path: root/net/sched/sch_api.c
2007-05-03[NET]: Rework dev_base via list_head (v3)Pavel Emelianov
Cleanup of dev_base list use, with the aim to simplify making device list per-namespace. In almost every occasion, use of dev_base variable and dev->next pointer could be easily replaced by for_each_netdev loop. A few most complicated places were converted to using first_netdev()/next_netdev(). Signed-off-by: Pavel Emelianov <xemul@openvz.org> Acked-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: ingress: switch back to using ingress_lockPatrick McHardy
Switch ingress queueing back to use ingress_lock. qdisc_lock_tree now locks both the ingress and egress qdiscs on the device. All changes to data that might be used on both ingress and egress needs to be protected by using qdisc_lock_tree instead of manually taking dev->queue_lock. Additionally the qdisc stats_lock needs to be initialized to ingress_lock for ingress qdiscs. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: Eliminate qdisc_tree_lockPatrick McHardy
Since we're now holding the rtnl during the entire dump operation, we can remove qdisc_tree_lock, whose only purpose is to protect dump callbacks from concurrent changes to the qdisc tree. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: qdisc: remove unnecessary memory barriersPatrick McHardy
We're holding dev->queue_lock in qdisc_watchdog_schedule and qdisc_watchdog_cancel, no need for the barriers. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: Unline tcf_destroyPatrick McHardy
Uninline tcf_destroy and add a helper function to destroy an entire filter chain. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED] qdisc: avoid transmit softirq on watchdog wakeupStephen Hemminger
If possible, avoid having to do a transmit softirq when a qdisc watchdog decides to re-enable. The watchdog routine runs off a timer, so it is already in the same effective context as the softirq. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETEM]: avoid excessive requeuesStephen Hemminger
The netem code would call getnstimeofday() and dequeue/requeue after every packet, even if it was waiting. Avoid this overhead by using the throttled flag. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[PKT_SCHED] qdisc: Use rtnl registration interfaceThomas Graf
Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETLINK]: Use nlmsg_trim() where appropriateArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Convert skb->tail to sk_buff_data_tArnaldo Carvalho de Melo
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes on 64bit architectures, allowing us to combine the 4 bytes hole left by the layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4 64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN... :-) Many calculations that previously required that skb->{transport,network, mac}_header be first converted to a pointer now can be done directly, being meaningful as offsets or pointers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: Fix warningPatrick McHardy
net/sched/sch_api.c: In function 'psched_show': net/sched/sch_api.c:1219: warning: format '%08x' expects type 'unsigned int', but argument 6 has type 's64' Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: Export real timer resolution in /proc/net/pschedPatrick McHardy
The timer resolution exported in /proc/net/psched is used by userspace to calculate HTB's burst values. Currently it is set to HZ, since we're now using hrtimers, use KTIME_MONOTONIC_RES, which makes HTB use smaller burst values. This patch also affects libnl, which incorrectly uses this value for the SFQ perturbation parameter, which is always in seconds, and some routing cache values, which are in USER_HZ, so both cases are broken anyway. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: Add hrtimer based qdisc watchdogPatrick McHardy
2007-04-25[NET_SCHED]: Use ktime as clocksourcePatrick McHardy
Get rid of the manual clock source selection mess and use ktime. Also use a scalar representation, which allows to clean up pkt_sched.h a bit more and results in less ktime_to_ns() calls in most cases. The PSCHED_US2JIFFIE/PSCHED_JIFFIE2US macros are implemented quite inefficient by this patch, following patches will convert all qdiscs to hrtimers and get rid of them entirely. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET] SCHED: Use htons() where appropriate.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[PATCH] mark struct file_operations const 8Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[NET] SCHED: Fix whitespace errors.YOSHIFUJI Hideaki
2006-12-02[PKT_SCHED]: Remove unused exports.Adrian Bunk
This patch removes the following unused EXPORT_SYMBOL's: - sch_api.c: qdisc_lookup - sch_generic.c: __netdev_watchdog_up - sch_generic.c: noop_qdisc_ops - sch_generic.c: qdisc_alloc Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET_SCHED]: Fix endless loops caused by inaccurate qlen counters (part 1)Patrick McHardy
There are multiple problems related to qlen adjustment that can lead to an upper qdisc getting out of sync with the real number of packets queued, leading to endless dequeueing attempts by the upper layer code. All qdiscs must maintain an accurate q.qlen counter. There are basically two groups of operations affecting the qlen: operations that propagate down the tree (enqueue, dequeue, requeue, drop, reset) beginning at the root qdisc and operations only affecting a subtree or single qdisc (change, graft, delete class). Since qlen changes during operations from the second group don't propagate to ancestor qdiscs, their qlen values become desynchronized. This patch adds a function to propagate qlen changes up the qdisc tree, optionally calling a callback function to perform qdisc-internal maintenance when the child qdisc becomes empty. The follow-up patches will convert all qdiscs to use this function where necessary. Noticed by Timo Steinbach <tsteinbach@astaro.com>. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: net/sched annotations.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[NET_SCHED]: Fix fallout from dev->qdisc RCU changePatrick McHardy
The move of qdisc destruction to a rcu callback broke locking in the entire qdisc layer by invalidating previously valid assumptions about the context in which changes to the qdisc tree occur. The two assumptions were: - since changes only happen in process context, read_lock doesn't need bottem half protection. Now invalid since destruction of inner qdiscs, classifiers, actions and estimators happens in the RCU callback unless they're manually deleted, resulting in dead-locks when read_lock in process context is interrupted by write_lock_bh in bottem half context. - since changes only happen under the RTNL, no additional locking is necessary for data not used during packet processing (f.e. u32_list). Again, since destruction now happens in the RCU callback, this assumption is not valid anymore, causing races while using this data, which can result in corruption or use-after-free. Instead of "fixing" this by disabling bottem halfs everywhere and adding new locks/refcounting, this patch makes these assumptions valid again by moving destruction back to process context. Since only the dev->qdisc pointer is protected by RCU, but ->enqueue and the qdisc tree are still protected by dev->qdisc_lock, destruction of the tree can be performed immediately and only the final free needs to happen in the rcu callback to make sure dev_queue_xmit doesn't access already freed memory. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-04[PKT_SCHED]: Return ENOENT if qdisc module is unavailableJamal Hadi Salim
Return ENOENT if qdisc module is unavailable Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-09[PATCH] timer initialization cleanup: DEFINE_TIMERIngo Molnar
Clean up timer initialization by introducing DEFINE_TIMER a'la DEFINE_SPINLOCK. Build and boot-tested on x86. A similar patch has been been in the -RT tree for some time. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-29[NETLINK]: Convert netlink users to use group numbers instead of bitmasksPatrick McHardy
2005-07-05[PKT_SCHED]: Report rate estimator configuration errors during qdisc allocationThomas Graf
Current behaviour is to not report an error if a rate estimator is created together with a qdisc and the configuration of the rate estimator is bogus. This leads to unexpected behaviour because the user is not notified. New behaviour is to report the error and let the whole qdisc creation operation fail so the user is able to fix his mistake. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-05[PKT_SCHED]: Cleanup qdisc creation and alignment macrosThomas Graf
Adds qdisc_alloc() to share code between qdisc_create() and qdisc_create_dflt(). Hides the qdisc alignment behind macros and makes use of them. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-28[NETLINK]: Missing initializations in dumped dataPatrick McHardy
Mostly missing initialization of padding fields of 1 or 2 bytes length, two instances of uninitialized nlmsgerr->msg of 16 bytes length. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NETLINK]: Explicit typingJamal Hadi Salim
This patch converts "unsigned flags" to use more explict types like u16 instead and incrementally introduces NLMSG_NEW(). Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-03[PKT_SCHED]: netetm: adjust parent qlen when duplicatingStephen Hemminger
Fix qlen underrun when doing duplication with netem. If netem is used as leaf discipline, then the parent needs to be tweaked when packets are duplicated. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
