git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
drivers/net/wireless/wl12xx/wl1271_cmd.h
The current mac80211 code assumes that WEP is always available. If WEP
fails to initialize, ieee80211_register_hw will always fail.
In some cases (e.g. FIPS certification), the cryptography used by WEP is
unavailable. However, in such cases there is no good reason why CCMP
encryption (or even no link level encryption) cannot be used. So, this
patch removes mac80211's assumption that WEP (and TKIP) will always be
available for use.
The check should be against current top2 rate, instead of
current top rate.
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Acked-by: Felix Fietkau <nbd@openwrt.org>
The throughput should be considered when updating rate
with best probability.
drivers/net/wireless/libertas/host.h
Allow selection of minstrel_ht as default rate control algorithm. At
the moment minstrel_ht can only be requested by the driver code but
not selected as default in make menuconfig. Fix this by using
minstrel_ht when minstrel was selected as default and minstrel_ht
is available.
This change won't affect legacy devices as minstrel_ht falls back to
minstrel in that case.
Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com>
Reported-by: Johannes Berg <johannes@sipsolutions.net>
This check is duplicated in drv_get_survey.
Because of an ambiguity in the for_each_sta_info macro, it can
currently only be used if the third parameter is set to 'sta'.
Fix this by renaming the parameter to '_sta'.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
This avoids the extra queueing from calling netif_rx.
In preparation for a TX power setting interface in the nl80211, change the
.set_tx_power function to use mBm units instead of dBm for greater accuracy and
smaller power levels.
Also, already in advance move the tx_power_setting enumeration to nl80211.
This change affects the .tx_set_power function prototype. As a result, the
corresponding changes are needed to modules using it. These are mac80211,
iwmc3200wifi and rndis_wlan.
Cc: Samuel Ortiz <samuel.ortiz@intel.com>
Cc: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Signed-off-by: Juuso Oikarinen <juuso.oikarinen@nokia.com>
Acked-by: Samuel Ortiz <samuel.ortiz@intel.com>
Acked-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
While mesh_rx_plink_frame holds sta->lock...
mesh_rx_plink_frame ->
mesh_plink_inc_estab_count ->
ieee80211_bss_info_change_notify
...but ieee80211_bss_info_change_notify is allowed to sleep. A driver
taking advantage of that allowance can cause a scheduling while
atomic bug. Similar paths exist for mesh_plink_dec_estab_count,
so work around those as well.
http://bugzilla.kernel.org/show_bug.cgi?id=16099
Also, correct a minor kerneldoc comment error (mismatched function names).
Cc: stable@kernel.org
net/mac80211/rc80211_minstrel_ht.c:440:46: warning: incorrect type in argument 2 (different signedness)
net/mac80211/rc80211_minstrel_ht.c:440:46: expected int *idx
net/mac80211/rc80211_minstrel_ht.c:440:46: got unsigned int *<noident>
net/mac80211/rc80211_minstrel_ht.c:446:46: warning: incorrect type in argument 2 (different signedness)
net/mac80211/rc80211_minstrel_ht.c:446:46: expected int *idx
net/mac80211/rc80211_minstrel_ht.c:446:46: got unsigned int *<noident>
net/mac80211/rx.c:2059:39: warning: symbol 'mgmt' shadows an earlier one
net/mac80211/rx.c:1916:31: originally declared here
This mechanism introduced in this patch applies (at least) for hardware
designs using a single shared antenna for both WLAN and BT. In these designs,
the antenna must be toggled between WLAN and BT.
In those hardware, managing WLAN co-existence with Bluetooth requires WLAN
full power save whenever there is Bluetooth activity in order for WLAN to be
able to periodically relinquish the antenna to be used for BT. This is because
BT can only access the shared antenna when WLAN is idle or asleep.
Some hardware, for instance the wl1271, are able to indicate to the host
whenever there is BT traffic. In essence, the hardware will send an indication
to the host whenever there is, for example, SCO traffic or A2DP traffic, and
will send another indication when the traffic is over.
The hardware gets information of Bluetooth traffic via hardware co-existence
control lines - these lines are used to negotiate the shared antenna
ownership. The hardware will give the antenna to BT whenever WLAN is sleeping.
This patch adds the interface to mac80211 to facilitate temporarily disabling
of dynamic power save as per request of the WLAN driver. This interface will
immediately force WLAN to full powersave, hence allowing BT coexistence as
described above.
In these kind of shared antenna desings, when WLAN powersave is fully disabled,
Bluetooth will not work simultaneously with WLAN at all. This patch does not
address that problem. This interface will not change PSM state, so if PSM is
disabled it will remain so. Solving this problem requires knowledge about BT
state, and is best done in user-space.
Fix the following compile warning:
CC [M] net/mac80211/scan.o
net/mac80211/scan.c: In function 'ieee80211_request_internal_scan':
net/mac80211/scan.c:749:23: warning: comparison between 'enum nl80211_band' and 'enum ieee80211_band'
caused by the local variable band not being of the proper 'ieee80211_band' type.
Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com>
Currently, detection in hwsim and ath9k can
detect that two sw scans are in flight at the
same time, which isn't really true. It is
caused by a race condition, because the scan
complete callback is called too late, after
the lock has been dropped, so that a new scan
can be started before it is called.
It is also called too early semantically, as
it is currently called _after_ the return to
the operating channel -- it should be before
so that drivers know this is the operating
channel again.
net/mac80211/mlme.c
regression introduced by b8d92c9c141ee3dc9b3537b1f0ffb4a54ea8d9b2
In function ‘ieee80211_work_rx_queued_mgmt’:
warning: ‘rma’ may be used uninitialized in this function
this re-adds default value WORK_ACT_NONE back to rma
Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com>
When management frame protection (IEEE 802.11w) is used, we must use a
separate counter for tracking received CCMP packet number for the
management frames. The previously used NUM_RX_DATA_QUEUESth queue was
shared with data frames when QoS was not used and that can cause
problems in detecting replays incorrectly for robust management frames.
Add a new counter just for robust management frames to avoid this issue.
Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com>
Deauthentication frame needs to be protected when the pairwise key is
configured. mac80211 was removing the station entry (and its keys)
before actually sending out the Deauthentication frame. Fix this by
reordering the code to send the frame before the station entry gets
removed. This matches an earlier change that handled the Disassociation
frame processing, but missed Deauthentication frames.
The ps-qos latency handling is broken. It uses predetermined latency values
to select specific dynamic PS timeouts. With common AP configurations, these
values overlap with beacon interval and are therefore essentially useless
(for network latencies less than the beacon interval, PSM is disabled.)
This patch remedies the problem by replacing the predetermined network latency
values with one high value (1900ms) which is used to go trigger full psm. For
backwards compatibility, the value 2000ms is still mapped to a dynamic ps
timeout of 100ms.
Currently also the mac80211 internal value for storing user space configured
dynamic PSM values is incorrectly in the driver visible ieee80211_conf struct.
Move it to the ieee80211_local struct.
There is a circular locking dependency when configuring the
hardware ARP filters on association, occurring when flushing the mac80211
workqueue. This is what happens:
[ 92.026800] =======================================================
[ 92.030507] [ INFO: possible circular locking dependency detected ]
[ 92.030507] 2.6.34-04781-g2b2c009 #85
[ 92.030507] -------------------------------------------------------
[ 92.030507] modprobe/5225 is trying to acquire lock:
[ 92.030507] ((wiphy_name(local->hw.wiphy))){+.+.+.}, at: [<ffffffff8105b5c0>] flush_workq
ueue+0x0/0xb0
[ 92.030507]
[ 92.030507] but task is already holding lock:
[ 92.030507] (rtnl_mutex){+.+.+.}, at: [<ffffffff812b9ce2>] rtnl_lock+0x12/0x20
[ 92.030507]
[ 92.030507] which lock already depends on the new lock.
[ 92.030507]
[ 92.030507]
[ 92.030507] the existing dependency chain (in reverse order) is:
[ 92.030507]
[ 92.030507] -> #2 (rtnl_mutex){+.+.+.}:
[ 92.030507] [<ffffffff810761fb>] lock_acquire+0xdb/0x110
[ 92.030507] [<ffffffff81341754>] mutex_lock_nested+0x44/0x300
[ 92.030507] [<ffffffff812b9ce2>] rtnl_lock+0x12/0x20
[ 92.030507] [<ffffffffa022d47c>] ieee80211_assoc_done+0x6c/0xe0 [mac80211]
[ 92.030507] [<ffffffffa022f2ad>] ieee80211_work_work+0x31d/0x1280 [mac80211]
[ 92.030507] -> #1 ((&local->work_work)){+.+.+.}:
[ 92.030507] [<ffffffff8105a51a>] worker_thread+0x22a/0x370
[ 92.030507] [<ffffffff8105ecc6>] kthread+0x96/0xb0
[ 92.030507] [<ffffffff81003a94>] kernel_thread_helper+0x4/0x10
[ 92.030507]
[ 92.030507] -> #0 ((wiphy_name(local->hw.wiphy))){+.+.+.}:
[ 92.030507] [<ffffffff81075fdc>] __lock_acquire+0x1c0c/0x1d50
[ 92.030507] [<ffffffff8105b60e>] flush_workqueue+0x4e/0xb0
[ 92.030507] [<ffffffffa023ff7b>] ieee80211_stop_device+0x2b/0xb0 [mac80211]
[ 92.030507] [<ffffffffa0231635>] ieee80211_stop+0x3e5/0x680 [mac80211]
The locking in this case is quite complex. Fix the problem by rewriting the
way the hardware ARP filter list is handled - i.e. make a copy of the address
list to the bss_conf struct, and provide that list to the hardware driver
when needed.
The current patch will enable filtering also in promiscuous mode. This may need
to be changed in the future.
Reported-by: Reinette Chatre <reinette.chatre@intel.com>
Remove BSS from cfg80211 BSS list if we are only member in IBSS when
leaving it.
Signed-off-by: Teemu Paasikivi <ext-teemu.3.paasikivi@nokia.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Add changed basic rates flag to bss_changed while joinig ibss network.
This patch is split from the patch containing support for setting basic
rates when creating ibss network. Original patch was posted by Johannes
Berg on the linux-wireless posting list.
This patch adds support to nl80211 and mac80211 to set basic rates when
joining/creating ibss network.
Original patch was posted by Johannes Berg on the linux-wireless posting list.
Currently, driver tracing is sometimes invoked
after and sometimes before the actual driver
callback. This is fine as long as the driver
has no tracing itself, but as soon as it does
it gets confusing.
To make traces containing such information
easier to read, introduce a return tracer in
mac80211 that essentially brackets any driver
tracing, and invoke the real trace before the
driver's callback, only showing the return
value, if any, afterwards.
Since tracing records the process, there's no
problem with overlapping calls if that should
happen.
The recent change to processing action frames from
the management frame queue had already broken action
frame accounting, and my rework didn't help either.
So add back accounting and simplify the code with a
label rather than duplicating it, and also add
accounting for management frames.
Even before the recent changes, the documentation
for TX aggregation was somewhat out of date. Update
it and also add documentation for the RX side.
Allow drivers to sleep, and indicate this in
the documentation. ath9k has some locking I
don't understand, so keep it safe and disable
BHs in it, all other drivers look fine with
the context change.
To prepare for allowing drivers to sleep in
ampdu_action, change the locking in the TX
aggregation code to use the mutex the RX part
already uses. The spinlock is still necessary
around some code to avoid races with TX, but
now we can also synchronize_net() to avoid
getting an inconsistent sequence number.
Since we want the code to be able to sleep
in the future, it must not be called from
the timer directly. To achieve that, simply
call the function drivers would call, and
also use RCU in the timer to get the struct
so we don't need to rely on the spinlock in
the future.
ampdu_action, change the locking in the RX
aggregation code to use a mutex, so that it
would already allow drivers to sleep. But
explicitly disable BHs around the callback
for now since the TX part cannot yet sleep,
and drivers' locking might require it.
I noticed that when there was _no_ traffic at
all on a given aggregation session, it would
never time out. This won't happen unless you
forced creating a session, but fix it anyway.
the timer directly. To prepare, move it out
into the aggregation work.
Move the block-ack session works into common
code, since it will be needed for RX agg too
in the next patches.
When the driver or rate control requests starting
or stopping an aggregation session, that currently
causes a direct callback into the driver, which
could potentially cause locking problems. Also,
the functions need to be callable from contexts
that cannot sleep, and thus will interfere with
making the ampdu_action callback sleeping.
To address these issues, add a new work item for
each station that will process any start or stop
requests out of line.
mac80211 currently maintains the ampdu_lock to
avoid starting a queue due to one aggregation
session while another aggregation session needs
the queue stopped.
We can do better, however, and instead refcount
the queue stops for this particular purpose,
thus removing the need for the lock. This will
help making ampdu_action able to sleep.
The non-irqsafe aggregation start/stop done
callbacks are currently only used by ath9k_htc,
and can cause callbacks into the driver again.
This might lead to locking issues, which will
only get worse as we modify locking. To avoid
trouble, remove the non-irqsafe versions and
change ath9k_htc to use those instead.
Currently we allocate some memory for each TX
aggregation session and additionally keep a
state bitmap indicating the state it is in.
By using RCU to protect the pointer, moving
the state into the structure and some locking
trickery we can avoid locking when the TX agg
session is fully operational.
Currently we allocate some memory for each RX
flag indicating whether or not it is valid.
By using RCU to protect the pointer and making
sure that the memory is fully set up before it
becomes visible to the RX path, we can remove
the need for the bool that indicates validity,
as well as for locking on the RX path since it
is always synchronised against itself, and we
can guarantee that all other modifications are
done when the structure is not visible to the
RX path.
The net result is that since we remove locking
requirements from the RX path, we can in the
future use any kind of lock for the setup and
teardown code paths.
This moves the aggregation callback processing
to the per-sdata skb queue and a work function
rather than the tasklet.
Unfortunately, this means that it extends the
pkt_type hack to that skb queue. However, it
will enable making ampdu_action API changes
gradually, my current plan is to get rid of
this again by forcing drivers to only return
from ampdu_action() when everything is done,
thus removing the callbacks completely.
There's a corner case where we receive a fragmented
frame during a blockack session, in which case we
will terminate that session. To simplify future work
in this area that will culminate in allowing the
driver callbacks for aggregation to sleep, move the
processing of this case out of the RX path into the
interface work.
This will simplify future work because the new place
for this code doesn't require that the function will
always be atomic, which the RX path needs.
To prepare for making the ampdu_action callback
sleep, make mac80211 always process blockack
action frames from the skb queue. This gets rid
of the current special case for managed mode
interfaces as well.
Some code is duplicated between ibss, mesh and
managed mode regarding the queueing of management
frames. Since all modes now use a common skb
queue and a common work function, we can pull
the queueing code into the rx handler directly
and remove the duplicated length checks etc.
All the management processing functions free the
skb after they are done, so this can be done in
the new common code instead.
Even with the previous patch, IBSS, managed
and mesh modes all attach their own work
function to the shared work struct, which
means some duplicated code. Change that to
only have a frame processing function and a
further work function for each of them and
share some common code.
