[ Upstream commit 6ba542a291a5e558603ac51cda9bded347ce7627 ]
In sctp_setsockopt_auth_key, we create a temporary copy of the user
passed shared auth key for the endpoint or association and after
internal setup, we free it right away. Since it's sensitive data, we
should zero out the key before returning the memory back to the
allocator. Thus, use kzfree instead of kfree, just as we do in
sctp_auth_key_put().
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
[ Upstream commit 6e51fe7572590d8d86e93b547fab6693d305fd0d ]
Consider the following program, that sets the second argument to the
sendto() syscall incorrectly:
#include <string.h>
#include <arpa/inet.h>
#include <sys/socket.h>
int main(void)
int fd;
struct sockaddr_in sa;
fd = socket(AF_INET, SOCK_STREAM, 132 /*IPPROTO_SCTP*/);
if (fd < 0)
return 1;
memset(&sa, 0, sizeof(sa));
sa.sin_family = AF_INET;
sa.sin_addr.s_addr = inet_addr("127.0.0.1");
sa.sin_port = htons(11111);
sendto(fd, NULL, 1, 0, (struct sockaddr *)&sa, sizeof(sa));
return 0;
We get -ENOMEM:
$ strace -e sendto ./demo
sendto(3, NULL, 1, 0, {sa_family=AF_INET, sin_port=htons(11111), sin_addr=inet_addr("127.0.0.1")}, 16) = -1 ENOMEM (Cannot allocate memory)
Propagate the error code from sctp_user_addto_chunk(), so that we will
tell user space what actually went wrong:
sendto(3, NULL, 1, 0, {sa_family=AF_INET, sin_port=htons(11111), sin_addr=inet_addr("127.0.0.1")}, 16) = -1 EFAULT (Bad address)
Noticed while running Trinity (the syscall fuzzer).
Signed-off-by: Tommi Rantala <tt.rantala@gmail.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
[ Upstream commit 2eebc1e188e9e45886ee00662519849339884d6d ]
A few days ago Dave Jones reported this oops:
[22766.294255] general protection fault: 0000 [#1] PREEMPT SMP
[22766.295376] CPU 0
[22766.295384] Modules linked in:
[22766.387137] ffffffffa169f292 6b6b6b6b6b6b6b6b ffff880147c03a90
ffff880147c03a74
[22766.387135] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 00000000000
[22766.387136] Process trinity-watchdo (pid: 10896, threadinfo ffff88013e7d2000,
[22766.387137] Stack:
[22766.387140] ffff880147c03a10
[22766.387140] ffffffffa169f2b6
[22766.387140] ffff88013ed95728
[22766.387143] 0000000000000002
[22766.387143] 0000000000000000
[22766.387143] ffff880003fad062
[22766.387144] ffff88013c120000
[22766.387144]
[22766.387145] Call Trace:
[22766.387145] <IRQ>
[22766.387150] [<ffffffffa169f292>] ? __sctp_lookup_association+0x62/0xd0
[sctp]
[22766.387154] [<ffffffffa169f2b6>] __sctp_lookup_association+0x86/0xd0 [sctp]
[22766.387157] [<ffffffffa169f597>] sctp_rcv+0x207/0xbb0 [sctp]
[22766.387161] [<ffffffff810d4da8>] ? trace_hardirqs_off_caller+0x28/0xd0
[22766.387163] [<ffffffff815827e3>] ? nf_hook_slow+0x133/0x210
[22766.387166] [<ffffffff815902fc>] ? ip_local_deliver_finish+0x4c/0x4c0
[22766.387168] [<ffffffff8159043d>] ip_local_deliver_finish+0x18d/0x4c0
[22766.387169] [<ffffffff815902fc>] ? ip_local_deliver_finish+0x4c/0x4c0
[22766.387171] [<ffffffff81590a07>] ip_local_deliver+0x47/0x80
[22766.387172] [<ffffffff8158fd80>] ip_rcv_finish+0x150/0x680
[22766.387174] [<ffffffff81590c54>] ip_rcv+0x214/0x320
[22766.387176] [<ffffffff81558c07>] __netif_receive_skb+0x7b7/0x910
[22766.387178] [<ffffffff8155856c>] ? __netif_receive_skb+0x11c/0x910
[22766.387180] [<ffffffff810d423e>] ? put_lock_stats.isra.25+0xe/0x40
[22766.387182] [<ffffffff81558f83>] netif_receive_skb+0x23/0x1f0
[22766.387183] [<ffffffff815596a9>] ? dev_gro_receive+0x139/0x440
[22766.387185] [<ffffffff81559280>] napi_skb_finish+0x70/0xa0
[22766.387187] [<ffffffff81559cb5>] napi_gro_receive+0xf5/0x130
[22766.387218] [<ffffffffa01c4679>] e1000_receive_skb+0x59/0x70 [e1000e]
[22766.387242] [<ffffffffa01c5aab>] e1000_clean_rx_irq+0x28b/0x460 [e1000e]
[22766.387266] [<ffffffffa01c9c18>] e1000e_poll+0x78/0x430 [e1000e]
[22766.387268] [<ffffffff81559fea>] net_rx_action+0x1aa/0x3d0
[22766.387270] [<ffffffff810a495f>] ? account_system_vtime+0x10f/0x130
[22766.387273] [<ffffffff810734d0>] __do_softirq+0xe0/0x420
[22766.387275] [<ffffffff8169826c>] call_softirq+0x1c/0x30
[22766.387278] [<ffffffff8101db15>] do_softirq+0xd5/0x110
[22766.387279] [<ffffffff81073bc5>] irq_exit+0xd5/0xe0
[22766.387281] [<ffffffff81698b03>] do_IRQ+0x63/0xd0
[22766.387283] [<ffffffff8168ee2f>] common_interrupt+0x6f/0x6f
[22766.387283] <EOI>
[22766.387284]
[22766.387285] [<ffffffff8168eed9>] ? retint_swapgs+0x13/0x1b
[22766.387285] Code: c0 90 5d c3 66 0f 1f 44 00 00 4c 89 c8 5d c3 0f 1f 00 55 48
89 e5 48 83
ec 20 48 89 5d e8 4c 89 65 f0 4c 89 6d f8 66 66 66 66 90 <0f> b7 87 98 00 00 00
48 89 fb
49 89 f5 66 c1 c0 08 66 39 46 02
[22766.387307]
[22766.387307] RIP
[22766.387311] [<ffffffffa168a2c9>] sctp_assoc_is_match+0x19/0x90 [sctp]
[22766.387311] RSP <ffff880147c039b0>
[22766.387142] ffffffffa16ab120
[22766.599537] ---[ end trace 3f6dae82e37b17f5 ]---
[22766.601221] Kernel panic - not syncing: Fatal exception in interrupt
It appears from his analysis and some staring at the code that this is likely
occuring because an association is getting freed while still on the
sctp_assoc_hashtable. As a result, we get a gpf when traversing the hashtable
while a freed node corrupts part of the list.
Nominally I would think that an mibalanced refcount was responsible for this,
but I can't seem to find any obvious imbalance. What I did note however was
that the two places where we create an association using
sctp_primitive_ASSOCIATE (__sctp_connect and sctp_sendmsg), have failure paths
which free a newly created association after calling sctp_primitive_ASSOCIATE.
sctp_primitive_ASSOCIATE brings us into the sctp_sf_do_prm_asoc path, which
issues a SCTP_CMD_NEW_ASOC side effect, which in turn adds a new association to
the aforementioned hash table. the sctp command interpreter that process side
effects has not way to unwind previously processed commands, so freeing the
association from the __sctp_connect or sctp_sendmsg error path would lead to a
freed association remaining on this hash table.
I've fixed this but modifying sctp_[un]hash_established to use hlist_del_init,
which allows us to proerly use hlist_unhashed to check if the node is on a
hashlist safely during a delete. That in turn alows us to safely call
sctp_unhash_established in the __sctp_connect and sctp_sendmsg error paths
before freeing them, regardles of what the associations state is on the hash
list.
I noted, while I was doing this, that the __sctp_unhash_endpoint was using
hlist_unhsashed in a simmilar fashion, but never nullified any removed nodes
pointers to make that function work properly, so I fixed that up in a simmilar
fashion.
I attempted to test this using a virtual guest running the SCTP_RR test from
netperf in a loop while running the trinity fuzzer, both in a loop. I wasn't
able to recreate the problem prior to this fix, nor was I able to trigger the
failure after (neither of which I suppose is suprising). Given the trace above
however, I think its likely that this is what we hit.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Reported-by: davej@redhat.com
CC: davej@redhat.com
CC: "David S. Miller" <davem@davemloft.net>
CC: Vlad Yasevich <vyasevich@gmail.com>
CC: Sridhar Samudrala <sri@us.ibm.com>
CC: linux-sctp@vger.kernel.org
[ Upstream commit acdd5985364f8dc511a0762fab2e683f29d9d692 ]
getsockopt(..., SCTP_EVENTS, ...) performs a length check and returns
an error if the user provides less bytes than the size of struct
sctp_event_subscribe.
Struct sctp_event_subscribe needs to be extended by an u8 for every
new event or notification type that is added.
This obviously makes getsockopt fail for binaries that are compiled
against an older versions of <net/sctp/user.h> which do not contain
all event types.
This patch changes getsockopt behaviour to no longer return an error
if not enough bytes are being provided by the user. Instead, it
returns as much of sctp_event_subscribe as fits into the provided buffer.
This leads to the new behavior that users see what they have been aware
of at compile time.
The setsockopt(..., SCTP_EVENTS, ...) API is already behaving like this.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com>
Commit 8ffd3208 voids the previous patches f6778aab and 810c0719 for
limiting the autoclose value. If userspace passes in -1 on 32-bit
platform, the overflow check didn't work and autoclose would be set
to 0xffffffff.
This patch defines a max_autoclose (in seconds) for limiting the value
and exposes it through sysctl, with the following intentions.
1) Avoid overflowing autoclose * HZ.
2) Keep the default autoclose bound consistent across 32- and 64-bit
platforms (INT_MAX / HZ in this patch).
3) Keep the autoclose value consistent between setsockopt() and
getsockopt() calls.
Suggested-by: Vlad Yasevich <vladislav.yasevich@hp.com>
Signed-off-by: Xi Wang <xi.wang@gmail.com>
These files are non modular, but need to export symbols using
the macros now living in export.h -- call out the include so
that things won't break when we remove the implicit presence
of module.h from everywhere.
net/bluetooth/l2cap_core.c
closing socket
Trigger user ABORT if application closes a socket which has data
queued on the socket receive queue or chunks waiting on the
reassembly or ordering queue as this would imply data being lost
which defeats the point of a graceful shutdown.
This behavior is already practiced in TCP.
We do not check the input queue because that would mean to parse
all chunks on it to look for unacknowledged data which seems too
much of an effort. Control chunks or duplicated chunks may also
be in the input queue and should not be stopping a graceful
shutdown.
Signed-off-by: Thomas Graf <tgraf@infradead.org>
We forgot to send up SCTP_SENDER_DRY_EVENT notification when
user app subscribes to this event, and there is no data to be
sent or retransmit.
This is required by the Socket API and used by the DTLS/SCTP
implementation.
Reported-by: Michael Tüxen <Michael.Tuexen@lurchi.franken.de>
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Tested-by: Robin Seggelmann <seggelmann@fh-muenster.de>
Make the case labels the same indent as the switch.
git diff -w shows useless break;s removed after returns
and a comment added to an unnecessary default: break;
because of a dubious gcc warning.
Unnecessary casts of void * clutter the code.
These are the remainder casts after several specific
patches to remove netdev_priv and dev_priv.
Done via coccinelle script:
$ cat cast_void_pointer.cocci
type T;
T *pt;
void *pv;
- pt = (T *)pv;
+ pt = pv;
Acked-by: Paul Moore <paul.moore@hp.com>
Signed-off-by: David S. Miller <davem@conan.davemloft.net>
Signed-off-by: Michio Honda <micchie@sfc.wide.ad.jp>
Acked-by: Wei Yongjun <yjwei@cn.fujitsu.com>
In this case, the SCTP association transmits an ASCONF packet
including addition of the new IP address and deletion of the old
address. This patch implements this functionality.
In this case, the ASCONF chunk is added to the beginning of the
queue, because the other chunks cannot be transmitted in this state.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
This patch allows the application to operate Auto-ASCONF on/off
behavior via setsockopt() and getsockopt().
SCTP reconfigure the IP addresses in the association by using
ASCONF chunks as mentioned in RFC5061. For example, we can
start to use the newly configured IP address in the existing
association. This patch implements automatic ASCONF operation
in the SCTP stack with address events in the host computer,
which is called auto_asconf.
It's already known non-null above.
This variable only needs initialization when cmsgs.info
is NULL.
Use memset to ensure padding is also zeroed so
kernel doesn't leak any data.
The ipv6 routing lookup does give us a source address,
but instead of filling it into the dst, it's stored in
the flowi. We can use that instead of going through the
entire source address selection again.
Also the useless ->dst_saddr member of sctp_pf is removed.
And sctp_v6_dst_saddr() is removed, instead by introduce
sctp_v6_to_addr(), which can be reused to cleanup some dup
code.
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
This patch Implement socket option SCTP_GET_ASSOC_ID_LIST.
SCTP Socket API Extension:
8.2.6. Get the Current Identifiers of Associations
(SCTP_GET_ASSOC_ID_LIST)
This option gets the current list of SCTP association identifiers of
the SCTP associations handled by a one-to-many style socket.
We allow 0 port when adding new addresses. It only
makes sence to allow 0 port when removing addresses.
When removing the currently bound port will be used
when the port in the address is set to 0.
Use common function to simply code.
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net>
Add proper RCU annotations/verbs to sk_wq and wq members
Fix __sctp_write_space() sk_sleep() abuse (and sock->wq access)
Fix sunrpc sk_sleep() abuse too
The option name of Delayed SACK Timer should be SCTP_DELAYED_SACK,
not SCTP_DELAYED_ACK.
Left SCTP_DELAYED_ACK be concomitant with SCTP_DELAYED_SACK,
for making compatibility with existing applications.
Reference:
8.1.19. Get or Set Delayed SACK Timer (SCTP_DELAYED_SACK)
(http://tools.ietf.org/html/draft-ietf-tsvwg-sctpsocket-25)
drivers/net/bnx2x/bnx2x.h
drivers/net/wireless/iwlwifi/iwl-1000.c
drivers/net/wireless/iwlwifi/iwl-6000.c
drivers/net/wireless/iwlwifi/iwl-core.h
drivers/vhost/vhost.c
Get the sctp partial delivery point using SCTP_PARTIAL_DELIVERY_POINT
socket option should return 0 if success, not -ENOTSUPP.
SCTP_SET_PEER_PRIMARY_ADDR does not accpet v4mapped address, using
v4mapped address in SCTP_SET_PEER_PRIMARY_ADDR socket option will
get -EADDRNOTAVAIL error if v4map is enabled. This patch try to
fix it by mapping v4mapped address to v4 address if allowed.
This patch fixes a typo in net/core/datagram.c and in net/sctp/socket.c
Regards,
David Shwartz
Signed-off-by: David Shwartz <dshwatrz@gmail.com>
Robin Holt tried to boot a 16TB machine and found some limits were
reached : sysctl_tcp_mem[2], sysctl_udp_mem[2]
We can switch infrastructure to use long "instead" of "int", now
atomic_long_t primitives are available for free.
Reported-by: Robin Holt <holt@sgi.com>
Reviewed-by: Robin Holt <holt@sgi.com>
net/ipv4/Kconfig
net/ipv4/tcp_timer.c
Two user-controlled allocations in SCTP are subsequently dereferenced as
sockaddr structs, without checking if the dereferenced struct members fall
beyond the end of the allocated chunk. There doesn't appear to be any
information leakage here based on how these members are used and
additional checking, but it's still worth fixing.
[akpm@linux-foundation.org: remove unfashionable newlines, fix gmail tab->space conversion]
Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
Change "return (EXPR);" to "return EXPR;"
return is not a function, parentheses are not required.
This simple patch copies the current approach for SIOCINQ ioctl() from DCCP
into SCTP so that the userland code working with SCTP can use a similar
interface across different protocols to know how much space to allocate for
a buffer.
Signed-off-by: Diego Elio Pettenò <flameeyes@gmail.com>
No need to test twice sk->sk_shutdown & RCV_SHUTDOWN
Change SCTP_DEBUG_PRINTK and SCTP_DEBUG_PRINTK_IPADDR to
use do { print } while (0) guards.
Add SCTP_DEBUG_PRINTK_CONT to fix errors in log when
lines were continued.
Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt
Add a missing newline in "Failed bind hash alloc"
(Dropped the infiniband part, because Tetsuo modified the related code,
I will send a separate patch for it once this is accepted.)
This patch introduces /proc/sys/net/ipv4/ip_local_reserved_ports which
allows users to reserve ports for third-party applications.
The reserved ports will not be used by automatic port assignments
(e.g. when calling connect() or bind() with port number 0). Explicit
port allocation behavior is unchanged.
Signed-off-by: Octavian Purdila <opurdila@ixiacom.com>
Signed-off-by: WANG Cong <amwang@redhat.com>
Cc: Neil Horman <nhorman@tuxdriver.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
git://git.kernel.org/pub/scm/linux/kernel/git/vxy/lksctp-dev
Add missing linux/vmalloc.h include to net/sctp/probe.c
sk_callback_lock rwlock actually protects sk->sk_sleep pointer, so we
need two atomic operations (and associated dirtying) per incoming
packet.
RCU conversion is pretty much needed :
1) Add a new structure, called "struct socket_wq" to hold all fields
that will need rcu_read_lock() protection (currently: a
wait_queue_head_t and a struct fasync_struct pointer).
[Future patch will add a list anchor for wakeup coalescing]
2) Attach one of such structure to each "struct socket" created in
sock_alloc_inode().
3) Respect RCU grace period when freeing a "struct socket_wq"
4) Change sk_sleep pointer in "struct sock" by sk_wq, pointer to "struct
socket_wq"
5) Change sk_sleep() function to use new sk->sk_wq instead of
sk->sk_sleep
6) Change sk_has_sleeper() to wq_has_sleeper() that must be used inside
a rcu_read_lock() section.
7) Change all sk_has_sleeper() callers to :
- Use rcu_read_lock() instead of read_lock(&sk->sk_callback_lock)
- Use wq_has_sleeper() to eventually wakeup tasks.
- Use rcu_read_unlock() instead of read_unlock(&sk->sk_callback_lock)
8) sock_wake_async() is modified to use rcu protection as well.
9) Exceptions :
macvtap, drivers/net/tun.c, af_unix use integrated "struct socket_wq"
instead of dynamically allocated ones. They dont need rcu freeing.
Some cleanups or followups are probably needed, (possible
sk_callback_lock conversion to a spinlock for example...).
The function should use the address family of the address when
trying to determine the length of the structure.
Since the change of the atomics to percpu variables, we now
have to disable BH in process context when touching percpu variables.
sk->sk_data_ready() of sctp socket can be called from both BH and non-BH
contexts, but the default sk->sk_data_ready(), sock_def_readable(), can
not be used in this case. Therefore, we have to make a new function
sctp_data_ready() to grab sk->sk_data_ready() with BH disabling.
[ INFO: possible irq lock inversion dependency detected ]
2.6.33-rc6 #129
sctp_darn/1517 just changed the state of lock:
(clock-AF_INET){++.?..}, at: [<c06aab60>] sock_def_readable+0x20/0x80
but this lock took another, SOFTIRQ-unsafe lock in the past:
(slock-AF_INET){+.-...}
and interrupts could create inverse lock ordering between them.
1 lock held by sctp_darn/1517:
#0: (sk_lock-AF_INET){+.+.+.}, at: [<cdfe363d>] sctp_sendmsg+0x23d/0xc00 [sctp]
Current socket backlog limit is not enough to really stop DDOS attacks,
because user thread spend many time to process a full backlog each
round, and user might crazy spin on socket lock.
We should add backlog size and receive_queue size (aka rmem_alloc) to
pace writers, and let user run without being slow down too much.
Introduce a sk_rcvqueues_full() helper, to avoid taking socket lock in
stress situations.
Under huge stress from a multiqueue/RPS enabled NIC, a single flow udp
receiver can now process ~200.000 pps (instead of ~100 pps before the
patch) on a 8 core machine.
Define a new function to return the waitqueue of a "struct sock".
static inline wait_queue_head_t *sk_sleep(struct sock *sk)
return sk->sk_sleep;
Change all read occurrences of sk_sleep by a call to this function.
Needed for a future RCU conversion. sk_sleep wont be a field directly
available.
drivers/net/stmmac/stmmac_main.c
drivers/net/wireless/wl12xx/wl1271_cmd.c
drivers/net/wireless/wl12xx/wl1271_main.c
drivers/net/wireless/wl12xx/wl1271_spi.c
net/core/ethtool.c
net/mac80211/scan.c
Remove duplicate declaration of symbol: struct hlist_node *node was
already declared, the seconds declaration shadows the first one.
CC: Vlad Yasevich <vladislav.yasevich@hp.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Make sctp adapt to the limited socket backlog change.
Cc: Vlad Yasevich <vladislav.yasevich@hp.com>
Cc: Sridhar Samudrala <sri@us.ibm.com>
Signed-off-by: Zhu Yi <yi.zhu@intel.com>
