t_new rather obfuscates things where everyone else is using actual
function names instead of that macro, so replace it with kzalloc,
which is the function t_new wraps.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
The sctp_bind_addr structure has a 'malloced' member that is
always set to 0, thus in sctp_bind_addr_free() the kfree()
part can never be called. This part is embedded into
sctp_ep_common anyway and never alloced.
struct net will be needed shortly when the tunables are made per network
namespace.
- Move the address lists into struct net
- Add per network namespace initialization and cleanup
- Pass around struct net so it is everywhere I need it.
- Rename all of the global variable references into references
to the variables moved into struct net
Unnecessary casts of void * clutter the code.
These are the remainder casts after several specific
patches to remove netdev_priv and dev_priv.
Done via coccinelle script:
$ cat cast_void_pointer.cocci
type T;
T *pt;
void *pv;
- pt = (T *)pv;
+ pt = pv;
Acked-by: Paul Moore <paul.moore@hp.com>
Signed-off-by: David S. Miller <davem@conan.davemloft.net>
SCTP reconfigure the IP addresses in the association by using
ASCONF chunks as mentioned in RFC5061. For example, we can
start to use the newly configured IP address in the existing
association. This patch implements automatic ASCONF operation
in the SCTP stack with address events in the host computer,
which is called auto_asconf.
Signed-off-by: Michio Honda <micchie@sfc.wide.ad.jp>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Acked-by: Wei Yongjun <yjwei@cn.fujitsu.com>
Commit c182f90bc1f22ce5039b8722e45621d5f96862c2 ("SCTP: fix race
between sctp_bind_addr_free() and sctp_bind_addr_conflict()") and
commit 1231f0baa547a541a7481119323b7f964dda4788 ("net,rcu: convert
call_rcu(sctp_local_addr_free) to kfree_rcu()"), happening in
different trees, introduced a build failure.
Simply make the SCTP race fix use kfree_rcu() too.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits)
macvlan: fix panic if lowerdev in a bond
tg3: Add braces around 5906 workaround.
tg3: Fix NETIF_F_LOOPBACK error
macvlan: remove one synchronize_rcu() call
networking: NET_CLS_ROUTE4 depends on INET
irda: Fix error propagation in ircomm_lmp_connect_response()
irda: Kill set but unused variable 'bytes' in irlan_check_command_param()
irda: Kill set but unused variable 'clen' in ircomm_connect_indication()
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport()
be2net: Kill set but unused variable 'req' in lancer_fw_download()
irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication()
atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined.
rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer().
rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler()
rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection()
rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window()
pkt_sched: Kill set but unused variable 'protocol' in tc_classify()
isdn: capi: Use pr_debug() instead of ifdefs.
tg3: Update version to 3.119
tg3: Apply rx_discards fix to 5719/5720
Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c
as per Davem.
During the sctp_close() call, we do not use rcu primitives to
destroy the address list attached to the endpoint. At the same
time, we do the removal of addresses from this list before
attempting to remove the socket from the port hash
As a result, it is possible for another process to find the socket
in the port hash that is in the process of being closed. It then
proceeds to traverse the address list to find the conflict, only
to have that address list suddenly disappear without rcu() critical
section.
Fix issue by closing address list removal inside RCU critical
section.
Race can result in a kernel crash with general protection fault or
kernel NULL pointer dereference:
kernel: general protection fault: 0000 [#1] SMP
kernel: RIP: 0010:[<ffffffffa02f3dde>] [<ffffffffa02f3dde>] sctp_bind_addr_conflict+0x64/0x82 [sctp]
kernel: Call Trace:
kernel: [<ffffffffa02f415f>] ? sctp_get_port_local+0x17b/0x2a3 [sctp]
kernel: [<ffffffffa02f3d45>] ? sctp_bind_addr_match+0x33/0x68 [sctp]
kernel: [<ffffffffa02f4416>] ? sctp_do_bind+0xd3/0x141 [sctp]
kernel: [<ffffffffa02f5030>] ? sctp_bindx_add+0x4d/0x8e [sctp]
kernel: [<ffffffffa02f5183>] ? sctp_setsockopt_bindx+0x112/0x4a4 [sctp]
kernel: [<ffffffff81089e82>] ? generic_file_aio_write+0x7f/0x9b
kernel: [<ffffffffa02f763e>] ? sctp_setsockopt+0x14f/0xfee [sctp]
kernel: [<ffffffff810c11fb>] ? do_sync_write+0xab/0xeb
kernel: [<ffffffff810e82ab>] ? fsnotify+0x239/0x282
kernel: [<ffffffff810c2462>] ? alloc_file+0x18/0xb1
kernel: [<ffffffff8134a0b1>] ? compat_sys_setsockopt+0x1a5/0x1d9
kernel: [<ffffffff8134aaf1>] ? compat_sys_socketcall+0x143/0x1a4
kernel: [<ffffffff810467dc>] ? sysenter_dispatch+0x7/0x32
Signed-off-by: Jacek Luczak <luczak.jacek@gmail.com>
Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com>
CC: Eric Dumazet <eric.dumazet@gmail.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
The rcu callback sctp_local_addr_free() just calls a kfree(),
so we use kfree_rcu() instead of the call_rcu(sctp_local_addr_free).
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
call_rcu() will unconditionally reinitialize RCU head anyway.
This patch introduces a new sysctl option to make IPv4 Address Scoping
configurable <draft-stewart-tsvwg-sctp-ipv4-00.txt>.
In networking environments where DNAT rules in iptables prerouting
chains convert destination IP's to link-local/private IP addresses,
SCTP connections fail to establish as the INIT chunk is dropped by the
kernel due to address scope match failure.
For example to support overlapping IP addresses (same IP address with
different vlan id) a Layer-5 application listens on link local IP's,
and there is a DNAT rule that maps the destination IP to a link local
IP. Such applications never get the SCTP INIT if the address-scoping
draft is strictly followed.
This sysctl configuration allows SCTP to function in such
unconventional networking environments.
Sysctl options:
0 - Disable IPv4 address scoping draft altogether
1 - Enable IPv4 address scoping (default, current behavior)
2 - Enable address scoping but allow IPv4 private addresses in init/init-ack
3 - Enable address scoping but allow IPv4 link local address in init/init-ack
Signed-off-by: Bhaskar Dutta <bhaskar.dutta@globallogic.com>
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
sctp_is_any() function that is used to check for wildcard addresses
only looks at the address itself to determine the address family.
This function is used in the API to check the address passed in from
the user. If the user simply zerroes out the sockaddr_storage and
pass that in, we'll end up failing. So, let's try harder to determine
the address family by also checking the socket if it's possible.
Replacing (almost) all invocations of list_for_each() with
list_for_each_entry() tightens up the code and allows for the deletion
of numerous list iterator variables that are no longer necessary.
Since the lists are circular, we need to explicitely tag
the address to be deleted since we might end up freeing
the list head instead. This fixes some interesting SCTP
crashes.
Signed-off-by: Chidambar 'ilLogict' Zinnoury <illogict@online.fr>
I was notified by Randy Stewart that lksctp claims to be
"the reference implementation". First of all, "the
refrence implementation" was the original implementation
of SCTP in usersapce written ty Randy and a few others.
Second, after looking at the definiton of 'reference implementation',
we don't really meet the requirements.
ADD-IP spec has a special case for processing ABORTs:
F4) ... One special consideration is that ABORT
Chunks arriving destined to the IP address being deleted MUST be
ignored (see Section 5.3.1 for further details).
Check if the address we received on is in the DEL state, and if
so, ignore the ABORT.
During accept/migrate the code attempts to copy the addresses from
the parent endpoint to the new endpoint. However, if the parent
was bound to a wildcard address, then we end up pointlessly copying
all of the current addresses on the system.
After learning more about rcu, it looks like the ADD-IP hadling
doesn't need to call call_rcu_bh. All the rcu critical sections
use rcu_read_lock, so using call_rcu_bh is wrong here.
Now, restore the local_bh_disable() code blocks and use normal
call_rcu() calls. Also restore the missing return statement.
It gets pointer to fastcall function, expects a pointer to normal
one and calls the sucker.
Since the sctp_sockaddr_entry is now RCU enabled as part of
the patch to synchronize sctp_localaddr_list, it makes sense to
change all handling of these entries to RCU. This includes the
sctp_bind_addrs structure and it's list of bound addresses.
This list is currently protected by an external rw_lock and that
looks like an overkill. There are only 2 writers to the list:
bind()/bindx() calls, and BH processing of ASCONF-ACK chunks.
These are already seriealized via the socket lock, so they will
not step on each other. These are also relatively rare, so we
should be good with RCU.
The readers are varied and they are easily converted to RCU.
Acked-by: Sridhar Samdurala <sri@us.ibm.com>
sctp_localaddr_list is modified dynamically via NETDEV_UP
and NETDEV_DOWN events, but there is not synchronization
between writer (even handler) and readers. As a result,
the readers can access an entry that has been freed and
crash the sytem.
After Al Viro (finally) succeeded in removing the sched.h #include in module.h
recently, it makes sense again to remove other superfluous sched.h includes.
There are quite a lot of files which include it but don't actually need
anything defined in there. Presumably these includes were once needed for
macros that used to live in sched.h, but moved to other header files in the
course of cleaning it up.
To ease the pain, this time I did not fiddle with any header files and only
removed #includes from .c-files, which tend to cause less trouble.
Compile tested against 2.6.20-rc2 and 2.6.20-rc2-mm2 (with offsets) on alpha,
arm, i386, ia64, mips, powerpc, and x86_64 with allnoconfig, defconfig,
allmodconfig, and allyesconfig as well as a few randconfigs on x86_64 and all
configs in arch/arm/configs on arm. I also checked that no new warnings were
introduced by the patch (actually, some warnings are removed that were emitted
by unnecessarily included header files).
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
... switched to taking and returning pointers to net-endian
sctp_addr resp. Together, since the only user of sctp_find_unmatch_addr()
just passes its value to sctp_make_asconf_update_ip().
sctp_make_asconf_update_ip() is actually endian-agnostic.
Callers adjusted.
Callers adjusted.
instances of ->cmp_addr() are fine with switching both arguments
to net-endian; callers other than in sctp_cmp_addr_exact() (both
as ->cmp_addr(...) and direct calls of instances) adjusted;
sctp_cmp_addr_exact() switched to net-endian itself and adjustment
is done in its callers
Add sctp_chunk->source, sctp_sockaddr_entry->a, sctp_transport->ipaddr
and sctp_transport->saddr, maintain them as net-endian mirrors of
their host-endian counterparts.
Part 1: rename sctp_chunk->source, sctp_sockaddr_entry->a,
sctp_transport->ipaddr and sctp_transport->saddr (to ..._h)
The next patch will reintroduce these fields and keep them as
net-endian mirrors of the original (renamed) ones. Split in
two patches to make sure that we hadn't forgotten any instanes.
Later in the series we'll eliminate uses of host-endian variants
(basically switching users to net-endian counterparts as we
progress through that mess). Then host-endian ones will die.
Other embedded host-endian sctp_addr will be easier to switch
directly, so we leave them alone for now.
This implements Rules D1 and D4 of Sec 4.3 in the ADDIP draft.
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
- added typedef unsigned int __nocast gfp_t;
- replaced __nocast uses for gfp flags with gfp_t - it gives exactly
the same warnings as far as sparse is concerned, doesn't change
generated code (from gcc point of view we replaced unsigned int with
typedef) and documents what's going on far better.
infrastructure for it.
Let it rip!
