As gre does not have the srckey in the packet gre_pkt_to_tuple
needs to perform a lookup in it's per network namespace tables.
Pass in the proper network namespace to all pkt_to_tuple
implementations to ensure gre (and any similar protocols) can get this
right.
Stop guessing the struct net instead of remember it. Guessing is just
silly and will be problematic in the future when I implement routes
between network namespaces.
This work adds a direction parameter to netfilter zones, so identity
separation can be performed only in original/reply or both directions
(default). This basically opens up the possibility of doing NAT with
conflicting IP address/port tuples from multiple, isolated tenants
on a host (e.g. from a netns) without requiring each tenant to NAT
twice resp. to use its own dedicated IP address to SNAT to, meaning
overlapping tuples can be made unique with the zone identifier in
original direction, where the NAT engine will then allocate a unique
tuple in the commonly shared default zone for the reply direction.
In some restricted, local DNAT cases, also port redirection could be
used for making the reply traffic unique w/o requiring SNAT.
The consensus we've reached and discussed at NFWS and since the initial
implementation [1] was to directly integrate the direction meta data
into the existing zones infrastructure, as opposed to the ct->mark
approach we proposed initially.
As we pass the nf_conntrack_zone object directly around, we don't have
to touch all call-sites, but only those, that contain equality checks
of zones. Thus, based on the current direction (original or reply),
we either return the actual id, or the default NF_CT_DEFAULT_ZONE_ID.
CT expectations are direction-agnostic entities when expectations are
being compared among themselves, so we can only use the identifier
in this case.
Note that zone identifiers can not be included into the hash mix
anymore as they don't contain a "stable" value that would be equal
for both directions at all times, f.e. if only zone->id would
unconditionally be xor'ed into the table slot hash, then replies won't
find the corresponding conntracking entry anymore.
If no particular direction is specified when configuring zones, the
behaviour is exactly as we expect currently (both directions).
Support has been added for the CT netlink interface as well as the
x_tables raw CT target, which both already offer existing interfaces
to user space for the configuration of zones.
Below a minimal, simplified collision example (script in [2]) with
netperf sessions:
+--- tenant-1 ---+ mark := 1
| netperf |--+
+----------------+ | CT zone := mark [ORIGINAL]
[ip,sport] := X +--------------+ +--- gateway ---+
| mark routing |--| SNAT |-- ... +
+--- tenant-2 ---+ | ~~~|~~~
| netperf |--+ +-----------+ |
+----------------+ mark := 2 | netserver |------ ... +
[ip,sport] := X +-----------+
[ip,port] := Y
On the gateway netns, example:
iptables -t raw -A PREROUTING -j CT --zone mark --zone-dir ORIGINAL
iptables -t nat -A POSTROUTING -o <dev> -j SNAT --to-source <ip> --random-fully
iptables -t mangle -A PREROUTING -m conntrack --ctdir ORIGINAL -j CONNMARK --save-mark
iptables -t mangle -A POSTROUTING -m conntrack --ctdir REPLY -j CONNMARK --restore-mark
conntrack dump from gateway netns:
netperf -H 10.1.1.2 -t TCP_STREAM -l60 -p12865,5555 from each tenant netns
tcp 6 431995 ESTABLISHED src=40.1.1.1 dst=10.1.1.2 sport=5555 dport=12865 zone-orig=1
src=10.1.1.2 dst=10.1.1.1 sport=12865 dport=1024
[ASSURED] mark=1 secctx=system_u:object_r:unlabeled_t:s0 use=1
tcp 6 431994 ESTABLISHED src=40.1.1.1 dst=10.1.1.2 sport=5555 dport=12865 zone-orig=2
src=10.1.1.2 dst=10.1.1.1 sport=12865 dport=5555
[ASSURED] mark=2 secctx=system_u:object_r:unlabeled_t:s0 use=1
tcp 6 299 ESTABLISHED src=40.1.1.1 dst=10.1.1.2 sport=39438 dport=33768 zone-orig=1
src=10.1.1.2 dst=10.1.1.1 sport=33768 dport=39438
tcp 6 300 ESTABLISHED src=40.1.1.1 dst=10.1.1.2 sport=32889 dport=40206 zone-orig=2
src=10.1.1.2 dst=10.1.1.1 sport=40206 dport=32889
[ASSURED] mark=2 secctx=system_u:object_r:unlabeled_t:s0 use=2
Taking this further, test script in [2] creates 200 tenants and runs
original-tuple colliding netperf sessions each. A conntrack -L dump in
the gateway netns also confirms 200 overlapping entries, all in ESTABLISHED
state as expected.
I also did run various other tests with some permutations of the script,
to mention some: SNAT in random/random-fully/persistent mode, no zones (no
overlaps), static zones (original, reply, both directions), etc.
[1] http://thread.gmane.org/gmane.comp.security.firewalls.netfilter.devel/57412/
[2] https://paste.fedoraproject.org/242835/65657871/
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
This patch replaces the zone id which is pushed down into functions
with the actual zone object. It's a bigger one-time change, but
needed for later on extending zones with a direction parameter, and
thus decoupling this additional information from all call-sites.
No functional changes in this patch.
The default zone becomes a global const object, namely nf_ct_zone_dflt
and will be returned directly in various cases, one being, when there's
f.e. no zoning support.
Reuse existing percpu infrastructure John Fastabend added for qdisc.
This patch adds a new cpustats parameter to tcf_hash_create() and all
actions pass false, meaning this patch should have no effect yet.
Cc: Alexei Starovoitov <ast@plumgrid.com>
Acked-by: Jamal Hadi Salim <jhs@mojatatu.com>
Acked-by: John Fastabend <john.fastabend@gmail.com>
This action is meant to be passive, i.e. we should not alter
skb->nfct: If nfct is present just leave it alone.
Compile tested only.
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Acked-by: Pablo Neira Ayuso <pablo@netfilter.org>
This tc action allows you to retrieve the connection tracking mark
This action has been used heavily by openwrt for a few years now.
There are known limitations currently:
doesn't work for initial packets, since we only query the ct table.
Fine given use case is for returning packets
no implicit defrag.
frags should be rare so fix later..
won't work for more complex tasks, e.g. lookup of other extensions
since we have no means to store results
we still have a 2nd lookup later on via normal conntrack path.
This shouldn't break anything though since skb->nfct isn't altered.
V2:
remove unnecessary braces (Jiri)
change the action identifier to 14 (Jiri)
Fix some stylistic issues caught by checkpatch
V3:
Move module params to bottom (Cong)
Get rid of tcf_hashinfo_init and friends and conform to newer API (Cong)
Acked-by: Jiri Pirko <jiri@resnulli.us>
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com>
