path: root/net/sctp/sm_sideeffect.c
2006-01-17[SCTP]: Fix bad sysctl formatting of SCTP timeout values on 64-bit m/cs.Vlad Yasevich
Change all the structure members that hold jiffies to be of type unsigned long. This also corrects bad sysctl formating on 64 bit architectures. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
2006-01-09[NET]: Change some "if (x) BUG();" to "BUG_ON(x);"Kris Katterjohn
This changes some simple "if (x) BUG();" statements to "BUG_ON(x);" Signed-off-by: Kris Katterjohn <kjak@users.sourceforge.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[SCTP]: Update SCTP_PEER_ADDR_PARAMS socket option to the latest api draft.Frank Filz
This patch adds support to set/get heartbeat interval, maximum number of retransmissions, pathmtu, sackdelay time for a particular transport/ association/socket as per the latest SCTP sockets api draft11. Signed-off-by: Frank Filz <ffilz@us.ibm.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-11[SCTP]: Remove timeouts[] array from sctp_endpoint.Vladislav Yasevich
The socket level timeout values are maintained in sctp_sock and association level timeouts are in sctp_association. So there is no need for ep->timeouts. Signed-off-by: Vladislav Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-11[SCTP]: __nocast annotationsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-20[SCTP] sctp_connectx() API supportFrank Filz
Implements sctp_connectx() as defined in the SCTP sockets API draft by tunneling the request through a setsockopt(). Signed-off-by: Frank Filz <ffilzlnx@us.ibm.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
