path: root/net/mac80211/wep.h
2008-05-07mac80211: a few code cleanupsJohannes Berg
This has some code cleanups (some inspired by checkpatch), I got bored at probably a third of the output though so if somebody else wants to... Signed-off-by: Johannes Berg <johannes@sipsolutions.net Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08mac80211: rename filesJohannes Berg
This patch renames all mac80211 files (except ieee80211_i.h) to get rid of the useless ieee80211_ prefix. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-06mac80211: split ieee80211_txrx_dataJohannes Berg
Split it into ieee80211_tx_data and ieee80211_rx_data to clarify usage/flag usage and remove the stupid union thing. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29mac80211: split ieee80211_txrx_resultJohannes Berg
The _DROP result will need to be split in the RX path but not in the TX path, so for preparation split up the type into two types, one for RX and one for TX. Also make sure (via sparse) that they cannot be confused. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] mac80211: remove ieee80211_wep_get_keyidxJohannes Berg
This function is not used any more. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] mac80211: consolidate encryptionJohannes Berg
Currently we run through all crypto handlers for each transmitted frame although we already know which one will be used. This changes the code to invoke only the needed handler. It also moves the wep code into wep.c. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] mac80211: consolidate decryptionJohannes Berg
Currently, we run through all three crypto algorithms for each received frame even though we have previously determined which key we have and as such already know which algorithm will be used. Change it to invoke only the needed function. Also move the WEP decrypt handler to wep.c so that fewer functions need to be non-static. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-05-05[MAC80211]: Add mac80211 wireless stack.Jiri Benc
Add mac80211, the IEEE 802.11 software MAC layer. Signed-off-by: Jiri Benc <jbenc@suse.cz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
