As pointed out by Jiri, there is still a race condition between
tcf_block_put() and tcf_chain_destroy() in a RCU callback. There
is no way to make it correct without proper locking or synchronization,
because both operate on a shared list.
Locking is hard, because the only lock we can pick here is a spinlock,
however, in tc_dump_tfilter() we iterate this list with a sleeping
function called (tcf_chain_dump()), which makes using a lock to protect
chain_list almost impossible.
Jiri suggested the idea of holding a refcnt before flushing, this works
because it guarantees us there would be no parallel tcf_chain_destroy()
during the loop, therefore the race condition is gone. But we have to
be very careful with proper synchronization with RCU callbacks.
Suggested-by: Jiri Pirko <jiri@mellanox.com>
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Acked-by: Jiri Pirko <jiri@mellanox.com>
This patch fixes the following ugliness of tc filter chain refcnt:
a) tp proto should hold a refcnt to the chain too. This significantly
simplifies the logic.
b) Chain 0 is no longer special, it is created with refcnt=1 like any
other chains. All the ugliness in tcf_chain_put() can be gone!
c) No need to handle the flushing oddly, because block still holds
chain 0, it can not be released, this guarantees block is the last
user.
d) The race condition with RCU callbacks is easier to handle with just
a rcu_barrier(). Much easier to understand, nothing to hide. Thanks
to the previous patch. Please see also the comments in code.
e) Make the code understandable by humans, much less error-prone.
Fixes: 744a4cf63e52 ("net: sched: fix use after free when tcf_chain_destroy is called multiple times")
Fixes: 5bc1701881e3 ("net: sched: introduce multichain support for filters")
Cc: Jiri Pirko <jiri@mellanox.com>
There's a memleak happening for chain 0. The thing is, chain 0 needs to
be always present, not created on demand. Therefore tcf_block_get upon
creation of block calls the tcf_chain_create function directly. The
chain is created with refcnt == 1, which is not correct in this case and
causes the memleak. So move the refcnt increment into tcf_chain_get
function even for the case when chain needs to be created.
Reported-by: Jakub Kicinski <kubakici@wp.pl>
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
Tested-by: Jakub Kicinski <jakub.kicinski@netronome.com>
Three cases of simple overlapping changes.
For TC classes, their ->get() and ->put() are always paired, and the
reference counting is completely useless, because:
1) For class modification and dumping paths, we already hold RTNL lock,
so all of these ->get(),->change(),->put() are atomic.
2) For filter bindiing/unbinding, we use other reference counter than
this one, and they should have RTNL lock too.
3) For ->qlen_notify(), it is special because it is called on ->enqueue()
path, but we already hold qdisc tree lock there, and we hold this
tree lock when graft or delete the class too, so it should not be gone
or changed until we release the tree lock.
Therefore, this patch removes ->get() and ->put(), but:
1) Adds a new ->find() to find the pointer to a class by classid, no
refcnt.
2) Move the original class destroy upon the last refcnt into ->delete(),
right after releasing tree lock. This is fine because the class is
already removed from hash when holding the lock.
For those who also use ->put() as ->unbind(), just rename them to reflect
this change.
Acked-by: Jamal Hadi Salim <jhs@mojatatu.com>
tcf_chain_flush needs to be called with RTNL. However, on
free_tcf->
tcf_action_goto_chain_fini->
tcf_chain_put->
tcf_chain_destroy->
tcf_chain_flush
callpath, it is called without RTNL.
This issue was notified by following warning:
[ 155.599052] WARNING: suspicious RCU usage
[ 155.603165] 4.13.0-rc5jiri+ #54 Not tainted
[ 155.607456] -----------------------------
[ 155.611561] net/sched/cls_api.c:195 suspicious rcu_dereference_protected() usage!
Since on this callpath, the chain is guaranteed to be already empty
by check in tcf_chain_put, move the tcf_chain_flush call out and call it
only where it is needed - into tcf_block_put.
Fixes: db50514f9a9c ("net: sched: add termination action to allow goto chain")
The goto_chain termination action takes a reference of a chain. In that
case, there is an issue when block_put is called tcf_chain_destroy
directly. The follo-up call of tcf_chain_put by goto_chain action free
works with memory that is already freed. This was caught by kasan:
[ 220.337908] BUG: KASAN: use-after-free in tcf_chain_put+0x1b/0x50
[ 220.344103] Read of size 4 at addr ffff88036d1f2cec by task systemd-journal/261
[ 220.353047] CPU: 0 PID: 261 Comm: systemd-journal Not tainted 4.13.0-rc5jiri+ #54
[ 220.360661] Hardware name: Mellanox Technologies Ltd. Mellanox switch/Mellanox x86 mezzanine board, BIOS 4.6.5 08/02/2016
[ 220.371784] Call Trace:
[ 220.374290] <IRQ>
[ 220.376355] dump_stack+0xd5/0x150
[ 220.391485] print_address_description+0x86/0x410
[ 220.396308] kasan_report+0x181/0x4c0
[ 220.415211] tcf_chain_put+0x1b/0x50
[ 220.418949] free_tcf+0x95/0xc0
So allow tcf_chain_destroy to be called multiple times, free only in
case the reference count drops to 0.
The dereference before check is wrong and leads to an oops when
p_filter_chain is NULL. The check needs to be done on the pointer to
prevent NULL dereference.
Fixes: f93e1cdcf42c ("net/sched: fix filter flushing")
Acked-by: Cong Wang <xiyou.wangcong@gmail.com>
This change allows us to later indicate to rtnetlink core that certain
doit functions should be called without acquiring rtnl_mutex.
This change should have no effect, we simply replace the last (now
unused) calcit argument with the new flag.
Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
If we move up tcf_fill_node() we can get rid of these
forward declarations.
Also, move down tfilter_notify_chain() to group them together.
Reported-by: Jamal Hadi Salim <jhs@mojatatu.com>
Now we use 'unsigned long fh' as a pointer in every place,
it is safe to convert it to a void pointer now. This gets
rid of many casts to pointer.
Cc: Jiri Pirko <jiri@resnulli.us>
It is confusing to use 'unsigned long fh' as both a handle
and a pointer, especially commit 9ee7837449b3
("net sched filters: fix notification of filter delete with proper handle").
This patch introduces tfilter_del_notify() so that we can
pass it as a pointer as before, and we don't need to check
RTM_DELTFILTER in tcf_fill_node() any more.
This prepares for the next patch.
tcf_exts_change is always called on newly created exts, which are not used
on fastpath. Therefore, simple struct copy is enough.
For check in tcf_exts_dump use tcf_exts_has_actions helper instead
of exts->nr_actions for checking if there are any actions present.
The rest of the helpers are named tcf_exts_*, so change the name of
the action number helpers to be aligned. While at it, change to inline
functions.
tcf_chain_get() always creates a new filter chain if not found
in existing ones. This is totally unnecessary when we get or
delete filters, new chain should be only created for new filters
(or new actions).
With the introduction of chain goto action, the reclassification would
cause the re-iteration of the actual chain. It makes more sense to restart
the whole thing and re-iterate starting from the original tp - start
of chain 0.
Reviewed-by: Simon Horman <simon.horman@netronome.com>
When user instructs to remove all filters from chain, we cannot destroy
the chain as other actions may hold a reference. Also the put in errout
would try to destroy it again. So instead, just walk the chain and remove
all existing filters.
*p_filter_chain is rcu-dereferenced on reader path. So here in writer,
property assign the pointer.
Fixes: 2190d1d0944f ("net: sched: introduce helpers to work with filter chains")
Introduce new type of termination action called "goto_chain". This allows
user to specify a chain to be processed. This action type is
then processed as a return value in tcf_classify loop in similar
way as "reclassify" is, only it does not reset to the first filter
in chain but rather reset to the first filter of the desired chain.
Tp pointer will be needed by the next patch in order to get the chain.
Instead of having only one filter per block, introduce a list of chains
for every block. Create chain 0 by default. UAPI is extended so the user
can specify which chain he wants to change. If the new attribute is not
specified, chain 0 is used. That allows to maintain backward
compatibility. If chain does not exist and user wants to manipulate with
it, new chain is created with specified index. Also, when last filter is
removed from the chain, the chain is destroyed.
Since there will be multiple chains to dump, push chain dumping code to
a separate function.
Introduce struct tcf_chain object and set of helpers around it. Wraps up
insertion, deletion and search in the filter chain.
Call the helper from the function rather than to always adjust the
return value of the function.
The use of "nprio" variable in tc_ctl_tfilter is a bit cryptic and makes
a reader wonder what is going on for a while. So help him to understand
this priority allocation dance a litte bit better.
Make the name consistent with the rest of the helpers around.
Currently, the filter chains are direcly put into the private structures
of qdiscs. In order to be able to have multiple chains per qdisc and to
allow filter chains sharing among qdiscs, there is a need for common
object that would hold the chains. This introduces such object and calls
it "tcf_block".
Helpers to get and put the blocks are provided to be called from
individual qdisc code. Also, the original filter_list pointers are left
in qdisc privs to allow the entry into tcf_block processing without any
added overhead of possible multiple pointer dereference on fast path.
Move tc_classify function to cls_api.c where it belongs, rename it to
fit the namespace.
We could have a race condition where in ->classify() path we
dereference tp->root and meanwhile a parallel ->destroy() makes it
a NULL. Daniel cured this bug in commit d936377414fa
("net, sched: respect rcu grace period on cls destruction").
This happens when ->destroy() is called for deleting a filter to
check if we are the last one in tp, this tp is still linked and
visible at that time. The root cause of this problem is the semantic
of ->destroy(), it does two things (for non-force case):
1) check if tp is empty
2) if tp is empty we could really destroy it
and its caller, if cares, needs to check its return value to see if it
is really destroyed. Therefore we can't unlink tp unless we know it is
empty.
As suggested by Daniel, we could actually move the test logic to ->delete()
so that we can safely unlink tp after ->delete() tells us the last one is
just deleted and before ->destroy().
Fixes: 1e052be69d04 ("net_sched: destroy proto tp when all filters are gone")
Cc: Roi Dayan <roid@mellanox.com>
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: John Fastabend <john.fastabend@gmail.com>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
Add netlink_ext_ack arg to rtnl_doit_func. Pass extack arg to nlmsg_parse
for doit functions that call it directly.
This is the first step to using extended error reporting in rtnetlink.
>From here individual subsystems can be updated to set netlink_ext_ack as
needed.
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
Pass the new extended ACK reporting struct to all of the generic
netlink parsing functions. For now, pass NULL in almost all callers
(except for some in the core.)
Bring back the goto that was removed by accident.
Reported-by: Colin Ian King <colin.king@canonical.com>
Fixes: 40c81b25b16c ("sched: check negative err value to safe one level of indent")
As it is more common, check err for !0. That allows to safe one level of
indentation and makes the code easier to read. Also, make 'next' variable
global in function as it is used twice.
Curly braces need to be there, for stylistic reasons.
This makes the reader to know right away what is the error value.
Make the long function tc_ctl_tfilter a little bit shorter and easier to
read. Also make the creation of filter proto symmetric to destruction.
Creation is done in this file, move destruction to be at the same place.
This function destroys TC filter protocol, not TC filter. So name it
accordingly.
Shahar reported a soft lockup in tc_classify(), where we run into an
endless loop when walking the classifier chain due to tp->next == tp
which is a state we should never run into. The issue only seems to
trigger under load in the tc control path.
What happens is that in tc_ctl_tfilter(), thread A allocates a new
tp, initializes it, sets tp_created to 1, and calls into tp->ops->change()
with it. In that classifier callback we had to unlock/lock the rtnl
mutex and returned with -EAGAIN. One reason why we need to drop there
is, for example, that we need to request an action module to be loaded.
This happens via tcf_exts_validate() -> tcf_action_init/_1() meaning
after we loaded and found the requested action, we need to redo the
whole request so we don't race against others. While we had to unlock
rtnl in that time, thread B's request was processed next on that CPU.
Thread B added a new tp instance successfully to the classifier chain.
When thread A returned grabbing the rtnl mutex again, propagating -EAGAIN
and destroying its tp instance which never got linked, we goto replay
and redo A's request.
This time when walking the classifier chain in tc_ctl_tfilter() for
checking for existing tp instances we had a priority match and found
the tp instance that was created and linked by thread B. Now calling
again into tp->ops->change() with that tp was successful and returned
without error.
tp_created was never cleared in the second round, thus kernel thinks
that we need to link it into the classifier chain (once again). tp and
*back point to the same object due to the match we had earlier on. Thus
for thread B's already public tp, we reset tp->next to tp itself and
link it into the chain, which eventually causes the mentioned endless
loop in tc_classify() once a packet hits the data path.
Fix is to clear tp_created at the beginning of each request, also when
we replay it. On the paths that can cause -EAGAIN we already destroy
the original tp instance we had and on replay we really need to start
from scratch. It seems that this issue was first introduced in commit
12186be7d2e1 ("net_cls: fix unconfigured struct tcf_proto keeps chaining
and avoid kernel panic when we use cls_cgroup").
Fixes: 12186be7d2e1 ("net_cls: fix unconfigured struct tcf_proto keeps chaining and avoid kernel panic when we use cls_cgroup")
Reported-by: Shahar Klein <shahark@mellanox.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Cc: Cong Wang <xiyou.wangcong@gmail.com>
Tested-by: Shahar Klein <shahark@mellanox.com>
In order to support hardware offloading when the device given by the tc
rule is different from the Hardware underline device, extract the mirred
(egress) device from the tc action when a filter is added, using the new
tc_action_ops, get_dev().
Flower caches the information about the mirred device and use it for
calling ndo_setup_tc in filter change, update stats and delete.
Calling ndo_setup_tc of the mirred (egress) device instead of the
ingress device will allow a resolution between the software ingress
device and the underline hardware device.
The resolution will take place inside the offloading driver using
'egress_device' flag added to tc_to_netdev struct which is provided to
the offloading driver.
Signed-off-by: Hadar Hen Zion <hadarh@mellanox.com>
Should pass valid filter handle, not the netlink flags.
Fixes: 30a391a13ab92 ("net sched filters: pass netlink message flags in event notification")
Signed-off-by: Roman Mashak <mrv@mojatatu.com>
Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com>
Reported-by: Cong Wang <xiyou.wangcong@gmail.com>
Userland client should be able to read an event, and reflect it back to
the kernel, therefore it needs to extract complete set of netlink flags.
For example, this will allow "tc monitor" to distinguish Add and Replace
operations.
Daniel says:
While trying out [1][2], I noticed that tc monitor doesn't show the
correct handle on delete:
$ tc monitor
qdisc clsact ffff: dev eno1 parent ffff:fff1
filter dev eno1 ingress protocol all pref 49152 bpf handle 0x2a [...]
deleted filter dev eno1 ingress protocol all pref 49152 bpf handle 0xf3be0c80
some context to explain the above:
The user identity of any tc filter is represented by a 32-bit
identifier encoded in tcm->tcm_handle. Example 0x2a in the bpf filter
above. A user wishing to delete, get or even modify a specific filter
uses this handle to reference it.
Every classifier is free to provide its own semantics for the 32 bit handle.
Example: classifiers like u32 use schemes like 800:1:801 to describe
the semantics of their filters represented as hash table, bucket and
node ids etc.
Classifiers also have internal per-filter representation which is different
from this externally visible identity. Most classifiers set this
internal representation to be a pointer address (which allows fast retrieval
of said filters in their implementations). This internal representation
is referenced with the "fh" variable in the kernel control code.
When a user successfuly deletes a specific filter, by specifying the correct
tcm->tcm_handle, an event is generated to user space which indicates
which specific filter was deleted.
Before this patch, the "fh" value was sent to user space as the identity.
As an example what is shown in the sample bpf filter delete event above
is 0xf3be0c80. This is infact a 32-bit truncation of 0xffff8807f3be0c80
which happens to be a 64-bit memory address of the internal filter
representation (address of the corresponding filter's struct cls_bpf_prog);
After this patch the appropriate user identifiable handle as encoded
in the originating request tcm->tcm_handle is generated in the event.
One of the cardinal rules of netlink rules is to be able to take an
event (such as a delete in this case) and reflect it back to the
kernel and successfully delete the filter. This patch achieves that.
Note, this issue has existed since the original TC action
infrastructure code patch back in 2004 as found in:
https://git.kernel.org/cgit/linux/kernel/git/history/history.git/commit/
[1] http://patchwork.ozlabs.org/patch/682828/
[2] http://patchwork.ozlabs.org/patch/682829/
Fixes: 4e54c4816bfe ("[NET]: Add tc extensions infrastructure.")
Reported-by: Daniel Borkmann <daniel@iogearbox.net>
There are two ways to get tc filters from kernel to user space.
1) Full dump (tc_dump_tfilter())
2) RTM_GETTFILTER to get one precise filter, reducing overhead.
The second operation is unfortunately broadcasting its result,
polluting "tc monitor" users.
This patch makes sure only the requester gets the result, using
netlink_unicast() instead of rtnetlink_send()
Jamal cooked an iproute2 patch to implement "tc filter get" operation,
but other user space libraries already use RTM_GETTFILTER when a single
filter is queried, instead of dumping all filters.
As pointed out by Jamal, an action could be shared by
multiple filters, so we can't use list to chain them
any more after we get rid of the original tc_action.
Instead, we could just save pointers to these actions
in tcf_exts, since they are refcount'ed, so convert
the list to an array of pointers.
The "ugly" part is the action API still accepts list
as a parameter, I just introduce a helper function to
convert the array of pointers to a list, instead of
relying on the C99 feature to iterate the array.
Fixes: a85a970af265 ("net_sched: move tc_action into tcf_common")
When we check for RTM_DELTFILTER, we should also reject the request
for deleting all filters under a given parent when TCA_KIND attribute
is present. If present, it's currently just ignored but there's also
no point to let it pass in the first place either since this doesn't
have any meaning with wild-card removal.
Fixes: ea7f8277f907 ("net, cls: allow for deleting all filters for given parent")
Add a possibility where the user can just specify the parent and
all filters under that parent are then being purged. Currently,
for example for scripting, one needs to specify pref/prio to have
a well-defined number for 'tc filter del' command for addressing
the previously created instance or additionally filter handle in
case of priorities being the same. Improve usage by allowing the
option for tc to specify the parent and removing the whole chain
for that given parent.
Example usage after patch, no tc changes required:
# tc qdisc replace dev foo clsact
# tc filter add dev foo egress bpf da obj ./bpf.o
# tc filter show dev foo egress
filter protocol all pref 49151 bpf
filter protocol all pref 49151 bpf handle 0x1 bpf.o:[classifier] direct-action
filter protocol all pref 49152 bpf
filter protocol all pref 49152 bpf handle 0x1 bpf.o:[classifier] direct-action
# tc filter del dev foo egress
Previously, RTM_DELTFILTER requests with invalid prio of 0 were
rejected, so only netlink requests with RTM_NEWTFILTER and NLM_F_CREATE
flag were allowed where the kernel would auto-generate a pref/prio.
We can piggyback on that and use prio of 0 as a wildcard for
requests of RTM_DELTFILTER.
For notifying tc netlink monitoring users (e.g. libnl uses this
for caching), there are two options, that is, sending individual
tfilter_notify() notifications for each tcf_proto, or sending a
single one indicating wildcard removal. I tried both and there
are pros and cons for each, eventually I decided for sending
individual tfilter_notify(), so that user space can support this
seamlessly and there won't be a mess of changing each and every
application to make sure expectations from the kernel won't break
when they don't understand single notification. Since linear chains
don't really scale, I expect only a handful of classifiers to be
attached at max for a given parent anyway.
Acked-by: Alexei Starovoitov <ast@kernel.org>
