USHRT_MAX, which still
will not overflow.
In other words, this overflow check is not really necessary. Just
make it more correct.
Cc: Vlad Yasevich <vladislav.yasevich@hp.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
These files are non modular, but need to export symbols using
the macros now living in export.h -- call out the include so
that things won't break when we remove the implicit presence
of module.h from everywhere.
commit 66b13d99d96a (ipv4: tcp: fix TOS value in ACK messages sent from
TIME_WAIT) fixed IPv4 only.
This part is for the IPv6 side, adding a tclass param to ip6_xmit()
We alias tw_tclass and tw_tos, if socket family is INET6.
[ if sockets is ipv4-mapped, only IP_TOS socket option is used to fill
TOS field, TCLASS is not taken into account ]
skb truesize currently accounts for sk_buff struct and part of skb head.
kmalloc() roundings are also ignored.
Considering that skb_shared_info is larger than sk_buff, its time to
take it into account for better memory accounting.
This patch introduces SKB_TRUESIZE(X) macro to centralize various
assumptions into a single place.
At skb alloc phase, we put skb_shared_info struct at the exact end of
skb head, to allow a better use of memory (lowering number of
reallocations), since kmalloc() gives us power-of-two memory blocks.
Unless SLUB/SLUB debug is active, both skb->head and skb_shared_info are
aligned to cache lines, as before.
Note: This patch might trigger performance regressions because of
misconfigured protocol stacks, hitting per socket or global memory
limits that were previously not reached. But its a necessary step for a
more accurate memory accounting.
CC: Andi Kleen <ak@linux.intel.com>
CC: Ben Hutchings <bhutchings@solarflare.com>
MAINTAINERS
drivers/net/Kconfig
drivers/net/ethernet/broadcom/bnx2x/bnx2x_link.c
drivers/net/ethernet/broadcom/tg3.c
drivers/net/wireless/iwlwifi/iwl-pci.c
drivers/net/wireless/iwlwifi/iwl-trans-tx-pcie.c
drivers/net/wireless/rt2x00/rt2800usb.c
drivers/net/wireless/wl12xx/main.c
Attempt to reduce the number of IP packets emitted in response to single
SCTP packet (2e3216cd) introduced a complication - if a packet contains
two COOKIE_ECHO chunks and nothing else then SCTP state machine corks the
socket while processing first COOKIE_ECHO and then loses the association
and forgets to uncork the socket. To deal with the issue add new SCTP
command which can be used to set association explictly. Use this new
command when processing second COOKIE_ECHO chunk to restore the context
for SCTP state machine.
Signed-off-by: Max Matveev <makc@redhat.com>
With this patch a HEARTBEAT chunk is bundled into the ASCONF-ACK
for ADD IP ADDRESS, confirming the new destination as quickly as
possible.
Signed-off-by: Michio Honda <micchie@sfc.wide.ad.jp>
This patch fixes BUG that the ASCONF receiver transmits DATA chunks
to the newly added UNCONFIRMED destination.
net/bluetooth/l2cap_core.c
Packets to devices without NETIF_F_SCTP_CSUM (including NETIF_F_NO_CSUM)
should be properly checksummed because the packets can be diverted or
rerouted after construction. This still leaves packets diverted from
NETIF_F_SCTP_CSUM-enabled devices with broken checksums. Fixing this
needs implementing software offload fallback in networking core.
For users of sctp_checksum_disable, skb->ip_summed should be left as
CHECKSUM_NONE and not CHECKSUM_UNNECESSARY as per include/linux/skbuff.h.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
closing socket
Trigger user ABORT if application closes a socket which has data
queued on the socket receive queue or chunks waiting on the
reassembly or ordering queue as this would imply data being lost
which defeats the point of a graceful shutdown.
This behavior is already practiced in TCP.
We do not check the input queue because that would mean to parse
all chunks on it to look for unacknowledged data which seems too
much of an effort. Control chunks or duplicated chunks may also
be in the input queue and should not be stopping a graceful
shutdown.
Signed-off-by: Thomas Graf <tgraf@infradead.org>
When initiating a graceful shutdown while having data chunks
on the retransmission queue with a peer which is in zero
window mode the shutdown is never completed because the
retransmission error count is reset periodically by the
following two rules:
- Do not timeout association while doing zero window probe.
- Reset overall error count when a heartbeat request has
been acknowledged.
The graceful shutdown will wait for all outstanding TSN to
be acknowledged before sending the SHUTDOWN request. This
never happens due to the peer's zero window not acknowledging
the continuously retransmitted data chunks. Although the
error counter is incremented for each failed retransmission,
the receiving of the SACK announcing the zero window clears
the error count again immediately. Also heartbeat requests
continue to be sent periodically. The peer acknowledges these
requests causing the error counter to be reset as well.
This patch changes behaviour to only reset the overall error
counter for the above rules while not in shutdown. After
reaching the maximum number of retransmission attempts, the
T5 shutdown guard timer is scheduled to give the receiver
some additional time to recover. The timer is stopped as soon
as the receiver acknowledges any data.
The issue can be easily reproduced by establishing a sctp
association over the loopback device, constantly queueing
data at the sender while not reading any at the receiver.
Wait for the window to reach zero, then initiate a shutdown
by killing both processes simultaneously. The association
will never be freed and the chunks on the retransmission
queue will be retransmitted indefinitely.
We forgot to send up SCTP_SENDER_DRY_EVENT notification when
user app subscribes to this event, and there is no data to be
sent or retransmit.
This is required by the Socket API and used by the DTLS/SCTP
implementation.
Reported-by: Michael Tüxen <Michael.Tuexen@lurchi.franken.de>
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Tested-by: Robin Seggelmann <seggelmann@fh-muenster.de>
Current tcp/udp/sctp global memory limits are not taking into account
hugepages allocations, and allow 50% of ram to be used by buffers of a
single protocol [ not counting space used by sockets / inodes ...]
Lets use nr_free_buffer_pages() and allow a default of 1/8 of kernel ram
per protocol, and a minimum of 128 pages.
Heavy duty machines sysadmins probably need to tweak limits anyway.
References: https://bugzilla.stlinux.com/show_bug.cgi?id=38032
Reported-by: starlight <starlight@binnacle.cx>
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Make the case labels the same indent as the switch.
git diff -w shows useless break;s removed after returns
and a comment added to an unnecessary default: break;
because of a dubious gcc warning.
Unnecessary casts of void * clutter the code.
These are the remainder casts after several specific
patches to remove netdev_priv and dev_priv.
Done via coccinelle script:
$ cat cast_void_pointer.cocci
type T;
T *pt;
void *pv;
- pt = (T *)pv;
+ pt = pv;
Acked-by: Paul Moore <paul.moore@hp.com>
Signed-off-by: David S. Miller <davem@conan.davemloft.net>
Acked-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Outside of net/sctp/ipv6.c, IPV6 specific code needs to
be ifdef guarded.
This fixes build failures with IPV6 disabled.
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
In this case, the SCTP association transmits an ASCONF packet
including addition of the new IP address and deletion of the old
address. This patch implements this functionality.
In this case, the ASCONF chunk is added to the beginning of the
queue, because the other chunks cannot be transmitted in this state.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
This patch allows the application to operate Auto-ASCONF on/off
behavior via setsockopt() and getsockopt().
This patch allows the system administrator to change default
Auto-ASCONF on/off behavior via an sysctl value.
SCTP reconfigure the IP addresses in the association by using
ASCONF chunks as mentioned in RFC5061. For example, we can
start to use the newly configured IP address in the existing
association. This patch implements automatic ASCONF operation
in the SCTP stack with address events in the host computer,
which is called auto_asconf.
This patch fixes the problem that the original code cannot delete
the remote address where the corresponding transport is currently
directed, even when the ASCONF is sent from the other address (this
situation happens when the single-homed sender transmits ASCONF
with ADD and DEL.)
If the peer restart the asoc, we should not only fail any unsent/unacked
data, but also stop the T3-rtx, SACK, T4-rto timers, and teardown ASCONF
queues.
If an ASCONF chunk is outstanding, then the following ASCONF
chunk will be queued for later transmission. But when we free
the asoc, we forget to free the ASCONF queue at the same time,
this will cause memory leak.
The %pK format specifier is designed to hide exposed kernel pointers,
specifically via /proc interfaces. Exposing these pointers provides an
easy target for kernel write vulnerabilities, since they reveal the
locations of writable structures containing easily triggerable function
pointers. The behavior of %pK depends on the kptr_restrict sysctl.
If kptr_restrict is set to 0, no deviation from the standard %p behavior
occurs. If kptr_restrict is set to 1, the default, if the current user
(intended to be a reader via seq_printf(), etc.) does not have CAP_SYSLOG
(currently in the LSM tree), kernel pointers using %pK are printed as 0's.
If kptr_restrict is set to 2, kernel pointers using %pK are printed as
0's regardless of privileges. Replacing with 0's was chosen over the
default "(null)", which cannot be parsed by userland %p, which expects
"(nil)".
The supporting code for kptr_restrict and %pK are currently in the -mm
tree. This patch converts users of %p in net/ to %pK. Cases of printing
pointers to the syslog are not covered, since this would eliminate useful
information for postmortem debugging and the reading of the syslog is
already optionally protected by the dmesg_restrict sysctl.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Cc: Thomas Graf <tgraf@infradead.org>
Cc: Eugene Teo <eugeneteo@kernel.org>
Cc: Kees Cook <kees.cook@canonical.com>
Cc: Eric Paris <eparis@parisplace.org>
Commit c182f90bc1f22ce5039b8722e45621d5f96862c2 ("SCTP: fix race
between sctp_bind_addr_free() and sctp_bind_addr_conflict()") and
commit 1231f0baa547a541a7481119323b7f964dda4788 ("net,rcu: convert
call_rcu(sctp_local_addr_free) to kfree_rcu()"), happening in
different trees, introduced a build failure.
Simply make the SCTP race fix use kfree_rcu() too.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits)
macvlan: fix panic if lowerdev in a bond
tg3: Add braces around 5906 workaround.
tg3: Fix NETIF_F_LOOPBACK error
macvlan: remove one synchronize_rcu() call
networking: NET_CLS_ROUTE4 depends on INET
irda: Fix error propagation in ircomm_lmp_connect_response()
irda: Kill set but unused variable 'bytes' in irlan_check_command_param()
irda: Kill set but unused variable 'clen' in ircomm_connect_indication()
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport()
be2net: Kill set but unused variable 'req' in lancer_fw_download()
irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication()
atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined.
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer().
rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler()
rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection()
rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window()
pkt_sched: Kill set but unused variable 'protocol' in tc_classify()
isdn: capi: Use pr_debug() instead of ifdefs.
tg3: Update version to 3.119
tg3: Apply rx_discards fix to 5719/5720
Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c
as per Davem.
During the sctp_close() call, we do not use rcu primitives to
destroy the address list attached to the endpoint. At the same
time, we do the removal of addresses from this list before
attempting to remove the socket from the port hash
As a result, it is possible for another process to find the socket
in the port hash that is in the process of being closed. It then
proceeds to traverse the address list to find the conflict, only
to have that address list suddenly disappear without rcu() critical
section.
Fix issue by closing address list removal inside RCU critical
section.
Race can result in a kernel crash with general protection fault or
kernel NULL pointer dereference:
kernel: general protection fault: 0000 [#1] SMP
kernel: RIP: 0010:[<ffffffffa02f3dde>] [<ffffffffa02f3dde>] sctp_bind_addr_conflict+0x64/0x82 [sctp]
kernel: Call Trace:
kernel: [<ffffffffa02f415f>] ? sctp_get_port_local+0x17b/0x2a3 [sctp]
kernel: [<ffffffffa02f3d45>] ? sctp_bind_addr_match+0x33/0x68 [sctp]
kernel: [<ffffffffa02f4416>] ? sctp_do_bind+0xd3/0x141 [sctp]
kernel: [<ffffffffa02f5030>] ? sctp_bindx_add+0x4d/0x8e [sctp]
kernel: [<ffffffffa02f5183>] ? sctp_setsockopt_bindx+0x112/0x4a4 [sctp]
kernel: [<ffffffff81089e82>] ? generic_file_aio_write+0x7f/0x9b
kernel: [<ffffffffa02f763e>] ? sctp_setsockopt+0x14f/0xfee [sctp]
kernel: [<ffffffff810c11fb>] ? do_sync_write+0xab/0xeb
kernel: [<ffffffff810e82ab>] ? fsnotify+0x239/0x282
kernel: [<ffffffff810c2462>] ? alloc_file+0x18/0xb1
kernel: [<ffffffff8134a0b1>] ? compat_sys_setsockopt+0x1a5/0x1d9
kernel: [<ffffffff8134aaf1>] ? compat_sys_socketcall+0x143/0x1a4
kernel: [<ffffffff810467dc>] ? sysenter_dispatch+0x7/0x32
Signed-off-by: Jacek Luczak <luczak.jacek@gmail.com>
CC: Eric Dumazet <eric.dumazet@gmail.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
It's already known non-null above.
This variable only needs initialization when cmsgs.info
is NULL.
Use memset to ensure padding is also zeroed so
kernel doesn't leak any data.
Flow key is available, so fetch it from there.
I messed things up when I converted over to the transport
flow, I passed the ipv4 address value instead of it's address.
Now we can pick it out of the transport's flow key.
This allows us to acquire the exact route keying information from the
protocol, however that might be managed.
It handles all of the possibilities, from the simplest case of storing
the key in inet->cork.fl to the more complex setup SCTP has where
individual transports determine the flow.
Several future simplifications are possible now because of this.
For example, the sctp_addr unions can simply refer directly to
the flowi information.
