path: root/net/sched/cls_cgroup.c
2012-08-14net sched: Pass the skb into change so it can access NETLINK_CBEric W. Biederman
cls_flow.c plays with uids and gids. Unless I misread that code it is possible for classifiers to depend on the specific uid and gid values. Therefore I need to know the user namespace of the netlink socket that is installing the packet classifiers. Pass in the rtnetlink skb so I can access the NETLINK_CB of the passed packet. In particular I want access to sk_user_ns(NETLINK_CB(in_skb).ssk). Pass in not the user namespace but the incomming rtnetlink skb into the the classifier change routines as that is generally the more useful parameter. Cc: Jamal Hadi Salim <jhs@mojatatu.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-04-01cgroup: convert all non-memcg controllers to the new cftype interfaceTejun Heo
Convert debug, freezer, cpuset, cpu_cgroup, cpuacct, net_prio, blkio, net_cls and device controllers to use the new cftype based interface. Termination entry is added to cftype arrays and populate callbacks are replaced with cgroup_subsys->base_cftypes initializations. This is functionally identical transformation. There shouldn't be any visible behavior change. memcg is rather special and will be converted separately. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <paul@paulmenage.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Vivek Goyal <vgoyal@redhat.com>
2012-04-01cgroup: relocate cftype and cgroup_subsys definitions in controllersTejun Heo
blk-cgroup, netprio_cgroup, cls_cgroup and tcp_memcontrol unnecessarily define cftype array and cgroup_subsys structures at the top of the file, which is unconventional and necessiates forward declaration of methods. This patch relocates those below the definitions of the methods and removes the forward declarations. Note that forward declaration of tcp_files[] is added in tcp_memcontrol.c for tcp_init_cgroup(). This will be removed soon by another patch. This patch doesn't introduce any functional change. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizf@cn.fujitsu.com>
2012-02-02cgroup: remove cgroup_subsys argument from callbacksLi Zefan
The argument is not used at all, and it's not necessary, because a specific callback handler of course knows which subsys it belongs to. Now only ->pupulate() takes this argument, because the handlers of this callback always call cgroup_add_file()/cgroup_add_files(). So we reduce a few lines of code, though the shrinking of object size is minimal. 16 files changed, 113 insertions(+), 162 deletions(-) text data bss dec hex filename 5486240 656987 7039960 13183187 c928d3 vmlinux.o.orig 5486170 656987 7039960 13183117 c9288d vmlinux.o Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2011-07-06net: sched: constify tcf_proto and tc_actionEric Dumazet
Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-19net_sched: cleanupsEric Dumazet
Cleanup net/sched code to current CodingStyle and practices. Reduce inline abuse Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-03cls_cgroup: Fix crash on module unloadHerbert Xu
Somewhere along the lines net_cls_subsys_id became a macro when cls_cgroup is built as a module. Not only did it make cls_cgroup completely useless, it also causes it to crash on module unload. This patch fixes this by removing that macro. Thanks to Eric Dumazet for diagnosing this problem. Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-18sched: Fix softirq time accountingVenkatesh Pallipadi
Peter Zijlstra found a bug in the way softirq time is accounted in VIRT_CPU_ACCOUNTING on this thread: http://lkml.indiana.edu/hypermail//linux/kernel/1009.2/01366.html The problem is, softirq processing uses local_bh_disable internally. There is no way, later in the flow, to differentiate between whether softirq is being processed or is it just that bh has been disabled. So, a hardirq when bh is disabled results in time being wrongly accounted as softirq. Looking at the code a bit more, the problem exists in !VIRT_CPU_ACCOUNTING as well. As account_system_time() in normal tick based accouting also uses softirq_count, which will be set even when not in softirq with bh disabled. Peter also suggested solution of using 2*SOFTIRQ_OFFSET as irq count for local_bh_{disable,enable} and using just SOFTIRQ_OFFSET while softirq processing. The patch below does that and adds API in_serving_softirq() which returns whether we are currently processing softirq or not. Also changes one of the usages of softirq_count in net/sched/cls_cgroup.c to in_serving_softirq. Looks like many usages of in_softirq really want in_serving_softirq. Those changes can be made individually on a case by case basis. Signed-off-by: Venkatesh Pallipadi <venki@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1286237003-12406-2-git-send-email-venki@google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-24cls_cgroup: Store classid in struct sockHerbert Xu
Up until now cls_cgroup has relied on fetching the classid out of the current executing thread. This runs into trouble when a packet processing is delayed in which case it may execute out of another thread's context. Furthermore, even when a packet is not delayed we may fail to classify it if soft IRQs have been disabled, because this scenario is indistinguishable from one where a packet unrelated to the current thread is processed by a real soft IRQ. In fact, the current semantics is inherently broken, as a single skb may be constructed out of the writes of two different tasks. A different manifestation of this problem is when the TCP stack transmits in response of an incoming ACK. This is currently unclassified. As we already have a concept of packet ownership for accounting purposes in the skb->sk pointer, this is a natural place to store the classid in a persistent manner. This patch adds the cls_cgroup classid in struct sock, filling up an existing hole on 64-bit :) The value is set at socket creation time. So all sockets created via socket(2) automatically gains the ID of the thread creating it. Whenever another process touches the socket by either reading or writing to it, we will change the socket classid to that of the process if it has a valid (non-zero) classid. For sockets created on inbound connections through accept(2), we inherit the classid of the original listening socket through sk_clone, possibly preceding the actual accept(2) call. In order to minimise risks, I have not made this the authoritative classid. For now it is only used as a backup when we execute with soft IRQs disabled. Once we're completely happy with its semantics we can use it as the sole classid. Footnote: I have rearranged the error path on cls_group module creation. If we didn't do this, then there is a window where someone could create a tc rule using cls_group before the cgroup subsystem has been registered. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-23cgroups: net_cls as moduleBen Blum
Allows the net_cls cgroup subsystem to be compiled as a module This patch modifies net/sched/cls_cgroup.c to allow the net_cls subsystem to be optionally compiled as a module instead of builtin. The cgroup_subsys struct is moved around a bit to allow the subsys_id to be either declared as a compile-time constant by the cgroup_subsys.h include in cgroup.h, or, if it's a module, initialized within the struct by cgroup_load_subsys. Signed-off-by: Ben Blum <bblum@andrew.cmu.edu> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-15Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/scsi/fcoe/fcoe.c net/core/drop_monitor.c net/core/net-traces.c
2009-06-09cls_cgroup: Fix oops when user send improperly 'tc filter add' requestMinoru Usui
I found a bug in cls_cgroup_change() in cls_cgroup.c. cls_cgroup_change() expected tca[TCA_OPTIONS] was set from user space properly, but tc in iproute2-2.6.29-1 (which I used) didn't set it. In the current source code of tc in git, it set tca[TCA_OPTIONS]. git://git.kernel.org/pub/scm/linux/kernel/git/shemminger/iproute2.git If we always use a newest iproute2 in git when we use cls_cgroup, we don't face this oops probably. But I think, kernel shouldn't panic regardless of use program's behaviour. Signed-off-by: Minoru Usui <usui@mxm.nes.nec.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/forcedeth.c
2009-05-26cls_cgroup: read classid atomically in classifierPaul Menage
Avoid reading the unsynchronized value cs->classid multiple times, since it could change concurrently from non-zero to zero; this would result in the classifier returning a positive result with a bogus (zero) classid. Signed-off-by: Paul Menage <menage@google.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-17cls_cgroup: remove unneeded cgroup_lockLi Zefan
We can remove this lock here, since we are in cgroup write handler and thus the cgrp is guaranteed to be valid, and no lock is needed when writing a u32 variable. Signed-off-by: Li Zefan <lizf@cn.fujitsuc.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-29cls_cgroup: clean up for cgroup partLi Zefan
- It's better to use container_of() instead of casting cgroup_subsys_state * to cgroup_cls_state *. - Add helper function task_cls_state(). - Rename net_cls_state() to cgrp_cls_state(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-29cls_cgroup: fix an oops when removing a cgroupLi Zefan
When removing a cgroup, an oops was triggered immediately. The cause is wrong kfree() in cgrp_destroy(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20pkt_sched: remove unnecessary xchg() in packet classifiersPatrick McHardy
The use of xchg() hasn't been necessary since 2.2.something when proper locking was added to packet schedulers. In the case of classifiers they mostly weren't even necessary before that since they're mainly used to assign a NULL pointer to the filter root in the ->destroy path; the root is destroyed immediately after that. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-07pkt_sched: Control group classifierThomas Graf
The classifier should cover the most common use case and will work without any special configuration. The principle of the classifier is to directly access the task_struct via get_current(). In order for this to work, classification requests from softirqs must be ignored. This is not a problem because the vast majority of packets in softirq context are not assigned to a task anyway. For this to work, a mechanism is needed to trace softirq context. This repost goes back to the method of relying on the number of nested bh disable calls for the sake of not adding too much complexity and the option to come up with something more reliable if actually needed. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
