path: root/net/mac80211/mlme.c
2014-08-26Revert "mac80211: disable uAPSD if all ACs are under ACM"Johannes Berg
This reverts commit 24aa11ab8ae03292d38ec0dbd9bc2ac49fe8a6dd. That commit was wrong since it uses data that hasn't even been set up yet, but might be a hold-over from a previous connection. Additionally, it seems like a driver-specific workaround that shouldn't have been in mac80211 to start with. Cc: stable@vger.kernel.org Fixes: 24aa11ab8ae0 ("mac80211: disable uAPSD if all ACs are under ACM") Reviewed-by: Luciano Coelho <luciano.coelho@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-07-21mac80211: remove redundant IEEE80211_STA_CSA_RECEIVED flagLuciano Coelho
The csa_active flag was added in sdata a while ago and made IEEE80211_STA_CSA_RECEIVED redundant. The new flag is also used to mark when CSA is ongoing on other iftypes and took over the old one as the preferred method for checking whether we're in the middle of a channel switch. Remove the old, redundant flag. Signed-off-by: Luciano Coelho <luciano.coelho@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-07-21mac80211: move TDLS data to mgd private partArik Nemtsov
We can only be a station for TDLS connections. Also fix a bug where a delayed work could be left scheduled if the station interface was brought down during TDLS setup. Signed-off-by: Arik Nemtsov <arikx.nemtsov@intel.com> Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-07-21mac80211: add QoS IE during TDLS setup startArik Nemtsov
If QoS is supported by the card, add an appropriate IE to TDLS setup- request and setup-response frames. Consolidate the setting of the WMM info IE across mac80211. Signed-off-by: Arik Nemtsov <arikx.nemtsov@intel.com> Reviewed-by: Liad Kaufman <liad.kaufman@intel.com> Reviewed-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-06-25mac80211: use chanctx reservation for STA CSAMichal Kazior
Channel switch finalization is now 2-step. First step is when driver calls chswitch_done(), the other is when reservation is actually finalized (which be defered for in-place reservation). It is now safe to call ieee80211_chswitch_done() more than once. Also remove the ieee80211_vif_change_channel() because it is no longer used. Signed-off-by: Michal Kazior <michal.kazior@tieto.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-06-23mac80211: stop only the queues assigned to the vif during channel switchLuciano Coelho
Instead of stopping all the hardware queues during channel switch, which is especially bad when we have large CSA counts, stop only the queues that are assigned to the vif that is performing the channel switch. Additionally, check for (sdata->csa_block_tx) instead of calling ieee80211_csa_needs_block_tx(), which can now be removed. Signed-off-by: Luciano Coelho <luciano.coelho@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-06-23mac80211: introduce refcount for queue_stop_reasonsLuciano Coelho
Sometimes different vifs may be stopping the queues for the same reason (e.g. when several interfaces are performing a channel switch). Instead of using a bitmask for the reasons, use an integer that holds a refcount instead. In order to keep it backwards compatible, introduce a boolean in some functions that tell us whether the queue stopping should be refcounted or not. For now, use not refcounted for all calls to keep it functionally the same as before. Signed-off-by: Luciano Coelho <luciano.coelho@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-05-27Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
2014-05-13mac80211: fix suspend vs. association raceEmmanuel Grumbach
If the association is in progress while we suspend, the stack will be in a messed up state. Clean it before we suspend. This patch completes Johannes's patch: 1a1cb744de160ee70086a77afff605bbc275d291 Author: Johannes Berg <johannes.berg@intel.com> mac80211: fix suspend vs. authentication race Cc: <stable@vger.kernel.org> Fixes: 12e7f517029d ("mac80211: cleanup generic suspend/resume procedures") Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-05-07mac80211: ignore cqm during csaMichal Kazior
It is not guaranteed that multi-vif channel switching is tightly synchronized. It makes sense to ignore cqm (missing beacons, et al) while csa is progressing and re-check it after it completes. Signed-off-by: Michal Kazior <michal.kazior@tieto.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-05-06mac80211: fix CSA tx queue stoppingMichal Kazior
It was possible for tx queues to be stuck stopped if AP CSA finalization failed. In that case neither stop_ap nor do_stop woke the queues up. This means it was impossible to perform tx at all until driver was reloaded or a successful CSA was performed later. It was possible to solve this in a simpler manner however this is more robust and future proof (having multi-vif CSA in mind). New sdata->csa_block_tx is introduced to keep track of which interfaces requested tx to be blocked for CSA. This is required because mac80211 stops all tx queues for that purpose. This means queues must be awoken only when last tx-blocking CSA interface is finished. It is still possible to have tx queues stopped after CSA failure but as soon as offending interfaces are stopped from userspace (stop_ap or ifdown) tx queues are woken up properly. Signed-off-by: Michal Kazior <michal.kazior@tieto.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-04-25mac80211: change return value of notifier functionZhao, Gang
Return NOTIFY_DONE if we don't care this time's notification, return NOTIFY_OK if we successfully handled this time's notification. That's the formal way to do it. Signed-off-by: Zhao, Gang <gamerh2o@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-04-25mac80211: compute chanctx refcount on-the-flyMichal Kazior
It doesn't make much sense to store refcount in the chanctx structure. One still needs to hold chanctx_mtx to get the value safely. Besides, refcount isn't on performance critical paths. This will make implementing chanctx reservation refcounting a little easier. Signed-off-by: Michal Kazior <michal.kazior@tieto.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-03-20Merge branch 'for-john' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
2014-03-19cfg80211/mac80211: ignore signal if the frame was heard on wrong channelEmmanuel Grumbach
On 2.4Ghz band, the channels overlap since the delta between different channels is 5Mhz while the width of the receiver is 20Mhz (at least). This means that we can hear beacons or probe responses from adjacent channels. These frames will have a significant lower RSSI which will feed all kinds of logic with inaccurate data. An obvious example is the roaming algorithm that will think our AP is getting weak and will try to move to another AP. In order to avoid this, update the signal only if the frame has been heard on the same channel as the one advertised by the AP in its DS / HT IEs. We refrain from updating the values only if the AP is already in the BSS list so that we will still have a valid (but inaccurate) value if the AP was heard on an adjacent channel only. To achieve this, stop taking the channel from DS / HT IEs in mac80211. The DS / HT IEs is taken into account to discard the frame if it was received on a disabled channel. This can happen due to the same phenomenon: the frame is sent on channel 12, but heard on channel 11 while channel 12 can be disabled on certain devices. Since this check is done in cfg80211, stop even checking this in mac80211. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> [remove unused rx_freq variable] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-03-19mac80211: fix suspend vs. authentication raceJohannes Berg
Since Stanislaw's patch removing the quiescing code, mac80211 had a race regarding suspend vs. authentication: as cfg80211 doesn't track authentication attempts, it can't abort them. Therefore the attempts may be kept running while suspending, which can lead to all kinds of issues, in at least some cases causing an error in iwlmvm firmware. Fix this by aborting the authentication attempt when suspending. Cc: stable@vger.kernel.org Fixes: 12e7f517029d ("mac80211: cleanup generic suspend/resume procedures") Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-03-19mac80211: verify deauthentication and return error on failureJohannes Berg
When still authenticating the mac80211 code handling a deauthentication requests from userspace doesn't verify that the request is valid in any way, fix that. Additionally, it never returns an error, even if there's no connection or authentication attempt, fix that as well. While at it, move the message to not print a message in the error case and to distinguish between the two cases. Also simplify the code by duplicating the cfg80211 call. Reviewed-by: Luciano Coelho <luciano.coelho@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-03-19mac80211: fix potential use-after-freeJohannes Berg
The bss struct might be freed in ieee80211_rx_bss_put(), so we shouldn't use it afterwards. Cc: stable@vger.kernel.org (3.10+) Fixes: 817cee7675237 ("mac80211: track AP's beacon rate and give it to the driver") Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-03-04Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: drivers/net/wireless/ath/ath9k/recv.c drivers/net/wireless/mwifiex/pcie.c
2014-02-27mac80211: fix association to 20/40 MHz VHT networksJohannes Berg
When a VHT network uses 20 or 40 MHz as per the HT operation information, the channel center frequency segment 0 field in the VHT operation information is reserved, so ignore it. This fixes association with such networks when the AP puts 0 into the field, previously we'd disconnect due to an invalid channel with the message wlan0: AP VHT information is invalid, disable VHT Cc: stable@vger.kernel.org Fixes: f2d9d270c15ae ("mac80211: support VHT association") Reported-by: Tim Nelson <tim.l.nelson@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-24mac80211: don't validate unchanged AP bandwidth while trackingJohannes Berg
The MLME code in mac80211 must track whether or not the AP changed bandwidth, but if there's no change while tracking it shouldn't do anything, otherwise regulatory updates can make it impossible to connect to certain APs if the regulatory database doesn't match the information from the AP. See the precise scenario described in the code. This still leaves some possible problems with CSA or if the AP actually changed bandwidth, but those cases are less common and won't completely prevent using it. This fixes https://bugzilla.kernel.org/show_bug.cgi?id=70881 Cc: stable@vger.kernel.org Reported-and-tested-by: Nate Carlson <kernel@natecarlson.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-12ieee80211: Print human-readable disassoc/deauth reason codesCalvin Owens
Create a function to return a descriptive string for each reason code, and print that in addition to the numeric value in the kernel log. These codes are easily found on popular search engines, but one is generally not able to access the internet when dealing with wireless connectivity issues. Signed-off-by: Calvin Owens <jcalvinowens@gmail.com> [use 'unknown' rather than 'invalid' since more valid codes exist] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-11mac80211: fix memory leakEytan Lifshitz
In case ieee80211_prep_connection() fails to dereference sdata->vif.chanctx_conf, the function returns and doesn't free new_sta. fixed. Signed-off-by: Eytan Lifshitz <eytan.lifshitz@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-11mac80211: reset probe_send_count also in HW_CONNECTION_MONITOR caseEliad Peller
In case of beacon_loss with IEEE80211_HW_CONNECTION_MONITOR device, mac80211 probes the ap (and disconnects on timeout) but ignores the ack. If we already got an ack, there's no reason to continue disconnecting. this can help devices that supports IEEE80211_HW_CONNECTION_MONITOR only partially (e.g. take care of keep alives, but does not probe the ap. In case the device wants to disconnect without probing, it can just call ieee80211_connection_loss. Signed-off-by: Eliad Peller <eliadx.peller@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-05mac80211: order IEs in association request correctlyJohannes Berg
In association request frames, there may be IEs passed from userspace (such as interworking IEs) between HT and VHT, so add code to insert those inbetween them. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-04mac80211: move csa_active setting in STA CSAMichal Kazior
The sdata->vif.csa_active could be left set after, e.g. channel context constraints check fail in STA mode leaving the interface in a strange state for a brief period of time until it is disconnected. This was harmless but ugly. Signed-off-by: Michal Kazior <michal.kazior@tieto.com> Reviewed-by: Luciano Coelho <luciano.coelho@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-02-04mac80211: advertise BF STS according to AP supportEyal Shapira
Restrict our published beamformee STS capability according to the AP value. Some AP show bad behaviour in interoperability testing when our capabilities are better. Signed-off-by: Eyal Shapira <eyalx.shapira@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-19mac80211: fix iflist_mtx/mtx locking in radar detectionJohannes Berg
The scan code creates an iflist_mtx -> mtx locking dependency, and a few other places, notably radar detection, were creating the opposite dependency, causing lockdep to complain. As scan and radar detection are mutually exclusive, the deadlock can't really happen in practice, but it's still bad form. A similar issue exists in the monitor mode code, but this is only used by channel-context drivers right now and those have to have hardware scan, so that also can't happen. Still, fix these issues by making some of the channel context code require the mtx to be held rather than acquiring it, thus allowing the monitor/radar callers to keep the iflist_mtx->mtx lock ordering. While at it, also fix access to the local->scanning variable in the radar code, and document that radar_detect_enabled is now properly protected by the mtx. All this would now introduce an ABBA deadlock between the DFS work cancelling and local->mtx, so change the locking there a bit to not need to use cancel_delayed_work_sync() but be able to just use cancel_delayed_work(). The work is also safely stopped/removed when the interface is stopped, so no extra changes are needed. Reported-by: Kalle Valo <kvalo@qca.qualcomm.com> Tested-by: Simon Wunderlich <sw@simonwunderlich.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-16mac80211: don't delay station destructionJohannes Berg
If we can assume that stations are never referenced by the driver after sta_state returns (and this is true since the previous iwlmvm patch and for all other drivers) then we don't need to delay station destruction, and don't need to play tricks with rcu_barrier() etc. This should speed up some scenarios like hostapd shutdown. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-06Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: drivers/net/wireless/brcm80211/Kconfig net/mac80211/util.c
2013-12-02mac80211: update ht flag if bss configuration changedAvri Altman
There's a bug in tracking HT opmode changes in mac80211, it fails to update the driver when the channel parameters don't change. Move the code to do the HT opmode checking independently of the channel/bandwidth tracking. Signed-off-by: Avri Altman <avri.altman@intel.com> [edit commit message] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-11-25mac80211: move csa_chandef to sdataLuciano Coelho
There is no reason why we should have only one channel switch announcement at a time for a single phy. When support for channel switch with multiple contexts and multiple vifs per context is implemented, we will need the chandef data for each vif. Move the csa_chandef structure to sdata to prepare for this. Reviewed-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luciano Coelho <luciano.coelho@intel.com> [Fixed compilation with mesh] Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-11-25mac80211: add generic cipher scheme supportMax Stepanov
This adds generic cipher scheme support to mac80211, such schemes are fully under control by the driver. On hw registration drivers may specify additional HW ciphers with a scheme how these ciphers have to be handled by mac80211 TX/RR. A cipher scheme specifies a cipher suite value, a size of the security header to be added to or stripped from frames and how the PN is to be verified on RX. Signed-off-by: Max Stepanov <Max.Stepanov@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-11-25cfg80211/mac80211: DFS setup chandef for cac eventJanusz Dziedzic
To report channel width correctly we have to send correct channel parameters from mac80211 when calling cfg80211_cac_event(). This is required in case of using channel width higher than 20MHz and we have to set correct dfs channel state after CAC (NL80211_DFS_AVAILABLE). Signed-off-by: Janusz Dziedzic <janusz.dziedzic@tieto.com> Reviewed-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-11-25mac80211: remove useless tests for arrayJohannes Berg
Coverity points out that checking assoc_data->ie is completely useless since it's an array in the struct and can't be NULL - remove the useless checks. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-11-25mac80211: fix connection pollingEliad Peller
Commit 392b9ff ("mac80211: change beacon/connection polling") removed the IEEE80211_STA_BEACON_POLL flag. However, it accidentally removed the setting of IEEE80211_STA_CONNECTION_POLL, making the connection polling completely useless (the flag is always clear, so the result is never being checked). Fix it. Signed-off-by: Eliad Peller <eliad@wizery.com> Acked-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-11-05Merge branch 'for-john' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next Conflicts: net/wireless/reg.c
2013-11-04Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: drivers/net/wireless/iwlwifi/pcie/drv.c
2013-10-28mac80211: refactor the parsing of chan switch ieChun-Yeow Yeoh
Refactor the channel switch IE parsing to reduce the number of function parameters. Signed-off-by: Chun-Yeow Yeoh <yeohchunyeow@cozybit.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-10-28mac80211: implement SMPS for APEmmanuel Grumbach
When the driver requests to move to STATIC or DYNAMIC SMPS, we send an action frame to each associated station and reconfigure the channel context / driver. Of course, non-MIMO stations are ignored. The beacon isn't updated. The association response will include the original capabilities. Stations that associate while in non-OFF SMPS mode will get an action frame right after association to inform them about our current state. Note that we wait until the end of the EAPOL. Sending an action frame before the EAPOL is finished can be an issue for a few clients. Clients aren't likely to send EAPOL frames in MIMO anyway. When the SMPS configuration gets more permissive (e.g. STATIC -> OFF), we don't wake up stations that are asleep We remember that they don't know about the change and send the action frame when they wake up. When the SMPS configuration gets more restrictive (e.g. OFF -> STATIC), we set the TIM bit for every sleeping STA. uAPSD stations might send MIMO until they poll the action frame, but this is for a short period of time. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> [fix vht streams loop, initialisation] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-10-17mac80211: disable WMM with invalid parametersJohannes Berg
Some APs (notably a Sitecom WL-153 v1 with firmware 1.45) are sending invalid WMM parameters setting AIFSN, ECWmin and ECWmax to zero. The spec mandates that the value of AIFSN is at least 2, and some cards (e.g. Intel with the iwldvm driver) can't transmit when the invalid QoS parameters are actually uploaded to the firmware. Since there's little chance of being able to guess the values that the AP actually meant, disable WMM if such an invalid case is found. Since ECWmin/ECWmax are allowed to be zero, only verify AIFSN >= 2 and ECWmin <= ECWmax. Reviewed-by: Eliad Peller <eliad@wizery.com> Reported-by: Antonio Quartulli <antonio@meshcoding.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-10-02mac80211: implement STA CSA for drivers using channel contextsArik Nemtsov
Limit the current implementation to a single channel context used by a single vif, thereby avoiding multi-vif/channel complexities. Reuse the main function from AP CSA code, but move a portion out in order to fit the STA scenario. Add a new mac80211 HW flag so we don't break devices that don't support channel switch with channel-contexts. The new behavior will be opt-in. Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-09-26mac80211: split off channel switch parsing functionSimon Wunderlich
The channel switch parsing function can be re-used for the IBSS code, put the common part into an extra function. Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de> [also move/rename chandef_downgrade] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-09-26mac80211: change beacon/connection pollingStanislaw Gruszka
Since when we detect beacon lost we do active AP probing (using nullfunc frame or probe request) there is no need to have beacon polling. Flags IEEE80211_STA_BEACON_POLL seems to be used just for historical reasons. Change also make that after we start connection poll due to beacon loss, next received beacon will abort the poll. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-08-28Merge branch 'for-john' of ↵John W. Linville
2013-08-23mac80211: ignore (E)CSA in probe response framesJohannes Berg
Seth reports that some APs, notably the Netgear WNDAP360, send invalid ECSA IEs in probe response frames with the operating class and channel number both set to zero, even when no channel switch is being done. As a result, any scan while connected to such an AP results in the connection being dropped. Fix this by ignoring any channel switch announcment in probe response frames entirely, since we're connected to the AP we will be receiving a beacon (and maybe even an action frame) if a channel switch is done, which is sufficient. Cc: stable@vger.kernel.org # 3.10 Reported-by: Seth Forshee <seth.forshee@canonical.com> Tested-by: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-08-16Merge branch 'for-john' of ↵John W. Linville
2013-08-09Merge branch 'master' of ↵John W. Linville
2013-08-09mac80211: fix ieee80211_sta_process_chanswitch for 5/10 MHz channelsSimon Wunderlich
Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-07-31mac80211: continue using disabled channels while connectedJohannes Berg
In case the AP has different regulatory information than we do, it can happen that we connect to an AP based on e.g. the world roaming regulatory data, and then update our database with the AP's country information disables the channel the AP is using. If this happens on an HT AP, the bandwidth tracking code will hit the WARN_ON() and disconnect. Since that's not very useful, ignore the channel-disable flag in bandwidth tracking. Cc: stable@vger.kernel.org Reported-by: Chris Wright <chrisw@sous-sol.org> Tested-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
