path: root/net/sched
2009-05-02net: Only store high 16 bits of kernel generated filter prioritiesRobert Love
The kernel should only be using the high 16 bits of a kernel generated priority. Filter priorities in all other cases only use the upper 16 bits of the u32 'prio' field of 'struct tcf_proto', but when the kernel generates the priority of a filter is saves all 32 bits which can result in incorrect lookup failures when a filter needs to be deleted or modified. Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-20net: sch_netem: Fix an inconsistency in ingress netem timestamps.Jarek Poplawski
Alex Sidorenko reported: "while experimenting with 'netem' we have found some strange behaviour. It seemed that ingress delay as measured by 'ping' command shows up on some hosts but not on others. After some investigation I have found that the problem is that skbuff->tstamp field value depends on whether there are any packet sniffers enabled. That is: - if any ptype_all handler is registered, the tstamp field is as expected - if there are no ptype_all handlers, the tstamp field does not show the delay" This patch prevents unnecessary update of tstamp in dev_queue_xmit_nit() on ingress path (with act_mirred) adding a check, so minimal overhead on the fast path, but only when sniffers etc. are active. Since netem at ingress seems to logically emulate a network before a host, tstamp is zeroed to trigger the update and pretend delays are from the outside. Reported-by: Alex Sidorenko <alexandre.sidorenko@hp.com> Tested-by: Alex Sidorenko <alexandre.sidorenko@hp.com> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-13netsched: Allow meta match on vlan tag on receiveStephen Hemminger
When vlan acceleration is used on receive, the vlan tag is maintained outside of the skb data. The existing vlan tag match only works on TX path because it uses vlan_get_tag which tests for VLAN_HW_TX_ACCEL. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-21net/*: use linux/kernel.h swap()Ilpo Järvinen
tcp_sack_swap seems unnecessary so I pushed swap to the caller. Also removed comment that seemed then pointless, and added include when not already there. Compile tested. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-15pkt_sched: Change misleading code in class delete.Jarek Poplawski
While looking for a possible reason of bugzilla report on HTB oops: http://bugzilla.kernel.org/show_bug.cgi?id=12858 I found the code in htb_delete calling htb_destroy_class on zero refcount is very misleading: it can suggest this is a common path, and destroy is called under sch_tree_lock. Actually, this can never happen like this because before deletion cops->get() is done, and after delete a class is still used by tclass_notify. The class destroy is always called from cops->put(), so without sch_tree_lock. This doesn't mean much now (since 2.6.27) because all vulnerable calls were moved from htb_destroy_class to htb_delete, but there was a bug in older kernels. The same change is done for other classful scheds, which, it seems, didn't have similar locking problems here. Reported-by: m0sia <m0sia@m0sia.ru> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-05Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/tokenring/tmspci.c drivers/net/ucc_geth_mii.c
2009-03-04pkt_sched: act_police: Fix a rate estimator test.Jarek Poplawski
A commit c1b56878fb68e9c14070939ea4537ad4db79ffae "tc: policing requires a rate estimator" introduced a test which invalidates previously working configs, based on examples from iproute2: doc/actions/actions-general. This is too rigorous: a rate estimator is needed only when police's "avrate" option is used. Reported-by: Joao Correia <joaomiguelcorreia@gmail.com> Diagnosed-by: John Dykstra <john.dykstra1@gmail.com> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-01Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-tx.c net/8021q/vlan_core.c net/core/dev.c
2009-02-27pkt_sched: sch_drr: Fix oops in drr_change_class.Jarek Poplawski
drr_change_class lacks a check for NULL of tca[TCA_OPTIONS], so oops is possible. Reported-by: Denys Fedoryschenko <denys@visp.net.lb> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-10pkt_sched: sch_multiq: Change errno on non-multiqueue devices use.Jarek Poplawski
Current "RTNETLINK answers: Invalid argument" warning, while trying to add multiq qdisc to non-multiqueue device, isn't very helpful and some of these devs can be changed btw., so let's use a better errno. With feedback from Stephen Hemminger <shemminger@vyatta.com> Reported-by: Badalian Vyacheslav <slavon@bigtelecom.ru> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01pkt_sched: sch_htb: Use workqueue to schedule after too many events.Jarek Poplawski
Patrick McHardy <kaber@trash.net> suggested using a workqueue instead of hrtimers to trigger netif_schedule() when there is a problem with setting exact time of this event: 'The differnce - yeah, it shouldn't make much, mainly wake up the qdisc earlier (but not too early) after "too many events" occured _and_ no further enqueue events wake up the qdisc anyways.' Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01pkt_sched: sch_htb: Warn on too many events.Jarek Poplawski
Let's get some info on possible config problems. This patch brings back an old warning, but is printed only once now. With feedback from Patrick McHardy <kaber@trash.net> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01pkt_sched: sch_hfsc: sch_htb: Add non-work-conserving warning handler.Jarek Poplawski
Patrick McHardy <kaber@trash.net> suggested: > How about making this flag and the warning message (in a out-of-line > function) globally available? Other qdiscs (f.i. HFSC) can't deal with > inner non-work-conserving qdiscs as well. This patch uses qdisc->flags field of "suspected" child qdisc. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-12pkt_sched: sch_htb: Break all htb_do_events() after 2 jiffiesJarek Poplawski
Currently htb_do_events() breaks events recounting for a level after 2 jiffies, but there is no reason to repeat this for next levels and increase delays even more (with softirqs disabled). htb_dequeue_tree() can add to this too, btw. In such a case q->now time is invalid anyway. Thanks to Patrick McHardy for spotting an error around earlier version of this patch. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-12pkt_sched: sch_htb: Consider used jiffies in htb_do_events()Jarek Poplawski
Next event time should consider jiffies used for recounting. Otherwise qdisc_watchdog_schedule() triggers hrtimer immediately with the event in the past, and may cause very high ksoftirqd cpu usage (if highres is on). There is also removed checking "event" for zero in htb_dequeue(): it's always true in this place. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (84 commits) wimax: fix kernel-doc for debufs_dentry member of struct wimax_dev net: convert pegasus driver to net_device_ops bnx2x: Prevent eeprom set when driver is down net: switch kaweth driver to netdevops pcnet32: round off carrier watch timer i2400m/usb: wrap USB power saving in #ifdef CONFIG_PM wimax: testing for rfkill support should also test for CONFIG_RFKILL_MODULE wimax: fix kconfig interactions with rfkill and input layers wimax: fix '#ifndef CONFIG_BUG' layout to avoid warning r6040: bump release number to 0.20 r6040: warn about MAC address being unset r6040: check PHY status when bringing interface up r6040: make printks consistent with DRV_NAME gianfar: Fixup use of BUS_ID_SIZE mlx4_en: Returning real Max in get_ringparam mlx4_en: Consider inline packets on completion netdev: bfin_mac: enable bfin_mac net dev driver for BF51x qeth: convert to net_device_ops vlan: add neigh_setup dm9601: warn on invalid mac address ...
2009-01-08remove lots of double-semicolonsFernando Carrijo
Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: Theodore Ts'o <tytso@mit.edu> Acked-by: Mark Fasheh <mfasheh@suse.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: James Morris <jmorris@namei.org> Acked-by: Casey Schaufler <casey@schaufler-ca.com> Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06sch_teql: convert to net_device_opsStephen Hemminger
Convert this driver to net_device_ops. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-05pkt_sched: cls_u32: Fix locking in u32_change()Jarek Poplawski
New nodes are inserted in u32_change() under rtnl_lock() with wmb(), so without tcf_tree_lock() like in other classifiers (e.g. cls_fw). This isn't enough without rmb() on the read side, but on the other hand adding such barriers doesn't give any savings, so the lock is added instead. Reported-by: m0sia <m0sia@plotinka.ru> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-05Revert "net: Fix for initial link state in 2.6.28"David S. Miller
This reverts commit 22604c866889c4b2e12b73cbf1683bda1b72a313. We can't fix this issue in this way, because we now can try to take the dev_base_lock rwlock as a writer in software interrupt context and that is not allowed without major surgery elsewhere. This initial link state problem needs to be solved in some other way. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-04net: Fix for initial link state in 2.6.28Michael Marineau
From: Michael Marineau <mike@marineau.org> Commit b47300168e770b60ab96c8924854c3b0eb4260eb "Do not fire linkwatch events until the device is registered." was made as a workaround for drivers that call netif_carrier_off before registering the device. Unfortunately this causes these drivers to incorrectly report their link status as IF_OPER_UNKNOWN which can falsely set the IFF_RUNNING flag when the interface is first brought up. This issues was previously pointed out[1] but was dismissed saying that IFF_RUNNING is not related to the link status. From my digging IFF_RUNNING, as reported to userspace, is based on the link state. It is set based on __LINK_STATE_START and IF_OPER_UP or IF_OPER_UNKNOWN. See [2], [3], and [4]. (Whether or not the kernel has IFF_RUNNING set in flags is not reported to user space so it may well be independent of the link, I don't know if and when it may get set.) The end result depends slightly depending on the driver. The the two I tested were e1000e and b44. With e1000e if the system is booted without a network cable attached the interface will falsely report RUNNING when it is brought up causing NetworkManager to attempt to start it and eventually time out. With b44 when the system is booted with a network cable attached and brought up with dhcpcd it will time out the first time. The attached patch that will still set the operstate variable correctly to IF_OPER_UP/DOWN/etc when linkwatch_fire_event is called but then return rather than skipping the linkwatch_fire_event call entirely as the previous fix did. (sorry it isn't inline, I don't have a patch friendly email client at the moment) Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-29cls_cgroup: clean up KconfigLi Zefan
cls_cgroup can't be compiled as a module, since it's not supported by cgroup. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-29cls_cgroup: clean up for cgroup partLi Zefan
- It's better to use container_of() instead of casting cgroup_subsys_state * to cgroup_cls_state *. - Add helper function task_cls_state(). - Rename net_cls_state() to cgrp_cls_state(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-29cls_cgroup: fix an oops when removing a cgroupLi Zefan
When removing a cgroup, an oops was triggered immediately. The cause is wrong kfree() in cgrp_destroy(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1429 commits) net: Allow dependancies of FDDI & Tokenring to be modular. igb: Fix build warning when DCA is disabled. net: Fix warning fallout from recent NAPI interface changes. gro: Fix potential use after free sfc: If AN is enabled, always read speed/duplex from the AN advertising bits sfc: When disabling the NIC, close the device rather than unregistering it sfc: SFT9001: Add cable diagnostics sfc: Add support for multiple PHY self-tests sfc: Merge top-level functions for self-tests sfc: Clean up PHY mode management in loopback self-test sfc: Fix unreliable link detection in some loopback modes sfc: Generate unique names for per-NIC workqueues 802.3ad: use standard ethhdr instead of ad_header 802.3ad: generalize out mac address initializer 802.3ad: initialize ports LACPDU from const initializer 802.3ad: remove typedef around ad_system 802.3ad: turn ports is_individual into a bool 802.3ad: turn ports is_enabled into a bool 802.3ad: make ntt bool ixgbe: Fix set_ringparam in ixgbe to use the same memory pools. ... Fixed trivial IPv4/6 address printing conflicts in fs/cifs/connect.c due to the conversion to %pI (in this networking merge) and the addition of doing IPv6 addresses (from the earlier merge of CIFS).
2008-12-25Merge branch 'next' into for-linusJames Morris
2008-12-22pkt_sched: Remove smp_wmb() in qdisc_watchdog()Jarek Poplawski
While implementing a TCQ_F_THROTTLED flag there was used an smp_wmb() in qdisc_watchdog(), but since this flag is practically used only in sch_netem(), and since it's not even clear what reordering is avoided here (TCQ_F_THROTTLED vs. __QDISC_STATE_SCHED?) it seems the barrier could be safely removed. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-21pkt_sched: Annotate uninitialized var in sfq_enqueue()Jarek Poplawski
Some gcc versions warn that ret may be used uninitialized in sfq_enqueue(). It's a false positive, so let's annotate this. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-15Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/e1000e/ich8lan.c
2008-12-15SCHED: netem: Correct documentation comment in code.Jesper Dangaard Brouer
The netem simulator is no longer limited by Linux timer resolution HZ. Not since Patrick McHardy changed the QoS system to use hrtimer. Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-09pkt_sched: sch_htb: Optimize WARN_ONs in htb_dequeue_tree() etc.Jarek Poplawski
We can skip WARN_ON() in htb_dequeue_tree() because there should be always a similar warning from htb_lookup_leaf() earlier. The first WARN_ON() in in htb_lookup_leaf() is changed to BUG_ON() because most likly this should end with oops anyway. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-09pkt_sched: sch_htb: Optimize htb_find_next_upper()Jarek Poplawski
htb_id_find_next_upper() is usually called to find a class with next id after some previously removed class, so let's move a check for equality to the end: it's the least likely here. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-04Merge branch 'master' into nextJames Morris
Conflicts: fs/nfsd/nfs4recover.c Manually fixed above to use new creds API functions, e.g. nfs4_save_creds(). Signed-off-by: James Morris <jmorris@namei.org>
2008-12-03pkt_sched: sch_htb: Replace HTB_ACCNT() macro with inlinesJarek Poplawski
Replace HTB_ACCNT() macro with inlines to make it more readable. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-03pkt_sched: sch_htb: Remove L2T()Jarek Poplawski
L2T() is currently used only in one place (and has one spurious parameter, btw), so let's: 'get rid of L2T completely, and just use "qdisc_l2t(rate, size)" directly.' - quote & feedback from David S. Miller. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-03pkt_sched: sch_htb: Clean htb_class prio and quantum fieldsJarek Poplawski
While implementing htb_parent_to_leaf() there where added backup prio and quantum struct htb_class fields to preserve these values for inner classes in case of their return to leaf. This patch cleans this a bit by removing union leaf duplicates. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-03pkt_sched: sch_htb: Remove htb_sched nwc_hit fieldJarek Poplawski
Remove practically unused struct htb_sched nwc_hit field. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-03pkt_sched: sch_htb: Remove htb_class aprio fieldJarek Poplawski
Remove practically unused struct htb_class aprio field. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-28pkt_sched: fix sparse warningHannes Eder
Impact: make global function static Fix the following sparse warning: net/sched/sch_api.c:192:14: warning: symbol 'qdisc_match_from_root' was not declared. Should it be static? Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-26pkt_sched: gen_estimator: Optimize gen_estimator_active()Jarek Poplawski
Since all other gen_estimator functions use bstats and rate_est params together, and searching for them is optimized now, let's use this also in gen_estimator_active(). The return type of gen_estimator_active() is changed to bool, and gen_find_node() parameters to const, btw. In tcf_act_police_locate() a check for ACT_P_CREATED is added before calling gen_estimator_active(). Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25tc: policing requires a rate estimatorStephen Hemminger
Found that while trying average rate policing, it was possible to request average rate policing without a rate estimator. This results in no policing which is harmless but incorrect. Since policing could be setup in two steps, need to check in the kernel. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25tc: check for errors in gen_rate_estimator creationStephen Hemminger
The functions gen_new_estimator and gen_replace_estimator can return errors, but they were being ignored. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25tc: propogate errors from tcf_hash_createStephen Hemminger
Allow tcf_hash_create to return different errors on estimator failure. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25pkt_sched: fix warning in net/sched/sch_hfsc.cIngo Molnar
this warning: net/sched/sch_hfsc.c: In function ‘hfsc_enqueue’: net/sched/sch_hfsc.c:1577: warning: ‘err’ may be used uninitialized in this function triggers because GCC does not recognize the (correct) error flow between hfsc_classify(), 'cl' and 'err'. Annotate it. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25pkt_sched: sch_api: Remove qdisc_list_lockJarek Poplawski
After implementing qdisc->ops->peek() there is no more calling qdisc_tree_decrease_qlen() without rtnl_lock(), so qdisc_list_lock added by commit: f6e0b239a2657ea8cb67f0d83d0bfdbfd19a481b "pkt_sched: Fix qdisc list locking" can be removed. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-24pkt_sched: sch_drr: fix drr_dequeue loop()Patrick McHardy
Jarek Poplawski points out: If all child qdiscs of sch_drr are non-work-conserving (e.g. sch_tbf) drr_dequeue() will busy-loop waiting for skbs instead of leaving the job for a watchdog. Checking for list_empty() in each loop isn't necessary either, because this can never be true except the first time. Using non-work-conserving qdiscs as children of DRR makes no sense, simply bail out in that case. Reported-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-21pkt_sched: sch_drr: Fix qlen in drr_drop()Jarek Poplawski
Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ixgbe/ixgbe_main.c include/net/mac80211.h net/phonet/af_phonet.c
2008-11-20pkt_sched: remove unnecessary xchg() in packet classifiersPatrick McHardy
The use of xchg() hasn't been necessary since 2.2.something when proper locking was added to packet schedulers. In the case of classifiers they mostly weren't even necessary before that since they're mainly used to assign a NULL pointer to the filter root in the ->destroy path; the root is destroyed immediately after that. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20pkt_sched: remove unnecessary xchg() in packet schedulersPatrick McHardy
The use of xchg() hasn't been necessary since 2.2.something when proper locking was added to packet schedulers. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
