path: root/net/sctp/protocol.c
2006-12-02[SCTP]: Annotate ->supported_addrs().Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Annotate ->inaddr_any().Al Viro
2006-12-02[SCTP]: Don't bother setting sin_port in ->from_sk().Al Viro
... the only caller will overwrite immediately Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: ->a_h is gone now.Al Viro
2006-12-02[SCTP]: Trivial parts of a_h -> a switch.Al Viro
2006-12-02[SCTP]: ->get_saddr() switched to net-endian.Al Viro
2006-12-02[SCTP]: Switch ->from_addr_param() to net-endian.Al Viro
2006-12-02[SCTP]: Switch sctp_add_bind_addr() to net-endian.Al Viro
2006-12-02[SCTP]: Switch ->from_skb() to net-endian.Al Viro
All instances switched, callers updated. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Annotate ->dst_saddr()Al Viro
switched to taking a pointer to net-endian sctp_addr and a net-endian port number. Instances and callers adjusted; interestingly enough, the only calls are direct calls of specific instances - the method is not used at all. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Switch ->cmp_addr() and sctp_cmp_addr_exact() to net-endian.Al Viro
instances of ->cmp_addr() are fine with switching both arguments to net-endian; callers other than in sctp_cmp_addr_exact() (both as ->cmp_addr(...) and direct calls of instances) adjusted; sctp_cmp_addr_exact() switched to net-endian itself and adjustment is done in its callers Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP] embedded sctp_addr: net-endian mirrorsAl Viro
Add sctp_chunk->source, sctp_sockaddr_entry->a, sctp_transport->ipaddr and sctp_transport->saddr, maintain them as net-endian mirrors of their host-endian counterparts. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Beginning of conversion to net-endian for embedded sctp_addr.Al Viro
Part 1: rename sctp_chunk->source, sctp_sockaddr_entry->a, sctp_transport->ipaddr and sctp_transport->saddr (to ..._h) The next patch will reintroduce these fields and keep them as net-endian mirrors of the original (renamed) ones. Split in two patches to make sure that we hadn't forgotten any instanes. Later in the series we'll eliminate uses of host-endian variants (basically switching users to net-endian counterparts as we progress through that mess). Then host-endian ones will die. Other embedded host-endian sctp_addr will be easier to switch directly, so we leave them alone for now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Trivial sctp endianness annotations.Al Viro
2006-12-02[TCP]: Don't set SKB owner in tcp_transmit_skb().David S. Miller
The data itself is already charged to the SKB, doing the skb_set_owner_w() just generates a lot of noise and extra atomics we don't really need. Lmbench improvements on lat_tcp are minimal: before: TCP latency using localhost: 23.2701 microseconds TCP latency using localhost: 23.1994 microseconds TCP latency using localhost: 23.2257 microseconds after: TCP latency using localhost: 22.8380 microseconds TCP latency using localhost: 22.9465 microseconds TCP latency using localhost: 22.8462 microseconds Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-30[SCTP]: Correctly set IP id for SCTP trafficVlad Yasevich
Make SCTP 1-1 style and peeled-off associations behave like TCP when setting IP id. In both cases, we set the inet_sk(sk)->daddr and initialize inet_sk(sk)->id to a random value. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[SCTP]: CleanupsAdrian Bunk
This patch contains the following cleanups: - make the following needlessly global function static: - socket.c: sctp_apply_peer_addr_params() - add proper prototypes for the several global functions in include/net/sctp/sctp.h Note that this fixes wrong prototypes for the following functions: - sctp_snmp_proc_exit() - sctp_eps_proc_exit() - sctp_assocs_proc_exit() The latter was spotted by the GNU C compiler and reported by David Woodhouse. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[SCTP]: Change globals to __read_mostlyBrian Haley
Change sctp globals to __read_mostly. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[SCTP]: Remove multiple levels of msecs to jiffies conversions.Vladislav Yasevich
The SCTP sysctl entries are displayed in milliseconds, but stored internally in jiffies. This results in multiple levels of msecs to jiffies conversion and as a result produces a truncation error. This patch makes things consistent in that we store and display defaults in milliseconds and only convert once for use by association. This patch also adds some sane min/max values so that we don't go off the deep end. Signed-off-by: Vladislav Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[SCTP]: ADDIP: Don't use an address as source until it is ASCONF-ACKedSridhar Samudrala
This implements Rules D1 and D4 of Sec 4.3 in the ADDIP draft. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[SCTP]: Reject sctp packets with broadcast addresses.Vlad Yasevich
2006-03-20[NET]: Identation & other cleanups related to compat_[gs]etsockopt csetArnaldo Carvalho de Melo
No code changes, just tidying up, in some cases moving EXPORT_SYMBOLs to just after the function exported, etc. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NET]: {get|set}sockopt compatibility layerDmitry Mishin
This patch extends {get|set}sockopt compatibility layer in order to move protocol specific parts to their place and avoid huge universal net/compat.c file in the future. Signed-off-by: Dmitry Mishin <dim@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[INET_SOCK]: Move struct inet_sock & helper functions to net/inet_sock.hArnaldo Carvalho de Melo
To help in reducing the number of include dependencies, several files were touched as they were getting needed headers indirectly for stuff they use. Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had linux/dccp.h include twice. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: move struct proto_ops to constEric Dumazet
I noticed that some of 'struct proto_ops' used in the kernel may share a cache line used by locks or other heavily modified data. (default linker alignement is 32 bytes, and L1_CACHE_LINE is 64 or 128 at least) This patch makes sure a 'struct proto_ops' can be declared as const, so that all cpus can share all parts of it without false sharing. This is not mandatory : a driver can still use a read/write structure if it needs to (and eventually a __read_mostly) I made a global stubstitute to change all existing occurences to make them const. This should reduce the possibility of false sharing on SMP, and speedup some socket system calls. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-11[SCTP]: Include ulpevents in socket receive buffer accounting.Neil Horman
Also introduces a sysctl option to configure the receive buffer accounting policy to be either at socket or association level. Default is all the associations on the same socket share the receive buffer. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-11[SCTP]: Fix potential NULL pointer dereference in sctp_v4_get_saddrVladislav Yasevich
It is possible to get to sctp_v4_get_saddr() without a valid association. This happens when processing OOTB packets and the cached route entry is no longer valid. However, when responding to OOTB packets we already properly set the source address based on the information in the OOTB packet. So, if we we get to sctp_v4_get_saddr() without an association we can simply return. Signed-off-by: Vladislav Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-03[IPV4]: Replace __in_dev_get with __in_dev_get_rcu/rtnlHerbert Xu
The following patch renames __in_dev_get() to __in_dev_get_rtnl() and introduces __in_dev_get_rcu() to cover the second case. 1) RCU with refcnt should use in_dev_get(). 2) RCU without refcnt should use __in_dev_get_rcu(). 3) All others must hold RTNL and use __in_dev_get_rtnl(). There is one exception in net/ipv4/route.c which is in fact a pre-existing race condition. I've marked it as such so that we remember to fix it. This patch is based on suggestions and prior work by Suzanne Wood and Paul McKenney. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: use __read_mostly on kmem_cache_t , DEFINE_SNMP_STAT pointersEric Dumazet
This patch puts mostly read only data in the right section (read_mostly), to help sharing of these data between CPUS without memory ping pongs. On one of my production machine, tcp_statistics was sitting in a heavily modified cache line, so *every* SNMP update had to force a reload. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET]: Make inet_create try to load protocol modulesArnaldo Carvalho de Melo
Syntax is net-pf-PROTOCOL_FAMILY-PROTOCOL-SOCK_TYPE and if this fails net-pf-PROTOCOL_FAMILY-PROTOCOL. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Cleanup INET_REFCNT_DEBUG codeArnaldo Carvalho de Melo
2005-07-11[SCTP]: __nocast annotationsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-28[SCTP] Make init & delayed sack timeouts configurable by user.Vlad Yasevich
2005-06-13[SCTP] Add support for ip_nonlocal_bind sysctl & IP_FREEBIND socket optionNeil Horman
Signed-off-by: Neil Horman <nhorman@redhat.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-28[SCTP] Fix SCTP sendbuffer accouting.Neil Horman
- Include chunk and skb sizes in sendbuffer accounting. - 2 policies are supported. 0: per socket accouting, 1: per association accounting DaveM: I've made the default per-socket. Signed-off-by: Neil Horman <nhorman@redhat.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-28[SCTP] Fix bug in sctp_init() error handling code.Neil Horman
