path: root/net/sctp/ipv6.c
2009-11-05sctp: ipv6: avoid touching device refcountEric Dumazet
Avoid touching device refcount in sctp/ipv6, thanks to RCU Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05net: drop capability from protocol definitionsEric Paris
struct can_proto had a capability field which wasn't ever used. It is dropped entirely. struct inet_protosw had a capability field which can be more clearly expressed in the code by just checking if sock->type = SOCK_RAW. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-14net: constify struct inet6_protocolAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-23ipv6: Use correct data types for ICMPv6 type and codeBrian Haley
Change all the code that deals directly with ICMPv6 type and code values to use u8 instead of a signed int as that's the actual data type. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-16sctp: Inherit all socket options from parent correctly.Vlad Yasevich
During peeloff/accept() sctp needs to save the parent socket state into the new socket so that any options set on the parent are inherited by the child socket. This was found when the parent/listener socket issues SO_BINDTODEVICE, but the data was misrouted after a route cache flush. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-22sctp/ipv6.c: use ipv6_addr_copyJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-29net: replace %p6 with %pI6Harvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-28net, misc: replace uses of NIP6_FMT with %p6Harvey Harrison
2008-10-08ipv6: added net argument to ICMP6_INC_STATS_BHDenis V. Lunev
Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-01sctp: try harder to figure out address family when checking wildcardsVlad Yasevich
sctp_is_any() function that is used to check for wildcard addresses only looks at the address itself to determine the address family. This function is used in the API to check the address passed in from the user. If the user simply zerroes out the sockaddr_storage and pass that in, we'll end up failing. So, let's try harder to determine the address family by also checking the socket if it's possible. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2008-08-14netns: Add network namespace argument to rt6_fill_node() and ↵Brian Haley
ipv6_dev_get_saddr() ipv6_dev_get_saddr() blindly de-references dst_dev to get the network namespace, but some callers might pass NULL. Change callers to pass a namespace pointer instead. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-03sctp: Drop ipfargok in sctp_xmit functionHerbert Xu
The ipfragok flag controls whether the packet may be fragmented either on the local host on beyond. The latter is only valid on IPv4. In fact, we never want to do the latter even on IPv4 when PMTU is enabled. This is because even though we can't fragment packets within SCTP due to the prtocol's inherent faults, we can still fragment it at IP layer. By setting the DF bit we will improve the PMTU process. RFC 2960 only says that we SHOULD clear the DF bit in this case, so we're compliant even if we set the DF bit. In fact RFC 4960 no longer has this statement. Once we make this change, we only need to control the local fragmentation. There is already a bit in the skb which controls that, local_df. So this patch sets that instead of using the ipfragok argument. The only complication is that there isn't a struct sock object per transport, so for IPv4 we have to resort to changing the pmtudisc field for every packet. This should be safe though as the protocol is single-threaded. Note that after this patch we can remove ipfragok from the rest of the stack too. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18sctp: Support ipv6only AF_INET6 sockets.Vlad Yasevich
2008-06-04sctp: Fix ECN markings for IPv6Vlad Yasevich
Commit e9df2e8fd8fbc95c57dbd1d33dada66c4627b44c ("[IPV6]: Use appropriate sock tclass setting for routing lookup.") also changed the way that ECN capable transports mark this capability in IPv6. As a result, SCTP was not marking ECN capablity because the traffic class was never set. This patch brings back the markings for IPv6 traffic. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-05[SCTP]: Fix NULL dereference of asoc.YOSHIFUJI Hideaki
Commit 7cbca67c073263c179f605bdbbdc565ab29d801d ("[IPV6]: Support Source Address Selection API (RFC5014)") introduced NULL dereference of asoc to sctp_v6_get_saddr in net/sctp/ipv6.c. Pointed out by Johann Felix Soden <johfel@users.sourceforge.net>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-04-14Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ehea/ehea_main.c drivers/net/wireless/iwlwifi/Kconfig drivers/net/wireless/rt2x00/rt61pci.c net/ipv4/inet_timewait_sock.c net/ipv6/raw.c net/mac80211/ieee80211_sta.c
2008-04-12[SCTP]: IPv4 vs IPv6 addresses mess in sctp_inet[6]addr_event.Pavel Emelyanov
All IP addresses that are present in a system are duplicated on struct sctp_sockaddr_entry. They are linked in the global list called sctp_local_addr_list. And this struct unions IPv4 and IPv6 addresses. So, there can be rare case, when a sockaddr_in.sin_addr coincides with the corresponding part of the sockaddr_in6 and the notifier for IPv4 will carry away an IPv6 entry. The fix is to check the family before comparing the addresses. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit sock->sk_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-sock inlines: sock_net(), sock_net_set() and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-25[IPV6]: Support Source Address Selection API (RFC5014).YOSHIFUJI Hideaki
2008-03-21Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6
2008-03-20[SCTP]: Fix a race between module load and protosw accessVlad Yasevich
There is a race is SCTP between the loading of the module and the access by the socket layer to the protocol functions. In particular, a list of addresss that SCTP maintains is not initialized prior to the registration with the protosw. Thus it is possible for a user application to gain access to SCTP functions before everything has been initialized. The problem shows up as odd crashes during connection initializtion when we try to access the SCTP address list. The solution is to refactor how we do registration and initialize the lists prior to registering with the protosw. Care must be taken since the address list initialization depends on some other pieces of SCTP initialization. Also the clean-up in case of failure now also needs to be refactored. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Acked-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-18Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/rt2x00/rt2x00dev.c net/8021q/vlan_dev.c
2008-03-11[SCTP]: Fix local_addr deletions during list traversals.Chidambar 'ilLogict' Zinnoury
Since the lists are circular, we need to explicitely tag the address to be deleted since we might end up freeing the list head instead. This fixes some interesting SCTP crashes. Signed-off-by: Chidambar 'ilLogict' Zinnoury <illogict@online.fr> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-05net: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-05[NETNS][IPV6] route6 - add netns parameter to ip6_route_outputDaniel Lezcano
Add an netns parameter to ip6_route_output. That will allow to access to the right routing table for outgoing traffic. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-04[IPV6] ADDRCONF: Convert ipv6_get_saddr() to ipv6_dev_get_saddr().YOSHIFUJI Hideaki
Since most users of ipv6_get_saddr() pass non-NULL as dst argument, use ipv6_dev_get_saddr() directly. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-02-28[SCTP]: Clean up naming conventions of sctp protocol/address family registrationNeil Horman
I noticed while looking into some odd behavior in sctp, that the variable name sctp_pf_inet6_specific was used twice to represent two different pieces of data (its both a structure name and a pointer to that type of structure), which is confusing to say the least, and potentially dangerous depending on the variable scope. This patch cleans that up, and makes the protocol and address family registration names in SCTP more regular, increasing readability. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> ipv6.c | 12 ++++++------ protocol.c | 12 ++++++------ 2 files changed, 12 insertions(+), 12 deletions(-)
2008-02-05[SCTP]: Stop claiming that this is a "reference implementation"Vlad Yasevich
I was notified by Randy Stewart that lksctp claims to be "the reference implementation". First of all, "the refrence implementation" was the original implementation of SCTP in usersapce written ty Randy and a few others. Second, after looking at the definiton of 'reference implementation', we don't really meet the requirements. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2008-01-28[NETNS][IPV6]: inet6_addr - check ipv6 address per namespaceDaniel Lezcano
When a new address is added, we must check if the new address does not already exists. This patch makes this check to be aware of a network namespace, so the check will look if the address already exists for the specified network namespace. While the addresses are browsed, the addresses which do not belong to the namespace are discarded. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[SCTP]: Change use_as_src into a full address stateVlad Yasevich
2007-11-01[NET]: Forget the zero_it argument of sk_alloc()Pavel Emelyanov
Finally, the zero_it argument can be completely removed from the callers and from the function prototype. Besides, fix the checkpatch.pl warnings about using the assignments inside if-s. This patch is rather big, and it is a part of the previous one. I splitted it wishing to make the patches more readable. Hope this particular split helped. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[IPV6]: Replace sk_buff ** with sk_buff * in input handlersHerbert Xu
With all the users of the double pointers removed from the IPv6 input path, this patch converts all occurances of sk_buff ** to sk_buff * in IPv6 input handlers. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make the device list and device lookups per namespace.Eric W. Biederman
This patch makes most of the generic device layer network namespace safe. This patch makes dev_base_head a network namespace variable, and then it picks up a few associated variables. The functions: dev_getbyhwaddr dev_getfirsthwbytype dev_get_by_flags dev_get_by_name __dev_get_by_name dev_get_by_index __dev_get_by_index dev_ioctl dev_ethtool dev_load wireless_process_ioctl were modified to take a network namespace argument, and deal with it. vlan_ioctl_set and brioctl_set were modified so their hooks will receive a network namespace argument. So basically anthing in the core of the network stack that was affected to by the change of dev_base was modified to handle multiple network namespaces. The rest of the network stack was simply modified to explicitly use &init_net the initial network namespace. This can be fixed when those components of the network stack are modified to handle multiple network namespaces. For now the ifindex generator is left global. Fundametally ifindex numbers are per namespace, or else we will have corner case problems with migration when we get that far. At the same time there are assumptions in the network stack that the ifindex of a network device won't change. Making the ifindex number global seems a good compromise until the network stack can cope with ifindex changes when you change namespaces, and the like. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make socket creation namespace safe.Eric W. Biederman
This patch passes in the namespace a new socket should be created in and has the socket code do the appropriate reference counting. By virtue of this all socket create methods are touched. In addition the socket create methods are modified so that they will fail if you attempt to create a socket in a non-default network namespace. Failing if we attempt to create a socket outside of the default network namespace ensures that as we incrementally make the network stack network namespace aware we will not export functionality that someone has not audited and made certain is network namespace safe. Allowing us to partially enable network namespaces before all of the exotic protocols are supported. Any protocol layers I have missed will fail to compile because I now pass an extra parameter into the socket creation code. [ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPV6]: Add v4mapped address inlineBrian Haley
Add v4mapped address inline to avoid calls to ipv6_addr_type(). Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[SCTP]: Convert bind_addr_list locking to RCUVlad Yasevich
Since the sctp_sockaddr_entry is now RCU enabled as part of the patch to synchronize sctp_localaddr_list, it makes sense to change all handling of these entries to RCU. This includes the sctp_bind_addrs structure and it's list of bound addresses. This list is currently protected by an external rw_lock and that looks like an overkill. There are only 2 writers to the list: bind()/bindx() calls, and BH processing of ASCONF-ACK chunks. These are already seriealized via the socket lock, so they will not step on each other. These are also relatively rare, so we should be good with RCU. The readers are varied and they are easily converted to RCU. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Sridhar Samdurala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[SCTP]: Add RCU synchronization around sctp_localaddr_listVlad Yasevich
sctp_localaddr_list is modified dynamically via NETDEV_UP and NETDEV_DOWN events, but there is not synchronization between writer (even handler) and readers. As a result, the readers can access an entry that has been freed and crash the sytem. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Sridhar Samdurala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-01SCTP: IPv4 mapped addr not returned in SCTPv6 accept()Dave Johnson
An accept() call on a SCTPv6 socket that returns due to connection of a IPv4 mapped peer will fill out the 'struct sockaddr' with a zero IPv6 address instead of the IPv4 mapped address of the peer. This is due to the v4mapped flag not getting copied into the new socket on accept() as well as a missing check for INET6 socket type in sctp_v4_to_sk_*addr(). Signed-off-by: Dave Johnson <djohnson@sw.starentnetworks.com> Cc: Srinivas Akkipeddi <sakkiped@starentnetworks.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2007-07-05SCTP: Add scope_id validation for link-local bindsVlad Yasevich
SCTP currently permits users to bind to link-local addresses, but doesn't verify that the scope id specified at bind matches the interface that the address is configured on. It was report that this can hang a system. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-04[SCTP]: Re-order SCTP initializations to avoid race with sctp_rcv()Sridhar Samudrala
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: cleanup extra semicolonsStephen Hemminger
Spring cleaning time... There seems to be a lot of places in the network code that have extra bogus semicolons after conditionals. Most commonly is a bogus semicolon after: switch() { } Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Use offsets for skb->{mac,network,transport}_header on 64bit ↵Arnaldo Carvalho de Melo
architectures With this we save 8 bytes per network packet, leaving a 4 bytes hole to be used in further shrinking work, likely with the offsetization of other pointers, such as ->{data,tail,end}, at the cost of adds, that were minimized by the usual practice of setting skb->{mac,nh,n}.raw to a local variable that is then accessed multiple times in each function, it also is not more expensive than before with regards to most of the handling of such headers, like setting one of these headers to another (transport to network, etc), or subtracting, adding to/from it, comparing them, etc. Now we have this layout for sk_buff on a x86_64 machine: [acme@mica net-2.6.22]$ pahole vmlinux sk_buff struct sk_buff { struct sk_buff * next; /* 0 8 */ struct sk_buff * prev; /* 8 8 */ struct rb_node rb; /* 16 24 */ struct sock * sk; /* 40 8 */ ktime_t tstamp; /* 48 8 */ struct net_device * dev; /* 56 8 */ /* --- cacheline 1 boundary (64 bytes) --- */ struct net_device * input_dev; /* 64 8 */ sk_buff_data_t transport_header; /* 72 4 */ sk_buff_data_t network_header; /* 76 4 */ sk_buff_data_t mac_header; /* 80 4 */ /* XXX 4 bytes hole, try to pack */ struct dst_entry * dst; /* 88 8 */ struct sec_path * sp; /* 96 8 */ char cb[48]; /* 104 48 */ /* cacheline 2 boundary (128 bytes) was 24 bytes ago*/ unsigned int len; /* 152 4 */ unsigned int data_len; /* 156 4 */ unsigned int mac_len; /* 160 4 */ union { __wsum csum; /* 4 */ __u32 csum_offset; /* 4 */ }; /* 164 4 */ __u32 priority; /* 168 4 */ __u8 local_df:1; /* 172 1 */ __u8 cloned:1; /* 172 1 */ __u8 ip_summed:2; /* 172 1 */ __u8 nohdr:1; /* 172 1 */ __u8 nfctinfo:3; /* 172 1 */ __u8 pkt_type:3; /* 173 1 */ __u8 fclone:2; /* 173 1 */ __u8 ipvs_property:1; /* 173 1 */ /* XXX 2 bits hole, try to pack */ __be16 protocol; /* 174 2 */ void (*destructor)(struct sk_buff *); /* 176 8 */ struct nf_conntrack * nfct; /* 184 8 */ /* --- cacheline 3 boundary (192 bytes) --- */ struct sk_buff * nfct_reasm; /* 192 8 */ struct nf_bridge_info *nf_bridge; /* 200 8 */ __u16 tc_index; /* 208 2 */ __u16 tc_verd; /* 210 2 */ dma_cookie_t dma_cookie; /* 212 4 */ __u32 secmark; /* 216 4 */ __u32 mark; /* 220 4 */ unsigned int truesize; /* 224 4 */ atomic_t users; /* 228 4 */ unsigned char * head; /* 232 8 */ unsigned char * data; /* 240 8 */ unsigned char * tail; /* 248 8 */ /* --- cacheline 4 boundary (256 bytes) --- */ unsigned char * end; /* 256 8 */ }; /* size: 264, cachelines: 5 */ /* sum members: 260, holes: 1, sum holes: 4 */ /* bit holes: 1, sum bit holes: 2 bits */ /* last cacheline: 8 bytes */ On 32 bits nothing changes, and pointers continue to be used with the compiler turning all this abstraction layer into dust. But there are some sk_buff validation tricks that are now possible, humm... :-) Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: unions of just one member don't get anything done, kill themArnaldo Carvalho de Melo
Renaming skb->h to skb->transport_header, skb->nh to skb->network_header and skb->mac to skb->mac_header, to match the names of the associated helpers (skb[_[re]set]_{transport,network,mac}_header). Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SCTP]: Eliminate some pointer attributions to the skb layer headersArnaldo Carvalho de Melo
2007-04-25[SCTP]: Introduce sctp_hdr()Arnaldo Carvalho de Melo
For consistency with all the other skb->h.raw accessors. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ipv6_hdr(), remove skb->nh.ipv6hArnaldo Carvalho de Melo
Now the skb->nh union has just one member, .raw, i.e. it is just like the skb->mac union, strange, no? I'm just leaving it like that till the transport layer is done with, when we'll rename skb->mac.raw to skb->mac_header (or ->mac_header_offset?), ditto for ->{h,nh}. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ip_hdr(), remove skb->nh.iphArnaldo Carvalho de Melo
2007-04-25[SK_BUFF] ipv6: More skb_reset_network_header conversions related to skb_pullArnaldo Carvalho de Melo
Now related to this form: skb->nh.ipv6h = (struct ipv6hdr *)skb_put(skb, length); That, as the others, is done when skb->tail is still equal to skb->data, making the conversion to skb_reset_network_header possible. Also one more case equivalent to skb->nh.raw = skb->data, of this form: iph = (struct ipv6hdr *)skb->data; <SNIP> skb->nh.ipv6h = iph; Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-08[SCTP] ipv6: inconsistent lock state ipv6_add_addr/sctp_v6_copy_addrlistJarek Poplawski
lockdep found that dev->lock taken from softirq in ipv6_add_addr is also taken in sctp_v6_copy_addrlist with softirqs enabled, so lockup is possible. Noticed-by: Simon Arlott <simon@arlott.org> Signed-off-by: Jarek Poplawski <jarkao2@o2.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
