path: root/net/netlabel/netlabel_unlabeled.c
2007-02-28[NET]: Fix kfree(skb)Patrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02NetLabel: honor the audit_enabled flagPaul Moore
The audit_enabled flag is used to signal when syscall auditing is to be performed. While NetLabel uses a Netlink interface instead of syscalls, it is reasonable to consider the NetLabel Netlink interface as a form of syscall so pay attention to the audit_enabled flag when generating audit messages in NetLabel. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02NetLabel: convert the unlabeled accept flag to use RCUPaul Moore
Currently the NetLabel unlabeled packet accept flag is an atomic type and it is checked for every non-NetLabel packet which comes into the system but rarely ever changed. This patch changes this flag to a normal integer and protects it with RCU locking. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2006-12-02[GENL]: Add genlmsg_put_reply() to simplify building reply headersThomas Graf
By modyfing genlmsg_put() to take a genl_family and by adding genlmsg_put_reply() the process of constructing the netlink and generic netlink headers is simplified. Signed-off-by: Thomas Graf <tgraf@suug.ch> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[GENL]: Add genlmsg_reply() to simply unicast replies to requestsThomas Graf
A generic netlink user has no interest in knowing how to address the source of the original request. Signed-off-by: Thomas Graf <tgraf@suug.ch> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETLINK]: Do precise netlink message allocations where possibleThomas Graf
Account for the netlink message header size directly in nlmsg_new() instead of relying on the caller calculate it correctly. Replaces error handling of message construction functions when constructing notifications with bug traps since a failure implies a bug in calculating the size of the skb. Signed-off-by: Thomas Graf <tgraf@suug.ch> Acked-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-29[NetLabel]: audit fixups due to delayed feedbackPaul Moore
Fix some issues Steve Grubb had with the way NetLabel was using the audit subsystem. This should make NetLabel more consistent with other kernel generated audit messages specifying configuration changes. Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: Steve Grubb <sgrubb@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[NetLabel]: add audit support for configuration changesPaul Moore
This patch adds audit support to NetLabel, including six new audit message types shown below. #define AUDIT_MAC_UNLBL_ACCEPT 1406 #define AUDIT_MAC_UNLBL_DENY 1407 #define AUDIT_MAC_CIPSOV4_ADD 1408 #define AUDIT_MAC_CIPSOV4_DEL 1409 #define AUDIT_MAC_MAP_ADD 1410 #define AUDIT_MAC_MAP_DEL 1411 Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-25[NetLabel]: rework the Netlink attribute handling (part 2)Paul Moore
At the suggestion of Thomas Graf, rewrite NetLabel's use of Netlink attributes to better follow the common Netlink attribute usage. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NetLabel]: CIPSOv4 and Unlabeled packet integrationPaul Moore
Add CIPSO/IPv4 and unlabeled packet management to the NetLabel subsystem. The CIPSO/IPv4 changes allow the configuration of CIPSO/IPv4 within the overall NetLabel framework. The unlabeled packet changes allows NetLabel to pass unlabeled packets without error. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
