Commit a93d01f5777e ("RDS: TCP: avoid bad page reference in
rds_tcp_listen_data_ready") added the function
rds_tcp_listen_sock_def_readable() to handle the case when a
partially set-up acceptor socket drops into rds_tcp_listen_data_ready().
However, if the listen socket (rtn->rds_tcp_listen_sock) is itself going
through a tear-down via rds_tcp_listen_stop(), the (*ready)() will be
null and we would hit a panic of the form
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: (null)
? rds_tcp_listen_data_ready+0x59/0xb0 [rds_tcp]
tcp_data_queue+0x39d/0x5b0
tcp_rcv_established+0x2e5/0x660
tcp_v4_do_rcv+0x122/0x220
tcp_v4_rcv+0x8b7/0x980
In the above case, it is not fatal to encounter a NULL value for
ready- we should just drop the packet and let the flush of the
acceptor thread finish gracefully.
In general, the tear-down sequence for listen() and accept() socket
that is ensured by this commit is:
rtn->rds_tcp_listen_sock = NULL; /* prevent any new accepts */
In rds_tcp_listen_stop():
serialize with, and prevent, further callbacks using lock_sock()
flush rds_wq
flush acceptor workq
sock_release(listen socket)
Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
As the existing comments in rds_tcp_listen_data_ready() indicate,
it is possible under some race-windows to get to this function with the
accept() socket. If that happens, we could run into a sequence whereby
thread 1 thread 2
rds_tcp_accept_one() thread
sets up new_sock via ->accept().
The sk_user_data is now
sock_def_readable
data comes in for new_sock,
->sk_data_ready is called, and
we land in rds_tcp_listen_data_ready
rds_tcp_set_callbacks()
takes the sk_callback_lock and
sets up sk_user_data to be the cp
read_lock sk_callback_lock
ready = cp
unlock sk_callback_lock
page fault on ready
In the above sequence, we end up with a panic on a bad page reference
when trying to execute (*ready)(). Instead we need to call
sock_def_readable() safely, which is what this patch achieves.
Acked-by: Santosh Shilimkar <santosh.shilimkar@oracle.com>
This patch adds ->conn_path_connect callbacks in the rds_transport
that are used to set up a single connection path.
The ->sk_user_data contains a pointer to the rds_conn_path
for the socket. Use this consistently in the rds_tcp_data_ready
callbacks to get the rds_conn_path for rds_recv_incoming.
The socket callbacks should all operate on a struct rds_conn_path,
in preparation for a MP capable RDS-TCP.
The struct rds_tcp_connection is the transport-specific private
data structure that tracks TCP information per rds_conn_path.
Modify this structure to have a back-pointer to the rds_conn_path
for which it is the ->cp_transport_data.
Refactor code to avoid separate indirections for single-path
and multipath transports. All transports (both single and mp-capable)
will get a pointer to the rds_conn_path, and can trivially derive
the rds_connection from the ->cp_conn.
Fix coding style issues in the following files:
ib_cm.c: add space
loop.c: convert spaces to tabs
sysctl.c: add space
tcp.h: convert spaces to tabs
tcp_connect.c:remove extra indentation in switch statement
tcp_recv.c: convert spaces to tabs
tcp_send.c: convert spaces to tabs
transport.c: move brace up one line on for statement
Signed-off-by: Joshua Houghton <josh@awful.name>
When rds_tcp_accept_one() has to replace the existing tcp socket
with a newer tcp socket (duelling-syn resolution), it must lock_sock()
to suppress the rds_tcp_data_recv() path while callbacks are being
changed. Also, existing RDS datagram reassembly state must be reset,
so that the next datagram on the new socket does not have corrupted
state. Similarly when resetting the newly accepted socket, appropriate
locks and synchronization is needed.
This commit ensures correct synchronization by invoking
kernel_sock_shutdown to reset a newly accepted sock, and by taking
appropriate lock_sock()s (for old and new sockets) when resetting
existing callbacks.
An arbitration scheme for duelling SYNs is implemented as part of
commit 241b271952eb ("RDS-TCP: Reset tcp callbacks if re-using an
outgoing socket in rds_tcp_accept_one()") which ensures that both nodes
involved will arrive at the same arbitration decision. However, this
needs to be synchronized with an outgoing SYN to be generated by
rds_tcp_conn_connect(). This commit achieves the synchronization
through the t_conn_lock mutex in struct rds_tcp_connection.
The rds_conn_state is checked in rds_tcp_conn_connect() after acquiring
the t_conn_lock mutex. A SYN is sent out only if the RDS connection is
not already UP (an UP would indicate that rds_tcp_accept_one() has
completed 3WH, so no SYN needs to be generated).
Similarly, the rds_conn_state is checked in rds_tcp_accept_one() after
acquiring the t_conn_lock mutex. The only acceptable states (to
allow continuation of the arbitration logic) are UP (i.e., outgoing SYN
was SYN-ACKed by peer after it sent us the SYN) or CONNECTING (we sent
outgoing SYN before we saw incoming SYN).
Register pernet subsys init/stop functions that will set up
and tear down per-net RDS-TCP listen endpoints. Unregister
pernet subusys functions on 'modprobe -r' to clean up these
end points.
Enable keepalive on both accept and connect socket endpoints.
The keepalive timer expiration will ensure that client socket
endpoints will be removed as appropriate from the netns when
an interface is removed from a namespace.
Register a device notifier callback that will clean up all
sockets (and thus avoid the need to wait for keepalive timeout)
when the loopback device is unregistered from the netns indicating
that the netns is getting deleted.
instances get considerably simpler from that...
Several spots in the kernel perform a sequence like:
skb_queue_tail(&sk->s_receive_queue, skb);
sk->sk_data_ready(sk, skb->len);
But at the moment we place the SKB onto the socket receive queue it
can be consumed and freed up. So this skb->len access is potentially
to freed up memory.
Furthermore, the skb->len can be modified by the consumer so it is
possible that the value isn't accurate.
And finally, no actual implementation of this callback actually uses
the length argument. And since nobody actually cared about it's
value, lots of call sites pass arbitrary values in such as '0' and
even '1'.
So just remove the length argument from the callback, that way there
is no confusion whatsoever and all of these use-after-free cases get
fixed as a side effect.
Based upon a patch by Eric Dumazet and his suggestion to audit this
issue tree-wide.
The RDS protocol has lots of functions that should be
declared static. rds_message_get/add_version_extension is
removed since it defined but never used.
The trivial amount of memory saved isn't worth the cost of dealing with section
mismatches.
Signed-off-by: Zach Brown <zach.brown@oracle.com>
We now ask the transport to give us a rm for the congestion
map, and then we handle it normally. Previously, the
transport defined a function that we would call to send
a congestion map.
Convert TCP and loop transports to new cong map method.
Signed-off-by: Andy Grover <andy.grover@oracle.com>
This code allows RDS to be tunneled over a TCP connection.
RDMA operations are disabled when using TCP transport,
but this frees RDS from the IB/RDMA stack dependency, and allows
it to be used with standard Ethernet adapters, or in a VM.
