path: root/net/sctp/sm_sideeffect.c
2007-08-30SCTP: Use net_ratelimit to suppress error messages print too fastWei Yongjun
When multi bundling SHUTDOWN-ACK message is received in ESTAB state, this will cause "sctp protocol violation state" message print many times. If SHUTDOWN-ACK is bundled 300 times in one packet, message will be print 300 times. The same problem also exists when received unexpected HEARTBEAT-ACK message which is bundled message times. This patch used net_ratelimit() to suppress error messages print too fast. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2007-08-29SCTP: properly clean up fragment and ordering queues during FWD-TSN.Vlad Yasevich
When we recieve a FWD-TSN (meaning the peer has abandoned the data), we need to clean up any partially received messages that may be hanging out on the re-assembly or re-ordering queues. This is a MUST requirement that was not properly done before. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com.>
2007-05-04[SCTP]: Set assoc_id correctly during INIT collision.Vlad Yasevich
During the INIT/COOKIE-ACK collision cases, it's possible to get into a situation where the association id is not yet set at the time of the user event generation. As a result, user events have an association id set to 0 which will confuse applications. This happens if we hit case B of duplicate cookie processing. In the particular example found and provided by Oscar Isaula <Oscar.Isaula@motorola.com>, flow looks like this: A B ---- INIT-------> (lost) <---------INIT------ ---- INIT-ACK---> <------ Cookie ECHO When the Cookie Echo is received, we end up trying to update the association that was created on A as a result of the (lost) INIT, but that association doesn't have the ID set yet. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: cleanup extra semicolonsStephen Hemminger
Spring cleaning time... There seems to be a lot of places in the network code that have extra bogus semicolons after conditionals. Most commonly is a bogus semicolon after: switch() { } Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SCTP]: Implement sac_info field in SCTP_ASSOC_CHANGE notification.Vlad Yasevich
As stated in the sctp socket api draft: sac_info: variable If the sac_state is SCTP_COMM_LOST and an ABORT chunk was received for this association, sac_info[] contains the complete ABORT chunk as defined in the SCTP specification RFC2960 [RFC2960] section 3.3.7. We now save received ABORT chunks into the sac_info field and pass that to the user. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] SCTP: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-01-30[SCTP]: Force update of the rto when processing HB-ACKVlad Yasevich
When processing a HEARTBEAT-ACK it's possible that the transport rto timers will not be updated because a prior T3-RTX processing would have cleared the rto_pending flag on the transport. However, if we received a valid HEARTBEAT-ACK, we want to force update the rto variables, so re-set the rto_pending flag before calling sctp_transport_update_rto(). Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-01-23[SCTP]: Fix SACK sequence during shutdownVlad Yasevich
Currently, when association enters SHUTDOWN state,the implementation will SACK any DATA first and then transmit the SHUTDOWN chunk. This is against the order required by 2960bis spec. SHUTDOWN must always be first, followed by SACK. This change forces this order and also enables bundling. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: SCTP_CMD_PROCESS_CTSN annotations.Al Viro
argument passed as __be32 Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Trivial ->ipaddr_h -> ->ipaddr conversions.Al Viro
2006-12-02[SCTP]: sctp_assoc_del_peer() switched to net-endian.Al Viro
Callers adjusted. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Switch ->primary_addr to net-endian.Al Viro
Users adjusted. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Switch ->cmp_addr() and sctp_cmp_addr_exact() to net-endian.Al Viro
instances of ->cmp_addr() are fine with switching both arguments to net-endian; callers other than in sctp_cmp_addr_exact() (both as ->cmp_addr(...) and direct calls of instances) adjusted; sctp_cmp_addr_exact() switched to net-endian itself and adjustment is done in its callers Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Beginning of conversion to net-endian for embedded sctp_addr.Al Viro
Part 1: rename sctp_chunk->source, sctp_sockaddr_entry->a, sctp_transport->ipaddr and sctp_transport->saddr (to ..._h) The next patch will reintroduce these fields and keep them as net-endian mirrors of the original (renamed) ones. Split in two patches to make sure that we hadn't forgotten any instanes. Later in the series we'll eliminate uses of host-endian variants (basically switching users to net-endian counterparts as we progress through that mess). Then host-endian ones will die. Other embedded host-endian sctp_addr will be easier to switch directly, so we leave them alone for now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: SCTP_CMD_ASSOC_FAILED annotations.Al Viro
also always get __be16 protocol error; switch to SCTP_PERR() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: SCTP_CMD_INIT_FAILED annotations.Al Viro
argument stored for SCTP_CMD_INIT_FAILED is always __be16 (protocol error). Introduced new field and accessor for it (SCTP_PERR()); switched to their use (from SCTP_U32() and .u32) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[SCTP]: Verify all the paths to a peer via heartbeat before using them.Sridhar Samudrala
This patch implements Path Initialization procedure as described in Sec 2.36 of RFC4460. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-19[SCTP]: Set sk_err so that poll wakes up after a non-blocking connect failure.Sridhar Samudrala
Also fix some other cases where sk_err is not set for 1-1 style sockets. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
2006-01-17[SCTP]: Fix bad sysctl formatting of SCTP timeout values on 64-bit m/cs.Vlad Yasevich
Change all the structure members that hold jiffies to be of type unsigned long. This also corrects bad sysctl formating on 64 bit architectures. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
2006-01-09[NET]: Change some "if (x) BUG();" to "BUG_ON(x);"Kris Katterjohn
This changes some simple "if (x) BUG();" statements to "BUG_ON(x);" Signed-off-by: Kris Katterjohn <kjak@users.sourceforge.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[SCTP]: Update SCTP_PEER_ADDR_PARAMS socket option to the latest api draft.Frank Filz
This patch adds support to set/get heartbeat interval, maximum number of retransmissions, pathmtu, sackdelay time for a particular transport/ association/socket as per the latest SCTP sockets api draft11. Signed-off-by: Frank Filz <ffilz@us.ibm.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-11[SCTP]: Remove timeouts[] array from sctp_endpoint.Vladislav Yasevich
The socket level timeout values are maintained in sctp_sock and association level timeouts are in sctp_association. So there is no need for ep->timeouts. Signed-off-by: Vladislav Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-11[SCTP]: __nocast annotationsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-20[SCTP] sctp_connectx() API supportFrank Filz
Implements sctp_connectx() as defined in the SCTP sockets API draft by tunneling the request through a setsockopt(). Signed-off-by: Frank Filz <ffilzlnx@us.ibm.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
