* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (34 commits)
net: Add support for SMSC LAN9530, LAN9730 and LAN89530
mlx4_en: Restoring RX buffer pointer in case of failure
mlx4: Sensing link type at device initialization
ipv4: Fix "Set rt->rt_iif more sanely on output routes."
MAINTAINERS: add entry for Xen network backend
be2net: Fix suspend/resume operation
be2net: Rename some struct members for clarity
pppoe: drop PPPOX_ZOMBIEs in pppoe_flush_dev
dsa/mv88e6131: add support for mv88e6085 switch
ipv6: Enable RFS sk_rxhash tracking for ipv6 sockets (v2)
be2net: Fix a potential crash during shutdown.
bna: Fix for handling firmware heartbeat failure
can: mcp251x: Allow pass IRQ flags through platform data.
smsc911x: fix mac_lock acquision before calling smsc911x_mac_read
iwlwifi: accept EEPROM version 0x423 for iwl6000
rt2x00: fix cancelling uninitialized work
rtlwifi: Fix some warnings/bugs
p54usb: IDs for two new devices
wl12xx: fix potential buffer overflow in testmode nvs push
zd1211rw: reset rx idle timer from tasklet
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6:
Fix common misspellings
Cleaning the ieee80211_rx_data.flags field here is wrong, instead the
flags should be valid accross processing the frame on different
interfaces. Fix this by removing the incorrect flags=0 assignment.
Introduced in commit 554891e63a29af35cc6bb403ef34e319518114d0
(mac80211: move packet flags into packet).
Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com>
Suppose the aggregation reorder buffer looks like this:
x-T-R1-y-R2,
where x and y are frames that have not been received, T is a received
frame that has timed out, and R1,R2 are received frames that have not
yet timed out. The proper behavior in this scenario is to move the
window past x (skipping it), release T and R1, and leave the window at y
until y is received or R2 times out.
As written, this code will instead leave the window at R1, because it
has not yet timed out. Fix this by exiting the reorder loop only when
the frame that has not timed out AND there are skipped frames earlier in
the current valid window.
Signed-off-by: Daniel Halperin <dhalperi@cs.washington.edu>
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
The flag isn't very descriptive -- the intention
is that the driver provides a TSF timestamp at
the beginning of the MPDU -- make that clearer
by renaming the flag to RX_FLAG_MACTIME_MPDU.
ieee80211_rx_h_check returned RX_DROP_MONITOR in case the if statement
in question was true but the same return value is also used directly
after the if clause. Hence, we can just drop the whole if clause and as
such simplify the code.
mac80211 now supports passing MCS index to radiotap, so update the
comments regarding this
Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com>
Since 4-addr frames completely override the source address which will
make it into the converted 802.3 frames, receiving frames for other
4-addr stations will confuse the bridging code.
To be able to handle traffic for all connected devices, the bridge
code will automatically turn on promiscuous mode, which triggers
this problem.
Reported-by: Steve Brown <sbrown@cortland.com>
This should decrease un-necessary flushes, on/off channel work,
and channel changes in cases where the only scanned channel is
the current operating channel.
* Removes SCAN_OFF_CHANNEL flag, uses SDATA_STATE_OFFCHANNEL
and is-scanning flags instead.
* Add helper method to determine if we are currently configured
for the operating channel.
* Do no blindly go off/on channel in work.c Instead, only call
appropriate on/off code when we really need to change channels.
Always enable offchannel-ps mode when starting work,
and disable it when we are done.
* Consolidate ieee80211_offchannel_stop_station and
ieee80211_offchannel_stop_beaconing, call it
ieee80211_offchannel_stop_vifs instead.
* Accept non-beacon frames when scanning on operating channel.
* Scan state machine optimized to minimize on/off channel
transitions. Also, when going on-channel, go ahead and
re-enable beaconing. We're going to be there for 200ms,
so seems like some useful beaconing could happen.
Always enable offchannel-ps mode when starting software
scan, and disable it when we are done.
* Grab local->mtx earlier in __ieee80211_scan_completed_finish
so that we are protected when calling hw_config(), etc.
* Pass probe-responses up the stack if scanning on local
channel, so that mlme can take a look.
Signed-off-by: Ben Greear <greearb@candelatech.com>
I can't think of a valid use case for this aside from debugging (which can
also be done with a real monitor interface), and dropping these frames saves
some precious CPU cycles.
While leaving oper channel, STA informs sleep state to AP to
stop sending data. Till sending ack for the nullfunc, AP
continues to send the data to STA which restarts ps_timer that
is causing unnecessary nullfunc exchange on timer expiry
when the STA was already moved to offchannel. So don't restart ps_timer
on data reception during scan. This issue was identified by
the following warning.
WARNING: at net/mac80211/tx.c:661 invoke_tx_handlers+0xf07/0x1330 [mac80211]
wlan0: Dropped data frame as no usable bitrate found while scanning and
associated. Target station: 00:03:7f:0b:a6:1b on 5 GHz band
Call Trace:
[<ffffffffa0413ba7>] invoke_tx_handlers+0xf07/0x1330 [mac80211]
[<ffffffffa0414056>] ieee80211_tx+0x86/0x2c0 [mac80211]
[<ffffffffa0414345>] ieee80211_xmit+0xb5/0x1d0 [mac80211]
[<ffffffffa04037e0>] ieee80211_dynamic_ps_enable_work+0x0/0xb0 [mac80211]
[<ffffffffa04158cf>] ieee80211_tx_skb+0x4f/0x60 [mac80211]
[<ffffffffa04026e6>] ieee80211_send_nullfunc+0x46/0x60 [mac80211]
[<ffffffffa0403885>] ieee80211_dynamic_ps_enable_work+0xa5/0xb0 [mac80211]
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
Signed-off-by: Rajkumar Manoharan <rmanoharan@atheros.com>
Beacons from external BSSes are required for updating overlapping BSS
info (i.e. ERP protection). Pass them up unconditionally.
Signed-off-by: Arik Nemtsov <arik@wizery.com>
When operating in AP mode the wl1271 hardware filters out null-data
packets as well as management packets. This makes it impossible for
mac80211 to monitor the PS mode by using the PM bit of incoming frames.
Implement a HW flag to indicate that mac80211 should ignore the PM bit.
In addition, expose ieee80211_sta_ps_transition() to make low-level
drivers capable of controlling PS-mode.
This adds the MCS information we currently get
from the drivers into radiotap.
This particular error isn't about multicast.
When running as a 4-addr station against an AP that has the 4-addr VLAN
interface and the main 3-addr AP interface bridged together, sometimes
frames originating from the station were looping back from the 3-addr AP
interface, causing the bridge code to emit warnings about receiving frames
with its own source address.
I'm not sure why this is happening yet, but I think it's a good idea to
drop all frames (except 802.1x/EAP frames) that do not match the configured
addressing mode, including 4-address frames sent to a 3-address station.
User test reports indicate that the problem goes away with this patch.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
net/bluetooth/Makefile
This reverts enables the reorder release timer once again.
The issues laid out in:
<http://www.spinics.net/lists/linux-wireless/msg57214.html>
Have been addressed by:
mac80211: serialize rx path workers
mac80211: ignore PSM bit of reordered frames
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
This patch addresses the issue of serialization between
the main rx path and various reorder release timers.
It converts the previously local "frames" queue into
a global rx queue [rx_skb_queue]. This way, everyone
(be it the main rx-path or some reorder release timeout)
can add frames to it.
Only one active rx handler worker [ieee80211_rx_handlers]
is needed. All other threads which have lost the race of
"runnning_rx_handler" can now simply "return", knowing that
the thread who had the "edge" will also take care of their
workload.
This patch tackles one of the problems of my
reorder release timer patch from August.
What if the reorder release triggers and ap_sta_ps_end
(called by ieee80211_rx_h_sta_process) accidentally clears
the WLAN_STA_PS_STA flag, because 100ms ago - when the STA
was still active - frames were put into the reorder buffer.
Commit b51aff057c9d0ef6c529dc25fd9f775faf7b6c63 said:
Under memory pressure, the mac80211 mesh code
may helpfully print a message that it failed
to clone a mesh frame and then will proceed
to crash trying to use it anyway. Fix that.
Avoid the reference whenever the frame copy is unsuccessful
regardless of the debug message being suppressed or printed.
Cc: stable@kernel.org [2.6.27+]
Signed-off-by: Milton Miller <miltonm@bga.com>
net/ipv4/fib_frontend.c
iwlwifi and other drivers like to blink their LED
based on throughput. Implement this generically in
mac80211, based on a throughput table the driver
specifies. That way, drivers can set the blink
frequencies depending on their desired behaviour
and max throughput.
All the drivers need to do is provide an LED class
device, best with blink hardware offload.
Acked-by: Javier Cardona <javier@cozybit.com>
Let path selection frames for protocols other than HWMP be sent to
userspace via NL80211_CMD_REGISTER_FRAME. Also allow userspace to send
and receive mesh path selection frames.
Signed-off-by: Javier Cardona <javier@cozybit.com>
Add a new notification to indicate that a received, unprotected
Deauthentication or Disassociation frame was dropped due to
management frame protection being in use. This notification is
needed to allow user space (e.g., wpa_supplicant) to implement
SA Query procedure to recover from association state mismatch
between an AP and STA.
This is needed to avoid getting stuck in non-working state when MFP
(IEEE 802.11w) is used and a protected Deauthentication or
Disassociation frame is dropped for any reason. After that, the
station would silently discard any unprotected Deauthentication or
Disassociation frame that could be indicating that the AP does not
have association for the STA (when the Reason Code would be 6 or 7).
IEEE Std 802.11w-2009, 11.13 describes this recovery mechanism.
Signed-off-by: Jouni Malinen <j@w1.fi>
Using the default key for "any key set" isn't
quite what we should do. It works, but with the
upcoming changes it makes life unnecessarily
complex, so do something better here and really
check for "any key".
Extend nl80211 to report an exponential weighted moving average (EWMA) of the
signal value. Since the signal value usually fluctuates between different
packets, an average can be more useful than the value of the last packet.
This uses the recently added generic EWMA library function.
v2: fix ABI breakage and change factor to be a power of 2.
Signed-off-by: Bruno Randolf <br1@einfach.org>
drivers/net/wireless/ath/ath9k/ar9003_eeprom.c
Remove a superfluous ieee80211_is_data check as that was checked a few
lines before already and we wont't get here for non-data frames at all.
Second, the frame was already converted to 802.3 header format and
reading the fc and addr1 fields was only possible because the 802.3
header is short enough and didn't overwrite the relevant parts of the
802.11 header. Make the code more obvious by checking the ethernet
header's h_dest field.
Furthermore reorder the conditions to reduce the number of checks
when dynamic powersave is not needed (AP mode for example).
Th commit titled "mac80211: clean up rx handling wrt. found_sta"
removed found_sta variable which caused a MIC failure event
to be reported twice for a single failure to supplicant resulted
in STA disconnect.
This should fix WPA specific countermeasures WiFi test case (5.2.17)
issues with mac80211 based drivers which report MIC failure events in
rx status.
Cc: Stable <stable@kernel.org> (2.6.37)
Signed-off-by: Senthil Balasubramanian <senthilkumar@atheros.com>
This patch fixes an curious issue due to insufficient
rx frame filtering.
Saqeb Akhter reported frequent disconnects while streaming
videos over samba: <http://marc.info/?m=128600031109136>
> [ 1166.512087] wlan1: deauthenticated from 30:46:9a:10:49:f7 (Reason: 7)
> [ 1526.059997] wlan1: deauthenticated from 30:46:9a:10:49:f7 (Reason: 7)
> [ 2125.324356] wlan1: deauthenticated from 30:46:9a:10:49:f7 (Reason: 7)
The reason is that the device generates frames with slightly
bogus SA/TA addresses.
e.g.:
[ 2314.402316] Ignore 9f:1f:31:f8:64:ff
[ 2314.402321] Ignore 9f:1f:31:f8:64:ff
[ 2352.453804] Ignore 0d:1f:31:f8:64:ff
[ 2352.453808] Ignore 0d:1f:31:f8:64:ff
^^ the group-address flag is set!
(the correct SA/TA would be: 00:1f:31:f8:64:ff)
Since the AP does not know from where the frames come, it
generates a DEAUTH response for the (invalid) mcast address.
This mcast deauth frame then passes through all filters and
tricks the stack into thinking that the AP brutally kicked
us!
This patch fixes the problem by simply ignoring
non-broadcast, group-addressed deauth/disassoc frames.
Cc: Jouni Malinen <j@w1.fi>
Cc: Johannes Berg <johannes@sipsolutions.net>
Reported-by: Saqeb Akhter <saqeb.akhter@gmail.com>
The RX aggregation locking documentation was
wrong, which led Christian to also code the
timer timeout handling for it somewhat wrongly.
Fix the documentation, the two places that
need to hold the reorder lock across accesses
to the structure, and the debugfs code that
should just use RCU.
Also, remove acquiring the sta->lock across
reorder timeouts since it isn't necessary, and
change a few places to GFP_KERNEL because the
code path here doesn't need atomic allocations
as I noticed when reviewing all this.
Acked-by: Christian Lamparter <chunkeey@googlemail.com>
This reverts commit 86107fd170bc379869250eb7e1bd393a3a70e8ae.
This patch inadvertantly changed the userland ABI.
The code to handle powersaving stations has a race:
when the powersave flag is lifted from a station,
we could transmit a packet that is being processed
for TX at the same time right away, even if there
are other frames queued for it. This would cause
frame reordering. To fix this, lift the flag only
under the appropriate lock that blocks TX.
Additionally, the code to allow drivers to block a
station while frames for it are on the HW queue is
never re-enabled the station, so traffic would get
stuck indefinitely. Fix this by clearing the flag
for this appropriately.
Finally, as an optimisation, don't do anything if
the driver unblocks an already unblocked station.
Several serve threading problems in the current
release reorder timer implementation have been
discovered.
A lengthy discussion - which lists some of the
pitfalls and possible solutions - can be found at:
http://marc.info/?t=128635927000001
But due to the complicated nature of the subject and
the imminent advent of a new -rc cycle, it was
decided to disable the feature for the time being.
This adds API to allow adding per-station GTKs,
updates mac80211 to support it, and also allows
drivers to remove a key from hwaccel again when
this may be necessary due to multiple GTKs.
Initialize the rate table for WDS interfaces, and
add cases to allow WDS packets to pass the xmit and receive
tests.
Signed-off-by: Bill Jordan <bjordan@rajant.com>
commit 8c0c709eea5cbab97fb464cd68b06f24acc58ee1
Author: Johannes Berg <johannes@sipsolutions.net>
Date: Wed Nov 25 17:46:15 2009 +0100
mac80211: move cmntr flag out of rx flags
moved the CMNTR flag into the skb RX flags for
some aggregation cleanups, but this was wrong
since the optimisation this flag tried to make
requires that it is kept across the processing
of multiple interfaces -- which isn't true for
flags in the skb. The patch not only broke the
optimisation, it also introduced a bug: under
some (common!) circumstances the flag will be
set on an already freed skb!
However, investigating this in more detail, I
found that most of the flags that we set should
be per packet, _except_ for this one, due to
a-MPDU processing. Additionally, the flags used
for processing (currently just this one) need
to be reset before processing a new packet.
Since we haven't actually seen bugs reported as
a result of the wrong flags handling (which is
not too surprising -- the only real bug case I
can come up with is an a-MSDU contained in an
a-MPDU), I'll make a different fix for rc.
Even if the reorder timeout timer fires while
scanning, the frames weren't received during
scanning and therefore shouldn't be dropped.
To implement this, changes to the passive scan
RX handler simplify understanding it, because
it currently checks HW_SCANNING independently
of a packet's in-scan receive status (which
doesn't make a big difference, since scan_rx()
will only pick up probe responses and beacons,
which can't be aggregated.)
If a station was found, then we'll have exited
the function already, so it is not necessary to
have a variable keeping track of it.
There are now four instances of vaguely the same
code that does packet preparation, checking for
MMIC errors and reporting them, and then invoking
packet processing. Consolidate all of these.
The first argument to prepare_for_handlers is always
the sdata that can just be stored in rx data directly
(and even already is, in two of four code paths.)
This reverts commit cd87a2d3a33d75a646f1aa1aa2ee5bf712d6f963.
Author reports it conflicts with proper fixes, applied hereafter.
When using multiple STA interfaces on the same radio, some
data packets need to be received on all interfaces
(broadcast, for instance).
Make the STA loop look similar to the mgt-data loop.
Also, add logic to check RX_FLAG_MMIC_ERROR for last
interface in mgt-data loop.
Acked-by: Johannes Berg <johannes@sipsolutions.net>
drivers/net/wireless/ath/ath5k/base.c
net/mac80211/main.c
