path: root/net/mac80211/scan.c
2009-05-20mac80211: cancel/restart all timers across suspend/resumeJohannes Berg
We forgot to cancel all timers in mac80211 when suspending. In particular we forgot to deal with some things that can cause hardware reconfiguration -- while it is down. While at it we go ahead and add a warning in ieee80211_sta_work() if its run while the suspend->resume cycle is in effect. This should not happen and if it does it would indicate there is a bug lurking in either mac80211 or mac80211 drivers. With this now wpa_supplicant doesn't blink when I go to suspend and resume where as before there where issues with some timers running during the suspend->resume cycle. This caused a lot of incorrect assumptions and would at times bring back the device in an incoherent, but mostly recoverable, state. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-11mac80211: improve scan timingJohannes Berg
The call to ieee80211_hw_config() is supposed to apply changes synchronously, so once it returns the parameters are applied to the hardware. Thus, there really is no need to delay the probing by the channel switch time again since the channel switch has already happened once we get to this code. Additionally, there is no need to wait for a NAV update (probe delay) when the channel is passively scanned. Remove that extra time too. This cuts scanning time from over 7 seconds to under 4 on ar9170, which is due to the number of channels scanned and ar9170's switch time being advertised as 135ms (my test now indicates it is about 77ms with the current driver, but the difference might also be due to using a different machine with different USB controllers). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-11mac80211: fix scan channel raceJohannes Berg
When a software scan starts, it first sets sw_scanning, but leaves the scan_channel "unset" (it currently actually gets initialised to a default). Now, when something else tries to (re)configure the hardware in the window between these two events (after sw_scanning = true, but before scan_channel is set), the current code switches to the (unset!) scan_channel. This causes trouble, especially when switching bands and sending frames on the wrong channel. To work around this, leave scan_channel initialised to NULL and use it to determine whether or not a switch to a different channel should occur (and also use the same condition to check whether to adjust power for scan or not). Additionally, avoid reconfiguring the hardware completely when recalculating idle resulted in no changes, this was the problem that originally led us to discover the race condition in the first place, which was helpfully bisected by Pavel. This part of the patch should not be necessary with the other fixes, but not calling the ieee80211_hw_config function when we know it to be unnecessary is certainly a correct thing to do. Unfortunately, this patch cannot and does not fix the race condition completely, but due to the way the scan code is structured it makes the particular problem Pavel discovered (race while changing channel at the same time as transmitting frames) go away. To fix it completely, more work especially with locking configuration is needed. Bisected-by: Pavel Roskin <proski@gnu.org> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-06mac80211: tell driver when idleJohannes Berg
When we aren't doing anything in mac80211, we can turn off much of the hardware, depending on the driver/hw. Not doing anything, aka being idle, means: * no monitor interfaces * no AP/mesh/wds interfaces * any station interfaces are in DISABLED state * any IBSS interfaces aren't trying to be in a network * we aren't trying to scan By creating a new function that verifies these conditions and calling it at strategic points where the states of those conditions change, we can easily make mac80211 tell the driver when we are idle to save power. Additionally, this fixes a small quirk where a recalculated powersave state is passed to the driver even if the hardware is about to stopped completely. This patch intentionally doesn't touch radio_enabled because that is currently implemented to be a soft rfkill which is inappropriate here when we need to be able to wake up with low latency. One thing I'm not entirely sure about is this: phy0: device no longer idle - in use wlan0: direct probe to AP 00:11:24:91:07:4d try 1 wlan0 direct probe responded wlan0: authenticate with AP 00:11:24:91:07:4d wlan0: authenticated > phy0: device now idle > phy0: device no longer idle - in use wlan0: associate with AP 00:11:24:91:07:4d wlan0: RX AssocResp from 00:11:24:91:07:4d (capab=0x401 status=0 aid=1) wlan0: associated Is it appropriate to go into idle state for a short time when we have just authenticated, but not associated yet? This happens only with the userspace SME, because we cannot really know how long it will wait before asking us to associate. Would going idle after a short timeout be more appropriate? We may need to revisit this, depending on what happens. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-06mac80211: add driver ops wrappersJohannes Berg
In order to later add tracing or verifications to the driver calls mac80211 makes, this patch adds static inline wrappers for all operations. All calls are now written as drv_<op>(local, ...); instead of local->ops-><op>(&local->hw, ...); Where necessary, the wrappers also do existence checking and return default values as appropriate. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-06mac80211: unify config_interface and bss_info_changedJohannes Berg
The config_interface method is a little strange, it contains the BSSID and beacon updates, while bss_info_changed contains most other BSS information for each interface. This patch removes config_interface and rolls all the information it previously passed to drivers into bss_info_changed. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-06mac80211: fix scan races and rework scanningJohannes Berg
There are some places marked /* XXX maybe racy? */ and they really are racy because there's no locking. This patch reworks much of the scan code, and introduces proper locking for the scan request as well as the internal scanning (which is necessary for IBSS/managed modes). Helper functions are added to call the scanning code whenever necessary. The scan deferring is changed to simply queue the scanning work instead of trying to start the scan in place, the scanning work will then take care of the rest. Also, currently when internal scans are requested for an interface that is trying to associate, we reject such scans. This was not intended, the mlme code has provisions to scan twice when it can't find the BSS to associate with right away; this has never worked properly. Fix this by not rejecting internal scan requests for an interface that is associating. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22mac80211: convert to cfg80211 IBSS APIJohannes Berg
This converts mac80211 to the new cfg80211 IBSS API, the wext handling functions are called where appropriate. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22mac80211: improve powersave implementationJohannes Berg
When you have multiple virtual interfaces the current implementation requires setting them up properly from userspace, which is undesirable when we want to default to power save mode. Keep track of powersave requested from userspace per managed mode interface, and only enable powersave globally when exactly one managed mode interface is active and has powersave turned on. Second, only start the dynPS timer when PS is turned on, and properly turn it off when PS is turned off. Third, fix the scan_sdata abuse in the dynps code. Finally, also reorder the code and refactor the code that enables PS or the dynps timer instead of having it copied in two places. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22mac80211: pass all probe request IEs to driverJohannes Berg
Instead of just passing the cfg80211-requested IEs, pass the locally generated ones as well. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27mac80211: disable power save when scanningKalle Valo
When software scanning we need to disable power save so that all possible probe responses and beacons are received. For hardware scanning assume that hardware will take care of that and document that assumption. Signed-off-by: Kalle Valo <kalle.valo@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27mac80211: don't drop nullfunc frames during software scanKalle Valo
ieee80211_tx_h_check_assoc() was dropping everything else than probe requests during software scan. So the nullfunc frame with the power save bit was dropped and AP never received it. This meant that AP never buffered any frames for the station during software scan. Fix this by allowing to transmit both probe request and nullfunc frames during software scan. Tested with stlc45xx. Signed-off-by: Kalle Valo <kalle.valo@nokia.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-16mac80211: handle failed scan requests in STA modeHelmut Schaa
If cfg80211 requests a scan it awaits either a return code != 0 from the scan function or the cfg80211_scan_done to be called. In case of a STA mac80211's scan function ever returns 0 and queues the scan request. If ieee80211_sta_work is executed and ieee80211_start_scan fails for some reason cfg80211_scan_done will never be called but cfg80211 still thinks the scan was triggered successfully and will refuse any future scan requests due to drv->scan_req not being cleaned up. If a scan is triggered from within the MLME a similar problem appears. If ieee80211_start_scan returns an error, local->scan_req will not be reset and mac80211 will refuse any future scan requests. Hence, in both cases call ieee80211_scan_failed (which notifies cfg80211 and resets local->scan_req) if ieee80211_start_scan returns an error. Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27mac80211: Add software scan notifiersMichael Buesch
This adds optional notifier functions for software scan. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27cfg80211: clean up signal typeJohannes Berg
It wasn't a good idea to make the signal type a per-BSS option, although then it is closer to the actual value. Move it to be a per-wiphy setting, update mac80211 to match. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27nl80211: Optional IEs into scan requestJouni Malinen
This extends the NL80211_CMD_TRIGGER_SCAN command to allow applications to specify a set of information element(s) to be added into Probe Request frames with NL80211_ATTR_IE. This provides support for the MLME-SCAN.request primitive parameter VendorSpecificInfo and can be used, e.g., to implement WPS scanning. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27mac80211: split IBSS/managed codeJohannes Berg
This patch splits out the ibss code and data from managed (station) mode. The reason to do this is to better separate the state machines, and have the code be contained better so it gets easier to determine what exactly a given change will affect, that in turn makes it easier to understand. This is quite some churn, especially because I split sdata->u.sta into sdata->u.mgd and sdata->u.ibss, but I think it's easier to maintain that way. I've also shuffled around some code -- null function sending is only applicable to managed interfaces so put that into that file, some other functions are needed from various places so put them into util, and also rearranged the prototypes in ieee80211_i.h accordingly. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-13mac80211: use cfg80211s BSS infrastructureJohannes Berg
Remove all the code from mac80211 to keep track of BSSes and use the cfg80211-provided code completely. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-13mac80211: dont add BSS when creating IBSSJohannes Berg
There's no need to create a BSS struct only to pass it to ieee80211_sta_join_ibss, so refactor this function into __ieee80211_sta_join_ibss which takes all the relevant paramters, and ieee80211_sta_join_ibss which takes a BSS struct (used when joining an IBSS that already has other members). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-13cfg80211/nl80211: scanning (and mac80211 update to use it)Johannes Berg
This patch adds basic scan capability to cfg80211/nl80211 and changes mac80211 to use it. The BSS list that cfg80211 maintains is made driver-accessible with a private area in each BSS struct, but mac80211 doesn't yet use it. That's another large project. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-13mac80211: fix beacon enable moreJohannes Berg
Hopefully the last required fix ... disable beaconing only on beaconing interfaces, and thus avoid calling ieee80211_if_config for purely virtual interfaces (those driver doesn't know about). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-11mac80211: Free current bss information in few places where we don't need it ↵Vasanthakumar Thiagarajan
any more Signed-off-by: Vasanthakumar Thiagarajan <vasanth@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: don't try to powersave/config disabled interfacesJohannes Berg
2009-01-29mac80211: Add capability to enable/disable beaconingJohannes Berg
This patch adds a flag to notify drivers to start and stop beaconing when needed, for example, during a scan run. Based on Sujith's first patch to do the same, but now disables beaconing for all virtual interfaces while scanning, has a separate change flag and tracks user-space requests. Signed-off-by: Sujith <Sujith.Manoharan@atheros.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: Enhancements to dynamic power save.Vivek Natarajan
This patch enables mac80211 to send a null frame and also to check for tim in the beacon if dynamic power save is enabled. Signed-off-by: Vivek Natarajan <vnatarajan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-10wireless: move mesh config length constantJohannes Berg
This is a constant from the 802.11 specification. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31mac80211: introduce hw config change flagsJohannes Berg
This makes mac80211 notify the driver which configuration actually changed, e.g. channel etc. No driver changes, this is just plumbing, driver authors are expected to act on this if they want to. Also remove the HW CONFIG debug printk, it's incorrect, often we configure something else. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31mac80211: clean up ieee80211_hw_config errorsJohannes Berg
Warn when ieee80211_hw_config returns an error, it shouldn't happen; remove a number of printks that would happen in such a case and one printk that is user-triggerable. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-14mac80211: Fix scan RX processing oopsJouni Malinen
ieee80211_bss_info_update() can return NULL. Verify that this is not the case before calling ieee802111_rx_bss_put() which would trigger an oops in interrupt context in atomic_dec_and_lock(). Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Benoit Papillault <benoit.papillault@free.fr> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15mac80211: use nl80211 interface typesJohannes Berg
There's really no reason for mac80211 to be using its own interface type defines. Use the nl80211 types and simplify the configuration code a bit: there's no need to translate them any more now. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15mac80211: clean up scan namespaceJohannes Berg
Most of the scan functions are called ieee80211_sta_scan_* or similar, make clean it up so they are all just called ieee80211_scan_*. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15mac80211: fix scan vs. interface removal raceJohannes Berg
When we remove an interface, we can currently end up having a pointer to it left in local->scan_sdata after it has been set down, and then with a hardware scan the scan completion can try to access it which is a bug. Alternatively, a scan that started as a hardware scan may terminate as though it was a software scan, if the timing is just right. On SMP systems, software scan also has a similar problem, just canceling the delayed work and setting a flag isn't enough since it may be running concurrently; in this case we would also never restore state of other interfaces. This patch hopefully fixes the problems by always invoking ieee80211_scan_completed or requiring it to be invoked by the driver, I suspect the drivers that have ->hw_scan() are buggy. The bug will not manifest itself unless you remove the interface while hw-scanning which will also turn off the hw, and then add a new interface which will be unusable until you scan once. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15mac80211: split off mesh handling entirelyJohannes Berg
This patch splits off mesh handling from the STA/IBSS. Unfortunately it increases mesh code size a bit, but I think it makes things clearer. The patch also reduces per-interface run-time memory usage. Also clean up a few places where ifdef is not required. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15mac80211: move STA timer restartJohannes Berg
This I shouldn't have moved to the scan implementation, move it back to the MLME where it belongs, to the notification. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-11mac80211: move frame TX functionJohannes Berg
The ieee80211_sta_tx function isn't MLME code any more, it's getting used by a lot of code. Move it to utils and rename it to ieee80211_tx_skb. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-11mac80211: clarify scan requestJohannes Berg
When a scan is requested for non-STA interfaces, we simply fire off a scan, but for STA interfaces we shouldn't because they could be in the middle of an association. This clarifies the corresponding code. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-11mac80211: move BSS handling to scan codeJohannes Berg
This moves all the BSS list handling out of mlme.c to scan.c, no further changes except fixing kzalloc/atomic_inc/atomic_inc to kzalloc/atomic_set(2). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-11mac80211: refactor and move scan RX codeJohannes Berg
This patch refactors some code and moves the scan RX function to scan.c. More importantly, however, it changes it so that the MLME's beacon/probe_resp functions aren't invoked when scanning so that we can remove a "if (scanning)" conditions from two places. There's a very slight behavioural change in this patch: now, when scanning, IBSS and mesh aren't updated even on the same channel. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-11mac80211: start moving scan code from mlmeJohannes Berg
Here's a first patch to move some code from mlme.c to a new file called scan.c. The end result will hopefully be a more manageable mlme.c. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
