path: root/net/sched/cls_cgroup.c
2013-01-14pkt_sched: namespace aware act_mirredBenjamin LaHaise
Eric Dumazet pointed out that act_mirred needs to find the current net_ns, and struct net pointer is not provided in the call chain. His original patch made use of current->nsproxy->net_ns to find the network namespace, but this fails to work correctly for userspace code that makes use of netlink sockets in different network namespaces. Instead, pass the "struct net *" down along the call chain to where it is needed. This version removes the ifb changes as Eric has submitted that patch separately, but is otherwise identical to the previous version. Signed-off-by: Benjamin LaHaise <bcrl@kvack.org> Tested-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Jamal Hadi Salim <jhs@mojatatu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking changes from David Miller: 1) Allow to dump, monitor, and change the bridge multicast database using netlink. From Cong Wang. 2) RFC 5961 TCP blind data injection attack mitigation, from Eric Dumazet. 3) Networking user namespace support from Eric W. Biederman. 4) tuntap/virtio-net multiqueue support by Jason Wang. 5) Support for checksum offload of encapsulated packets (basically, tunneled traffic can still be checksummed by HW). From Joseph Gasparakis. 6) Allow BPF filter access to VLAN tags, from Eric Dumazet and Daniel Borkmann. 7) Bridge port parameters over netlink and BPDU blocking support from Stephen Hemminger. 8) Improve data access patterns during inet socket demux by rearranging socket layout, from Eric Dumazet. 9) TIPC protocol updates and cleanups from Ying Xue, Paul Gortmaker, and Jon Maloy. 10) Update TCP socket hash sizing to be more in line with current day realities. The existing heurstics were choosen a decade ago. From Eric Dumazet. 11) Fix races, queue bloat, and excessive wakeups in ATM and associated drivers, from Krzysztof Mazur and David Woodhouse. 12) Support DOVE (Distributed Overlay Virtual Ethernet) extensions in VXLAN driver, from David Stevens. 13) Add "oops_only" mode to netconsole, from Amerigo Wang. 14) Support set and query of VEB/VEPA bridge mode via PF_BRIDGE, also allow DCB netlink to work on namespaces other than the initial namespace. From John Fastabend. 15) Support PTP in the Tigon3 driver, from Matt Carlson. 16) tun/vhost zero copy fixes and improvements, plus turn it on by default, from Michael S. Tsirkin. 17) Support per-association statistics in SCTP, from Michele Baldessari. And many, many, driver updates, cleanups, and improvements. Too numerous to mention individually. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) net/mlx4_en: Add support for destination MAC in steering rules net/mlx4_en: Use generic etherdevice.h functions. net: ethtool: Add destination MAC address to flow steering API bridge: add support of adding and deleting mdb entries bridge: notify mdb changes via netlink ndisc: Unexport ndisc_{build,send}_skb(). uapi: add missing netconf.h to export list pkt_sched: avoid requeues if possible solos-pci: fix double-free of TX skb in DMA mode bnx2: Fix accidental reversions. bna: Driver Version Updated to 3.1.2.1 bna: Firmware update bna: Add RX State bna: Rx Page Based Allocation bna: TX Intr Coalescing Fix bna: Tx and Rx Optimizations bna: Code Cleanup and Enhancements ath9k: check pdata variable before dereferencing it ath5k: RX timestamp is reported at end of frame ath9k_htc: RX timestamp is reported at end of frame ...
2012-11-22netcls_cgroup: move config inheritance to ->css_online() and remove ↵Tejun Heo
.broken_hierarchy marking It turns out that we'll have to live with attributes which are inherited at cgroup creation time but not affected by further updates to the parent afterwards - such attributes are already in wide use e.g. for cpuset. So, there's nothing to do for netcls_cgroup for hierarchy support. Its current behavior - inherit only during creation - is good enough. Move config inheriting from ->css_alloc() to ->css_online() for consistency, which doesn't change behavior at all, and remove .broken_hierarchy marking. Signed-off-by: Tejun Heo <tj@kernel.org> Tested-and-Acked-by: Daniel Wagner <daniel.wagner@bmw-carit.de> Acked-by: David S. Miller <davem@davemloft.net>
2012-11-19cgroup: rename ->create/post_create/pre_destroy/destroy() to ↵Tejun Heo
->css_alloc/online/offline/free() Rename cgroup_subsys css lifetime related callbacks to better describe what their roles are. Also, update documentation. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2012-10-26cgroup: net_cls: Rework update socket logicDaniel Wagner
The cgroup logic part of net_cls is very similar as the one in net_prio. Let's stream line the net_cls logic with the net_prio one. The net_prio update logic was changed by following commit (note there were some changes necessary later on) commit 406a3c638ce8b17d9704052c07955490f732c2b8 Author: John Fastabend <john.r.fastabend@intel.com> Date: Fri Jul 20 10:39:25 2012 +0000 net: netprio_cgroup: rework update socket logic Instead of updating the sk_cgrp_prioidx struct field on every send this only updates the field when a task is moved via cgroup infrastructure. This allows sockets that may be used by a kernel worker thread to be managed. For example in the iscsi case today a user can put iscsid in a netprio cgroup and control traffic will be sent with the correct sk_cgrp_prioidx value set but as soon as data is sent the kernel worker thread isssues a send and sk_cgrp_prioidx is updated with the kernel worker threads value which is the default case. It seems more correct to only update the field when the user explicitly sets it via control group infrastructure. This allows the users to manage sockets that may be used with other threads. Since classid is now updated when the task is moved between the cgroups, we don't have to call sock_update_classid() from various places to ensure we always using the latest classid value. [v2: Use iterate_fd() instead of open coding] Signed-off-by: Daniel Wagner <daniel.wagner@bmw-carit.de> Cc: Li Zefan <lizefan@huawei.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Jamal Hadi Salim <jhs@mojatatu.com> Cc: Joe Perches <joe@perches.com> Cc: John Fastabend <john.r.fastabend@intel.com> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Stanislav Kinsbursky <skinsbursky@parallels.com> Cc: Tejun Heo <tj@kernel.org> Cc: <netdev@vger.kernel.org> Cc: <cgroups@vger.kernel.org> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace changes from Eric Biederman: "This is a mostly modest set of changes to enable basic user namespace support. This allows the code to code to compile with user namespaces enabled and removes the assumption there is only the initial user namespace. Everything is converted except for the most complex of the filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs, nfs, ocfs2 and xfs as those patches need a bit more review. The strategy is to push kuid_t and kgid_t values are far down into subsystems and filesystems as reasonable. Leaving the make_kuid and from_kuid operations to happen at the edge of userspace, as the values come off the disk, and as the values come in from the network. Letting compile type incompatible compile errors (present when user namespaces are enabled) guide me to find the issues. The most tricky areas have been the places where we had an implicit union of uid and gid values and were storing them in an unsigned int. Those places were converted into explicit unions. I made certain to handle those places with simple trivial patches. Out of that work I discovered we have generic interfaces for storing quota by projid. I had never heard of the project identifiers before. Adding full user namespace support for project identifiers accounts for most of the code size growth in my git tree. Ultimately there will be work to relax privlige checks from "capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing root in a user names to do those things that today we only forbid to non-root users because it will confuse suid root applications. While I was pushing kuid_t and kgid_t changes deep into the audit code I made a few other cleanups. I capitalized on the fact we process netlink messages in the context of the message sender. I removed usage of NETLINK_CRED, and started directly using current->tty. Some of these patches have also made it into maintainer trees, with no problems from identical code from different trees showing up in linux-next. After reading through all of this code I feel like I might be able to win a game of kernel trivial pursuit." Fix up some fairly trivial conflicts in netfilter uid/git logging code. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits) userns: Convert the ufs filesystem to use kuid/kgid where appropriate userns: Convert the udf filesystem to use kuid/kgid where appropriate userns: Convert ubifs to use kuid/kgid userns: Convert squashfs to use kuid/kgid where appropriate userns: Convert reiserfs to use kuid and kgid where appropriate userns: Convert jfs to use kuid/kgid where appropriate userns: Convert jffs2 to use kuid and kgid where appropriate userns: Convert hpfs to use kuid and kgid where appropriate userns: Convert btrfs to use kuid/kgid where appropriate userns: Convert bfs to use kuid/kgid where appropriate userns: Convert affs to use kuid/kgid wherwe appropriate userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids userns: On ia64 deal with current_uid and current_gid being kuid and kgid userns: On ppc convert current_uid from a kuid before printing. userns: Convert s390 getting uid and gid system calls to use kuid and kgid userns: Convert s390 hypfs to use kuid and kgid where appropriate userns: Convert binder ipc to use kuids userns: Teach security_path_chown to take kuids and kgids userns: Add user namespace support to IMA userns: Convert EVM to deal with kuids and kgids in it's hmac computation ...
2012-10-02Merge branch 'for-3.7-hierarchy' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup hierarchy update from Tejun Heo: "Currently, different cgroup subsystems handle nested cgroups completely differently. There's no consistency among subsystems and the behaviors often are outright broken. People at least seem to agree that the broken hierarhcy behaviors need to be weeded out if any progress is gonna be made on this front and that the fallouts from deprecating the broken behaviors should be acceptable especially given that the current behaviors don't make much sense when nested. This patch makes cgroup emit warning messages if cgroups for subsystems with broken hierarchy behavior are nested to prepare for fixing them in the future. This was put in a separate branch because more related changes were expected (didn't make it this round) and the memory cgroup wanted to pull in this and make changes on top." * 'for-3.7-hierarchy' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cgroup: mark subsystems with broken hierarchy support and whine if cgroups are nested for them
2012-09-14cgroup: mark subsystems with broken hierarchy support and whine if cgroups ↵Tejun Heo
are nested for them Currently, cgroup hierarchy support is a mess. cpu related subsystems behave correctly - configuration, accounting and control on a parent properly cover its children. blkio and freezer completely ignore hierarchy and treat all cgroups as if they're directly under the root cgroup. Others show yet different behaviors. These differing interpretations of cgroup hierarchy make using cgroup confusing and it impossible to co-mount controllers into the same hierarchy and obtain sane behavior. Eventually, we want full hierarchy support from all subsystems and probably a unified hierarchy. Users using separate hierarchies expecting completely different behaviors depending on the mounted subsystem is deterimental to making any progress on this front. This patch adds cgroup_subsys.broken_hierarchy and sets it to %true for controllers which are lacking in hierarchy support. The goal of this patch is two-fold. * Move users away from using hierarchy on currently non-hierarchical subsystems, so that implementing proper hierarchy support on those doesn't surprise them. * Keep track of which controllers are broken how and nudge the subsystems to implement proper hierarchy support. For now, start with a single warning message. We can whine louder later on. v2: Fixed a typo spotted by Michal. Warning message updated. v3: Updated memcg part so that it doesn't generate warning in the cases where .use_hierarchy=false doesn't make the behavior different from root.use_hierarchy=true. Fixed a typo spotted by Glauber. v4: Check ->broken_hierarchy after cgroup creation is complete so that ->create() can affect the result per Michal. Dropped unnecessary memcg root handling per Michal. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Li Zefan <lizefan@huawei.com> Acked-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Glauber Costa <glommer@parallels.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul Turner <pjt@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Thomas Graf <tgraf@suug.ch> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2012-09-14cgroup: Assign subsystem IDs during compile timeDaniel Wagner
WARNING: With this change it is impossible to load external built controllers anymore. In case where CONFIG_NETPRIO_CGROUP=m and CONFIG_NET_CLS_CGROUP=m is set, corresponding subsys_id should also be a constant. Up to now, net_prio_subsys_id and net_cls_subsys_id would be of the type int and the value would be assigned during runtime. By switching the macro definition IS_SUBSYS_ENABLED from IS_BUILTIN to IS_ENABLED, all *_subsys_id will have constant value. That means we need to remove all the code which assumes a value can be assigned to net_prio_subsys_id and net_cls_subsys_id. A close look is necessary on the RCU part which was introduces by following patch: commit f845172531fb7410c7fb7780b1a6e51ee6df7d52 Author: Herbert Xu <herbert@gondor.apana.org.au> Mon May 24 09:12:34 2010 Committer: David S. Miller <davem@davemloft.net> Mon May 24 09:12:34 2010 cls_cgroup: Store classid in struct sock Tis code was added to init_cgroup_cls() /* We can't use rcu_assign_pointer because this is an int. */ smp_wmb(); net_cls_subsys_id = net_cls_subsys.subsys_id; respectively to exit_cgroup_cls() net_cls_subsys_id = -1; synchronize_rcu(); and in module version of task_cls_classid() rcu_read_lock(); id = rcu_dereference(net_cls_subsys_id); if (id >= 0) classid = container_of(task_subsys_state(p, id), struct cgroup_cls_state, css)->classid; rcu_read_unlock(); Without an explicit explaination why the RCU part is needed. (The rcu_deference was fixed by exchanging it to rcu_derefence_index_check() in a later commit, but that is a minor detail.) So here is my pondering why it was introduced and why it safe to remove it now. Note that this code was copied over to net_prio the reasoning holds for that subsystem too. The idea behind the RCU use for net_cls_subsys_id is to make sure we get a valid pointer back from task_subsys_state(). task_subsys_state() is just blindly accessing the subsys array and returning the pointer. Obviously, passing in -1 as id into task_subsys_state() returns an invalid value (out of lower bound). So this code makes sure that only after module is loaded and the subsystem registered, the id is assigned. Before unregistering the module all old readers must have left the critical section. This is done by assigning -1 to the id and issuing a synchronized_rcu(). Any new readers wont call task_subsys_state() anymore and therefore it is safe to unregister the subsystem. The new code relies on the same trick, but it looks at the subsys pointer return by task_subsys_state() (remember the id is constant and therefore we allways have a valid index into the subsys array). No precautions need to be taken during module loading module. Eventually, all CPUs will get a valid pointer back from task_subsys_state() because rebind_subsystem() which is called after the module init() function will assigned subsys[net_cls_subsys_id] the newly loaded module subsystem pointer. When the subsystem is about to be removed, rebind_subsystem() will called before the module exit() function. In this case, rebind_subsys() will assign subsys[net_cls_subsys_id] a NULL pointer and then it calls synchronize_rcu(). All old readers have left by then the critical section. Any new reader wont access the subsystem anymore. At this point we are safe to unregister the subsystem. No synchronize_rcu() call is needed. Signed-off-by: Daniel Wagner <daniel.wagner@bmw-carit.de> Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Eric Dumazet <edumazet@google.com> Cc: Gao feng <gaofeng@cn.fujitsu.com> Cc: Glauber Costa <glommer@parallels.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Jamal Hadi Salim <jhs@mojatatu.com> Cc: John Fastabend <john.r.fastabend@intel.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: netdev@vger.kernel.org Cc: cgroups@vger.kernel.org
2012-08-14net sched: Pass the skb into change so it can access NETLINK_CBEric W. Biederman
cls_flow.c plays with uids and gids. Unless I misread that code it is possible for classifiers to depend on the specific uid and gid values. Therefore I need to know the user namespace of the netlink socket that is installing the packet classifiers. Pass in the rtnetlink skb so I can access the NETLINK_CB of the passed packet. In particular I want access to sk_user_ns(NETLINK_CB(in_skb).ssk). Pass in not the user namespace but the incomming rtnetlink skb into the the classifier change routines as that is generally the more useful parameter. Cc: Jamal Hadi Salim <jhs@mojatatu.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-04-01cgroup: convert all non-memcg controllers to the new cftype interfaceTejun Heo
Convert debug, freezer, cpuset, cpu_cgroup, cpuacct, net_prio, blkio, net_cls and device controllers to use the new cftype based interface. Termination entry is added to cftype arrays and populate callbacks are replaced with cgroup_subsys->base_cftypes initializations. This is functionally identical transformation. There shouldn't be any visible behavior change. memcg is rather special and will be converted separately. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <paul@paulmenage.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Vivek Goyal <vgoyal@redhat.com>
2012-04-01cgroup: relocate cftype and cgroup_subsys definitions in controllersTejun Heo
blk-cgroup, netprio_cgroup, cls_cgroup and tcp_memcontrol unnecessarily define cftype array and cgroup_subsys structures at the top of the file, which is unconventional and necessiates forward declaration of methods. This patch relocates those below the definitions of the methods and removes the forward declarations. Note that forward declaration of tcp_files[] is added in tcp_memcontrol.c for tcp_init_cgroup(). This will be removed soon by another patch. This patch doesn't introduce any functional change. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizf@cn.fujitsu.com>
2012-02-02cgroup: remove cgroup_subsys argument from callbacksLi Zefan
The argument is not used at all, and it's not necessary, because a specific callback handler of course knows which subsys it belongs to. Now only ->pupulate() takes this argument, because the handlers of this callback always call cgroup_add_file()/cgroup_add_files(). So we reduce a few lines of code, though the shrinking of object size is minimal. 16 files changed, 113 insertions(+), 162 deletions(-) text data bss dec hex filename 5486240 656987 7039960 13183187 c928d3 vmlinux.o.orig 5486170 656987 7039960 13183117 c9288d vmlinux.o Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2011-07-06net: sched: constify tcf_proto and tc_actionEric Dumazet
Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-19net_sched: cleanupsEric Dumazet
Cleanup net/sched code to current CodingStyle and practices. Reduce inline abuse Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-03cls_cgroup: Fix crash on module unloadHerbert Xu
Somewhere along the lines net_cls_subsys_id became a macro when cls_cgroup is built as a module. Not only did it make cls_cgroup completely useless, it also causes it to crash on module unload. This patch fixes this by removing that macro. Thanks to Eric Dumazet for diagnosing this problem. Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-18sched: Fix softirq time accountingVenkatesh Pallipadi
Peter Zijlstra found a bug in the way softirq time is accounted in VIRT_CPU_ACCOUNTING on this thread: http://lkml.indiana.edu/hypermail//linux/kernel/1009.2/01366.html The problem is, softirq processing uses local_bh_disable internally. There is no way, later in the flow, to differentiate between whether softirq is being processed or is it just that bh has been disabled. So, a hardirq when bh is disabled results in time being wrongly accounted as softirq. Looking at the code a bit more, the problem exists in !VIRT_CPU_ACCOUNTING as well. As account_system_time() in normal tick based accouting also uses softirq_count, which will be set even when not in softirq with bh disabled. Peter also suggested solution of using 2*SOFTIRQ_OFFSET as irq count for local_bh_{disable,enable} and using just SOFTIRQ_OFFSET while softirq processing. The patch below does that and adds API in_serving_softirq() which returns whether we are currently processing softirq or not. Also changes one of the usages of softirq_count in net/sched/cls_cgroup.c to in_serving_softirq. Looks like many usages of in_softirq really want in_serving_softirq. Those changes can be made individually on a case by case basis. Signed-off-by: Venkatesh Pallipadi <venki@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1286237003-12406-2-git-send-email-venki@google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-24cls_cgroup: Store classid in struct sockHerbert Xu
Up until now cls_cgroup has relied on fetching the classid out of the current executing thread. This runs into trouble when a packet processing is delayed in which case it may execute out of another thread's context. Furthermore, even when a packet is not delayed we may fail to classify it if soft IRQs have been disabled, because this scenario is indistinguishable from one where a packet unrelated to the current thread is processed by a real soft IRQ. In fact, the current semantics is inherently broken, as a single skb may be constructed out of the writes of two different tasks. A different manifestation of this problem is when the TCP stack transmits in response of an incoming ACK. This is currently unclassified. As we already have a concept of packet ownership for accounting purposes in the skb->sk pointer, this is a natural place to store the classid in a persistent manner. This patch adds the cls_cgroup classid in struct sock, filling up an existing hole on 64-bit :) The value is set at socket creation time. So all sockets created via socket(2) automatically gains the ID of the thread creating it. Whenever another process touches the socket by either reading or writing to it, we will change the socket classid to that of the process if it has a valid (non-zero) classid. For sockets created on inbound connections through accept(2), we inherit the classid of the original listening socket through sk_clone, possibly preceding the actual accept(2) call. In order to minimise risks, I have not made this the authoritative classid. For now it is only used as a backup when we execute with soft IRQs disabled. Once we're completely happy with its semantics we can use it as the sole classid. Footnote: I have rearranged the error path on cls_group module creation. If we didn't do this, then there is a window where someone could create a tc rule using cls_group before the cgroup subsystem has been registered. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-23cgroups: net_cls as moduleBen Blum
Allows the net_cls cgroup subsystem to be compiled as a module This patch modifies net/sched/cls_cgroup.c to allow the net_cls subsystem to be optionally compiled as a module instead of builtin. The cgroup_subsys struct is moved around a bit to allow the subsys_id to be either declared as a compile-time constant by the cgroup_subsys.h include in cgroup.h, or, if it's a module, initialized within the struct by cgroup_load_subsys. Signed-off-by: Ben Blum <bblum@andrew.cmu.edu> Acked-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-15Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/scsi/fcoe/fcoe.c net/core/drop_monitor.c net/core/net-traces.c
2009-06-09cls_cgroup: Fix oops when user send improperly 'tc filter add' requestMinoru Usui
I found a bug in cls_cgroup_change() in cls_cgroup.c. cls_cgroup_change() expected tca[TCA_OPTIONS] was set from user space properly, but tc in iproute2-2.6.29-1 (which I used) didn't set it. In the current source code of tc in git, it set tca[TCA_OPTIONS]. git://git.kernel.org/pub/scm/linux/kernel/git/shemminger/iproute2.git If we always use a newest iproute2 in git when we use cls_cgroup, we don't face this oops probably. But I think, kernel shouldn't panic regardless of use program's behaviour. Signed-off-by: Minoru Usui <usui@mxm.nes.nec.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/forcedeth.c
2009-05-26cls_cgroup: read classid atomically in classifierPaul Menage
Avoid reading the unsynchronized value cs->classid multiple times, since it could change concurrently from non-zero to zero; this would result in the classifier returning a positive result with a bogus (zero) classid. Signed-off-by: Paul Menage <menage@google.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-17cls_cgroup: remove unneeded cgroup_lockLi Zefan
We can remove this lock here, since we are in cgroup write handler and thus the cgrp is guaranteed to be valid, and no lock is needed when writing a u32 variable. Signed-off-by: Li Zefan <lizf@cn.fujitsuc.com> Acked-by: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-29cls_cgroup: clean up for cgroup partLi Zefan
- It's better to use container_of() instead of casting cgroup_subsys_state * to cgroup_cls_state *. - Add helper function task_cls_state(). - Rename net_cls_state() to cgrp_cls_state(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-29cls_cgroup: fix an oops when removing a cgroupLi Zefan
When removing a cgroup, an oops was triggered immediately. The cause is wrong kfree() in cgrp_destroy(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20pkt_sched: remove unnecessary xchg() in packet classifiersPatrick McHardy
The use of xchg() hasn't been necessary since 2.2.something when proper locking was added to packet schedulers. In the case of classifiers they mostly weren't even necessary before that since they're mainly used to assign a NULL pointer to the filter root in the ->destroy path; the root is destroyed immediately after that. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-07pkt_sched: Control group classifierThomas Graf
The classifier should cover the most common use case and will work without any special configuration. The principle of the classifier is to directly access the task_struct via get_current(). In order for this to work, classification requests from softirqs must be ignored. This is not a problem because the vast majority of packets in softirq context are not assigned to a task anyway. For this to work, a mechanism is needed to trace softirq context. This repost goes back to the method of relying on the number of nested bh disable calls for the sake of not adding too much complexity and the option to come up with something more reliable if actually needed. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
