path: root/net/sctp/ipv6.c
2013-08-09net: sctp: trivial: update bug report in header commentDaniel Borkmann
With the restructuring of the lksctp.org site, we only allow bug reports through the SCTP mailing list linux-sctp@vger.kernel.org, not via SF, as SF is only used for web hosting and nothing more. While at it, also remove the obvious statement that bugs will be fixed and incooperated into the kernel. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-02sctp: Don't lookup dst if transport dst is still validfan.du
When sctp sits on IPv6, sctp_transport_dst_check pass cookie as ZERO, as a result ip6_dst_check always fail out. This behaviour makes transport->dst useless, because every sctp_packet_transmit must look for valid dst. Add a dst_cookie into sctp_transport, and set the cookie whenever we get new dst for sctp_transport. So dst validness could be checked against it. Since I have split genid for IPv4 and IPv6, also delete/add IPv6 address will also bump IPv6 genid. So issues we discussed in: http://marc.info/?l=linux-netdev&m=137404469219410&w=4 have all been sloved for this patch. Signed-off-by: Fan Du <fan.du@windriver.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-24net: sctp: trivial: update mailing list addressDaniel Borkmann
The SCTP mailing list address to send patches or questions to is linux-sctp@vger.kernel.org and not lksctp-developers@lists.sourceforge.net anymore. Therefore, update all occurences. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-01net: sctp: rework debugging framework to use pr_debug and friendsDaniel Borkmann
We should get rid of all own SCTP debug printk macros and use the ones that the kernel offers anyway instead. This makes the code more readable and conform to the kernel code, and offers all the features of dynamic debbuging that pr_debug() et al has, such as only turning on/off portions of debug messages at runtime through debugfs. The runtime cost of having CONFIG_DYNAMIC_DEBUG enabled, but none of the debug statements printing, is negligible [1]. If kernel debugging is completly turned off, then these statements will also compile into "empty" functions. While we're at it, we also need to change the Kconfig option as it /now/ only refers to the ifdef'ed code portions in outqueue.c that enable further debugging/tracing of SCTP transaction fields. Also, since SCTP_ASSERT code was enabled with this Kconfig option and has now been removed, we transform those code parts into WARNs resp. where appropriate BUG_ONs so that those bugs can be more easily detected as probably not many people have SCTP debugging permanently turned on. To turn on all SCTP debugging, the following steps are needed: # mount -t debugfs none /sys/kernel/debug # echo -n 'module sctp +p' > /sys/kernel/debug/dynamic_debug/control This can be done more fine-grained on a per file, per line basis and others as described in [2]. [1] https://www.kernel.org/doc/ols/2009/ols2009-pages-39-46.pdf [2] Documentation/dynamic-debug-howto.txt Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17net: sctp: remove SCTP_STATIC macroDaniel Borkmann
SCTP_STATIC is just another define for the static keyword. It's use is inconsistent in the SCTP code anyway and it was introduced in the initial implementation of SCTP in 2.5. We have a regression suite in lksctp-tools, but this is for user space only, so noone makes use of this macro anymore. The kernel test suite for 2.5 is incompatible with the current SCTP code anyway. So simply Remove it, to be more consistent with the rest of the kernel code. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-17net: sctp: get rid of t_new macro for kzallocDaniel Borkmann
t_new rather obfuscates things where everyone else is using actual function names instead of that macro, so replace it with kzalloc, which is the function t_new wraps. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-13sctp: Correct byte order of access to skb->{network, transport}_headerSimon Horman
Corrects an byte order conflict introduced by 158874cac61245b84e939c92c53db7000122b7b0 ("sctp: Correct access to skb->{network, transport}_header"). The values in question are host byte order. Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-28sctp: Correct access to skb->{network, transport}_headerSimon Horman
This corrects an regression introduced by "net: Use 16bits for *_headers fields of struct skbuff" when NET_SKBUFF_DATA_USES_OFFSET is not set. In that case sk_buff_data_t will be a pointer, however, skb->{network,transport}_header is now __u16. Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-13net: sctp: sctp_v6_get_dst: fix boolean test in dst cacheDaniel Borkmann
We walk through the bind address list and try to get the best source address for a given destination. However, currently, we take the 'continue' path of the loop when an entry is invalid (!laddr->valid) *and* the entry state does not equal SCTP_ADDR_SRC (laddr->state != SCTP_ADDR_SRC). Thus, still, invalid entries with SCTP_ADDR_SRC might not 'continue' as well as valid entries with SCTP_ADDR_{NEW, SRC, DEL}, with a possible false baddr and matchlen as a result, causing in worst case dst route to be false or possibly NULL. This test should actually be a '||' instead of '&&'. But lets fix it and make this a bit easier to read by having the condition the same way as similarly done in sctp_v4_get_dst. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-30sctp: fix CONFIG_SCTP_DBG_MSG=y null pointer dereference in sctp_v6_get_dst()Tommi Rantala
Trinity (the syscall fuzzer) triggered the following BUG, reproducible only when the kernel is configured with CONFIG_SCTP_DBG_MSG=y. When CONFIG_SCTP_DBG_MSG is not set, the null pointer is never dereferenced. ---[ end trace a4de0bfcb38a3642 ]--- BUG: unable to handle kernel NULL pointer dereference at 0000000000000100 IP: [<ffffffff8136796e>] ip6_string+0x1e/0xa0 PGD 4eead067 PUD 4e472067 PMD 0 Oops: 0000 [#1] PREEMPT SMP Modules linked in: CPU 3 Pid: 21324, comm: trinity-child11 Tainted: G W 3.7.0-rc7+ #61 ASUSTeK Computer INC. EB1012/EB1012 RIP: 0010:[<ffffffff8136796e>] [<ffffffff8136796e>] ip6_string+0x1e/0xa0 RSP: 0018:ffff88004e4637a0 EFLAGS: 00010046 RAX: ffff88004e4637da RBX: ffff88004e4637da RCX: 0000000000000000 RDX: ffffffff8246e92a RSI: 0000000000000100 RDI: ffff88004e4637da RBP: ffff88004e4637a8 R08: 000000000000ffff R09: 000000000000ffff R10: 0000000000000000 R11: 0000000000000000 R12: ffffffff8289d600 R13: ffffffff8289d230 R14: ffffffff8246e928 R15: ffffffff8289d600 FS: 00007fed95153700(0000) GS:ffff88005fd80000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000100 CR3: 000000004eeac000 CR4: 00000000000007e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process trinity-child11 (pid: 21324, threadinfo ffff88004e462000, task ffff8800524b0000) Stack: ffff88004e4637da ffff88004e463828 ffffffff81368eee 000000004e4637d8 ffffffff0000ffff ffff88000000ffff 0000000000000000 000000004e4637f8 ffffffff826285d8 ffff88004e4637f8 0000000000000000 ffff8800524b06b0 Call Trace: [<ffffffff81368eee>] ip6_addr_string.isra.11+0x3e/0xa0 [<ffffffff81369183>] pointer.isra.12+0x233/0x2d0 [<ffffffff810a413a>] ? vprintk_emit+0x1ba/0x450 [<ffffffff8110953d>] ? trace_hardirqs_on_caller+0x10d/0x1a0 [<ffffffff81369757>] vsnprintf+0x187/0x5d0 [<ffffffff81369c62>] vscnprintf+0x12/0x30 [<ffffffff810a4028>] vprintk_emit+0xa8/0x450 [<ffffffff81e5cb00>] printk+0x49/0x4b [<ffffffff81d17221>] sctp_v6_get_dst+0x731/0x780 [<ffffffff81d16e15>] ? sctp_v6_get_dst+0x325/0x780 [<ffffffff81d00a96>] sctp_transport_route+0x46/0x120 [<ffffffff81cff0f1>] sctp_assoc_add_peer+0x161/0x350 [<ffffffff81d0fd8d>] sctp_sendmsg+0x6cd/0xcb0 [<ffffffff81b55bf0>] ? inet_create+0x670/0x670 [<ffffffff81b55cfb>] inet_sendmsg+0x10b/0x220 [<ffffffff81b55bf0>] ? inet_create+0x670/0x670 [<ffffffff81a72a64>] ? sock_update_classid+0xa4/0x2b0 [<ffffffff81a72ab0>] ? sock_update_classid+0xf0/0x2b0 [<ffffffff81a6ac1c>] sock_sendmsg+0xdc/0xf0 [<ffffffff8118e9e5>] ? might_fault+0x85/0x90 [<ffffffff8118e99c>] ? might_fault+0x3c/0x90 [<ffffffff81a6e12a>] sys_sendto+0xfa/0x130 [<ffffffff810a9887>] ? do_setitimer+0x197/0x380 [<ffffffff81e960d5>] ? sysret_check+0x22/0x5d [<ffffffff81e960a9>] system_call_fastpath+0x16/0x1b Code: 01 eb 89 66 2e 0f 1f 84 00 00 00 00 00 55 48 89 f8 31 c9 48 89 e5 53 eb 12 0f 1f 40 00 48 83 c1 01 48 83 c0 04 48 83 f9 08 74 70 <0f> b6 3c 4e 89 fb 83 e7 0f c0 eb 04 41 89 d8 41 83 e0 0f 0f b6 RIP [<ffffffff8136796e>] ip6_string+0x1e/0xa0 RSP <ffff88004e4637a0> CR2: 0000000000000100 ---[ end trace a4de0bfcb38a3643 ]--- Signed-off-by: Tommi Rantala <tt.rantala@gmail.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14sctp: Make the mib per network namespaceEric W. Biederman
Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14sctp: Enable sctp in all network namespacesEric W. Biederman
- Fix the sctp_af operations to work in all namespaces - Enable sctp socket creation in all network namespaces. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14sctp: Make the address lists per network namespaceEric W. Biederman
- Move the address lists into struct net - Add per network namespace initialization and cleanup - Pass around struct net so it is everywhere I need it. - Rename all of the global variable references into references to the variables moved into struct net Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14sctp: Make the association hashtable handle multiple network namespacesEric W. Biederman
- Use struct net in the hash calculation - Use sock_net(association.base.sk) in the association lookups. - On receive calculate the network namespace from skb->dev. - Pass struct net from receive down to the functions that actually do the association lookup. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-12ipv6: Add redirect support to all protocol icmp error handlers.David S. Miller
2011-11-22net: remove ipv6_addr_copy()Alexey Dobriyan
C assignment can handle struct in6_addr copying. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-27ipv6: tcp: fix TCLASS value in ACK messages sent from TIME_WAITEric Dumazet
commit 66b13d99d96a (ipv4: tcp: fix TOS value in ACK messages sent from TIME_WAIT) fixed IPv4 only. This part is for the IPv6 side, adding a tclass param to ip6_xmit() We alias tw_tclass and tw_tos, if socket family is INET6. [ if sockets is ipv4-mapped, only IP_TOS socket option is used to fill TOS field, TCLASS is not taken into account ] Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02sctp: Add Auto-ASCONF support (core).Michio Honda
SCTP reconfigure the IP addresses in the association by using ASCONF chunks as mentioned in RFC5061. For example, we can start to use the newly configured IP address in the existing association. This patch implements automatic ASCONF operation in the SCTP stack with address events in the host computer, which is called auto_asconf. Signed-off-by: Michio Honda <micchie@sfc.wide.ad.jp> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Acked-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits) macvlan: fix panic if lowerdev in a bond tg3: Add braces around 5906 workaround. tg3: Fix NETIF_F_LOOPBACK error macvlan: remove one synchronize_rcu() call networking: NET_CLS_ROUTE4 depends on INET irda: Fix error propagation in ircomm_lmp_connect_response() irda: Kill set but unused variable 'bytes' in irlan_check_command_param() irda: Kill set but unused variable 'clen' in ircomm_connect_indication() rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport() be2net: Kill set but unused variable 'req' in lancer_fw_download() irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication() atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined. rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer(). rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler() rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection() rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window() pkt_sched: Kill set but unused variable 'protocol' in tc_classify() isdn: capi: Use pr_debug() instead of ifdefs. tg3: Update version to 3.119 tg3: Apply rx_discards fix to 5719/5720 ... Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c as per Davem.
2011-05-07net,rcu: convert call_rcu(sctp_local_addr_free) to kfree_rcu()Lai Jiangshan
The rcu callback sctp_local_addr_free() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(sctp_local_addr_free). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-04-27sctp: clean up route lookup callsVlad Yasevich
Change the call to take the transport parameter and set the cached 'dst' appropriately inside the get_dst() function calls. This will allow us in the future to clean up source address storage as well. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27sctp: remove useless arguments from get_saddr() callVlad Yasevich
There is no point in passing a destination address to a get_saddr() call. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27sctp: make sctp over IPv6 work with IPsecVlad Yasevich
SCTP never called xfrm_output after it's v6 route lookups so that never really worked with ipsec. Additioanlly, we never passed port nubmers and protocol in the flowi, so any port based policies were never applied as well. Now that we can fixed ipv6 routing lookup code, using ip6_dst_lookup_flow() and pass port numbers. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27sctp: cache the ipv6 source after route lookupVlad Yasevich
The ipv6 routing lookup does give us a source address, but instead of filling it into the dst, it's stored in the flowi. We can use that instead of going through the entire source address selection again. Also the useless ->dst_saddr member of sctp_pf is removed. And sctp_v6_dst_saddr() is removed, instead by introduce sctp_v6_to_addr(), which can be reused to cleanup some dup code. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27sctp: fix sctp to work with ipv6 source address routingWeixing Shi
In the below test case, using the source address routing, sctp can not work. Node-A 1)ifconfig eth0 inet6 add 2001:1::1/64 2)ip -6 rule add from 2001:1::1 table 100 pref 100 3)ip -6 route add 2001:2::1 dev eth0 table 100 4)sctp_darn -H 2001:1::1 -P 250 -l & Node-B 1)ifconfig eth0 inet6 add 2001:2::1/64 2)ip -6 rule add from 2001:2::1 table 100 pref 100 3)ip -6 route add 2001:1::1 dev eth0 table 100 4)sctp_darn -H 2001:2::1 -P 250 -h 2001:1::1 -p 250 -s root cause: Node-A and Node-B use the source address routing, and at begining, source address will be NULL,sctp will search the routing table by the destination address, because using the source address routing table, and the result dst_entry will be NULL. solution: walk through the bind address list to get the source address and then lookup the routing table again to get the correct dst_entry. Signed-off-by: Weixing Shi <Weixing.Shi@windriver.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-22inet: constify ip headers and in6_addrEric Dumazet
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers where possible, to make code intention more obvious. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-12ipv6: Convert to use flowi6 where applicable.David S. Miller
2011-03-12net: Put flowi_* prefix on AF independent members of struct flowiDavid S. Miller
I intend to turn struct flowi into a union of AF specific flowi structs. There will be a common structure that each variant includes first, much like struct sock_common. This is the first step to move in that direction. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-26net/sctp: Use pr_fmt and pr_<level>Joe Perches
Change SCTP_DEBUG_PRINTK and SCTP_DEBUG_PRINTK_IPADDR to use do { print } while (0) guards. Add SCTP_DEBUG_PRINTK_CONT to fix errors in log when lines were continued. Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt Add a missing newline in "Failed bind hash alloc" Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-15net: replace ipfragok with skb->local_dfShan Wei
As Herbert Xu said: we should be able to simply replace ipfragok with skb->local_df. commit f88037(sctp: Drop ipfargok in sctp_xmit function) has droped ipfragok and set local_df value properly. The patch kills the ipfragok parameter of .queue_xmit(). Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03SCTP: Change to use ipv6_addr_copy()Brian Haley
Change SCTP IPv6 code to use ipv6_addr_copy() Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-30sctp: Use ipv6_addr_diff() in sctp_v6_addr_match_len().YOSHIFUJI Hideaki / 吉藤英明
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-20ipv6: convert idev_list to list macrosstephen hemminger
Convert to list macro's for the list of addresses per interface in IPv6. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-17net: remove INIT_RCU_HEAD() usageAlexey Dobriyan
call_rcu() will unconditionally reinitialize RCU head anyway. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05sctp: ipv6: avoid touching device refcountEric Dumazet
Avoid touching device refcount in sctp/ipv6, thanks to RCU Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05net: drop capability from protocol definitionsEric Paris
struct can_proto had a capability field which wasn't ever used. It is dropped entirely. struct inet_protosw had a capability field which can be more clearly expressed in the code by just checking if sock->type = SOCK_RAW. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-14net: constify struct inet6_protocolAlexey Dobriyan
2009-06-23ipv6: Use correct data types for ICMPv6 type and codeBrian Haley
Change all the code that deals directly with ICMPv6 type and code values to use u8 instead of a signed int as that's the actual data type. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-16sctp: Inherit all socket options from parent correctly.Vlad Yasevich
During peeloff/accept() sctp needs to save the parent socket state into the new socket so that any options set on the parent are inherited by the child socket. This was found when the parent/listener socket issues SO_BINDTODEVICE, but the data was misrouted after a route cache flush. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-22sctp/ipv6.c: use ipv6_addr_copyJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-29net: replace %p6 with %pI6Harvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-28net, misc: replace uses of NIP6_FMT with %p6Harvey Harrison
2008-10-08ipv6: added net argument to ICMP6_INC_STATS_BHDenis V. Lunev
Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01sctp: try harder to figure out address family when checking wildcardsVlad Yasevich
sctp_is_any() function that is used to check for wildcard addresses only looks at the address itself to determine the address family. This function is used in the API to check the address passed in from the user. If the user simply zerroes out the sockaddr_storage and pass that in, we'll end up failing. So, let's try harder to determine the address family by also checking the socket if it's possible. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2008-08-14netns: Add network namespace argument to rt6_fill_node() and ↵Brian Haley
ipv6_dev_get_saddr() ipv6_dev_get_saddr() blindly de-references dst_dev to get the network namespace, but some callers might pass NULL. Change callers to pass a namespace pointer instead. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-03sctp: Drop ipfargok in sctp_xmit functionHerbert Xu
The ipfragok flag controls whether the packet may be fragmented either on the local host on beyond. The latter is only valid on IPv4. In fact, we never want to do the latter even on IPv4 when PMTU is enabled. This is because even though we can't fragment packets within SCTP due to the prtocol's inherent faults, we can still fragment it at IP layer. By setting the DF bit we will improve the PMTU process. RFC 2960 only says that we SHOULD clear the DF bit in this case, so we're compliant even if we set the DF bit. In fact RFC 4960 no longer has this statement. Once we make this change, we only need to control the local fragmentation. There is already a bit in the skb which controls that, local_df. So this patch sets that instead of using the ipfragok argument. The only complication is that there isn't a struct sock object per transport, so for IPv4 we have to resort to changing the pmtudisc field for every packet. This should be safe though as the protocol is single-threaded. Note that after this patch we can remove ipfragok from the rest of the stack too. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18sctp: Support ipv6only AF_INET6 sockets.Vlad Yasevich
2008-06-04sctp: Fix ECN markings for IPv6Vlad Yasevich
Commit e9df2e8fd8fbc95c57dbd1d33dada66c4627b44c ("[IPV6]: Use appropriate sock tclass setting for routing lookup.") also changed the way that ECN capable transports mark this capability in IPv6. As a result, SCTP was not marking ECN capablity because the traffic class was never set. This patch brings back the markings for IPv6 traffic. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
