path: root/net/mac80211/wext.c
2009-03-05mac80211: Fix quality reporting for wireless statsJohannes Berg
Since "mac80211/cfg80211: move iwrange handler to cfg80211", the results for link quality from "iwlist scan" and "iwconfig" commands have been very different. The results are now consistent. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Reported- and tested-by: Larry Finger <larry.finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27mac80211/cfg80211: move iwrange handler to cfg80211Johannes Berg
The previous patch made cfg80211 generally aware of the signal type a given hardware will give, so now it can implement SIOCGIWRANGE itself, removing more wext stuff from mac80211. Might need to be a little more parametrized once we have more hardware using cfg80211 and new hardware capabilities. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27cfg80211/mac80211: fill qual.qual value/adjust max_qual.qualJohannes Berg
Due to various bugs in the software stack we end up having to fill qual.qual; level should be used, but wpa_supplicant doesn't properly ignore qual.qual, NM should use qual.level regardless of that because qual.qual is 0 but doesn't handle IW_QUAL_DBM right now. So fill qual.qual with the qual.level value clamped to -110..-40 dBm or just the regular 'unspecified' signal level. This requires a mac80211 change to properly announce the max_qual.qual and avg_qual.qual values. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27mac80211: split IBSS/managed codeJohannes Berg
This patch splits out the ibss code and data from managed (station) mode. The reason to do this is to better separate the state machines, and have the code be contained better so it gets easier to determine what exactly a given change will affect, that in turn makes it easier to understand. This is quite some churn, especially because I split sdata->u.sta into sdata->u.mgd and sdata->u.ibss, but I think it's easier to maintain that way. I've also shuffled around some code -- null function sending is only applicable to managed interfaces so put that into that file, some other functions are needed from various places so put them into util, and also rearranged the prototypes in ieee80211_i.h accordingly. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-13mac80211: calculate wstats_flags on the flyJohannes Berg
Just to make wext.c more self-contained. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-13cfg80211/nl80211: scanning (and mac80211 update to use it)Johannes Berg
This patch adds basic scan capability to cfg80211/nl80211 and changes mac80211 to use it. The BSS list that cfg80211 maintains is made driver-accessible with a private area in each BSS struct, but mac80211 doesn't yet use it. That's another large project. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-13mac80211: properly validate/translate IW_AUTH_MFP valuesJohannes Berg
Make sure nobody passes in bogus values, and translate the values (although it isn't necessary). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-09mac80211: remove HW_SIGNAL_DBJohannes Berg
Giving the signal in dB isn't much more useful to userspace than giving the signal in unspecified units. This removes some radiotap information for zd1211 (the only driver using this flag), but it helps a lot for getting cfg80211-based scanning which won't support dB, and zd1211 being dB is a little fishy anyway. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Bruno Randolf <bruno@thinktube.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-30mac80211: Cancel the dynamic ps timer in ioctl_siwpower.Vivek Natarajan
If the dynamic power save timer has been started before the power save is disabled using iwconfig, we fail to cancel the timer. Hence cancel it while disabling power save. Signed-off-by: Vivek Natarajan <vnatarajan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: 802.11w - Add driver capability flag for MFPJouni Malinen
This allows user space to determine whether a driver supports MFP and behave properly without having to ask user to configure this in MFP-optional mode. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: 802.11w - Configuration of MFP disabled/optional/requiredJouni Malinen
Add new WEXT IW_AUTH_* parameter for setting MFP disabled/optional/required. Signed-off-by: Jouni Malinen <j@w1.fi> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: 802.11w - WEXT configuration for IGTKJouni Malinen
Added new SIOCSIWENCODEEXT algorithm for configuring BIP (AES-CMAC) keys (IGTK). Signed-off-by: Jouni Malinen <j@w1.fi> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: 802.11w - WEXT parameter for setting mgmt cipherJouni Malinen
Add a new IW_AUTH parameter for setting cipher suite for multicast/broadcast management frames. This is for full-mac drivers that take care of RSN IE generation for (re)association request frames. Signed-off-by: Jouni Malinen <j@w1.fi> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: extend/document powersave APIJohannes Berg
This modifies hardware flags for powersave to support three different flags: * IEEE80211_HW_SUPPORTS_PS - indicates general PS support * IEEE80211_HW_PS_NULLFUNC_STACK - indicates nullfunc sending in software * IEEE80211_HW_SUPPORTS_DYNAMIC_PS - indicates dynamic PS on the device It also adds documentation for all this which explains how to set the various flags. Additionally, it fixes a few things: * a spot where && was used to test flags * enable CONF_PS only when associated again Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: move dynamic PS timeout to hardware configJohannes Berg
This will be needed for drivers that set the IEEE80211_HW_NO_STACK_DYNAMIC_PS flag and still want to handle dynamic PS. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Reviewed-by: Kalle Valo <kalle.valo@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: validate SIOCSIWPOWER arguments betterJohannes Berg
Don't accept any arguments we don't handle, and return error codes instead of using an uninitialised stack value. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Reviewed-by: Kalle Valo <kalle.valo@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: remove user_power_level from driver APIJohannes Berg
I missed this during review of "mac80211: Fix tx power setting", the user_power_level shouldn't be available to the driver but rather be an internal value used to calculate the value for the driver. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Vasanthakumar Thiagarajan <vasanth@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: Allow to set channel in adhoc properlyAlina Friedrichsen
The last patch fixes a bug that it was not possible to set the channel manually in the ad hoc mode properly. Please commit this patches so that we don't need the proprietary Broadcom driver in the near future anymore. Signed-off-by: Alina Friedrichsen <x-alina@gmx.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: Fix tx power settingVasanthakumar Thiagarajan
power_level in ieee80211_conf is being used for more than one purpose. It being used as user configured power limit and the final power limit given to the driver. By doing so, except very first time, the tx power limit is taken from min(chan->max_power, local->hw.conf.power_level) which is not what we want. This patch defines a new memeber in ieee80211_conf which is meant only for user configured power limit. Signed-off-by: Vasanthakumar Thiagarajan <vasanth@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: Enhancements to dynamic power save.Vivek Natarajan
This patch enables mac80211 to send a null frame and also to check for tim in the beacon if dynamic power save is enabled. Signed-off-by: Vivek Natarajan <vnatarajan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: A couple of fixes to dynamic power save.Vivek Natarajan
a) hw_config() should not be called from siwpower() for the drivers which do not support dynamic powersave. b) IEEE80211_HW_NO_STACK_DYNAMIC_PS needs to be verified in set_associated() also before enabling the power save timers. Signed-off-by: Vivek Natarajan <vnatarajan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: Scale down to non-HT association with TKIP/WEP as pairwise cipherVasanthakumar Thiagarajan
As TKIP is not updated to new security needs which arise when TKIP is used to encrypt A-MPDU aggregated data frames, IEEE802.11n does not allow any cipher other than CCMP (Which has new extensions defined) as pairwise cipher between HT peers. When such configuration (TKIP/WEP in HT) is forced, we still associate in non-HT mode (11a/b/g). Signed-off-by: Vasanthakumar Thiagarajan <vasanth@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-12-19mac80211: implement dynamic power saveKalle Valo
This patch implements dynamic power save for mac80211. Basically it means enabling power save mode after an idle period. Implementing it dynamically gives a good compromise of low power consumption and low latency. Some hardware have support for this in firmware, but some require the host to do it. The dynamic power save is implemented by adding an timeout to ieee80211_subif_start_xmit(). The timeout can be enabled from userspace with Wireless Extensions. For example, the command below enables the dynamic power save and sets the time timeout to 500 ms: iwconfig wlan0 power timeout 500m Power save now only works with devices which handle power save in firmware. It's also disabled by default and the heuristics when and how to enable is considered as a policy decision and will be left for the userspace to handle. In case the firmware has support for this, drivers can disable this feature with IEEE80211_HW_NO_STACK_DYNAMIC_PS. Big thanks to Johannes Berg for the help with the design and code. Signed-off-by: Kalle Valo <kalle.valo@nokia.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-12-19mac80211: enable IEEE80211_CONF_PS only when associatedKalle Valo
Also disable power save when disassociated. It makes no sense to have power save enabled while disassociated. iwlwifi seems to have this check in the driver, but it's better to do this in mac80211 instead. Signed-off-by: Kalle Valo <kalle.valo@nokia.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-12-12mac80211: Disable requests for new scans in AP modeJouni Malinen
AP mode operations are seriously affected if mac80211 runs through a multi-second scan while the AP is trying to send Beacon frames on the operation channel. While this could be implemented in a way that does not cause too many problems, it is not very simple and will require synchronization with Beacon frame scheduling in the drivers (scan one channel at a time between Beacon frames). Furthermore, such scanning takes quite a bit longer time and existing userspace applications would be likely to timeout while waiting for the results. For now, just refuse requests for new scans (SIOCSIWSCAN) when in AP mode. In practice, this moves the rejection from iwl* drivers into mac80211 to make it apply to every mac80211-based driver. This issue shows up in associated stations getting disconnected when something (e.g., Network Manager) requests a scan while the interface is in AP mode. When doing this continuously (e.g., NM does it every 120 seconds), the network gets close to useless. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-12-12mac80211: remove fragmentation offload functionalityJohannes Berg
There's no driver that actually does fragmentation on the device, and the callback is buggy (when it returns an error, mac80211's fragmentation status is changed so reading the frag threshold from userspace reads the new value despite the error). Let's just remove it, if we really find some hardware supporting it we can add it back later. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-12-05cfg80211: handle SIOCGIWMODE/SIOCSIWMODEJohannes Berg
further reducing wext code in mac80211. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-12-05cfg80211: handle SIOCGIWNAMEJohannes Berg
This patch moves the SIOCGIWNAME handling from mac80211 to cfg80211. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-26Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/hp-plus.c drivers/net/wireless/ath5k/base.c drivers/net/wireless/ath9k/recv.c net/wireless/reg.c
2008-11-25mac80211 : Fix setting ad-hoc mode and non-ibss channelAbhijeet Kolekar
Patch fixes the kernel trace when user tries to set ad-hoc mode on non IBSS channel. e.g iwconfig wlan0 chan 36 mode ad-hoc Signed-off-by: Abhijeet Kolekar <abhijeet.kolekar@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-10mac80211: remove SSID driver codeJohannes Berg
Remove the SSID from the driver API since now there is no driver that requires knowing the SSID and I think it's unlikely that any hardware design that does require the SSID will play well with mac80211. This also removes support for setting the SSID in master mode which will require a patch to hostapd to not try. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31mac80211: make use of regulatory tx power settings on change of tx powerLuis R. Rodriguez
We do not know what max power to allow until a device is targeting a channel, therefore only allow changing tx power if a channel is defined. Also make use of the channel's max power setting as defined by regulatory rules before allowing the user to use the requested power setting. If the user asked us to figure it out we use the max allowed by regulatory. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31mac80211/drivers: rewrite the rate control APIJohannes Berg
So after the previous changes we were still unhappy with how convoluted the API is and decided to make things simpler for everybody. This completely changes the rate control API, now taking into account 802.11n with MCS rates and more control, most drivers don't support that though. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31mac80211: make retry limits part of hw configJohannes Berg
Instead of having a separate callback, use the HW config callback with a new flag to change retry limits. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31mac80211: introduce hw config change flagsJohannes Berg
This makes mac80211 notify the driver which configuration actually changed, e.g. channel etc. No driver changes, this is just plumbing, driver authors are expected to act on this if they want to. Also remove the HW CONFIG debug printk, it's incorrect, often we configure something else. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31802.11: clean up/fix HT supportJohannes Berg
This patch cleans up a number of things: * the unusable definition of the HT capabilities/HT information information elements * variable names that are hard to understand * mac80211: move ieee80211_handle_ht to ht.c and remove the unused enable_ht parameter * mac80211: fix bug with MCS rate 32 in ieee80211_handle_ht * mac80211: fix bug with casting the result of ieee80211_bss_get_ie to an information element _contents_ rather than the whole element, add size checking (another out-of-bounds access bug fixed!) * mac80211: remove some unused return values in favour of BUG_ON checking * a few minor other things Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31mac80211: clean up ieee80211_hw_config errorsJohannes Berg
Warn when ieee80211_hw_config returns an error, it shouldn't happen; remove a number of printks that would happen in such a case and one printk that is user-triggerable. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-14ath9k/mac80211: disallow fragmentation in ath9k, report to userspaceJohannes Berg
As I've reported, ath9k currently fails utterly when fragmentation is enabled. This makes ath9k "support" hardware fragmentation by not supporting fragmentation at all to avoid the double-free issue. The patch also changes mac80211 to report errors from the driver operation to userspace. That hack in ath9k should be removed once the rate control algorithm it has is fixed, and we can at that time consider removing the hw fragmentation support entirely since it's not used by any driver. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: stable@kernel.org Acked-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15mac80211: move txrate_idx into RC algorithmsJohannes Berg
The sta_info->txrate_idx member isn't used by all RC algorithms in the way it was intended to be used, move it into those that require it (only PID) and keep track in the core code of which rate was last used for reporting to userspace and the mesh MLME. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15mac80211: use nl80211 interface typesJohannes Berg
There's really no reason for mac80211 to be using its own interface type defines. Use the nl80211 types and simplify the configuration code a bit: there's no need to translate them any more now. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15mac80211: clean up scan namespaceJohannes Berg
Most of the scan functions are called ieee80211_sta_scan_* or similar, make clean it up so they are all just called ieee80211_scan_*. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15mac80211: move ieee80211_set_freq to utilsJohannes Berg
It really doesn't belong into the wireless extensions code. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-22mac80211: cleanup mlme state namespaceTomas Winkler
This patch move add STA_MLME to station mlme state defines. Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-22replace net_device arguments with ieee80211_{local,sub_if_data} as appropriateJasper Bryant-Greene
This patch replaces net_device arguments to mac80211 internal functions with ieee80211_{local,sub_if_data} as appropriate. It also does the same for many 802.11s mesh functions, and changes the mesh path table to be indexed on sub_if_data rather than net_device. If the mesh part needs to be a separate patch let me know, but since mesh uses a lot of mac80211 functions which were being converted anyway, the changes go hand-in-hand somewhat. This patch probably does not convert all the functions which could be converted, but it is a large chunk and followup patches will be provided. Signed-off-by: Jasper Bryant-Greene <jasper@amiton.co.nz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-14mac80211: revamp beacon configurationJohannes Berg
This patch changes mac80211's beacon configuration handling to never pass skbs to the driver directly but rather always require the driver to use ieee80211_beacon_get(). Additionally, it introduces "change flags" on the config_interface() call to enable drivers to figure out what is changing. Finally, it removes the beacon_update() driver callback in favour of having IBSS beacon delivered by ieee80211_beacon_get() as well. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-14mac80211: push interface checks downJohannes Berg
This patch pushes the "netif_running()" and "same type as before" checks down into ieee80211_if_change_type() to centralise the logic instead of duplicating it for cfg80211 and wext. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-14mac80211: revamp virtual interface handlingJohannes Berg
This patch revamps the virtual interface handling and makes the code much easier to follow. Fewer functions, better names, less spaghetti code. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-14mac80211: make master netdev handling saneJohannes Berg
Currently, almost every interface type has a 'bss' pointer pointing to BSS information. This BSS information, however, is for a _local_ BSS, not for the BSS we joined, so having it on a STA mode interface makes little sense, but now they have it pointing to the master device, which is an AP mode virtual interface. However, except for some bitrate control data, this pointer is only used in AP/VLAN modes (for power saving stations.) Overall, it is not necessary to even have the master netdev be a valid virtual interface, and it doesn't have to be on the list of interfaces either. This patch changes the master netdev to be special, it now - no longer is on the list of virtual interfaces, which lets me remove a lot of tests for that - no longer has sub_if_data attached, since that isn't used Additionally, this patch changes some vlan/ap mode handling that is related to these 'bss' pointers described above (but in the VLAN case they actually make sense because there they point to the AP they belong to); it also adds some debugging code to IEEE80211_DEV_TO_SUB_IF to validate it is not called on the master netdev any more. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-14mac80211: power management wext hooksSamuel Ortiz
This patch implements the power management routines wireless extensions for mac80211. For now we only support switching PS mode between on and off. Signed-off-by: Samuel Ortiz <sameo@openedhand.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-08mac80211: add support for iwconfig wlanX frag autoEmmanuel Grumbach
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
