path: root/net/netlink/genetlink.c
2013-11-28genetlink/pmcraid: use proper genetlink multicast APIJohannes Berg
The pmcraid driver is abusing the genetlink API and is using its family ID as the multicast group ID, which is invalid and may belong to somebody else (and likely will.) Make it use the correct API, but since this may already be used as-is by userspace, reserve a family ID for this code and also reserve that group ID to not break userspace assumptions. My previous patch broke event delivery in the driver as I missed that it wasn't using the right API and forgot to update it later in my series. While changing this, I noticed that the genetlink code could use the static group ID instead of a strcmp(), so also do that for the VFS_DQUOT family. Cc: Anil Ravindranath <anil_ravindranath@pmc-sierra.com> Cc: "James E.J. Bottomley" <JBottomley@parallels.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-28genetlink: Fix uninitialized variable in genl_validate_assign_mc_groups()Geert Uytterhoeven
net/netlink/genetlink.c: In function ‘genl_validate_assign_mc_groups’: net/netlink/genetlink.c:217: warning: ‘err’ may be used uninitialized in this function Commit 2a94fe48f32ccf7321450a2cc07f2b724a444e5b ("genetlink: make multicast groups const, prevent abuse") split genl_register_mc_group() in multiple functions, but dropped the initialization of err. Initialize err to zero to fix this. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-21genetlink: fix genlmsg_multicast() bugJohannes Berg
Unfortunately, I introduced a tremendously stupid bug into genlmsg_multicast() when doing all those multicast group changes: it adjusts the group number, but then passes it to genlmsg_multicast_netns() which does that again. Somehow, my tests failed to catch this, so add a warning into genlmsg_multicast_netns() and remove the offending group ID adjustment. Also add a warning to the similar code in other functions so people who misuse them are more loudly warned. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-19genetlink: make multicast groups const, prevent abuseJohannes Berg
Register generic netlink multicast groups as an array with the family and give them contiguous group IDs. Then instead of passing the global group ID to the various functions that send messages, pass the ID relative to the family - for most families that's just 0 because the only have one group. This avoids the list_head and ID in each group, adding a new field for the mcast group ID offset to the family. At the same time, this allows us to prevent abusing groups again like the quota and dropmon code did, since we can now check that a family only uses a group it owns. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-19genetlink: pass family to functions using groupsJohannes Berg
This doesn't really change anything, but prepares for the next patch that will change the APIs to pass the group ID within the family, rather than the global group ID. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-19genetlink: remove family pointer from genl_multicast_groupJohannes Berg
There's no reason to have the family pointer there since it can just be passed internally where needed, so remove it. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-19genetlink: remove genl_unregister_mc_group()Johannes Berg
There are no users of this API remaining, and we'll soon change group registration to be static (like ops are now) Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-19quota/genetlink: use proper genetlink multicast APIsJohannes Berg
The quota code is abusing the genetlink API and is using its family ID as the multicast group ID, which is invalid and may belong to somebody else (and likely will.) Make the quota code use the correct API, but since this is already used as-is by userspace, reserve a family ID for this code and also reserve that group ID to not break userspace assumptions. Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-19drop_monitor/genetlink: use proper genetlink multicast APIsJohannes Berg
The drop monitor code is abusing the genetlink API and is statically using the generic netlink multicast group 1, even if that group belongs to somebody else (which it invariably will, since it's not reserved.) Make the drop monitor code use the proper APIs to reserve a group ID, but also reserve the group id 1 in generic netlink code to preserve the userspace API. Since drop monitor can be a module, don't clear the bit for it on unregistration. Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-19genetlink: only pass array to genl_register_family_with_ops()Johannes Berg
As suggested by David Miller, make genl_register_family_with_ops() a macro and pass only the array, evaluating ARRAY_SIZE() in the macro, this is a little safer. The openvswitch has some indirection, assing ops/n_ops directly in that code. This might ultimately just assign the pointers in the family initializations, saving the struct genl_family_and_ops and code (once mcast groups are handled differently.) Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-18genetlink: rename shadowed variableJohannes Berg
Sparse pointed out that the new flags variable I had added shadowed an existing one, rename the new one to avoid that, making the code clearer. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-15genetlink: unify registration functionsJohannes Berg
Now that the ops assignment is just two variables rather than a long list iteration etc., there's no reason to separately export __genl_register_family() and __genl_register_family_with_ops(). Unify the two functions into __genl_register_family() and make genl_register_family_with_ops() call it after assigning the ops. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-14genetlink: allow making ops constJohannes Berg
Allow making the ops array const by not modifying the ops flags on registration but rather only when ops are sent out in the family information. No users are updated yet except for the pre_doit/post_doit calls in wireless (the only ones that exist now.) Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-14genetlink: register family ops as arrayJohannes Berg
Instead of using a linked list, use an array. This reduces the data size needed by the users of genetlink, for example in wireless (net/wireless/nl80211.c) on 64-bit it frees up over 1K of data space. Remove the attempted sending of CTRL_CMD_NEWOPS ctrl event since genl_ctrl_event(CTRL_CMD_NEWOPS, ...) only returns -EINVAL anyway, therefore no such event could ever be sent. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-14genetlink: remove genl_register_ops/genl_unregister_opsJohannes Berg
genl_register_ops() is still needed for internal registration, but is no longer available to users of the API. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-28genl: Hold reference on correct module while netlink-dump.Pravin B Shelar
netlink dump operations take module as parameter to hold reference for entire netlink dump duration. Currently it holds ref only on genl module which is not correct when we use ops registered to genl from another module. Following patch adds module pointer to genl_ops so that netlink can hold ref count on it. CC: Jesse Gross <jesse@nicira.com> CC: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-28genl: Fix genl dumpit() locking.Pravin B Shelar
In case of genl-family with parallel ops off, dumpif() callback is expected to run under genl_lock, But commit def3117493eafd9df (genl: Allow concurrent genl callbacks.) changed this behaviour where only first dumpit() op was called under genl-lock. For subsequent dump, only nlk->cb_lock was taken. Following patch fixes it by defining locked dumpit() and done() callback which takes care of genl-locking. CC: Jesse Gross <jesse@nicira.com> CC: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-22Revert "genetlink: fix family dump race"Johannes Berg
This reverts commit 58ad436fcf49810aa006016107f494c9ac9013db. It turns out that the change introduced a potential deadlock by causing a locking dependency with netlink's cb_mutex. I can't seem to find a way to resolve this without doing major changes to the locking, so revert this. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Acked-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-13genetlink: fix family dump raceJohannes Berg
When dumping generic netlink families, only the first dump call is locked with genl_lock(), which protects the list of families, and thus subsequent calls can access the data without locking, racing against family addition/removal. This can cause a crash. Fix it - the locking needs to be conditional because the first time around it's already locked. A similar bug was reported to me on an old kernel (3.4.47) but the exact scenario that happened there is no longer possible, on those kernels the first round wasn't locked either. Looking at the current code I found the race described above, which had also existed on the old kernel. Cc: stable@vger.kernel.org Reported-by: Andrei Otcheretianski <andrei.otcheretianski@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-30genetlink: fix usage of NLM_F_EXCL or NLM_F_REPLACEPablo Neira
Currently, it is not possible to use neither NLM_F_EXCL nor NLM_F_REPLACE from genetlink. This is due to this checking in genl_family_rcv_msg: if (nlh->nlmsg_flags & NLM_F_DUMP) NLM_F_DUMP is NLM_F_MATCH|NLM_F_ROOT. Thus, if NLM_F_EXCL or NLM_F_REPLACE flag is set, genetlink believes that you're requesting a dump and it calls the .dumpit callback. The solution that I propose is to refine this checking to make it stricter: if ((nlh->nlmsg_flags & NLM_F_DUMP) == NLM_F_DUMP) And given the combination NLM_F_REPLACE and NLM_F_EXCL does not make sense to me, it removes the ambiguity. There was a patch that tried to fix this some time ago (0ab03c2 netlink: test for all flags of the NLM_F_DUMP composite) but it tried to resolve this ambiguity in *all* existing netlink subsystems, not only genetlink. That patch was reverted since it broke iproute2, which is using NLM_F_ROOT to request the dump of the routing cache. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-27genetlink: release cb_lock before requesting additional moduleStanislaw Gruszka
Requesting external module with cb_lock taken can result in the deadlock like showed below: [ 2458.111347] Showing all locks held in the system: [ 2458.111347] 1 lock held by NetworkManager/582: [ 2458.111347] #0: (cb_lock){++++++}, at: [<ffffffff8162bc79>] genl_rcv+0x19/0x40 [ 2458.111347] 1 lock held by modprobe/603: [ 2458.111347] #0: (cb_lock){++++++}, at: [<ffffffff8162baa5>] genl_lock_all+0x15/0x30 [ 2461.579457] SysRq : Show Blocked State [ 2461.580103] task PC stack pid father [ 2461.580103] NetworkManager D ffff880034b84500 4040 582 1 0x00000080 [ 2461.580103] ffff8800197ff720 0000000000000046 00000000001d5340 ffff8800197fffd8 [ 2461.580103] ffff8800197fffd8 00000000001d5340 ffff880019631700 7fffffffffffffff [ 2461.580103] ffff8800197ff880 ffff8800197ff878 ffff880019631700 ffff880019631700 [ 2461.580103] Call Trace: [ 2461.580103] [<ffffffff817355f9>] schedule+0x29/0x70 [ 2461.580103] [<ffffffff81731ad1>] schedule_timeout+0x1c1/0x360 [ 2461.580103] [<ffffffff810e69eb>] ? mark_held_locks+0xbb/0x140 [ 2461.580103] [<ffffffff817377ac>] ? _raw_spin_unlock_irq+0x2c/0x50 [ 2461.580103] [<ffffffff810e6b6d>] ? trace_hardirqs_on_caller+0xfd/0x1c0 [ 2461.580103] [<ffffffff81736398>] wait_for_completion_killable+0xe8/0x170 [ 2461.580103] [<ffffffff810b7fa0>] ? wake_up_state+0x20/0x20 [ 2461.580103] [<ffffffff81095825>] call_usermodehelper_exec+0x1a5/0x210 [ 2461.580103] [<ffffffff817362ed>] ? wait_for_completion_killable+0x3d/0x170 [ 2461.580103] [<ffffffff81095cc3>] __request_module+0x1b3/0x370 [ 2461.580103] [<ffffffff810e6b6d>] ? trace_hardirqs_on_caller+0xfd/0x1c0 [ 2461.580103] [<ffffffff8162c5c9>] ctrl_getfamily+0x159/0x190 [ 2461.580103] [<ffffffff8162d8a4>] genl_family_rcv_msg+0x1f4/0x2e0 [ 2461.580103] [<ffffffff8162d990>] ? genl_family_rcv_msg+0x2e0/0x2e0 [ 2461.580103] [<ffffffff8162da1e>] genl_rcv_msg+0x8e/0xd0 [ 2461.580103] [<ffffffff8162b729>] netlink_rcv_skb+0xa9/0xc0 [ 2461.580103] [<ffffffff8162bc88>] genl_rcv+0x28/0x40 [ 2461.580103] [<ffffffff8162ad6d>] netlink_unicast+0xdd/0x190 [ 2461.580103] [<ffffffff8162b149>] netlink_sendmsg+0x329/0x750 [ 2461.580103] [<ffffffff815db849>] sock_sendmsg+0x99/0xd0 [ 2461.580103] [<ffffffff810bb58f>] ? local_clock+0x5f/0x70 [ 2461.580103] [<ffffffff810e96e8>] ? lock_release_non_nested+0x308/0x350 [ 2461.580103] [<ffffffff815dbc6e>] ___sys_sendmsg+0x39e/0x3b0 [ 2461.580103] [<ffffffff810565af>] ? kvm_clock_read+0x2f/0x50 [ 2461.580103] [<ffffffff810218b9>] ? sched_clock+0x9/0x10 [ 2461.580103] [<ffffffff810bb2bd>] ? sched_clock_local+0x1d/0x80 [ 2461.580103] [<ffffffff810bb448>] ? sched_clock_cpu+0xa8/0x100 [ 2461.580103] [<ffffffff810e33ad>] ? trace_hardirqs_off+0xd/0x10 [ 2461.580103] [<ffffffff810bb58f>] ? local_clock+0x5f/0x70 [ 2461.580103] [<ffffffff810e3f7f>] ? lock_release_holdtime.part.28+0xf/0x1a0 [ 2461.580103] [<ffffffff8120fec9>] ? fget_light+0xf9/0x510 [ 2461.580103] [<ffffffff8120fe0c>] ? fget_light+0x3c/0x510 [ 2461.580103] [<ffffffff815dd1d2>] __sys_sendmsg+0x42/0x80 [ 2461.580103] [<ffffffff815dd222>] SyS_sendmsg+0x12/0x20 [ 2461.580103] [<ffffffff81741ad9>] system_call_fastpath+0x16/0x1b [ 2461.580103] modprobe D ffff88000f2c8000 4632 603 602 0x00000080 [ 2461.580103] ffff88000f04fba8 0000000000000046 00000000001d5340 ffff88000f04ffd8 [ 2461.580103] ffff88000f04ffd8 00000000001d5340 ffff8800377d4500 ffff8800377d4500 [ 2461.580103] ffffffff81d0b260 ffffffff81d0b268 ffffffff00000000 ffffffff81d0b2b0 [ 2461.580103] Call Trace: [ 2461.580103] [<ffffffff817355f9>] schedule+0x29/0x70 [ 2461.580103] [<ffffffff81736d4d>] rwsem_down_write_failed+0xed/0x1a0 [ 2461.580103] [<ffffffff810bb200>] ? update_cpu_load_active+0x10/0xb0 [ 2461.580103] [<ffffffff8137b473>] call_rwsem_down_write_failed+0x13/0x20 [ 2461.580103] [<ffffffff8173492d>] ? down_write+0x9d/0xb2 [ 2461.580103] [<ffffffff8162baa5>] ? genl_lock_all+0x15/0x30 [ 2461.580103] [<ffffffff8162baa5>] genl_lock_all+0x15/0x30 [ 2461.580103] [<ffffffff8162cbb3>] genl_register_family+0x53/0x1f0 [ 2461.580103] [<ffffffffa01dc000>] ? 0xffffffffa01dbfff [ 2461.580103] [<ffffffff8162d650>] genl_register_family_with_ops+0x20/0x80 [ 2461.580103] [<ffffffffa01dc000>] ? 0xffffffffa01dbfff [ 2461.580103] [<ffffffffa017fe84>] nl80211_init+0x24/0xf0 [cfg80211] [ 2461.580103] [<ffffffffa01dc000>] ? 0xffffffffa01dbfff [ 2461.580103] [<ffffffffa01dc043>] cfg80211_init+0x43/0xdb [cfg80211] [ 2461.580103] [<ffffffff810020fa>] do_one_initcall+0xfa/0x1b0 [ 2461.580103] [<ffffffff8105cb93>] ? set_memory_nx+0x43/0x50 [ 2461.580103] [<ffffffff810f75af>] load_module+0x1c6f/0x27f0 [ 2461.580103] [<ffffffff810f2c90>] ? store_uevent+0x40/0x40 [ 2461.580103] [<ffffffff810f82c6>] SyS_finit_module+0x86/0xb0 [ 2461.580103] [<ffffffff81741ad9>] system_call_fastpath+0x16/0x1b [ 2461.580103] Sched Debug Version: v0.10, 3.11.0-0.rc1.git4.1.fc20.x86_64 #1 Problem start to happen after adding net-pf-16-proto-16-family-nl80211 alias name to cfg80211 module by below commit (though that commit itself is perfectly fine): commit fb4e156886ce6e8309e912d8b370d192330d19d3 Author: Marcel Holtmann <marcel@holtmann.org> Date: Sun Apr 28 16:22:06 2013 -0700 nl80211: Add generic netlink module alias for cfg80211/nl80211 Reported-and-tested-by: Jeff Layton <jlayton@redhat.com> Reported-by: Richard W.M. Jones <rjones@redhat.com> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Reviewed-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-26genetlink: fix possible memory leak in genl_family_rcv_msg()Wei Yongjun
'attrbuf' is malloced in genl_family_rcv_msg() when family->maxattr && family->parallel_ops, thus should be freed before leaving from the error handling cases, otherwise it will cause memory leak. Introduced by commit def3117493eafd9dfa1f809d861e0031b2cc8a07 (genl: Allow concurrent genl callbacks.) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-25genl: Allow concurrent genl callbacks.Pravin B Shelar
All genl callbacks are serialized by genl-mutex. This can become bottleneck in multi threaded case. Following patch adds an parameter to genl_family so that a particular family can get concurrent netlink callback without genl_lock held. New rw-sem is used to protect genl callback from genl family unregister. in case of parallel_ops genl-family read-lock is taken for callbacks and write lock is taken for register or unregistration for any family. In case of locked genl family semaphore and gel-mutex is locked for any openration. Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-20genetlink: trigger BUG_ON if a group name is too longMasatake YAMATO
Trigger BUG_ON if a group name is longer than GENL_NAMSIZ. Signed-off-by: Masatake YAMATO <yamato@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-10netlink: Rename pid to portid to avoid confusionEric W. Biederman
It is a frequent mistake to confuse the netlink port identifier with a process identifier. Try to reduce this confusion by renaming fields that hold port identifiers portid instead of pid. I have carefully avoided changing the structures exported to userspace to avoid changing the userspace API. I have successfully built an allyesconfig kernel with this change. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-08netlink: hide struct module parameter in netlink_kernel_createPablo Neira Ayuso
This patch defines netlink_kernel_create as a wrapper function of __netlink_kernel_create to hide the struct module *me parameter (which seems to be THIS_MODULE in all existing netlink subsystems). Suggested by David S. Miller. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-08netlink: kill netlink_set_nonrootPablo Neira Ayuso
Replace netlink_set_nonroot by one new field `flags' in struct netlink_kernel_cfg that is passed to netlink_kernel_create. This patch also renames NL_NONROOT_* to NL_CFG_F_NONROOT_* since now the flags field in nl_table is generic (so we can add more flags if needed in the future). Also adjust all callers in the net-next tree to use these flags instead of netlink_set_nonroot. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-24genetlink: define lockdep_genl_is_held() when CONFIG_LOCKDEPWANG Cong
lockdep_is_held() is defined when CONFIG_LOCKDEP, not CONFIG_PROVE_LOCKING. Cc: "David S. Miller" <davem@davemloft.net> Cc: Jesse Gross <jesse@nicira.com> Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-10net: Fix (nearly-)kernel-doc comments for various functionsBen Hutchings
Fix incorrect start markers, wrapped summary lines, missing section breaks, incorrect separators, and some name mismatches. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-29netlink: add netlink_kernel_cfg parameter to netlink_kernel_createPablo Neira Ayuso
This patch adds the following structure: struct netlink_kernel_cfg { unsigned int groups; void (*input)(struct sk_buff *skb); struct mutex *cb_mutex; }; That can be passed to netlink_kernel_create to set optional configurations for netlink kernel sockets. I've populated this structure by looking for NULL and zero parameters at the existing code. The remaining parameters that always need to be set are still left in the original interface. That includes optional parameters for the netlink socket creation. This allows easy extensibility of this interface in the future. This patch also adapts all callers to use this new interface. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-29genetlink: Build a generic netlink family module aliasNeil Horman
Generic netlink searches for -type- formatted aliases when requesting a module to fulfill a protocol request (i.e. net-pf-16-proto-16-type-<x>, where x is a type value). However generic netlink protocols have no well defined type numbers, they have string names. Modify genl_ctrl_getfamily to request an alias in the format net-pf-16-proto-16-family-<x> instead, where x is a generic string, and add a macro that builds on the previously added MODULE_ALIAS_NET_PF_PROTO_NAME macro to allow modules to specifify those generic strings. Note, l2tp previously hacked together an net-pf-16-proto-16-type-l2tp alias using the MODULE_ALIAS macro, with these updates we can convert that to use the PROTO_NAME macro. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: Eric Dumazet <eric.dumazet@gmail.com> CC: James Chapman <jchapman@katalix.com> CC: David Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-01genetlink: Stop using NLA_PUT*().David S. Miller
These macros contain a hidden goto, and are thus extremely error prone and make code hard to audit. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-26netlink: add netlink_dump_control structure for netlink_dump_start()Pablo Neira Ayuso
Davem considers that the argument list of this interface is getting out of control. This patch tries to address this issue following his proposal: struct netlink_dump_control c = { .dump = dump, .done = done, ... }; netlink_dump_start(..., &c); Suggested by David S. Miller. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-30net: Deinline __nlmsg_put and genlmsg_put. -7k code on i386 defconfig.Denys Vlasenko
text data bss dec hex filename 8455963 532732 1810804 10799499 a4c98b vmlinux.o.before 8448899 532732 1810804 10792435 a4adf3 vmlinux.o This change also removes commented-out copy of __nlmsg_put which was last touched in 2005 with "Enable once all users have been converted" comment on top. Changes in v2: rediffed against net-next. Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-14Merge branch 'for-linus' of git://selinuxproject.org/~jmorris/linux-securityLinus Torvalds
* 'for-linus' of git://selinuxproject.org/~jmorris/linux-security: capabilities: remove __cap_full_set definition security: remove the security_netlink_recv hook as it is equivalent to capable() ptrace: do not audit capability check when outputing /proc/pid/stat capabilities: remove task_ns_* functions capabitlies: ns_capable can use the cap helpers rather than lsm call capabilities: style only - move capable below ns_capable capabilites: introduce new has_ns_capabilities_noaudit capabilities: call has_ns_capability from has_capability capabilities: remove all _real_ interfaces capabilities: introduce security_capable_noaudit capabilities: reverse arguments to security_capable capabilities: remove the task from capable LSM hook entirely selinux: sparse fix: fix several warnings in the security server cod selinux: sparse fix: fix warnings in netlink code selinux: sparse fix: eliminate warnings for selinuxfs selinux: sparse fix: declare selinux_disable() in security.h selinux: sparse fix: move selinux_complete_init selinux: sparse fix: make selinux_secmark_refcount static SELinux: Fix RCU deref check warning in sel_netport_insert() Manually fix up a semantic mis-merge wrt security_netlink_recv(): - the interface was removed in commit fd7784615248 ("security: remove the security_netlink_recv hook as it is equivalent to capable()") - a new user of it appeared in commit a38f7907b926 ("crypto: Add userspace configuration API") causing no automatic merge conflict, but Eric Paris pointed out the issue.
2012-01-05security: remove the security_netlink_recv hook as it is equivalent to capable()Eric Paris
Once upon a time netlink was not sync and we had to get the effective capabilities from the skb that was being received. Today we instead get the capabilities from the current task. This has rendered the entire purpose of the hook moot as it is now functionally equivalent to the capable() call. Signed-off-by: Eric Paris <eparis@redhat.com>
2011-12-28genetlink: add auto module loadingStephen Hemminger
When testing L2TP support, I discovered that the l2tp module is not autoloaded as are other netlink interfaces. There is because of lack of hook in genetlink to call request_module and load the module. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-22netlink: af_netlink cleanup (v2)stephen hemminger
Don't inline functions that cover several lines, and do inline the trivial ones. Also make some arguments const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-03genetlink: Add lockdep_genl_is_held().Pravin B Shelar
Open vSwitch uses genl_mutex locking to protect datapath data-structures like flow-table, flow-actions. Following patch adds lockdep_genl_is_held() which is used for rcu annotation to prove locking. Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2011-12-03genetlink: Add genl_notify()Pravin B Shelar
Open vSwitch uses Generic Netlink interface for communication between userspace and kernel module. genl_notify() is used for sending notification back to userspace. genl_notify() is analogous to rtnl_notify() but uses genl_sock instead of rtnl. Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2011-06-09rtnetlink: Compute and store minimum ifinfo dump sizeGreg Rose
The message size allocated for rtnl ifinfo dumps was limited to a single page. This is not enough for additional interface info available with devices that support SR-IOV and caused a bug in which VF info would not be displayed if more than approximately 40 VFs were created per interface. Implement a new function pointer for the rtnl_register service that will calculate the amount of data required for the ifinfo dump and allocate enough data to satisfy the request. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-01-19Revert "netlink: test for all flags of the NLM_F_DUMP composite"David S. Miller
This reverts commit 0ab03c2b1478f2438d2c80204f7fef65b1bca9cf. It breaks several things including the avahi daemon. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-09netlink: test for all flags of the NLM_F_DUMP compositeJan Engelhardt
Due to NLM_F_DUMP is composed of two bits, NLM_F_ROOT | NLM_F_MATCH, when doing "if (x & NLM_F_DUMP)", it tests for _either_ of the bits being set. Because NLM_F_MATCH's value overlaps with NLM_F_EXCL, non-dump requests with NLM_F_EXCL set are mistaken as dump requests. Substitute the condition to test for _all_ bits being set. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Acked-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05genetlink: introduce pre_doit/post_doit hooksJohannes Berg
Each family may have some amount of boilerplate locking code that applies to most, or even all, commands. This allows a family to handle such things in a more generic way, by allowing it to a) include private flags in each operation b) specify a pre_doit hook that is called, before an operation's doit() callback and may return an error directly, c) specify a post_doit hook that can undo locking or similar things done by pre_doit, and finally d) include two private pointers in each info struct passed between all these operations including doit(). (It's two because I'll need two in nl80211 -- can be extended.) Signed-off-by: Johannes Berg <johannes.berg@intel.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-07-26genetlink: use genl_register_family_with_ops()Changli Gao
Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-26genetlink: cleanup code according to CodingStyleChangli Gao
If the function is exported, the EXPORT* macro for it should follow immediately after the closing function brace line. Signed-off-by: Changli Gao <xiaosuo@gmail.com> ---- net/netlink/genetlink.c | 9 ++++----- 1 file changed, 4 insertions(+), 5 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03netlink: Export genl_lock() API for use by modulesJames Chapman
This lets kernel modules which use genl netlink APIs serialize netlink processing. Signed-off-by: James Chapman <jchapman@katalix.com> Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-13genetlink: optimize ctrl_dumpfamily()Samir Bellabes
there is a unnecessary test which can be replaced by a good initialization in the 'for' statement Noticed by Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Samir Bellabes <sam@synack.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
