path: root/net/mac80211/debugfs.c
2014-12-15mac80211: move U-APSD enablement to vif flagsJohannes Berg
In order to let drivers have more dynamic U-APSD support, move the enablement flag to the virtual interface driver flags. This lets drivers not only set it up differently for different interfaces, but also enable/disable on the fly if needed. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-09-11mac80211: replace SMPS hw flags with wiphy feature bitsEliad Peller
Use the new static_smps / dynamic_smps feature bits instead of mac80211-internal hw flags. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-09-05mac80211: add Intel Mobile Communications copyrightJohannes Berg
Our legal structure changed at some point (see wikipedia), but we forgot to immediately switch over to the new copyright notice. For files that we have modified in the time since the change, add the proper copyright notice now. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-04-09mac80211: use RCU_INIT_POINTERMonam Agarwal
rcu_assign_pointer() ensures that the initialization of a structure is carried out before storing a pointer to that structure. However, in the case that NULL is assigned there's no structure to initialize so using RCU_INIT_POINTER instead is safe and more efficient. Signed-off-by: Monam Agarwal <monamagarwal123@gmail.com> [squash eight tiny patches, rewrite commit log] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-12-02mac80211: Tx frame latency statisticsMatti Gottlieb
Measure TX latency and jitter statistics per station per TID. These Measurements are disabled by default and can be enabled via debugfs. Features included for each station's TID: 1. Keep count of the maximum and average latency of Tx frames. 2. Keep track of many frames arrived in a specific time range (need to enable through debugfs and configure the bins ranges) Signed-off-by: Matti Gottlieb <matti.gottlieb@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-10-01mac80211: fix some snprintf misusesEliad Peller
In some debugfs related functions snprintf was used while scnprintf should have been used instead. (blindly adding the return value of snprintf and supplying it to the next snprintf might result in buffer overflow when the input is too big) Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-02-11mac80211: remove IEEE80211_HW_SCAN_WHILE_IDLEJohannes Berg
There are only a few drivers that use HW scan, and all of those don't need a non-idle transition before starting the scan -- some don't even care about idle at all. Remove the flag and code associated with it. The only driver that really actually needed this is wl1251 and it can just do it itself in the hw_scan callback -- implement that. Acked-by: Luciano Coelho <coelho@ti.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-01-31mac80211: inform the driver about update of dtim_periodEmmanuel Grumbach
Currently, when the driver requires the DTIM period, mac80211 will wait to hear a beacon before association. This behavior is suboptimal since some drivers may be able to deal with knowing the DTIM period after the association, if they get it at all. To address this, notify the drivers with bss_info_changed with the new BSS_CHANGED_DTIM_PERIOD flag when the DTIM becomes known. This might be when changing to associated, or later when the entire association was done with only probe response information. Rename the hardware flag for the current behaviour to IEEE80211_HW_NEED_DTIM_BEFORE_ASSOC to more accurately reflect its behaviour. IEEE80211_HW_NEED_DTIM_PERIOD is no longer accurate as all drivers get the DTIM period now, just not before association. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-09-19mac80211: make reset debugfs depend on CONFIG_PMJohannes Berg
The suspend/resume code depends on CONFIG_PM, so the reset debugfs file can only be made available if that is enabled. Fengguang Wu's zero-day build testing found this. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-08-20mac80211: remove freq/chantype from debugfsJohannes Berg
You can now get these values through iw, and they conflict with multi-channel work. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-12mac80211: redesign scan RXJohannes Berg
Scan receive is rather inefficient when there are multiple virtual interfaces. We iterate all of the virtual interfaces and then notify cfg80211 about each beacon many times. Redesign scan RX to happen before everything else. Then we can also get rid of IEEE80211_RX_IN_SCAN since we don't have to accept frames into the RX handlers for scanning or scheduled scanning any more. Overall, this simplifies the code. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-04-05simple_open: automatically convert to simple_open()Stephen Boyd
Many users of debugfs copy the implementation of default_open() when they want to support a custom read/write function op. This leads to a proliferation of the default_open() implementation across the entire tree. Now that the common implementation has been consolidated into libfs we can replace all the users of this function with simple_open(). This replacement was done with the following semantic patch: <smpl> @ open @ identifier open_f != simple_open; identifier i, f; @@ -int open_f(struct inode *i, struct file *f) -{ ( -if (i->i_private) -f->private_data = i->i_private; | -f->private_data = i->i_private; ) -return 0; -} @ has_open depends on open @ identifier fops; identifier open.open_f; @@ struct file_operations fops = { ... -.open = open_f, +.open = simple_open, ... }; </smpl> [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-15mac80211: make uapsd_* keys per-vifEliad Peller
uapsd_queues and uapsd_max_sp_len are relevant only for managed interfaces, and can be configured differently for each vif. Move them from the local struct to sdata->u.mgd, and update the debugfs functions accordingly. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-06mac80211: support hw scan while idleEliad Peller
Currently, mac80211 goes to idle-off before starting a scan. However, some devices that implement hw scan might not need going idle-off in order to perform a hw scan, and thus saving some energy and simplifying their state machine. (Note that this is also the case for sched scan - it currently doesn't make mac80211 go idle-off) Add a new flag to indicate support for hw scan while idle. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-27mac80211: make CQM RSSI support per virtual interfaceJohannes Berg
Similar to the previous beacon filtering patch, make CQM RSSI support depend on the flags that the driver set for virtual interfaces. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Acked-by: Luciano Coelho <coelho@ti.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-01-27mac80211: make beacon filtering per virtual interfaceJohannes Berg
Due to firmware limitations, we may not be able to support beacon filtering on all virtual interfaces. To allow this in mac80211, introduce per-interface driver capability flags that the driver sets when an interface is added. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Acked-by: Luciano Coelho <coelho@ti.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-28mac80211: remove debugfs noack testSimon Wunderlich
This feature has been superseded by the NoAck per Queue feature. Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-11-09net/mac80211/debugfs.c: use kstrtoul, etcJulia Lawall
Use kstrtoul, etc instead of the now deprecated strict_strtoul, etc. A semantic patch rule for the kstrtoul case is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression a,b; {int,long} *c; @@ -strict_strtoul +kstrtoul (a,b,c) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-27mac80211: add ieee80211_vif param to tsf functionsEliad Peller
TSF can be kept per vif. Add ieee80211_vif param to set/get/reset_tsf, and move the debugfs entries to the per-vif directory. Update all the drivers that implement these callbacks. Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-13mac80211: add flag to indicate HW only Tx-agg setup supportArik Nemtsov
When this flag is set, Tx A-MPDU sessions will not be started by mac80211. This flag is required for devices that support Tx A-MPDU setup in hardware. Signed-off-by: Arik Nemtsov <arik@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-13mac80211: Remove unnecessary OOM logging messagesJoe Perches
Removing unnecessary messages saves code and text. Site specific OOM messages are duplications of a generic MM out of memory message and aren't really useful, so just delete them. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-29net/mac80211/debugfs: Convert to kstrou8_from_userPeter Huewe
This patch replaces the code for getting an number from a userspace buffer by a simple call to kstrou8_from_user. This makes it easier to read and less error prone. Since the old buffer was only 10 bytes long and the value is masked by a nibble-mask anyway, we don't need to use kstrtoul but rather kstrtou8. Kernel Version: v3.0-rc2 Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-05mac80211: add basic support for WoWLANJohannes Berg
This adds basic support for the new WoWLAN configuration in mac80211. The behaviour is completely offloaded to the driver though, with two new callbacks (suspend/resume). Options for the driver include a complete reconfiguration after wakeup, and exposing all the triggers it wants to support. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-04wifi: Add hwflags to debugfs.Ben Greear
Aids debugging wifi behaviour. Signed-off-by: Ben Greear <greearb@candelatech.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-02-18mac80211: Add power to debugfs.Ben Greear
2010-11-15mac80211: refactor debugfs function generation codeEliad Peller
refactor mac80211 debugfs code by using a format&copy function, instead of duplicating the code for each generated function. this change reduces about 600B from mac80211.ko Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-10-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits) bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL. vlan: Calling vlan_hwaccel_do_receive() is always valid. tproxy: use the interface primary IP address as a default value for --on-ip tproxy: added IPv6 support to the socket match cxgb3: function namespace cleanup tproxy: added IPv6 support to the TPROXY target tproxy: added IPv6 socket lookup function to nf_tproxy_core be2net: Changes to use only priority codes allowed by f/w tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled tproxy: added tproxy sockopt interface in the IPV6 layer tproxy: added udp6_lib_lookup function tproxy: added const specifiers to udp lookup functions tproxy: split off ipv6 defragmentation to a separate module l2tp: small cleanup nf_nat: restrict ICMP translation for embedded header can: mcp251x: fix generation of error frames can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set can-raw: add msg_flags to distinguish local traffic 9p: client code cleanup rds: make local functions/variables static ... Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and drivers/net/wireless/ath/ath9k/debug.c as per David
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-09-27mac80211: Support multiple VIFS per AP in debugfs.Ben Greear
Create 'stations' sub-directory under each netdev:[vif-name] directory to hold all stations for that network device. Signed-off-by: Ben Greear <greearb@candelatech.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-09-16net/wireless: use generic_file_llseek in debugfsArnd Bergmann
The default llseek operation is changing from default_llseek to no_llseek, so all code relying on the current behaviour needs to make that explicit. The wireless driver infrastructure and some of the drivers make use of generated debugfs files, so they cannot be converted by our script that automatically determines the right operation. All these files use debugfs and they typically rely on simple_read_from_buffer, so the best llseek operation here is generic_file_llseek. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: linux-wireless@vger.kernel.org Cc: netdev@vger.kernel.org
2010-08-25net/mac80211: Use wiphy_<level>Joe Perches
Standardize logging messages from printk(KERN_<level> "%s: " fmt , wiphy_name(foo), args); to wiphy_<level>(foo, fmt, args); Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-06-03mac80211: reduce debugfs code sizeFelix Fietkau
This patch reduces the binary size by around 25k (measured on MIPS, with CONFIG_MAC80211_DEBUG_COUNTERS enabled). Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-02-08mac80211: Added a new debugfs file for reading channel_typeBenoit Papillault
This file helps debugging HT channels since it displays if we are on ht20 or ht40+/ht40- Signed-off-by: Benoit Papillault <benoit.papillault@free.fr> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-01-12mac80211: add debugfs interface for U-APSD queue configurationKalle Valo
Because it's not yet decided how to configure which queues are U-APSD enabled, add a debugfs interface for testing purposes. Signed-off-by: Kalle Valo <kalle.valo@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-18mac80211: make software rate control optionalJohannes Berg
Some devices implement the entire rate control in firmware in some way, like wl1271 or like iwlwifi which does some things in software but not a lot. Therefore generic software rate control is rather useless for them and just adds avoidable overhead to the transmit path. It's fairly simple to let drivers indicate that they do not need rate control, but they need to fulfil a number of conditions that we encode in WARN_ONs. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-30cfg80211/mac80211: use debugfs_remove_recursiveJohannes Berg
We can save a lot of code and pointers in the structs by using debugfs_remove_recursive(). First, change cfg80211 to use debugfs_remove_recursive() so that drivers do not need to clean up any files they added to the per-wiphy debugfs (if and only if they are ok to be accessed until after wiphy_unregister!). Then also make mac80211 use debugfs_remove_recursive() where necessary -- it need not remove per-wiphy files as cfg80211 now removes those, but netdev etc. files still need to be handled but can now be removed without needing struct dentry pointers to all of them. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-24mac80211: remove master netdevJohannes Berg
With the internal 'pending' queue system in place, we can simply put packets there instead of pushing them off to the master dev, getting rid of the master interface completely. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-15mac80211: add queue debugfs fileJohannes Berg
I suspect that some driver bugs can cause queues to be stopped while they shouldn't be, but it's hard to find out whether that is the case or not without having any visible information about the queues. This adds a file to debugfs that allows us to see the queues' statuses. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-20mac80211/cfg80211: move wiphy specific debugfs entries to cfg80211Luis R. Rodriguez
This moves the cfg80211 specific stuff to new cfg80211 debugfs entries. Non-mac80211 will also get these entries now. There were only 4 which we take: rts_threshold fragmentation_threshold short_retry_limit long_retry_limit Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-13mac80211: make noack test availableJohannes Berg
There's this internal wifi_wme_noack_test variable that we use to set the QoS control if set. For one, it is unlikely that it is set. Secondly, if set it needs to influence the IEEE80211_TX_CTL_NO_ACK TX control flag, and finally we should also be able to set it at all, so make it available in debugfs. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-06mac80211: add driver ops wrappersJohannes Berg
In order to later add tracing or verifications to the driver calls mac80211 makes, this patch adds static inline wrappers for all operations. All calls are now written as drv_<op>(local, ...); instead of local->ops-><op>(&local->hw, ...); Where necessary, the wrappers also do existence checking and return default values as appropriate. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22nl80211: Add set/get for frag/rts threshold and retry limitsJouni Malinen
Add new nl80211 attributes that can be used with NL80211_CMD_SET_WIPHY and NL80211_CMD_GET_WIPHY to manage fragmentation/RTS threshold and retry limits. Since these values are stored in struct wiphy, remove the local copy from mac80211 where feasible (frag & rts threshold). The retry limits are currently needed in struct ieee80211_conf, but these could be eventually removed since the driver should have access to the values in struct wiphy. Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27mac80211: resume properly, add suspend/resume testJohannes Berg
When mac80211 resumes, it currently doesn't reconfigure the interfaces entirely and also doesn't reconfigure BSS information -- fix this. Also, to be able to test this, add a debugfs file that just calls the suspend/resume code to see what happens when we go through that, without needing the time-consuming suspend/resume cycle. (Original version broke the build for CONFIG_PM=n. Define alternative functions for that situation. -- JWL) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: Generic TSF debuggingAlina Friedrichsen
This patch enables low-level driver independent debugging of the TSF and remove the driver specific things of ath5k and ath9k from the debugfs. Signed-off-by: Alina Friedrichsen <x-alina@gmx.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: Read the TSF via debugfsAlina Friedrichsen
This patch adds an low-level driver independent entry to read the TSF value into the debugfs of mac80211. This makes debugging the IBSS handling of wifi drivers easier. Signed-off-by: Alina Friedrichsen <x-alina@gmx.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: remove unused variable in ieee80211_local ↵Rami Rosen
(dot11WEPUndecryptableCount). This patch removes an unused declaration of dot11WEPUndecryptableCount (an snmp counter) in ieee80211_local structure and its usage in debugfs.c since this counter is not incremented/decremented anywhere. Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31mac80211: make retry limits part of hw configJohannes Berg
Instead of having a separate callback, use the HW config callback with a new flag to change retry limits. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31mac80211: kill hw.conf.antenna_sel_{rx,tx}Johannes Berg
Never actually used. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15mac80211: make bridge_packets a virtual interface optionJohannes Berg
The bridge_packets configuration really should be per virtual interface (theoretically per AP/VLAN, but this is much easier); there currently is no way to set it yet though. Also invert the option to "NO_BRIDGE_PACKETS" so the default is to bridge. While at it, also document the flags properly. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-14mac80211: revamp virtual interface handlingJohannes Berg
This patch revamps the virtual interface handling and makes the code much easier to follow. Fewer functions, better names, less spaghetti code. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
