path: root/net/mac80211/ieee80211_rate.c
2008-01-28mac80211: make PID rate control algorithm the defaultStefano Brivio
This makes the new PID TX rate control algorithm the default instead of the rc80211_simple rate control algorithm. The simple algorithm was flawed in several ways: it wasn't responsive at all and didn't age the information it was relying on properly. The PID algorithm allows us to tune characteristics such as responsiveness by adjusting parameters and was found to generally behave better. The default algorithm can be overridden to select simple instead. Which ever algorithm is the default is included as part of the mac80211 module automatically. The other algorithm (simple vs. pid) can be selected for inclusion as well. If EMBEDDED is selected then the choice is available to have no default specified and neither algorithm included in mac80211. The default algorithm can be set through a modparam. While at it, mark rc80211-simple as deprecated, and schedule it for removal. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28mac80211: clean up rate selectionMattias Nissler
Move some code out of rc80211_simple since it's probably needed for all rate selection algorithms, and fix iwlwifi accordingly. While at it, clean up the rate_control_get_rate() interface. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-19NET: mac80211: fix inappropriate memory freeingCyrill Gorcunov
Fix inappropriate memory freeing in case of requested rate_control_ops was not found. In this case the list head entity is going to be accidentally wasted. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Acked-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-12-17ieee80211_rate: missed unlockCyrill Gorcunov
2007-11-10mac80211: don't allow registering the same rate control twiceJohannes Berg
Previously, mac80211 would allow registering the same rate control algorithm twice. This is a programming error in the registration and should not happen; additionally the second version could never be selected. Disallow this and warn about it. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-11-10mac80211: make simple rate control algorithm built-inJohannes Berg
Too frequently people do not have module autoloading enabled or fail to install the rate control module correctly, hence their hardware probing fails due to no rate control algorithm being available. This makes the 'simple' algorithm built into the mac80211 module unless EMBEDDED is enabled in which case it can be disabled (eg. if the wanted driver requires another rate control algorithm.) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[MAC80211]: remove management interfaceJohannes Berg
Removes the management interface since it is only required for hostapd/userspace MLME, will not be in the final tree at least in this form and hostapd/userspace MLME currently do not work against this tree anyway. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[MAC80211]: print out wiphy name instead of master deviceJohannes Berg
This makes mac80211 print out the wiphy name instead of the master device name where appropriate. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[MAC80211]: move some rate control functions out of ieee80211.cJohannes Berg
I think these can go with rate control just as well and it makes ieee80211.c more readable. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Jiri Benc <jbenc@suse.cz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-05[MAC80211]: Add mac80211 wireless stack.Jiri Benc
Add mac80211, the IEEE 802.11 software MAC layer. Signed-off-by: Jiri Benc <jbenc@suse.cz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
