path: root/net/mac80211
2009-09-11net: Add DEVTYPE support for Ethernet based devicesMarcel Holtmann
The Ethernet framing is used for a lot of devices these days. Most prominent are WiFi and WiMAX based devices. However for userspace application it is important to classify these devices correctly and not only see them as Ethernet devices. The daemons like HAL, DeviceKit or even NetworkManager with udev support tries to do the classification in userspace with a lot trickery and extra system calls. This is not good and actually reaches its limitations. Especially since the kernel does know the type of the Ethernet device it is pretty stupid. To solve this problem the underlying device type needs to be set and then the value will be exported as DEVTYPE via uevents and available within udev. # cat /sys/class/net/wlan0/uevent DEVTYPE=wlan INTERFACE=wlan0 IFINDEX=5 This is similar to subsystems like USB and SCSI that distinguish between hosts, devices, disks, partitions etc. The new SET_NETDEV_DEVTYPE() is a convenience helper to set the actual device type. All device types are free form, but for convenience the same strings as used with RFKILL are choosen. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2009-09-02wireless: remove mac80211 rate selection extra menuLuis R. Rodriguez
We can just display this upon enabling mac80211 with an 'if MAC80211 != n' check. Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-09-02net: file_operations should be constStephen Hemminger
All instances of file_operations should be const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01wireless: convert drivers to netdev_tx_tStephen Hemminger
Mostly just simple conversions: * ray_cs had bogus return of NET_TX_LOCKED but driver was not using NETIF_F_LLTX * hostap and ipw2x00 had some code that returned value from a called function that also had to change to return netdev_tx_t Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-28mac80211: Check pending scan request after having processed mgd workJouni Malinen
When the queued management work items are processed in ieee80211_sta_work() an item could be removed. This could change the anybusy from true to false, so we better check whether we can start a new scan only after having processed the pending work first. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-28mac80211: fix scan cancel on ifdownJohannes Berg
When an interface is taken down while a scan is pending -- i.e. a scan request was accepted but not yet acted upon due to other work being in progress -- we currently do not properly cancel that scan and end up getting stuck. Fix this by doing better checks when an interface is taken down. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-28mac80211: Fix output of minstrels rc_statsArnd Hannemann
An integer overflow in the minstrel debug code prevented the throughput to be displayed correctly. This patch fixes that, by permutating operations like proposed by Pavel Roskin. Signed-off-by: Arnd Hannemann <hannemann@nets.rwth-aachen.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-28mac80211: fix RX skb leaksJohannes Berg
In mac80211's RX path some of the warnings that warn about drivers passing invalid status values leak the skb, fix that by refactoring the code. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-28mac80211: Remove unnused throughput field from minstrel_rate.Arnd Hannemann
I noticed that the throughput field of the minstrel_rate struct is never used, so remove it. Signed-off-by: Arnd Hannemann <hannemann@nets.rwth-aachen.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-28mac80211: remove tasklet enable/disableJohannes Berg
Due to the way the tasklets work in mac80211 there's no need to ever disable them. However, we need to clear the pending packets when taking down the last interface because otherwise the tx_pending_tasklet might be queued if the driver mucks with the queues (which it shouldn't). I've had a situation occasionally with ar9170 in which ksoftirq was using 100% CPU time because a disabled tasklet was scheduled, and I think that was due to ar9170 receiving a packet while the tasklet was disabled. That's strange and it really should not do that for other reasons, but there's no need to waste that much CPU time over it, it should just warn instead. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-28mac80211: remove ieee80211_rx namespace hackJohn W. Linville
With the libipw naming scheme change, it is no longer necessary for mac80211 to avoid the ieee80211_rx name clash. Reported-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-28mac80211: fix configure_filter invocation after stopJohannes Berg
Since configure_filter can sleep now, any multicast configuration needed to be postponed to a work struct. This, however, lead to a problem that we could queue the work, stop the device and then afterwards invoke configure_filter which may lead to driver hangs and is a bug. To fix this, we can just cancel the filter work since it's unnecessary to do after stopping the hw. Since there are various places that call drv_stop, and two of them do very similar things, the code for them can be put into a shared function at the same time. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Reported-by: Lennert Buytenhek <buytenh@wantstofly.org> Tested-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-28mac80211: Update mesh config IE to 11s draft 3.02Javier Cardona
The mesh config information element has changed significantly since draft 1.08 This patch brings it up to date. Thanks to Sam Leffler and Rui Paulo for identifying this. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-20mac80211: fix register_hw error pathJohannes Berg
"cfg80211: fix alignment problem in scan request" introduced a bug into the error path, because now we allocate the entire scan request and not just the channel list (the channel list is allocated together with the scan request) -- on errors we thus also need to free the entire scan request. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-20mac80211: New stat counters for multicast and unicast forwarded framesDaniel Walker
This expands on the current fwded_frames stat counter which should be equal to the total of these two new counters. The new counters are called "fwded_mcast" and "fwded_unicast". Signed-off-by: Daniel Walker <dwalker@fifo99.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-20rc80211_pid_algo.c: remove unused variable declarationJohn W. Linville
CC [M] net/mac80211/rc80211_pid_algo.o net/mac80211/rc80211_pid_algo.c: In function ‘rate_control_pid_rate_init’: net/mac80211/rc80211_pid_algo.c:304: warning: unused variable ‘si’ Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-20mac80211: Decouple fail_avg stats used by mesh from rate control algorithm.Javier Cardona
Mesh uses the tx failure average to compute the (m)path metric. This used to be done inside the rate control module. This patch breaks the dependency between the mesh stack and the rate control algorithm. Mesh will now work independently of the chosen rate control algorithm. The mesh stack keeps a moving average of the average transmission losses for each mesh peer station. If the fail average exceeds a certain threshold, the peer link is marked as broken. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-20mac80211: remove deprecated APIJohannes Berg
All but two drivers have now stopped using the two deprecated members radio_enabled and beacon_int, so it's about time to remove them for good. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-20mac80211: allow configure_filter callback to sleepJohannes Berg
Over time, a whole bunch of drivers have come up with their own scheme to delay the configure_filter operation to a workqueue. To be able to simplify things, allow configure_filter to sleep, and add a new prepare_multicast callback that drivers that need the multicast address list implement. This new callback must be atomic, but most drivers either don't care or just calculate a hash which can be done atomically and then uploaded to the hardware non-atomically. A cursory look suggests that at76c50x-usb, ar9170, mwl8k (which is actually very broken now), rt2x00, wl1251, wl1271 and zd1211 should make use of this new capability. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14Merge branch 'master' of ↵David S. Miller
2009-08-14mac80211: Fix invalid length passed to IE parser for PLINK CONFIRM framesDavid Woo
The length of the fixed portion of plink confirm frames is 4 bytes longer than the other plink_action frames. This path corrects an error in the length adjustment done for these type of frames. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14mac80211: Mark a destination sequence number as valid when a PREQ is received.David Woo
If a PREQ frame is received giving us a fresher DSN than what we have, record the new dsn and mark it as valid. This patch fixes a bug in the setting of the MESH_PATH_DSN_VALID flag. Also, minor fix to coding style on that file. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14mac80211: Fix unresolved mesh frames queued without valid control.vifJavier Cardona
Mesh frames that could not be immediately resolved were queued with a NULL info->control.vif. This patch moves the call to mesh_nexthop_lookup closer to the point where it is handed over to ieee80211_tx(). This ensures that the unresolved frames are ready to be sent once the path is resolved. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14mac80211: Move mpath and mpp growth to mesh workqueue.Javier Cardona
This prevents calling rcu_synchronize from within the tx path by moving the table growth code to the mesh workqueue. Move mesh_table_free and mesh_table_grow from mesh.c to mesh_pathtbl.c and declare them static. Also, re-enable mesh in Kconfig and update the configuration description. Signed-off-by: Javier Cardona <javier@cozybit.com> Tested-by: Andrey Yurovsky <andrey@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14mac80211: Assign a default mesh beaconing interval.Javier Cardona
The mesh stack was enabling beaconing without specifying an interval. This patch defines a default beaconing interval of 1s. Incidentally, this fixes mesh beaconing in mac80211_hwsim devices. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14mac80211: Early detection of broken mesh paths when using minstrel.Javier Cardona
This change triggers a path discovery as soon as the link quality degrades below a certain threshold. This results in a faster path recovery time than by simply relying on the periodic path refresh mechanism to detect broken links. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14mac80211: Update the station failed frames average when minstrel is used.Javier Cardona
The fail_avg value is used to compute the mesh metric, and was only being set by the pid rate control module. This fixes the mesh path selection mechanism for cards that use mistrel for rate control. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14mac80211: Use 3-address format for mesh broadcast frames.Javier Cardona
The 11s task group recently changed the frame mesh multicast/broadcast frame format to use 3-address. This was done to avoid interactions with widely deployed lazy-WDS access points. This patch changes the format of group addressed frames, both mesh-originated and proxied, to use the data format defined in draft D2.08 and forward. The address fields used for group addressed frames is: In 802.11 header ToDS:0 FromDS:1 addr1: DA (broadcast/multicast address) addr2: TA addr3: Mesh SA In address extension header: addr4: SA (only present if frame was proxied) Note that this change breaks backward compatibility with earlier mesh stack versions. Signed-off-by: Andrey Yurovsky <andrey@cozybit.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14mac80211: Use correct sign for mesh active path refresh.Andrey Yurovsky
On locally originated traffic, we refresh active paths after a timeout. The decision to do this was using the wrong sign and therefore the refresh timer was triggered for every frame. Signed-off-by: Andrey Yurovsky <andrey@cozybit.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14mac80211: Improve dequeing from mpath frame queue.Javier Cardona
Also, fix typo in comment. Signed-off-by: Javier Cardona <javier@cozybit.com> Tested-by: Andrey Yurovsky <andrey@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14mac80211: small tx code cleanupJohannes Berg
It's really easier to read if it's not indented as much, so invert the condition and rearrange the code so the smaller chunk is indented instead. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14mac80211: sequence number micro-optimisationJohannes Berg
There's no need to mask the variable with 0xFFF0 since we ever only use it as a u16 and the lowest four bits can't ever be non-zero. The compiler cannot infer the latter, and therefore has to emit code to do the masking. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14mac80211: take statistics before encryptionJohannes Berg
When encryption is used, the number of bytes sent to the peer increases by the IV and ICV. This is accounted if software encryption is used, but not if the devices does hardware encryption. To make the numbers comparable, never account for that overhead. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14cfg80211: fix alignment problem in scan requestJohannes Berg
The memory layout for scan requests was rather wrong, we put the scan SSIDs before the channels which could lead to the channel pointers being unaligned in memory. It turns out that using a pointer to the channel array isn't necessary anyway since we can embed a zero-length array into the struct. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14mac80211: allow DMA optimisationJohannes Berg
If we have a lot of frames to transmit at once, for instance with fragmentation, it can be an optimisation to only tell the DMA engine about them on the last fragment/frame to avoid banging the IO too much. This patch allows implementation such an optimisation by telling the driver when more frames can be expected. Currently, this is used by mac80211 only on fragmented frames, but could also be used in the future on other frames when the queue was full and there are multiple frames pending. Note that drivers need to be careful when using this flag, they need to kick their DMA engines not just when this flag is clear, but also when the queue gets full so that progress can be made. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14nl80211: add generation number to all dumpsJohannes Berg
In order for userspace to be able to figure out whether it obtained a consistent snapshot of data or not when using netlink dumps, we need to have a generation number in each dump message that indicates whether the list has changed or not -- its value is arbitrary. This patch adds such a number to all dumps, this needs some mac80211 involvement to keep track of a generation number to start with when adding/removing mesh paths or stations. The wiphy and netdev lists can be fully handled within cfg80211, of course, but generation numbers need to be stored there as well. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14mac80211: stay authenticated after disassocJohannes Berg
After being disassociated by the AP, mac80211 currently reports this to cfg80211, and then goes to delete the association. That's fine, but cfg80211 assumes that it's still authenticated, however, mac80211 throws away all state. This fixes mac80211 to keep track of the authentication in that case so that cfg80211 can request a deauth or new association properly. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14mac80211: fix compilation of mesh (although its disabled)Luis R. Rodriguez
Mesh is currently disabled on mac80211, its marked as broken. This patch gets it to compile though, to account for the mac80211 workqueue changes. There was a simple typo in the patches for mesh for the workqueue migration, but we never compile tested it as we couldn't even select mesh as its broken. Lets at least let it compile for those interested in getting it fixed. Reported-by: Pat Erley <pat-lkml@erley.org> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-13mac80211: fix panic when splicing unprepared TIDsLuis R. Rodriguez
We splice skbs from the pending queue for a TID onto the local pending queue when tearing down a block ack request. This is not necessary unless we actually have received a request to start a block ack request (rate control, for example). If we never received that request we should not be splicing the tid pending queue as it would be null, causing a panic. Not sure yet how exactly we allowed through a call when the tid state does not have at least HT_ADDBA_REQUESTED_MSK set, that will require some further review as it is not quite obvious. For more information see the bug report: http://bugzilla.kernel.org/show_bug.cgi?id=13922 This fixes this oops: BUG: unable to handle kernel NULL pointer dereference at 00000030 IP: [<f8806c70>] ieee80211_agg_splice_packets+0x40/0xc0 [mac80211] *pdpt = 0000000002d1e001 *pde = 0000000000000000 Thread overran stack, or stack corrupted Oops: 0000 [#1] SMP last sysfs file: /sys/module/aes_generic/initstate Modules linked in: <bleh> Pid: 0, comm: swapper Not tainted (2.6.31-rc5-wl #2) Dell DV051 EIP: 0060:[<f8806c70>] EFLAGS: 00010292 CPU: 0 EIP is at ieee80211_agg_splice_packets+0x40/0xc0 [mac80211] EAX: 00000030 EBX: 0000004c ECX: 00000003 EDX: 00000000 ESI: c1c98000 EDI: f745a1c0 EBP: c076be58 ESP: c076be38 DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068 Process swapper (pid: 0, ti=c076a000 task=c0709160 task.ti=c076a000) Stack: <bleh2> Call Trace: [<f8806edb>] ? ieee80211_stop_tx_ba_cb+0xab/0x150 [mac80211] [<f8802f1e>] ? ieee80211_tasklet_handler+0xce/0x110 [mac80211] [<c04862ff>] ? net_rx_action+0xef/0x1d0 [<c0149378>] ? tasklet_action+0x58/0xc0 [<c014a0f2>] ? __do_softirq+0xc2/0x190 [<c018eb48>] ? handle_IRQ_event+0x58/0x140 [<c01205fe>] ? ack_apic_level+0x7e/0x270 [<c014a1fd>] ? do_softirq+0x3d/0x40 [<c014a345>] ? irq_exit+0x65/0x90 [<c010a6af>] ? do_IRQ+0x4f/0xc0 [<c014a35d>] ? irq_exit+0x7d/0x90 [<c011d547>] ? smp_apic_timer_interrupt+0x57/0x90 [<c01094a9>] ? common_interrupt+0x29/0x30 [<c010fd9e>] ? mwait_idle+0xbe/0x100 [<c0107e42>] ? cpu_idle+0x52/0x90 [<c054b1a5>] ? rest_init+0x55/0x60 [<c077492d>] ? start_kernel+0x315/0x37d [<c07743ce>] ? unknown_bootoption+0x0/0x1f9 [<c0774099>] ? i386_start_kernel+0x79/0x81 Code: <bleh3> EIP: [<f8806c70>] ieee80211_agg_splice_packets+0x40/0xc0 [mac80211] SS:ESP 0068:c076be38 CR2: 0000000000000030 Cc: stable@kernel.org Testedy-by: Jack Lau <jackelectronics@hotmail.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-04mac80211: FIF_PSPOLL filter flagIgor Perminov
When an interface is configured in the AP mode, the mac80211 implementation doesn't inform the driver to receive PS Poll frames. It leads to inability to communicate with power-saving stations reliably. The FIF_CONTROL flag isn't passed by mac80211 to ieee80211_ops.configure_filter when an interface is in the AP mode. And it's ok, because we don't want to receive ACK frames and other control ones, but only PS Poll ones. This patch introduces the FIF_PSPOLL filter flag in addition to FIF_CONTROL, which means for the driver "pass PS Poll frames". This flag is passed to the driver: A) When an interface is configured in the AP mode. B) In all cases, when the FIF_CONTROL flag was passed earlier (in addition to it). Signed-off-by: Igor Perminov <igor.perminov@inbox.ru> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-04mac80211: Increase timeouts for station pollingMaxim Levitsky
Do a probe request every 30 seconds, and wait for probe response, half a second This should lower the traffic that card sends, thus save power Wainting longer for response makes probe more robust against 'slow' access points Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Tested-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-04mac80211: Retry probe request few timesMaxim Levitsky
Retry 5 times (chosen arbitary ), before assuming that station is out of range. Fixes frequent disassociations while connected to weak, and sometimes even strong access points. Signed-off-by: Maxim Levitky <maximlevitsky@gmail.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-04cfg80211: enable country IE support to all cfg80211 driversLuis R. Rodriguez
Since the bss is always set now once we are connected, if the bss has its own information element we refer to it and pass that instead of relying on mac80211's parsing. Now all cfg80211 drivers get country IE support, automatically and we reduce the call overhead that we had on mac80211 which called this upon every beacon and instead now call this only upon a successfull connection by a STA on cfg80211. Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-04mac80211: fix powersaveJohannes Berg
Some of the recent MLME rework I did broke powersave because the ps_sdata isn't assigned at the right time, and the work item wasn't removed from the list before calling ieee80211_recalc_ps(). To be more specific, this broke the case where you'd enabled PS before associating, either automatically or with iwconfig. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-04mac80211: redefine usage of the mac80211 workqueueLuis R. Rodriguez
The mac80211 workqueue exists to enable mac80211 and drivers to queue their own work on a single threaded workqueue. mac80211 takes care to flush the workqueue during suspend but we never really had requirements on drivers for how they should use the workqueue in consideration for suspend. We extend mac80211 to document how the mac80211 workqueue should be used, how it should not be used and finally move raw access to the workqueue to mac80211 only. Drivers and mac80211 use helpers to queue work onto the mac80211 workqueue: * ieee80211_queue_work() * ieee80211_queue_delayed_work() These helpers will now warn if mac80211 already completed its suspend cycle and someone is trying to queue work. mac80211 flushes the mac80211 workqueue prior to suspend a few times, but we haven't taken the care to ensure drivers won't add more work after suspend. To help with this we add a warning when someone tries to add work and mac80211 already completed the suspend cycle. Drivers should ensure they cancel any work or delayed work in the mac80211 stop() callback. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-04mac80211: fix sparse warnings/errorsJohannes Berg
sparse complains about a shadowed variable, which we can just rename, and lots of stuff if the API tracer is enabled, so kick out the tracer code in a sparse run -- the macros just confuse it. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-04mac80211: disable beacons before removing the associated interfaceBob Copeland
When downing interfaces, it's a good idea to tell the driver to stop sending beacons; that way the driver doesn't need special code in ops->remove_interface() when it should already handle the case in bss_info_changed(). This fixes a potential crash with at least ath5k since the vif pointer will be nullified while beacon interrupts are still active. Signed-off-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-04mac80211: disable software retry for nowJohannes Berg
Pavel Roskin reported a problem that seems to be due to software retry of already transmitted frames. It turns out that we've never done that correctly, but due to some recent changes it now crashes in the TX code. I've added a comment in the patch that explains the problem better and also points to possible solutions -- which I can't implement right now. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-30Merge branch 'master' of ↵David S. Miller
