path: root/net/mac80211/ieee80211.c
2008-01-28mac80211: A-MPDU Rx stop aggregation on proper devRon Rindjunsky
This patch adds a check to insure that Rx A-MPDU will be stopped only for the proper device. Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28mac80211: add unified BSS configurationJohannes Berg
This patch (based on Ron Rindjunsky's) creates a framework for a unified way to pass BSS configuration to drivers that require the information, e.g. for implementing power save mode. This patch introduces new ieee80211_bss_conf structure that is passed to the driver via the new bss_info_changed() callback when the BSS configuration changes. This new BSS configuration infrastructure adds the following new features: * drivers are notified of their association AID * drivers are notified of association status and replaces the erp_ie_changed() callback. The patch also does the relevant driver updates for the latter change. Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28mac80211: add beacon configuration via cfg80211Johannes Berg
This patch implements the cfg80211 hooks for configuring beaconing on an access point interface in mac80211. While doing so, it fixes a number of races that could badly crash the machine when the beacon is changed while being requested by the driver. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28mac80211: move interface type to vif structureJohannes Berg
Drivers that support mixed AP/STA operation may well need to know the type of a virtual interface when iterating over them. The easiest way to support that is to move the interface type variable into the vif structure. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28mac80211: dont use interface indices in driversJohannes Berg
This patch gets rid of the if_id stuff where possible in favour of a new per-virtual-interface structure "struct ieee80211_vif". This structure is located at the end of the per-interface structure and contains a variable length driver-use data area. This has two advantages: * removes the need to look up interfaces by if_id, this is better for working with network namespaces and performance * allows drivers to store and retrieve per-interface data without having to allocate own lists/hash tables Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28mac80211: Add radio led triggerIvo van Doorn
Some devices have a seperate LED which indicates if the radio is enabled or not. This adds a LED trigger to mac80211 where drivers can hook into when they are interested in radio status changes. v2: Check hw.conf.radio_enabled when calling start(). Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28mac80211: better rate control algorithm selectionJohannes Berg
This patch changes mac80211's Kconfig/Makefile to: * select between the PID and the SIMPLE rate control algorithm as default * always allow tri-state for the rate control algorithms, building those that are selected 'y' into the mac80211 module (if that is a module, otherwise all into the kernel) * force the default rate control algorithm to be built into mac80211 It also makes both rate control algorithms proper modules again with MODULE_LICENSE etc. Only if EMBEDDED is the user allowed to select "NONE" as default which will cause no algorithm to be selected, this will work only when the driver brings one itself (e.g. iwlwifi drivers). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28mac80211: A-MPDU Rx adding basic functionalityRon Rindjunsky
This patch adds the basic needed abilities and functions for A-MPDU Rx session changed functions: - ieee80211_sta_process_addba_request - Rx A-MPDU initialization enabled - ieee80211_stop - stops all A-MPDU Rx in case interface goes down added functions: - ieee80211_send_delba - used for sending out Del BA in A-MPDU sessions - ieee80211_sta_stop_rx_BA_session - stopping Rx A-MPDU session - sta_rx_agg_session_timer_expired - stops A-MPDU Rx use if load is too low Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28mac80211: clean up eapol handling in TX pathJohannes Berg
The previous patch left only one user of the ieee80211_is_eapol() function and that user can be eliminated easily by introducing a new "frame is EAPOL" flag to handle the frame specially (we already have this information) instead of doing the (expensive) ieee80211_is_eapol() all the time. Also, allow unencrypted frames to be sent when they are injected. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28mac80211: make PID rate control algorithm the defaultStefano Brivio
This makes the new PID TX rate control algorithm the default instead of the rc80211_simple rate control algorithm. The simple algorithm was flawed in several ways: it wasn't responsive at all and didn't age the information it was relying on properly. The PID algorithm allows us to tune characteristics such as responsiveness by adjusting parameters and was found to generally behave better. The default algorithm can be overridden to select simple instead. Which ever algorithm is the default is included as part of the mac80211 module automatically. The other algorithm (simple vs. pid) can be selected for inclusion as well. If EMBEDDED is selected then the choice is available to have no default specified and neither algorithm included in mac80211. The default algorithm can be set through a modparam. While at it, mark rc80211-simple as deprecated, and schedule it for removal. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28mac80211: add PID controller based rate control algorithmMattias Nissler
Add a new rate control algorithm based on a PID controller. It samples the percentage of failed frames over time, feeds the result into the controller and uses its output to control the TX rate. Signed-off-by: Mattias Nissler <mattias.nissler@gmx.de> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28mac80211: clean up rate selectionMattias Nissler
Move some code out of rc80211_simple since it's probably needed for all rate selection algorithms, and fix iwlwifi accordingly. While at it, clean up the rate_control_get_rate() interface. Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28mac80211: adding 802.11n configuration flowsRon Rindjunsky
This patch configures the 802.11n mode of operation internally in ieee80211_conf structure and in the low-level driver as well (through op conf_ht). It does not include AP configuration flows. Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28mac80211: hardware scan reworkZhu Yi
The scan code in mac80211 makes the software scan assumption in various places. For example, we stop the Tx queue during a software scan so that all the Tx packets will be queued by the stack. We also drop frames not related to scan in the software scan process. But these are not true for hardware scan. Some wireless hardwares (for example iwl3945/4965) has the ability to perform the whole scan process by hardware and/or firmware. The hardware scan is relative powerful in that it tries to maintain normal network traffic while doing a scan in the background. Some drivers (i.e iwlwifi) do provide a way to tune the hardware scan parameters (for example if the STA is associated, what's the max time could the STA leave from the associated channel, how long the scans get suspended after returning to the service channel, etc). But basically this is transparent to the stack. mac80211 should not stop Tx queues or drop Rx packets during a hardware scan. This patch resolves the above problem by spliting the current scan indicator local->sta_scanning into local->sta_sw_scanning and local->sta_hw_scanning. It then changes the scan related code to be aware of hardware scan or software scan in various places. With this patch, iwlwifi performs much better in the scan-while-associated condition and disable_hw_scan=1 should never be required. Cc: Mohamed Abbas <mohamed.abbas@intel.com> Cc: Ben Cahill <ben.m.cahill@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-19mac80211: fix header opsJohannes Berg
When using recvfrom() on a SOCK_DGRAM packet socket, I noticed that the MAC address passed back for wireless frames was always completely wrong. The reason for this is that the header parse function assigned to our virtual interfaces is a function parsing an 802.11 rather than 802.3 header. This patch fixes it by keeping the default ethernet header operations assigned. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-11-30Merge branch 'fixes-davem' of ↵Herbert Xu
2007-11-29mac80211: Fix behavior of ieee80211_open and ieee80211_closeMichael Wu
This patch fixes: - Incorrect calls to ieee80211_hw_config when the radiotap flag is set. - Failure to actually unset the radiotap flag when all monitors are down. - Failure to call ieee80211_hw_config after successful interface start. Signed-off-by: Michael Wu <flamingice@sourmilk.net> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-11-29mac80211: free ifsta->extra_ie and clear IEEE80211_STA_PRIVACY_INVOKEDZhu Yi
I'm not sure if this is best choice, someone might have better solutions. But this patch fixed the connection problem when switching from a WPA enabled AP (using wpa_supplicant) to an open AP (using iwconfig). The root cause is when we connect to a WPA enabled AP, wpa_supplicant sets the ifsta->extra_ie thru SIOCSIWGENIE. But if we stop wpa_supplicant and connect to an open AP with iwconfig, there is no way to clear the extra_ie so that mac80211 keeps connecting with that. Someone could argue wpa_supplicant should clear the extra_ie during its shutdown. But mac80211 should also handle the unexpected shutdown case (ie. killall -9 wpa_supplicant). On Wed, 2007-11-21 at 16:19 +0100, Johannes Berg wrote: > Yeah. Can you amend the patch to also clear the > IEEE80211_STA_PRIVACY_INVOKED flag? Signed-off-by: Zhu Yi <yi.zhu@intel.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-11-20mac80211: fix allmulti/promisc behaviourJohannes Berg
When an interface with promisc/allmulti bit is taken down, the mac80211 state can become confused. This fixes it by making mac80211 keep track of all *active* interfaces that have the promisc/allmulti bit set in the sdata, we sync the interface bit into sdata at set_multicast_list() time so this works. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-11-20mac80211: fix ieee80211_set_multicast_listJohannes Berg
I recently experienced unexplainable behaviour with the b43 driver when I had broken firmware uploaded. The cause may have been that promisc mode was not correctly enabled or disabled and this bug may have been the cause. Note how the values are compared later in the function so just doing the & will result in the wrong thing being compared and the test being false almost always. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-11-10mac80211: allow driver to ask for a rate control algorithmJohannes Berg
This allows a driver to ask for a specific rate control algorithm. The rate control algorithm asked for must be registered and be available as a module or built-in. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-11-10mac80211: make simple rate control algorithm built-inJohannes Berg
Too frequently people do not have module autoloading enabled or fail to install the rate control module correctly, hence their hardware probing fails due to no rate control algorithm being available. This makes the 'simple' algorithm built into the mac80211 module unless EMBEDDED is enabled in which case it can be disabled (eg. if the wanted driver requires another rate control algorithm.) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[MAC80211]: make userspace-mlme a per-interface settingJohannes Berg
2007-10-10[MAC80211]: remove management interfaceJohannes Berg
Removes the management interface since it is only required for hostapd/userspace MLME, will not be in the final tree at least in this form and hostapd/userspace MLME currently do not work against this tree anyway. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[MAC80211]: add "invalid" interface typeJohannes Berg
Since I cannot convince the lazy driver authors (hello Michael) to stop (ab)using the MGMT interface type internally in their drivers, this patch introduces a new _INVALID type especially for their use and changes all affected drivers to use it. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[MAC80211]: Check open_count before calling config callback.Michael Buesch
Also remove the check for ops->config!=NULL, as it can never be NULL. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[PATCH] mac80211: remove generic IE for AP interfacesJohannes Berg
This is not useful since we do not support probe response offload to hardware at this time and beacons are set in another way. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] mac80211: fix iff_promiscs, iff_allmultis raceJohannes Berg
When we update the counters iff_promiscs and iff_allmultis in struct ieee80211_local we have no common lock held to protect them. The problem is that the update to each counter may not be atomic, so we could end up with iff_promiscs == -1 in unfortunate conditions. To fix it, use atomic_t values. It doesn't matter whether the two counters are updated together atomically or not, if there are two invocations of set_multicast_list we will end up with multiple configure_filter() invocations of which the latter will always be correct. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] mac80211: fix vlan bugJohannes Berg
VLAN interfaces have yet another bug: they aren't accounted for properly in the receive path in prepare_for_handlers(). I noticed this by code inspection, but it would be easy for the compiler to catch such things if we'd just use the proper enum where appropriate. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] mac80211: fix interface initialisation and deinitialisationJohannes Berg
When an interface is registered it is still uninitialised so ieee80211_if_reinit() can't be called on it (it will oops.) Hence, we need to move the uninit method assignment. Also, this patch fixes the bug that the master device is never initialised nor deinitialised at all. Oddly, the deinit code had an if statement to not run some code when running for the master interface (which never happened), but that if statement is also wrong. Fix that too. Now that the uninit code is run for the master device, another bug surfaced: it tries to remove all dependent interfaces and that oopses or BUGs at some point, either because it unregisters already unregistered interfaces (missing list_del bug) or due to trying to iterate a list that has had other things removed. Fix this too by handling the master interface specially. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] mac80211: fix virtual interface lockingJohannes Berg
Florian Lohoff noticed a bug in mac80211: when bringing the master interface down while other virtual interfaces are up we call dev_close() under a spinlock which is not allowed. This patch removes the sub_if_lock used by mac80211 in favour of using an RCU list. All list manipulations are already done under rtnl so are well protected against each other, and the read-side locks we took in the RX and TX code are already in RCU read-side critical sections. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Florian Lohoff <flo@rfc822.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: Satyam Sharma <satyam@infradead.org> Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] mac80211: validate VLAN interfaces betterJohannes Berg
This patch changes mac80211 to verify that VLAN interfaces are valid and not bother drivers about them any more. VLAN interfaces are now only valid when an AP interface is up with the same MAC address, and are automatically turned off when the AP interface is set down. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Jouni Malinen <j@w1.fi> Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[PATCH] mac80211: revamp interface and filter configurationJohannes Berg
Drivers are currently supposed to keep track of monitor interfaces if they allow so-called "hard" monitor, and they are also supposed to keep track of multicast etc. This patch changes that, replaces the set_multicast_list() callback with a new configure_filter() callback that takes filter flags (FIF_*) instead of interface flags (IFF_*). For a driver, this means it should open the filter as much as necessary to get all frames requested by the filter flags. Accordingly, the filter flags are named "positively", e.g. FIF_ALLMULTI. Multicast filtering is a bit special in that drivers that have no multicast address filters need to allow multicast frames through when either the FIF_ALLMULTI flag is set or when the mc_count value is positive. At the same time, drivers are no longer notified about monitor interfaces at all, this means they now need to implement the start() and stop() callbacks and the new change_filter_flags() callback. Also, the start()/stop() ordering changed, start() is now called *before* any add_interface() as it really should be, and stop() after any remove_interface(). The patch also changes the behaviour of setting the bssid to multicast for scanning when IEEE80211_HW_NO_PROBE_FILTERING is set; the IEEE80211_HW_NO_PROBE_FILTERING flag is removed and the filter flag FIF_BCN_PRBRESP_PROMISC introduced. This is a lot more efficient for hardware like b43 that supports it and other hardware can still set the BSSID to all-ones. Driver modifications by Johannes Berg (b43 & iwlwifi), Michael Wu (rtl8187, adm8211, and p54), Larry Finger (b43legacy), and Ivo van Doorn (rt2x00). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-10-10[NET]: Move hardware header operations out of netdevice.Stephen Hemminger
Since hardware header operations are part of the protocol class not the device instance, make them into a separate object and save memory. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Wrap hard_header_parseStephen Hemminger
Wrap the hard_header_parse function to simplify next step of header_ops conversion. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[MAC80211]: rename ieee80211_cfg.h to cfg.hMichael Wu
Might as well rename ieee80211_cfg.h to cfg.h to keep things consistent. Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[MAC80211]: print out wiphy name instead of master deviceJohannes Berg
This makes mac80211 print out the wiphy name instead of the master device name where appropriate. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[MAC80211]: remove key threshold stuffJohannes Berg
This patch removes the key threshold stuff from mac80211. I have patches for later that add it as a per-key setting to nl/cfg80211. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[MAC80211]: Add support for setting TX power and radio statusMichael Buesch
This adds support for disabling the radio and setting the TXpower through wext. This also fixes the prism TXpower ioctl (It always overwrote the TXpower value in ieee80211_hw_config()) Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[MAC80211]: use internal network device statsStephen Hemminger
Stats are now available for device usage inside network_device Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[MAC80211]: remove turbo modesJohannes Berg
This patch removes all mention of the atheros turbo modes that can't possibly work properly anyway since in some places we don't check for them when we should. I have no idea what the iwlwifi drivers were doing with these but it can't possibly have been correct. Cc: Zhu Yi <yi.zhu@intel.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make the device list and device lookups per namespace.Eric W. Biederman
This patch makes most of the generic device layer network namespace safe. This patch makes dev_base_head a network namespace variable, and then it picks up a few associated variables. The functions: dev_getbyhwaddr dev_getfirsthwbytype dev_get_by_flags dev_get_by_name __dev_get_by_name dev_get_by_index __dev_get_by_index dev_ioctl dev_ethtool dev_load wireless_process_ioctl were modified to take a network namespace argument, and deal with it. vlan_ioctl_set and brioctl_set were modified so their hooks will receive a network namespace argument. So basically anthing in the core of the network stack that was affected to by the change of dev_base was modified to handle multiple network namespaces. The rest of the network stack was simply modified to explicitly use &init_net the initial network namespace. This can be fixed when those components of the network stack are modified to handle multiple network namespaces. For now the ifindex generator is left global. Fundametally ifindex numbers are per namespace, or else we will have corner case problems with migration when we get that far. At the same time there are assumptions in the network stack that the ifindex of a network device won't change. Making the ifindex number global seems a good compromise until the network stack can cope with ifindex changes when you change namespaces, and the like. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[MAC80211]: rework key handlingJohannes Berg
This moves all the key handling code out from ieee80211_ioctl.c into key.c and also does the following changes including documentation updates in mac80211.h: 1) Turn off hardware acceleration for keys when the interface is down. This is necessary because otherwise monitor interfaces could be decrypting frames for other interfaces that are down at the moment. Also, it should go some way towards better suspend/resume support, in any case the routines used here could be used for that as well. Additionally, this makes the driver interface nicer, keys for a specific local MAC address are only ever present while an interface with that MAC address is enabled. 2) Change driver set_key() callback interface to allow only return values of -ENOSPC, -EOPNOTSUPP and 0, warn on all other return values. This allows debugging the stack when a driver notices it's handed a key while it is down. 3) Invert the flag meaning to KEY_FLAG_UPLOADED_TO_HARDWARE. 4) Remove REMOVE_ALL_KEYS command as it isn't used nor do we want to use it, we'll use DISABLE_KEY for each key. It is hard to use REMOVE_ALL_KEYS because we can handle multiple virtual interfaces with different key configuration, so we'd have to keep track of a lot of state for this and that isn't worth it. 5) Warn when disabling a key fails, it musn't. 6) Remove IEEE80211_HW_NO_TKIP_WMM_HWACCEL in favour of per-key IEEE80211_KEY_FLAG_WMM_STA to let driver sort it out itself. 7) Tell driver that a (non-WEP) key is used only for transmission by using an all-zeroes station MAC address when configuring. 8) Change the set_key() callback to have access to the local MAC address the key is being added for. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[MAC80211]: embed key conf in key, fix driver interfaceJohannes Berg
This patch embeds the struct ieee80211_key_conf into struct ieee80211_key and thus avoids allocations and having data present twice. This required some more changes: 1) The removal of the IEEE80211_KEY_DEFAULT_TX_KEY key flag. This flag isn't used by drivers nor should it be since we have a set_key_idx() callback. Maybe that callback needs to be extended to include the key conf, but only a driver that requires it will tell. 2) The removal of the IEEE80211_KEY_DEFAULT_WEP_ONLY key flag. This flag is global, so it shouldn't be passed in the key conf structure. Pass it to the function instead. Also, this patch removes the AID parameter to the set_key() callback because it is currently unused and the hardware currently cannot know about the AID anyway. I suspect this was used with some hardware that actually selected the AID itself, but that functionality was removed. Additionally, I've removed the ALG_NULL key algorithm since we have ALG_NONE. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[MAC80211]: Remove bitfields from struct ieee80211_sub_if_dataJiri Slaby
mac80211, remove bitfields from struct ieee80211_sub_if_data Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[MAC80211]: Remove bitfields from struct ieee80211_if_staJiri Slaby
mac80211, remove bitfields from struct ieee80211_if_sta Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[MAC80211]: Remove bitfields from struct ieee80211_tx_packet_dataJiri Slaby
remove bitfields from struct ieee80211_tx_packet_data [Johannes: completely clear flags in ieee80211_remove_tx_extra] Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[MAC80211]: remove unused ioctls (1)Johannes Berg
The ioctls * PRISM2_PARAM_ANTENNA_MODE * PRISM2_PARAM_STAT_TIME are not used by hostapd or wpa_supplicant. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[MAC80211]: remove radar stuffJohannes Berg
Unused in drivers, userspace and mac80211. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Michael Wu <flamingice@sourmilk.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
