path: root/net/rds
2010-09-08RDS: Do not mask address when pinning pagesAndy Grover
This does not appear to be necessary. Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS: Base init_depth and responder_resources on hw valuesAndy Grover
Instead of using a constant for initiator_depth and responder_resources, read the per-QP values when the device is enumerated, and then use these values when creating the connection. Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS: Implement atomic operationsAndy Grover
Implement a CMSG-based interface to do FADD and CSWP ops. Alter send routines to handle atomic ops. Add atomic counters to stats. Add xmit_atomic() to struct rds_transport Inline rds_ib_send_unmap_rdma into unmap_rm Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS: Clear up some confusing code in send_remove_from_sockAndy Grover
The previous code was correct, but made the assumption that if r_notifier was non-NULL then either r_recverr or r_notify was true. Valid, but fragile. Changed to explicitly check r_recverr (shows up in greps for recverr now, too.) Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS: make sure all sgs alloced are initializedAndy Grover
rds_message_alloc_sgs() now returns correctly-initialized sg lists, so calleds need not do this themselves. Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS: make m_rdma_op a member of rds_messageAndy Grover
This eliminates a separate memory alloc, although it is now necessary to add an "r_active" flag, since it is no longer to use the m_rdma_op pointer as an indicator of if an rdma op is present. rdma SGs allocated from rm sg pool. rds_rm_size also gets bigger. It's a little inefficient to run through CMSGs twice, but it makes later steps a lot smoother. Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS: fold rdma.h into rds.hAndy Grover
RDMA is now an intrinsic part of RDS, so it's easier to just have a single header. Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS: Explicitly allocate rm in sendmsg()Andy Grover
r_m_copy_from_user used to allocate the rm as well as kernel buffers for the data, and then copy the data in. Now, sendmsg() allocates the rm, although the data buffer alloc still happens in r_m_copy_from_user. SGs are still allocated with rm, but now r_m_alloc_sgs() is used to reserve them. This allows multiple SG lists to be allocated from the one rm -- this is important once we also want to alloc our rdma sgl from this pool. Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS: cleanup/fix rds_rdma_unuseAndy Grover
First, it looks to me like the atomic_inc is wrong. We should be decrementing refcount only once here, no? It's already being done by the mr_put() at the end. Second, simplify the logic a bit by bailing early (with a warning) if !mr. Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS: break out rdma and data ops into nested structs in rds_messageAndy Grover
Clearly separate rdma-related variables in rm from data-related ones. This is in anticipation of adding atomic support. Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS: cleanup: remove "== NULL"s and "!= NULL"s in ptr comparisonsAndy Grover
Favor "if (foo)" style over "if (foo != NULL)". Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS: move rds_shutdown_worker impl. to rds_conn_shutdownAndy Grover
This fits better in connection.c, rather than threads.c. Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS: Fix locking in send on m_rs_lockAndy Grover
Do not nest m_rs_lock under c_lock Disable interrupts in {rdma,atomic}_send_complete Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS: Rewrite rds_send_drop_to() for clarityAndy Grover
This function has been the source of numerous bugs; it's just too complicated. Simplified to nest spinlocks cleanly within the second loop body, and kick out early if there are no rms to drop. This will be a little slower because conn lock is grabbed for each entry instead of "caching" the lock across rms, but this should be entirely irrelevant to fastpath performance. Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS: Fix corrupted rds_mrsTina Yang
On second look at this bug (OFED #2002), it seems that the collision is not with the retransmission queue (packet acked by the peer), but with the local send completion. A theoretical sequence of events (from time t0 to t3) is thought to be as follows, Thread #1 t0: sock_release rds_release rds_send_drop_to /* wait on send completion */ t2: rds_rdma_drop_keys() /* destroy & free all mrs */ Thread #2 t1: rds_ib_send_cq_comp_handler rds_ib_send_unmap_rm rds_message_unmapped /* wake up #1 @ t0 */ t3: rds_message_put rds_message_purge rds_mr_put /* memory corruption detected */ The problem with the rds_rdma_drop_keys() is it could remove a mr's refcount more than its due (i.e. repeatedly as long as it still remains in the tree (mr->r_refcount > 0)). Theoretically it should remove only one reference - reference by the tree. /* Release any MRs associated with this socket */ while ((node = rb_first(&rs->rs_rdma_keys))) { mr = container_of(node, struct rds_mr, r_rb_node); if (mr->r_trans == rs->rs_transport) mr->r_invalidate = 0; rds_mr_put(mr); } I think the correct way of doing it is to remove the mr from the tree and rds_destroy_mr it first, then a rds_mr_put() to decrement its reference count by one. Whichever thread holds the last reference will free the mr via rds_mr_put(). Signed-off-by: Tina Yang <tina.yang@oracle.com> Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS: Fix BUG_ONs to not fire when in a taskletAndy Grover
in_interrupt() is true in softirqs. The BUG_ONs are supposed to check for if irqs are disabled, so we should use BUG_ON(irqs_disabled()) instead, duh. Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-08-18rds: fix a leak of kernel memoryEric Dumazet
struct rds_rdma_notify contains a 32 bits hole on 64bit arches, make sure it is zeroed before copying it to user. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-29net/rds: Add missing mutex_unlockJulia Lawall
Add a mutex_unlock missing on the error path. In each case, whenever the label out is reached from elsewhere in the function, mutex is not locked. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression E1; @@ * mutex_lock(E1); <+... when != E1 if (...) { ... when != E1 * return ...; } ...+> * mutex_unlock(E1); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Reviewed-by: Zach Brown <zach.brown@oracle.com> Acked-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17net: Remove unnecessary semicolons after switch statementsJoe Perches
Also added an explicit break; to avoid a fallthrough in net/ipv4/tcp_input.c Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/e100.c drivers/net/e1000e/netdev.c
2010-04-22rdma: potential ERR_PTR dereferenceDan Carpenter
In the original code, the "goto out" calls "rdma_destroy_id(cm_id);" That isn't needed here and would cause problems because "cm_id" is an ERR_PTR. The new code just returns directly. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20net: sk_sleep() helperEric Dumazet
Define a new function to return the waitqueue of a "struct sock". static inline wait_queue_head_t *sk_sleep(struct sock *sk) { return sk->sk_sleep; } Change all read occurrences of sk_sleep by a call to this function. Needed for a future RCU conversion. sk_sleep wont be a field directly available. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-24rds: cleanup: remove unneeded variableDan Carpenter
We never use "sk" so this patch removes it. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16RDS: Enable per-cpu workqueue threadsTina Yang
Create per-cpu workqueue threads instead of a single krdsd thread. This is a step towards better scalability. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16RDS: Do not call set_page_dirty() with irqs offAndy Grover
set_page_dirty() unconditionally re-enables interrupts, so if we call it with irqs off, they will be on after the call, and that's bad. This patch moves the call after we've re-enabled interrupts in send_drop_to(), so it's safe. Also, add BUG_ONs to let us know if we ever do call set_page_dirty with interrupts off. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16RDS: Properly unmap when getting a remote access errorSherman Pun
If the RDMA op has aborted with a remote access error, in addition to what we already do (tell userspace it has completed with an error) also unmap it and put() the rm. Otherwise, hangs may occur on arches that track maps and will not exit without proper cleanup. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16RDS: only put sockets that have seen congestion on the poll_waitqAndy Grover
rds_poll_waitq's listeners will be awoken if we receive a congestion notification. Bad performance may result because *all* polled sockets contend for this single lock. However, it should not be necessary to wake pollers when a congestion update arrives if they have never experienced congestion, and not putting these on the waitq will hopefully greatly reduce contention. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16RDS: Fix locking in rds_send_drop_to()Tina Yang
It seems rds_send_drop_to() called __rds_rdma_send_complete(rs, rm, RDS_RDMA_CANCELED) with only rds_sock lock, but not rds_message lock. It raced with other threads that is attempting to modify the rds_message as well, such as from within rds_rdma_send_complete(). Signed-off-by: Tina Yang <tina.yang@oracle.com> Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16RDS: Turn down alarming reconnect messagesAndy Grover
RDS's error messages when a connection goes down are a little extreme. A connection may go down, and it will be re-established, and everything is fine. This patch links these messages through rdsdebug(), instead of to printk directly. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16RDS: Workaround for in-use MRs on close causing crashAndy Grover
if a machine is shut down without closing sockets properly, and freeing all MRs, then a BUG_ON will bring it down. This patch changes these to WARN_ONs -- leaking MRs is not fatal (although not ideal, and there is more work to do here for a proper fix.) Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16RDS: Fix send locking issueTina Yang
Fix a deadlock between rds_rdma_send_complete() and rds_send_remove_from_sock() when rds socket lock and rds message lock are acquired out-of-order. Signed-off-by: Tina Yang <Tina.Yang@oracle.com> Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16RDS: Fix congestion issues for loopbackAndy Grover
We have two kinds of loopback: software (via loop transport) and hardware (via IB). sw is used for 127.0.0.1, and doesn't support rdma ops. hw is used for sends to local device IPs, and supports rdma. Both are used in different cases. For both of these, when there is a congestion map update, we want to call rds_cong_map_updated() but not actually send anything -- since loopback local and foreign congestion maps point to the same spot, they're already in sync. The old code never called sw loop's xmit_cong_map(),so rds_cong_map_updated() wasn't being called for it. sw loop ports would not work right with the congestion monitor. Fixing that meant that hw loopback now would send congestion maps to itself. This is also undesirable (racy), so we check for this case in the ib-specific xmit code. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16RDS/TCP: Wait to wake thread when write space availableAndy Grover
Instead of waking the send thread whenever any send space is available, wait until it is at least half empty. This is modeled on how sock_def_write_space() does it, and may help to minimize context switches. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16RDS: update copy_to_user state in tcp transportAndy Grover
Other transports use rds_page_copy_user, which updates our s_copy_to_user counter. TCP doesn't, so it needs to explicity call rds_stats_add(). Reported-by: Richard Frank <richard.frank@oracle.com> Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16RDS: sendmsg() should check sndtimeo, not rcvtimeoAndy Grover
Most likely cut n paste error - sendmsg() was checking sock_rcvtimeo. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16RDS: Do not BUG() on error returned from ib_post_sendAndy Grover
BUGging on a runtime error code should be avoided. This patch also eliminates all other BUG()s that have no real reason to exist. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-03net/rds: remove uses of NIPQUAD, use %pI4Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Cc: Andy Grover <andy.grover@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (45 commits) RDMA/cxgb3: Fix error paths in post_send and post_recv RDMA/nes: Fix stale ARP issue RDMA/nes: FIN during MPA startup causes timeout RDMA/nes: Free kmap() resources RDMA/nes: Check for zero STag RDMA/nes: Fix Xansation test crash on cm_node ref_count RDMA/nes: Abnormal listener exit causes loopback node crash RDMA/nes: Fix crash in nes_accept() RDMA/nes: Resource not freed for REJECTed connections RDMA/nes: MPA request/response error checking RDMA/nes: Fix query of ORD values RDMA/nes: Fix MAX_CM_BUFFER define RDMA/nes: Pass correct size to ioremap_nocache() RDMA/nes: Update copyright and branding string RDMA/nes: Add max_cqe check to nes_create_cq() RDMA/nes: Clean up struct nes_qp RDMA/nes: Implement IB_SIGNAL_ALL_WR as an iWARP extension RDMA/nes: Add additional SFP+ PHY uC status check and PHY reset RDMA/nes: Correct fast memory registration implementation IB/ehca: Fix error paths in post_send and post_recv ...
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1815 commits) mac80211: fix reorder buffer release iwmc3200wifi: Enable wimax core through module parameter iwmc3200wifi: Add wifi-wimax coexistence mode as a module parameter iwmc3200wifi: Coex table command does not expect a response iwmc3200wifi: Update wiwi priority table iwlwifi: driver version track kernel version iwlwifi: indicate uCode type when fail dump error/event log iwl3945: remove duplicated event logging code b43: fix two warnings ipw2100: fix rebooting hang with driver loaded cfg80211: indent regulatory messages with spaces iwmc3200wifi: fix NULL pointer dereference in pmkid update mac80211: Fix TX status reporting for injected data frames ath9k: enable 2GHz band only if the device supports it airo: Fix integer overflow warning rt2x00: Fix padding bug on L2PAD devices. WE: Fix set events not propagated b43legacy: avoid PPC fault during resume b43: avoid PPC fault during resume tcp: fix a timewait refcnt race ... Fix up conflicts due to sysctl cleanups (dead sysctl_check code and CTL_UNNUMBERED removed) in kernel/sysctl_check.c net/ipv4/sysctl_net_ipv4.c net/ipv6/addrconf.c net/sctp/sysctl.c
2009-11-29net: Move && and || to end of previous lineJoe Perches
Not including net/atm/ Compiled tested x86 allyesconfig only Added a > 80 column line or two, which I ignored. Existing checkpatch plaints willfully, cheerfully ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-19RDMA/cm: fix loopback address supportSean Hefty
The RDMA CM is intended to support the use of a loopback address when establishing a connection; however, the behavior of the CM when loopback addresses are used is confusing and does not always work, depending on whether loopback was specified by the server, the client, or both. The defined behavior of rdma_bind_addr is to associate an RDMA device with an rdma_cm_id, as long as the user specified a non- zero address. (ie they weren't just trying to reserve a port) Currently, if the loopback address is passed to rdam_bind_addr, no device is associated with the rdma_cm_id. Fix this. If a loopback address is specified by the client as the destination address for a connection, it will fail to establish a connection. This is true even if the server is listing across all addresses or on the loopback address itself. The issue is that the server tries to translate the IP address carried in the REQ message to a local net_device address, which fails. The translation is not needed in this case, since the REQ carries the actual HW address that should be used. Finally, cleanup loopback support to be more transport neutral. Replace separate calls to get/set the sgid and dgid from the device address to a single call that behaves correctly depending on the format of the device address. And support both IPv4 and IPv6 address formats. Signed-off-by: Sean Hefty <sean.hefty@intel.com> [ Fixed RDS build by s/ib_addr_get/rdma_addr_get/ - Roland ] Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-11-18sysctl: Drop & in front of every proc_handler.Eric W. Biederman
For consistency drop & in front of every proc_handler. Explicity taking the address is unnecessary and it prevents optimizations like stubbing the proc_handlers to NULL. Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joe Perches <joe@perches.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-12sysctl net: Remove unused binary sysctl codeEric W. Biederman
Now that sys_sysctl is a compatiblity wrapper around /proc/sys all sysctl strategy routines, and all ctl_name and strategy entries in the sysctl tables are unused, and can be revmoed. In addition neigh_sysctl_register has been modified to no longer take a strategy argument and it's callers have been modified not to pass one. Cc: "David Miller" <davem@davemloft.net> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: netdev@vger.kernel.org Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-05net: pass kern to net_proto_family create functionEric Paris
The generic __sock_create function has a kern argument which allows the security system to make decisions based on if a socket is being created by the kernel or by userspace. This patch passes that flag to the net_proto_family specific create function, so it can do the same thing. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-30RDS/IB+IW: Move recv processing to a taskletAndy Grover
Move receive processing from event handler to a tasklet. This should help prevent hangcheck timer from going off when RDS is under heavy load. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-30RDS: Do not send congestion updates to loopback connectionsAndy Grover
This issue was discovered by HP's Pradeep and fixed in OFED 1.3, but not fixed in later versions, since the fix's implementation was not immediately applyable to the later code. This patch should do the trick for 1.4+ codebases. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-30RDS: Fix panic on unloadAndy Grover
Remove explicit destruction of passive connection when destroying active end of the connection. The passive end is also on the device's connection list, and will thus be cleaned up properly. Panic was caused by trying to clean it up twice. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-30RDS: Fix potential race around rds_i[bw]_allocationAndy Grover
"At rds_ib_recv_refill_one(), it first executes atomic_read(&rds_ib_allocation) for if-condition checking, and then executes atomic_inc(&rds_ib_allocation) if the condition was not satisfied. However, if any other code which updates rds_ib_allocation executes between these two atomic operation executions, it seems that it may result race condition. (especially when rds_ib_allocation + 1 == rds_ib_sysctl_max_recv_allocation)" This patch fixes this by using atomic_inc_unless to eliminate the possibility of allocating more than rds_ib_sysctl_max_recv_allocation and then decrementing the count if the allocation fails. It also makes an identical change to the iwarp transport. Reported-by: Shin Hong <hongshin@gmail.com> Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
