path: root/net/mac80211/mesh_plink.c
2010-04-15Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: Documentation/feature-removal-schedule.txt drivers/net/wireless/ath/ath5k/phy.c drivers/net/wireless/wl12xx/wl1271_main.c
2010-04-08mac80211: Moved mesh action codes to a more visible locationJavier Cardona
Grouped mesh action codes together with the other action codes in ieee80211.h. Signed-off-by: Javier Cardona <javier@cozybit.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-02-08mac80211: allow station add/remove to sleepJohannes Berg
Many drivers would like to sleep during station addition and removal, and currently have a high complexity there from not being able to. This introduces two new callbacks sta_add() and sta_remove() that drivers can implement instead of using sta_notify() and that can sleep, and the new sta_add() callback is also allowed to fail. The reason we didn't do this previously is that the IBSS code wants to insert stations from the RX path, which is a tasklet, so cannot sleep. This patch will keep the station allocation in that path, but moves adding the station to the driver out of line. Since the addition can now fail, we can have IBSS peer structs the driver rejected -- in that case we still talk to the station but never tell the driver about it in the control.sta pointer. If there will ever be a driver that has a low limit on the number of stations and that cannot talk to any stations that are not known to it, we need to do come up with a new strategy of handling larger IBSSs, maybe quicker expiry or rejecting peers. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21mac80211: reduce reliance on netdevJohannes Berg
For bluetooth 3, we will most likely not have a netdev for a virtual interface (sdata), so prepare for that by reducing the reliance on having a netdev. This patch moves the name and address fields into the sdata struct and uses them from there all over. Some work is needed to keep them sync'ed, but that's not a lot of work and in slow paths anyway. In doing so, this also reduces the number of pointer dereferences in many places, because of things like sdata->dev->dev_addr becoming sdata->vif.addr. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21mac80211: make station management completely depend on vifJohannes Berg
The station management currently uses the virtual interface, but you cannot add the same station to multiple virtual interfaces if you're communicating with it in multiple ways. This restriction should be lifted so that in the future we can, for instance, support bluetooth 3 with an access point that mac80211 is already associated to. We can do that by requiring all sta_info_get users to provide the virtual interface and making the RX code aware that an address may match more than one station struct. Thanks to the previous patches this one isn't all that large and except for the RX and TX status paths changes has low complexity. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-18mac80211: remove encrypt parameter from ieee80211_tx_skbJohannes Berg
Since the flags moved into skb->cb, there's no longer a need to have the encrypt bool passed into the function, anyone who requires it set to 0 (false) can just set the flag directly. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-13mac80211: update copyrights to 2009Rui Paulo
Signed-off-by: Rui Paulo <rpaulo@gmail.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Reviewed-by: Andrey Yurovsky <andrey@cozybit.com> Tested-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-13mac80211: set the AID field correctly for mesh peer framesRui Paulo
This sets the AID field correctly for mesh peer confirm frames. Signed-off-by: Rui Paulo <rpaulo@gmail.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Reviewed-by: Andrey Yurovsky <andrey@cozybit.com> Tested-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-11mac80211: improve peer link management debuggingRui Paulo
Print the FSM state strings instead of just the numbers. Signed-off-by: Rui Paulo <rpaulo@gmail.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Reviewed-by: Andrey Yurovsky <andrey@cozybit.com> Tested-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-11mac80211: update peer link management IE and action framesRui Paulo
Update the length and format of the peer link management action frames. Signed-off-by: Rui Paulo <rpaulo@gmail.com> Signed-off-by: Javier Cardona <javier@cozybit.com> Reviewed-by: Andrey Yurovsky <andrey@cozybit.com> Tested-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-11mac80211: fix typo in a commentRui Paulo
Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: Rui Paulo <rpaulo@gmail.com> Reviewed-by: Andrey Yurovsky <andrey@cozybit.com> Tested-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-11mac80211: implement the meshconf formation info fieldRui Paulo
The Mesh Configuration Formation Info field contains the number of neighbors. This means that the beacon must be updated every time a peer joins or leaves. Signed-off-by: Rui Paulo <rpaulo@gmail.com> Signed-off-by: Javier Cardona <rpaulo@gmail.com> Reviewed-by: Andrey Yurovsky <andrey@cozybit.com> Tested-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14mac80211: Fix invalid length passed to IE parser for PLINK CONFIRM framesDavid Woo
The length of the fixed portion of plink confirm frames is 4 bytes longer than the other plink_action frames. This path corrects an error in the length adjustment done for these type of frames. Signed-off-by: Javier Cardona <javier@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-20mac80211: cancel/restart all timers across suspend/resumeJohannes Berg
We forgot to cancel all timers in mac80211 when suspending. In particular we forgot to deal with some things that can cause hardware reconfiguration -- while it is down. While at it we go ahead and add a warning in ieee80211_sta_work() if its run while the suspend->resume cycle is in effect. This should not happen and if it does it would indicate there is a bug lurking in either mac80211 or mac80211 drivers. With this now wpa_supplicant doesn't blink when I go to suspend and resume where as before there where issues with some timers running during the suspend->resume cycle. This caused a lot of incorrect assumptions and would at times bring back the device in an incoherent, but mostly recoverable, state. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29wireless: restrict to 32 legacy ratesJohannes Berg
Since the standards only define 12 legacy rates, 32 is certainly a sane upper limit and we don't need to use u64 everywhere. Add sanity checking that no more than 32 rates are registered and change the variables to u32 throughout. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: remove mesh_plink_close() method.Rami Rosen
This patch removes mesh_plink_close() method as it is unused. Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: 802.11w - Do not force Action frames to disable encryptionJouni Malinen
When sending out Action frames, allow ieee80211_tx_skb() to send them without enforcing do_not_encrypt. These frames will be encrypted if MFP has been negotiated. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-12mac80211: initialize RC data for all mesh links upon allocationChristian Lamparter
This patch fixes a panic that might occur, if the device is part of a mesh and tries to send with a higher rate index than "0". kernel BUG at net/mac80211/rate.c:239! invalid opcode: 0000 [#1] SMP [...] Call Trace: <IRQ> <0> ? invoke_tx_handlers+0x474/0xb57 [mac80211] ? __ieee80211_tx_prepare+0x260/0x2a8 [mac80211] ? ieee80211_master_start_xmit+0x300/0x43a [mac80211] ? __qdisc_run+0xde/0x1da ? net_tx_action+0xb4/0x102 Kernel panic - not syncing: Fatal exception in interrupt Signed-off-by: Christian Lamparter <chunkeey@web.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-27mac80211: convert to %pM away from print_macJohannes Berg
Also remove a few stray DECLARE_MAC_BUF that were no longer used at all. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-15mac80211: share sta->supp_ratesJohannes Berg
As more preparation for a saner rate control algorithm API, share the supported rates bitmap in the public API. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15mac80211: share STA information with driverJohannes Berg
This patch changes mac80211 to share some more data about stations with drivers. Should help iwlwifi and ath9k when they get around to updating, and might also help with implementing rate control algorithms without internals. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Sujith Manoharan <Sujith.Manoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15mac80211: split off mesh handling entirelyJohannes Berg
This patch splits off mesh handling from the STA/IBSS. Unfortunately it increases mesh code size a bit, but I think it makes things clearer. The patch also reduces per-interface run-time memory usage. Also clean up a few places where ifdef is not required. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-11mac80211: move frame TX functionJohannes Berg
The ieee80211_sta_tx function isn't MLME code any more, it's getting used by a lot of code. Move it to utils and rename it to ieee80211_tx_skb. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-11mac80211: fix action frame length checksJohannes Berg
The action frame length checks are one too small, there's not just an action code as the comment makes you believe, there's a category code too, and the category code is required in each action frame (hence part of IEEE80211_MIN_ACTION_SIZE). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-22replace net_device arguments with ieee80211_{local,sub_if_data} as appropriateJasper Bryant-Greene
This patch replaces net_device arguments to mac80211 internal functions with ieee80211_{local,sub_if_data} as appropriate. It also does the same for many 802.11s mesh functions, and changes the mesh path table to be indexed on sub_if_data rather than net_device. If the mesh part needs to be a separate patch let me know, but since mesh uses a lot of mac80211 functions which were being converted anyway, the changes go hand-in-hand somewhat. This patch probably does not convert all the functions which could be converted, but it is a large chunk and followup patches will be provided. Signed-off-by: Jasper Bryant-Greene <jasper@amiton.co.nz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-22mac80211: remove IEEE80211_FC helperHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-14mac80211: proper STA info lockingJohannes Berg
As discussed earlier, we can unify locking in struct sta_info and use just a single spinlock protecting all members of the structure that need protection. Many don't, but one of the especially bad ones is the 'flags' member that can currently be clobbered when RX and TX is being processed on different CPUs at the same time. Because having four spinlocks for different, mostly exclusive parts of a single structure is overkill, this patch also kills the ampdu and mesh plink spinlocks and uses just a single one for everything. Because none of the spinlocks are nested, this is safe. It remains to be seen whether or not we should make the sta flags use atomic bit operations instead, for now though this is a safe thing and using atomic operations instead will be very simple using the new static inline functions this patch introduces for accessing sta->flags. Since spin_lock_bh() is used with this lock, there shouldn't be any contention even if aggregation is enabled at around the same time as both requires frame transmission/reception which is in a bh context. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Tomas Winkler <tomasw@gmail.com> Cc: Ron Rindjunsky <ron.rindjunsky@intel.com> Cc: Luis Carlos Cobo <luisca@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08mac80211: rename filesJohannes Berg
This patch renames all mac80211 files (except ieee80211_i.h) to get rid of the useless ieee80211_ prefix. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08mac80211: clean up IEEE80211_FC useJohannes Berg
Really doesn't need to be defined four times. Also, while at it, remove a useless macro (IEEE80211_ALIGN32_PAD) and a function prototype for a function we don't actually have (ieee80211_set_compression.) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-01mac80211: automatically free sta struct when insertion failsJohannes Berg
When STA structure insertion fails, it has been allocated but isn't really alive yet, it isn't reachable by any other code and also can't yet have much configured. This patch changes the code so that when the insertion fails, the resulting STA pointer is no longer valid because it is freed. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-06mac80211: add PLINK_ prefix and kernel doc to enum plink_stateLuis Carlos Cobo
Signed-off-by: Luis Carlos Cobo <luisca@cozybit.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-06mac80211: clean up use of endianness conversion functionsLuis Carlos Cobo
2008-03-06mac80211: fix mesh endianness sparse warnings and unmark it as brokenLuis Carlos Cobo
This patch fixes all the mesh related endianness warnings reported by sparse. As they were the reason why Johannes marked mesh as BROKEN, that flag has been removed. Signed-off-by: Luis Carlos Cobo <luisca@cozybit.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-06mac80211: fix sta_info mesh timer bugJohannes Berg
I noticed a bug I introduced when mesh is enabled: sta_info_destroy() will end up calling cancel_timer() on a timer that has never been initialized because the timer is only initialized in mesh_plink_alloc(), not in sta_info_alloc(). This patch moves the initialization of all mesh related fields into sta_info_alloc(), adds a bit of sanity checking to the cfg80211 handlers and sta_info_insert() and makes mesh_plink_alloc() a static helper function that is only used from the mesh plink code. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Luis Carlos Cobo <luisca@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-06mac80211: split sta_info_addJohannes Berg
sta_info_add() has two functions: allocating a station info structure and inserting it into the hash table/list. Splitting these two functions allows allocating with GFP_KERNEL in many places instead of GFP_ATOMIC which is now required by the RCU protection. Additionally, in many places RCU protection is now no longer needed at all because between sta_info_alloc() and sta_info_insert() the caller owns the structure. This fixes a few race conditions with setting initial flags and similar, but not all (see comments in ieee80211_sta.c and cfg.c). More documentation on the existing races will be in a follow-up patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-06mac80211: RCU-ify STA info structure accessJohannes Berg
This makes access to the STA hash table/list use RCU to protect against freeing of items. However, it's not a true RCU, the copy step is missing: whenever somebody changes a STA item it is simply updated. This is an existing race condition that is now somewhat understandable. This patch also fixes the race key freeing vs. STA destruction by making sure that sta_info_destroy() is always called under RTNL and frees the key. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-06mac80211: fix kernel-doc comment for mesh_plink_deactivateJohannes Berg
Accidentally copied in a __mesh_plink_deactivate, noticed by Luis Carlos Cobo. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-06mac80211: add missing "break" statement in mesh codeJohannes Berg
This inserts a missing break statement which, if hit, would cause the code to fall-through and unlock a spinlock twice. Noticed via sparse's "lock count wrong in basic block" warning and careful code inspection. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Luis Carlos Cobo <luisca@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-06mac80211: clean up mesh codeJohannes Berg
Various cleanups, reducing the #ifdef mess and other things. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-06mac80211: mesh peer link implementationLuis Carlos Cobo
This file implements mesh discovery and peer link establishment support using the mesh peer link table provided in mesh_plinktbl.c. Secure peer links have not been implemented yet. Signed-off-by: Luis Carlos Cobo <luisca@cozybit.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
