path: root/net/sctp/bind_addr.c
2011-05-21sctp: Fix build failure.David S. Miller
Commit c182f90bc1f22ce5039b8722e45621d5f96862c2 ("SCTP: fix race between sctp_bind_addr_free() and sctp_bind_addr_conflict()") and commit 1231f0baa547a541a7481119323b7f964dda4788 ("net,rcu: convert call_rcu(sctp_local_addr_free) to kfree_rcu()"), happening in different trees, introduced a build failure. Simply make the SCTP race fix use kfree_rcu() too. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits) macvlan: fix panic if lowerdev in a bond tg3: Add braces around 5906 workaround. tg3: Fix NETIF_F_LOOPBACK error macvlan: remove one synchronize_rcu() call networking: NET_CLS_ROUTE4 depends on INET irda: Fix error propagation in ircomm_lmp_connect_response() irda: Kill set but unused variable 'bytes' in irlan_check_command_param() irda: Kill set but unused variable 'clen' in ircomm_connect_indication() rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport() be2net: Kill set but unused variable 'req' in lancer_fw_download() irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication() atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined. rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer(). rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler() rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection() rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window() pkt_sched: Kill set but unused variable 'protocol' in tc_classify() isdn: capi: Use pr_debug() instead of ifdefs. tg3: Update version to 3.119 tg3: Apply rx_discards fix to 5719/5720 ... Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c as per Davem.
2011-05-19SCTP: fix race between sctp_bind_addr_free() and sctp_bind_addr_conflict()Jacek Luczak
During the sctp_close() call, we do not use rcu primitives to destroy the address list attached to the endpoint. At the same time, we do the removal of addresses from this list before attempting to remove the socket from the port hash As a result, it is possible for another process to find the socket in the port hash that is in the process of being closed. It then proceeds to traverse the address list to find the conflict, only to have that address list suddenly disappear without rcu() critical section. Fix issue by closing address list removal inside RCU critical section. Race can result in a kernel crash with general protection fault or kernel NULL pointer dereference: kernel: general protection fault: 0000 [#1] SMP kernel: RIP: 0010:[<ffffffffa02f3dde>] [<ffffffffa02f3dde>] sctp_bind_addr_conflict+0x64/0x82 [sctp] kernel: Call Trace: kernel: [<ffffffffa02f415f>] ? sctp_get_port_local+0x17b/0x2a3 [sctp] kernel: [<ffffffffa02f3d45>] ? sctp_bind_addr_match+0x33/0x68 [sctp] kernel: [<ffffffffa02f4416>] ? sctp_do_bind+0xd3/0x141 [sctp] kernel: [<ffffffffa02f5030>] ? sctp_bindx_add+0x4d/0x8e [sctp] kernel: [<ffffffffa02f5183>] ? sctp_setsockopt_bindx+0x112/0x4a4 [sctp] kernel: [<ffffffff81089e82>] ? generic_file_aio_write+0x7f/0x9b kernel: [<ffffffffa02f763e>] ? sctp_setsockopt+0x14f/0xfee [sctp] kernel: [<ffffffff810c11fb>] ? do_sync_write+0xab/0xeb kernel: [<ffffffff810e82ab>] ? fsnotify+0x239/0x282 kernel: [<ffffffff810c2462>] ? alloc_file+0x18/0xb1 kernel: [<ffffffff8134a0b1>] ? compat_sys_setsockopt+0x1a5/0x1d9 kernel: [<ffffffff8134aaf1>] ? compat_sys_socketcall+0x143/0x1a4 kernel: [<ffffffff810467dc>] ? sysenter_dispatch+0x7/0x32 Signed-off-by: Jacek Luczak <luczak.jacek@gmail.com> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> CC: Eric Dumazet <eric.dumazet@gmail.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-07net,rcu: convert call_rcu(sctp_local_addr_free) to kfree_rcu()Lai Jiangshan
The rcu callback sctp_local_addr_free() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(sctp_local_addr_free). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-17net: remove INIT_RCU_HEAD() usageAlexey Dobriyan
call_rcu() will unconditionally reinitialize RCU head anyway. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-04sctp: Sysctl configuration for IPv4 Address ScopingBhaskar Dutta
This patch introduces a new sysctl option to make IPv4 Address Scoping configurable <draft-stewart-tsvwg-sctp-ipv4-00.txt>. In networking environments where DNAT rules in iptables prerouting chains convert destination IP's to link-local/private IP addresses, SCTP connections fail to establish as the INIT chunk is dropped by the kernel due to address scope match failure. For example to support overlapping IP addresses (same IP address with different vlan id) a Layer-5 application listens on link local IP's, and there is a DNAT rule that maps the destination IP to a link local IP. Such applications never get the SCTP INIT if the address-scoping draft is strictly followed. This sysctl configuration allows SCTP to function in such unconventional networking environments. Sysctl options: 0 - Disable IPv4 address scoping draft altogether 1 - Enable IPv4 address scoping (default, current behavior) 2 - Enable address scoping but allow IPv4 private addresses in init/init-ack 3 - Enable address scoping but allow IPv4 link local address in init/init-ack Signed-off-by: Bhaskar Dutta <bhaskar.dutta@globallogic.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2008-10-01sctp: try harder to figure out address family when checking wildcardsVlad Yasevich
sctp_is_any() function that is used to check for wildcard addresses only looks at the address itself to determine the address family. This function is used in the API to check the address passed in from the user. If the user simply zerroes out the sockaddr_storage and pass that in, we'll end up failing. So, let's try harder to determine the address family by also checking the socket if it's possible. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2008-07-18sctp: Support ipv6only AF_INET6 sockets.Vlad Yasevich
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-12[SCTP]: "list_for_each()" -> "list_for_each_entry()" where appropriate.Robert P. J. Day
Replacing (almost) all invocations of list_for_each() with list_for_each_entry() tightens up the code and allows for the deletion of numerous list iterator variables that are no longer necessary. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-11[SCTP]: Fix local_addr deletions during list traversals.Chidambar 'ilLogict' Zinnoury
Since the lists are circular, we need to explicitely tag the address to be deleted since we might end up freeing the list head instead. This fixes some interesting SCTP crashes. Signed-off-by: Chidambar 'ilLogict' Zinnoury <illogict@online.fr> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05[SCTP]: Stop claiming that this is a "reference implementation"Vlad Yasevich
I was notified by Randy Stewart that lksctp claims to be "the reference implementation". First of all, "the refrence implementation" was the original implementation of SCTP in usersapce written ty Randy and a few others. Second, after looking at the definiton of 'reference implementation', we don't really meet the requirements. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2008-01-28[SCTP]: Implement ADD-IP special case processing for ABORT chunkVlad Yasevich
ADD-IP spec has a special case for processing ABORTs: F4) ... One special consideration is that ABORT Chunks arriving destined to the IP address being deleted MUST be ignored (see Section 5.3.1 for further details). Check if the address we received on is in the DEL state, and if so, ignore the ABORT. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[SCTP]: Change use_as_src into a full address stateVlad Yasevich
2007-12-07[SCTP]: Fix the bind_addr info during migration.Vlad Yasevich
During accept/migrate the code attempts to copy the addresses from the parent endpoint to the new endpoint. However, if the parent was bound to a wildcard address, then we end up pointlessly copying all of the current addresses on the system. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-07SCTP: Update RCU handling during the ADD-IP caseVlad Yasevich
After learning more about rcu, it looks like the ADD-IP hadling doesn't need to call call_rcu_bh. All the rcu critical sections use rcu_read_lock, so using call_rcu_bh is wrong here. Now, restore the local_bh_disable() code blocks and use normal call_rcu() calls. Also restore the missing return statement. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2007-09-26fix sctp_del_bind_addr() last argument typeAl Viro
It gets pointer to fastcall function, expects a pointer to normal one and calls the sucker. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-16[SCTP]: Convert bind_addr_list locking to RCUVlad Yasevich
Since the sctp_sockaddr_entry is now RCU enabled as part of the patch to synchronize sctp_localaddr_list, it makes sense to change all handling of these entries to RCU. This includes the sctp_bind_addrs structure and it's list of bound addresses. This list is currently protected by an external rw_lock and that looks like an overkill. There are only 2 writers to the list: bind()/bindx() calls, and BH processing of ASCONF-ACK chunks. These are already seriealized via the socket lock, so they will not step on each other. These are also relatively rare, so we should be good with RCU. The readers are varied and they are easily converted to RCU. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Sridhar Samdurala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-16[SCTP]: Add RCU synchronization around sctp_localaddr_listVlad Yasevich
sctp_localaddr_list is modified dynamically via NETDEV_UP and NETDEV_DOWN events, but there is not synchronization between writer (even handler) and readers. As a result, the readers can access an entry that has been freed and crash the sytem. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Sridhar Samdurala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] SCTP: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: ->a_h is gone now.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: sctp_make_asconf_update_ip() and sctp_find_unmatch_addr().Al Viro
... switched to taking and returning pointers to net-endian sctp_addr resp. Together, since the only user of sctp_find_unmatch_addr() just passes its value to sctp_make_asconf_update_ip(). sctp_make_asconf_update_ip() is actually endian-agnostic. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Trivial parts of a_h -> a switch.Al Viro
2006-12-02[SCTP]: sctp_copy_one_addr() switched to net-endian.Al Viro
2006-12-02[SCTP]: Switch ->from_addr_param() to net-endian.Al Viro
2006-12-02[SCTP]: Switch sctp_add_bind_addr() to net-endian.Al Viro
2006-12-02[SCTP]: Switch sctp_del_bind_addr() to net-endian.Al Viro
Callers adjusted. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Switch sctp_bind_addr_match() to net-endian.Al Viro
2006-12-02[SCTP]: Switch ->cmp_addr() and sctp_cmp_addr_exact() to net-endian.Al Viro
instances of ->cmp_addr() are fine with switching both arguments to net-endian; callers other than in sctp_cmp_addr_exact() (both as ->cmp_addr(...) and direct calls of instances) adjusted; sctp_cmp_addr_exact() switched to net-endian itself and adjustment is done in its callers Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP] embedded sctp_addr: net-endian mirrorsAl Viro
Add sctp_chunk->source, sctp_sockaddr_entry->a, sctp_transport->ipaddr and sctp_transport->saddr, maintain them as net-endian mirrors of their host-endian counterparts. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP]: Beginning of conversion to net-endian for embedded sctp_addr.Al Viro
Part 1: rename sctp_chunk->source, sctp_sockaddr_entry->a, sctp_transport->ipaddr and sctp_transport->saddr (to ..._h) The next patch will reintroduce these fields and keep them as net-endian mirrors of the original (renamed) ones. Split in two patches to make sure that we hadn't forgotten any instanes. Later in the series we'll eliminate uses of host-endian variants (basically switching users to net-endian counterparts as we progress through that mess). Then host-endian ones will die. Other embedded host-endian sctp_addr will be easier to switch directly, so we leave them alone for now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[SCTP] bug: sctp_find_unmatch_addr() compares net-endian to host-endianAl Viro
2006-07-21[SCTP]: ADDIP: Don't use an address as source until it is ASCONF-ACKedSridhar Samudrala
This implements Rules D1 and D4 of Sec 4.3 in the ADDIP draft. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-11[SCTP]: __nocast annotationsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
