path: root/net/mac80211/main.c
2008-06-09mac80211: Fixing slow IBSS rejoinAssaf Krauss
This patch fixes the issue of slow reconnection to an IBSS cell after disconnection from it. Now the interface's bssid is reset upon ifdown. ieee80211_sta_find_ibss: if (found && memcmp(ifsta->bssid, bssid, ETH_ALEN) != 0 && (bss = ieee80211_rx_bss_get(dev, bssid, local->hw.conf.channel->center_freq, ifsta->ssid, ifsta->ssid_len))) Note: In general disconnection is still not handled properly in mac80211 Signed-off-by: Assaf Krauss <assaf.krauss@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-28mac80211: fix a typo in ieee80211_handle_filtered_frame commentYi Zhu
fix a typo in ieee80211_handle_filtered_frame comment Signed-off-by: Yi Zhu <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-04mac80211: Do not free net device after it is unregistered.Pavel Emelyanov
The error path in ieee80211_register_hw() may call the unregister_netdev() and right after it - the free_netdev(), which is wrong, since the unregister releases the device itself. So the proposed fix is to NULL the local->mdev after unregister is done and check this before calling free_netdev(). I checked - no code uses the local->mdev after unregister in this error path (but even if some did this would be a BUG). Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-30mac80211: insert WDS peer after adding interfaceJohannes Berg
This reorders the open code so that WDS peer STA info entries are added after the corresponding interface is added to the driver so that driver callbacks aren't invoked out of order. Also make any master device startup fatal. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-30mac80211: don't allow invalid WDS peer addressesJohannes Berg
Rather than just disallowing the zero address, disallow all invalid ones. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-30mac80211: assign conf.beacon_control for meshJohannes Berg
Drivers can rightfully assume that they get a beacon_control if the beacon is set. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-16mac80211: fix spinlock recursionJohannes Berg
When STAs are expired, we need to hold the sta_lock. Using the same lock for keys too would then mean we'd need another key free function, and that'll just lead to confusion, so just use a new spinlock for all key lists. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08mac80211: rename filesJohannes Berg
This patch renames all mac80211 files (except ieee80211_i.h) to get rid of the useless ieee80211_ prefix. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
