path: root/net/mac80211/mlme.c
2012-09-04mac80211: clear bssid on auth/assoc failureEliad Peller
ifmgd->bssid wasn't cleared properly in some auth/assoc failure cases, causing mac80211 and the low-level driver to go out of sync. Clear ifmgd->bssid on failure, and notify the driver. Cc: stable@kernel.org # 3.4+ Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-08-01mac80211: clear timer bits when disconnectingJohannes Berg
There's a corner case that can happen when we suspend with a timer running, then resume and disconnect. If we connect again, suspend and resume we might start timers that shouldn't be running. Reset the timer flags to avoid this. This affects both mesh and managed modes. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-17Merge branch 'for-john' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
2012-07-17mac80211: go out of PS before sending disassocEliad Peller
on disassoc, ieee80211_set_disassoc() goes out of PS before indicating BSS_CHANGED_ASSOC (not sure why this is needed, but some drivers might count on the current behavior). However, it does it after sending the disassoc frame, which results in null-data frame being sent (in order to go out of ps) after we were already sent the disassoc, which is invalid. Fix it by going out of ps before sending the disassoc. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-12Merge branch 'for-john' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next Conflicts: drivers/net/wireless/iwmc3200wifi/cfg80211.c drivers/net/wireless/mwifiex/cfg80211.c
2012-07-12mac80211: add time synchronisation with BSS for assocJohannes Berg
Some drivers (iwlegacy, iwlwifi and rt2x00) today use the bss_conf.last_tsf value. By itself though that value is completely worthless since it may be ancient. What really is needed is synchronisation between some device time and the TSF. To clarify this, rename bss_conf.last_tsf to sync_tsf and add sync_device_ts which is obtained from rx_status which gets a new field device_timestamp for this purpose. This is intentionally not using the mactime field since that is used for other things and in IBSS is expected to sync with the IBSS's TSF which isn't necessarily true for the device timestamp. Also, since we have the information and it's useful even before the connection has been established, give all the timing details to the driver before authenticating. Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-09Merge branch 'for-john' of git://git.sipsolutions.net/mac80211-nextJohn W. Linville
2012-07-09Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: net/mac80211/mlme.c
2012-07-09mac80211: destroy assoc_data correctly if assoc failsEliad Peller
If association failed due to internal error (e.g. no supported rates IE), we call ieee80211_destroy_assoc_data() with assoc=true, while we actually reject the association. This results in the BSSID not being zeroed out. After passing assoc=false, we no longer have to call sta_info_destroy_addr() explicitly. While on it, move the "associated" message after the assoc_success check. Cc: stable@vger.kernel.org [3.4+] Signed-off-by: Eliad Peller <eliad@wizery.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-07-09mac80211: remove unused assignmentJohannes Berg
ieee80211_mlme_notify_scan_completed() iterates all interfaces and doesn't need to assign anything to the sdata variable before the loop. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-09mac80211: update BSS info on AC parameters changeJohannes Berg
When the AC parameters change, drivers might rely on getting a bss_info_changed notification with BSS_CHANGED_QOS in addition to the conf_tx call. Always call the function when userspace updates are made (in AP/GO modes) and also set the change flag when updates were made by the AP (in managed mode.) Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-03mac80211: add TX prepare APIJohannes Berg
Some drivers require setup before being able to send management frames in managed mode, in particular in multi-channel cases. Introduce API to allow the drivers to do such setup while being able to sleep waiting for the setup to finish in the device. This isn't possible inside the TX call since that can't sleep. A future patch may also restructure the TX retry to wait for the driver to report the frame status, as suggested by Arik in http://mid.gmane.org/CA+XVXffKSEL6ZQPQ98x-zO-NL2=TNF1uN==mprRyUmAaRn254g@mail.gmail.com Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-02mac80211: allow calling ieee80211_ap_probereq_get() during auth/assocEliad Peller
Drivers might need getting the probe request (e.g. in order to extract the ssid) even during auth/assoc. Make ieee80211_ap_probereq_get() support it by considering auth_data/assoc_data as well. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-28Merge remote-tracking branch 'wireless-next/master' into mac80211-nextJohannes Berg
2012-06-28mac80211: don't require associated->beacon_ies for psEliad Peller
beacon_ies is needed only in order to extract the dtim period. However, even if it's missing we can still enter ps with dtim=1 (which also happens if the TIM ie is invalid). Most drivers don't use conf.max_sleep_period/ps_dtim_period anyway, and this check prevents them from entering ps if they don't have beacon (but only probe response), even though the beacon is not needed at all. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-28mac80211: flush queues before deauth/disassocEliad Peller
On deauth/disassoc we tear down all BA sessions. These DELBA packets are sent on the appropriate TID, while deauth/disassoc is always sent on VO. This sometimes ends with the DELBA being sent after the deauth was already sent. Fix it by flushing all the pending frames before sending deauth/disassoc. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-26Merge branch 'for-john' of git://git.sipsolutions.net/mac80211-nextJohn W. Linville
2012-06-24mac80211: clean up debuggingJohannes Berg
There are a few things that make the logging and debugging in mac80211 less useful than it should be right now: * a lot of messages should be pr_info, not pr_debug * wholesale use of pr_debug makes it require *both* Kconfig and dynamic configuration * there are still a lot of ifdefs * the style is very inconsistent, sometimes the sdata->name is printed in front Clean up everything, introducing new macros and separating out the station MLME debugging into a new Kconfig symbol. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-22Merge branch 'for-john' of git://git.sipsolutions.net/mac80211-nextJohn W. Linville
2012-06-21mac80211: clear ifmgd->bssid only after building DELBAEliad Peller
ieee80211_set_disassoc() clears ifmgd->bssid before building DELBA frames, resulting in frames with invalid bssid ("00:00:00:00:00:00"). Fix it by clearing ifmgd->bssid only after building all the needed frames. After this change, we no longer need to save the bssid (before clearing it), so remove the local array. Reported-by: Ido Yariv <ido@wizery.com> Cc: stable@vger.kernel.org Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-20mac80211: save wmm_acm per sdataYoni Divinsky
Save and configure the wmm_acm per sdata, rather than per hardware. If wmm_acm is saved per hardware when running two interfaces simultaneously on the same hardware one interface's wmm policy will be affected by the other interface. Signed-off-by: Yoni Divinsky <yoni.divinsky@ti.com> Signed-off-by: Luciano Coelho <coelho@ti.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-20mac80211: use the correct capability info in ieee80211_set_associated()Luciano Coelho
If an AP is beaconing with different capabilities than the one we get in the associate response, we were still using the capabilities received in the beacons. One example is when the AP is beaconing with the short slot bit set to zero and then we try to connect to it with long slot. In this case, we would keep using long slot until the next beacon was received. Fix this by using the correct capability value when calling ieee80211_handle_bss_capability(). We were using cbss->capability, but we should use the bss_conf->assoc_capability instead. Signed-off-by: Luciano Coelho <coelho@ti.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-20mac80211: initialize sta pointer to avoid false-positive warningLuciano Coelho
Some compilers (eg. gcc 4.4.1 for ARM) report a false positive warning in mlme.c: net/mac80211/mlme.c: In function 'ieee80211_prep_connection': net/mac80211/mlme.c:3035: warning: 'sta' may be used uninitialized in this function This is a false positive because the place where 'sta' is used is inside an if with the same condition of where it is set: [...] if (!have_sta) { sta = sta_info_alloc(sdata, cbss->bssid, GFP_KERNEL); if (!sta) return -ENOMEM; } [...] if (!have_sta) { [...] sta->sta.supp_rates[cbss->channel->band] = rates; [...] For some reason the compiler doesn't understand this and warns. While this is not a problem in the code itself, we can avoid polluting the build logs with false positives by setting sta to NULL on declaration and checking for sta instead of !have_sta in the second if. Reported-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Luciano Coelho <coelho@ti.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-13Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: drivers/net/wireless/ath/ath9k/main.c net/bluetooth/hci_event.c
2012-06-13mac80211: stop polling in disassociationDavid Spinadel
Stop connection monitor poll during disassociation. This clears the polling flags and if a scan was deferred it will be run. Without this fix, if a scan was deferred due to connection monitoring while disassociation happens, this scan blocks further scan requests until interface down/up which causes problems connecting to another AP. Signed-off-by: David Spinadel <david.spinadel@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-12Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: MAINTAINERS drivers/net/wireless/iwlwifi/pcie/trans.c
2012-06-08mac80211: add back channel change flagStanislaw Gruszka
commit 24398e39c8ee4a9d9123eed322b859ece4d16cac Author: Johannes Berg <johannes.berg@intel.com> Date: Wed Mar 28 10:58:36 2012 +0200 mac80211: set HT channel before association removed IEEE80211_CONF_CHANGE_CHANNEL argument from ieee80211_hw_config, which is required by iwl4965 driver, otherwise that driver does not configure channel properly and is not able to associate. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-06mac80211: do remain-on-channel while idleJohannes Berg
The IDLE handling in HW off-channel is broken right now since we turn off IDLE only when the off-channel period already started. Therefore, all drivers that use it today (only iwlwifi!) must support off-channel while idle, so playing with idle isn't needed at all. Off-channel in general, since it's no longer used for authentication/association, shouldn't affect PS, so also remove that logic. Also document a small caveat for reporting TX status from off-channel frames in HW remain-on-channel. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-06mac80211: print info when disabling HTJohannes Berg
Make mac80211 print a message when it disables HT due to the connection using WEP/TKIP or due to the AP not supporting WMM/QoS. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-06Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: drivers/net/wireless/iwlwifi/iwl-drv.c
2012-06-05mac80211: simplify association HT parametersJohannes Berg
Instead of passing around the entire HT information IE, extract only the HT parameters field and disable HT if the HT information IE isn't present and well- formed. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-05mac80211: remove ieee80211_get_operstate()Eliad Peller
ieee80211_get_operstate() was used by drivers in order to know whether the sta link is up, but it's no longer needed (nor used) as mac80211 notifies the drivers about authorization changes (via the sta_state callback) Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-05net: mac80211: Convert printk(KERN_DEBUG to pr_debugJoe Perches
Standardize the debugging to be able to use dynamic_debug. Coalesce formats, align arguments. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-05mac80211: send beacon loss events to userspaceHolger Schurig
Send beacon loss events to userspace, so it will be able to initiate roaming before disconnection Signed-off-by: Holger Schurig <holgerschurig@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-05mac80211: fail authentication when AP denied authenticationEliad Peller
ieee80211_rx_mgmt_auth() doesn't handle denied authentication properly - it authenticates the station and waits for association (for 5 seconds) instead of failing the authentication. Fix it by destroying auth_data and bailing out instead. Signed-off-by: Eliad Peller <eliad@wizery.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Cc: stable@vger.kernel.org #3.4 Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-04mac80211: run scan after finish connection monitoringStanislaw Gruszka
commit 133d40f9a22bdfd2617a446f1e3209537c5415ec Author: Stanislaw Gruszka <sgruszka@redhat.com> Date: Wed Mar 28 16:01:19 2012 +0200 mac80211: do not scan and monitor connection in parallel add bug, which make possible to start a scan and never finish it, so make every new scanning request finish with -EBUSY error. This can happen on code paths where we finish connection monitoring and clear IEEE80211_STA_*_POLL flags, but do not check if scan was deferred. This patch fixes those code paths. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-25mac80211: Fix race in checking AP status by sending null frameSoumik Das
mac80211 tries to verify the existence of the current AP by probing or sending a NULL frame in function ieee80211_mgd_probe_ap_send. It 1st sends a null frame to the AP, increments probe_send_count and waits for the ACK to the NULL frame for a finite duration of time. At times, it happens that by the time mac80211 gets to increment probe_send_count, the ACK for the NULL frame transmitted has already been processed. This leads to a race condition where mac80211 times out waiting for the ACK for the NULL frame causing unnecessary disconnection with the AP. Signed-off-by: Soumik Das <soumik.das@stericsson.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-15net: Convert net_ratelimit uses to net_<level>_ratelimitedJoe Perches
Standardize the net core ratelimited logging functions. Coalesce formats, align arguments. Change a printk then vprintk sequence to use printf extension %pV. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-14Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next
2012-05-09mac80211: Convert compare_ether_addr to ether_addr_equalJoe Perches
Use the new bool function ether_addr_equal to add some clarity and reduce the likelihood for misuse of compare_ether_addr for sorting. Done via cocci script: $ cat compare_ether_addr.cocci @@ expression a,b; @@ - !compare_ether_addr(a, b) + ether_addr_equal(a, b) @@ expression a,b; @@ - compare_ether_addr(a, b) + !ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) == 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) != 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) == 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) != 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !!ether_addr_equal(a, b) + ether_addr_equal(a, b) Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-08mac80211: fix rate control update on 2040 bss changeRajkumar Manoharan
The rate control updation never be called on 2040 BSS change. The station should update its rate control on receiving beacon with different HT mode in the HT operation IE. Not doing so, leads to sending frames with higher(ht40) rates whereas AP is operating in lower mode (ht20). Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/intel/e1000e/param.c drivers/net/wireless/iwlwifi/iwl-agn-rx.c drivers/net/wireless/iwlwifi/iwl-trans-pcie-rx.c drivers/net/wireless/iwlwifi/iwl-trans.h Resolved the iwlwifi conflict with mainline using 3-way diff posted by John Linville and Stephen Rothwell. In 'net' we added a bug fix to make iwlwifi report a more accurate skb->truesize but this conflicted with RX path changes that happened meanwhile in net-next. In e1000e a conflict arose in the validation code for settings of adapter->itr. 'net-next' had more sophisticated logic so that logic was used. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-24mac80211: call ieee80211_mgd_stop() on interface stopEliad Peller
ieee80211_mgd_teardown() is called on netdev removal, which occurs after the vif was already removed from the low-level driver, resulting in the following warning: [ 4809.014734] ------------[ cut here ]------------ [ 4809.019861] WARNING: at net/mac80211/driver-ops.h:12 ieee80211_bss_info_change_notify+0x200/0x2c8 [mac80211]() [ 4809.030388] wlan0: Failed check-sdata-in-driver check, flags: 0x4 [ 4809.036862] Modules linked in: wlcore_sdio(-) wl12xx wlcore mac80211 cfg80211 [last unloaded: cfg80211] [ 4809.046849] [<c001bd4c>] (unwind_backtrace+0x0/0x12c) [ 4809.055937] [<c047cf1c>] (dump_stack+0x20/0x24) [ 4809.065385] [<c003e334>] (warn_slowpath_common+0x5c/0x74) [ 4809.075589] [<c003e408>] (warn_slowpath_fmt+0x40/0x48) [ 4809.088291] [<bf033630>] (ieee80211_bss_info_change_notify+0x200/0x2c8 [mac80211]) [ 4809.102844] [<bf067f84>] (ieee80211_destroy_auth_data+0x80/0xa4 [mac80211]) [ 4809.116276] [<bf068004>] (ieee80211_mgd_teardown+0x5c/0x74 [mac80211]) [ 4809.129331] [<bf043f18>] (ieee80211_teardown_sdata+0xb0/0xd8 [mac80211]) [ 4809.141595] [<c03b5e58>] (rollback_registered_many+0x228/0x2f0) [ 4809.153056] [<c03b5f48>] (unregister_netdevice_many+0x28/0x50) [ 4809.165696] [<bf041ea8>] (ieee80211_remove_interfaces+0xb4/0xdc [mac80211]) [ 4809.179151] [<bf032174>] (ieee80211_unregister_hw+0x50/0xf0 [mac80211]) [ 4809.191043] [<bf0bebb4>] (wlcore_remove+0x5c/0x7c [wlcore]) [ 4809.201491] [<c02c6918>] (platform_drv_remove+0x24/0x28) [ 4809.212029] [<c02c4d50>] (__device_release_driver+0x8c/0xcc) [ 4809.222738] [<c02c4e84>] (device_release_driver+0x30/0x3c) [ 4809.233099] [<c02c4258>] (bus_remove_device+0x10c/0x128) [ 4809.242620] [<c02c26f8>] (device_del+0x11c/0x17c) [ 4809.252150] [<c02c6de0>] (platform_device_del+0x28/0x68) [ 4809.263051] [<bf0df49c>] (wl1271_remove+0x3c/0x50 [wlcore_sdio]) [ 4809.273590] [<c03806b0>] (sdio_bus_remove+0x48/0xf8) [ 4809.283754] [<c02c4d50>] (__device_release_driver+0x8c/0xcc) [ 4809.293729] [<c02c4e2c>] (driver_detach+0x9c/0xc4) [ 4809.303163] [<c02c3d7c>] (bus_remove_driver+0xc4/0xf4) [ 4809.312973] [<c02c5a98>] (driver_unregister+0x70/0x7c) [ 4809.323220] [<c03809c4>] (sdio_unregister_driver+0x24/0x2c) [ 4809.334213] [<bf0df458>] (wl1271_exit+0x14/0x1c [wlcore_sdio]) [ 4809.344930] [<c009b1a4>] (sys_delete_module+0x228/0x2a8) [ 4809.354734] ---[ end trace 515290ccf5feb522 ]--- Rename ieee80211_mgd_teardown() to ieee80211_mgd_stop(), and call it on ieee80211_do_stop(). Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-13mac80211: do not scan and monitor connection in parallelStanislaw Gruszka
Before we send probes in connection monitoring we check if scan is not pending. But we do that check without locking. Fix that and also do not start scan if connection monitoring is in progress. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-12Merge branch 'master' of ↵John W. Linville
2012-04-10mac80211: sanity check for null SSIDStanislaw Gruszka
While associated we should never have empty SSID, but life can be full of surprises, and is allways better to print a warning than crash. Before memcpy() in ieee80211_probereq_get() check ssid_len instead of ssid pointer, sice pointer it always passed by "ssidie + 2" expression to send probe functions, so practically never can be NULL. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-10mac80211: use IEEE80211_NUM_ACSJohannes Berg
When comparing hw->queues to determine if the device is QoS capable, use IEEE80211_NUM_ACS instead of just 4. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-10mac80211: notify driver of rate control updatesJohannes Berg
Devices that have internal rate control need to be notified when the bandwidth or SMPS state changes just like external rate control algorithms get a notification now. Add this notification and clarify the change bits while at it, the HT_CHANGED bit really meant only bandwidth changed. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-10mac80211: remove queue stop on rate control updateJohannes Berg
We currently stop the queue when changing the rate control between 20/40 MHz in the BSS. This seems to have been necessary when we actually changed the channel, but now that we just update the station it doesn't seem right any more. Remove it. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-10mac80211: remove channel type argument from rate_updateJohannes Berg
The channel type argument to the rate_update() callback isn't really the correct way to give the rate control algorithm about the desired RX bandwidth of the peer. Remove this argument, and instead update the STA capabilities with 20/40 appropriately. The SMPS update done by this callback works in the same way, so this makes the callback cleaner. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
