path: root/net/sctp/associola.c
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-30[SCTP]: Remove temporary associations from backlog and hash.Vlad Yasevich
Every time SCTP creates a temporary association, the stack hashes it, puts it on a list of endpoint associations and increments the backlog. However, the lifetime of a temporary association is the processing time of a current packet and it's destroyed after that. In fact, we don't really want anyone else finding this association. There is no reason to do this extra work. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-21[SCTP]: Verify all the paths to a peer via heartbeat before using them.Sridhar Samudrala
This patch implements Path Initialization procedure as described in Sec 2.36 of RFC4460. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[SCTP]: Update SCTP_PEER_ADDR_PARAMS socket option to the latest api draft.Frank Filz
This patch adds support to set/get heartbeat interval, maximum number of retransmissions, pathmtu, sackdelay time for a particular transport/ association/socket as per the latest SCTP sockets api draft11. Signed-off-by: Frank Filz <ffilz@us.ibm.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-11[SCTP]: Include ulpevents in socket receive buffer accounting.Neil Horman
Also introduces a sysctl option to configure the receive buffer accounting policy to be either at socket or association level. Default is all the associations on the same socket share the receive buffer. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-11[SCTP]: Remove timeouts[] array from sctp_endpoint.Vladislav Yasevich
The socket level timeout values are maintained in sctp_sock and association level timeouts are in sctp_association. So there is no need for ep->timeouts. Signed-off-by: Vladislav Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-08[NET]: kfree cleanupJesper Juhl
From: Jesper Juhl <jesper.juhl@gmail.com> This is the net/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in net/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Arnaldo Carvalho de Melo <acme@conectiva.com.br> Acked-by: Marcel Holtmann <marcel@holtmann.org> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-11[SCTP]: __nocast annotationsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-08[SCTP]: Use struct list_head for chunk lists, not sk_buff_head.David S. Miller
2005-06-20[SCTP] sctp_connectx() API supportFrank Filz
Implements sctp_connectx() as defined in the SCTP sockets API draft by tunneling the request through a setsockopt(). Signed-off-by: Frank Filz <ffilzlnx@us.ibm.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
